Home » Modeling » GMF (Graphical Modeling Framework) » uml2 project with gmf
uml2 project with gmf [message #175800] Wed, 05 March 2008 09:08 Go to next message
Originally posted by: treppa.hotter.com
I use org.eclipse.uml2.diagram.def_0.7.100.v200801081543 with GMF21M4
and would like to see e.g. deployment diagram
if I generate UML.genmodel from UML.ecore, get more than 6000 errors (e.g.
duplicate method as java problem)
if I generate e.g. deploymentdiagram.gmfgen from deploymentdiagram.gmfmap,
get:
source feature must be owned ... error
How can I repair these?
Would be important
Regards,Trep
Re: uml2 project with gmf [message #175816 is a reply to message #175800] Wed, 05 March 2008 09:38 Go to previous messageGo to next message
Trep,
UML ships a GenModel for UML.ecore. You should use that. Their
GenModel is a derived GenModel to handle UML concepts like redefinition
and subset/superset. It seems pointless to try to generate that model
when it already exists... Doesn't the UML Tools component already have
these things too?
Trep wrote:
> Hello,
> (e.g. duplicate method as java problem)
> deploymentdiagram.gmfmap, get:
> Would be important
> Regards,Trep
Re: uml2 project with gmf [message #175837 is a reply to message #175816] Wed, 05 March 2008 10:31 Go to previous messageGo to next message
Originally posted by: Trep.gmail.com
Yes, I had uml.ecore, and regeneration resulted duplicate methods
(but renaming the package was also unsuccessful :( )
My question is so:
get:
(and it is in the original deploymentdiagram.gmfgen)
I rewrote something in the diagram, so I need to regenerate this, but some
LinkMapping in the original gmfmap file has no source/target feature is set
Trep
Re: uml2 project with gmf [message #175862 is a reply to message #175837] Wed, 05 March 2008 12:28 Go to previous messageGo to next message
I wonder how could they build it having only targetfeature in the gmfmap's
linkmapping
Trep
Re: uml2 project with gmf [message #176311 is a reply to message #175862] Thu, 06 March 2008 12:42 Go to previous message
I ignored the validation errors, but I got a 'problem opening
(creation)wizard' in a new eclipse instance
Trep
Previous Topic:Reorder nodes in Compartment
Next Topic:Problem : Audit constraints
Current Time: Thu Jul 17 19:34:14 EDT 2025
Powered by FUDForum. Page generated in 0.04723 seconds
