Home » Modeling » GMF (Graphical Modeling Framework) » How to make diagram elements un-movable
How to make diagram elements un-movable [message #175454] Tue, 04 March 2008 06:51 Go to next message
Originally posted by: fbanica.soluta.net
I would like to ask how can I make some of the diagram elements un-movable?
I want to have some figures which the user will be not able to move around
at all. They should stay in position no matter what. How can I can do this?
Is it possible? Thanks,
Floppy
Re: How to make diagram elements un-movable [message #175494 is a reply to message #175454] Tue, 04 March 2008 07:32 Go to previous messageGo to next message
Hi Florin,
Install a NonResizableEditPolicy whose getMoveCommand() will always
return an UnexecutableCommand.
Boris
Florin Banica wrote:
> Hello,
> Floppy
Re: How to make diagram elements un-movable [message #175672 is a reply to message #175494] Tue, 04 March 2008 11:45 Go to previous messageGo to next message
Could you be more specific, please? Which role should I use? And is this to
be installed on the element itself or on its "father"?
Floppy
"Boris Blajer" <boris.blajer@borland.com> wrote in message
news:fqjfge$7to$1@build.eclipse.org...
> Hi Florin,
> Install a NonResizableEditPolicy whose getMoveCommand() will always return
> Best regards,
> Boris
>> Hello,
>> un-movable? I want to have some figures which the user will be not able
>> to move around at all. They should stay in position no matter what. How
>> can I can do this? Is it possible? Thanks,
>> Floppy
Re: How to make diagram elements un-movable [message #175744 is a reply to message #175672] Wed, 05 March 2008 05:33 Go to previous message
Hi Florin,
The edit policy should be installed on the element itself. It does
really not matter which role you will use (you can use a unique role
just for this purpose), because the commands returned from different
edit policies are chained together, and chaining an unexecutable command
to anything will make it unexecutable.
However, for performance reasons, I would recommend to use the
PRIMARY_DRAG_ROLE, since the edit policy that normally controlls this
behavior (or actually, delegates this behavior to the parent) is
typically installed for this role.
Boris
> Floppy
>> Hi Florin,
>> Best regards,
>> Boris
>>> Hello,
>>> Floppy
Previous Topic:Reloading/Refreshing GMF editor without reopening the editor
Next Topic:Curved forking(bending) for connection seperation
Current Time: Wed Jul 16 14:53:48 EDT 2025
Powered by FUDForum. Page generated in 0.03643 seconds
