| Javacc Builder [message #16581] |
Tue, 19 February 2008 10:46  |
Hi to all.
I'm trying to write an eclipse-plugin for a new language.
I have to define a customized IDE for my language: a syntax highlighting
editor with error marks.
I need javacc like compiler.
Is there some info to use javacc with IMP?
Thank you in advance
Giuseppe
| Re: Javacc Builder [message #18422 is a reply to message #16581] |
Tue, 15 April 2008 09:33  |
Giuseppe wrote:
> Hi to all.
At the moment, there is no JavaCC IDE based on IMP, and IMP doesn't
provide any metatooling or framework support classes.
In case you're really just asking about a JavaCC IDE, a quick
googling gave this:
http://sourceforge.net/projects/eclipse-javacc
so there is some support for using JavaCC in Eclipse. In other words,
at least you'd get syntax highlighting, outlining, a builder, and so
on while working on the JavaCC grammar for your language.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://eclipse-imp.sourceforge.net)
X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
| Re: Javacc Builder [message #570078 is a reply to message #16581] |
Tue, 08 April 2008 16:52  |
Hi Giuseppe,
IMP will not give you much help for building the compiler itself. LPG
support associated with IMP will help you in writing a grammar and
generating a parser. (You can use LPG with or without IMP.)
IMP will help you build an IDE with a syntax highlighting editor with
error markers. It also makes it easy to get several additional features
such as source-text folding, an outline view, hover help, and others.
Most IMP IDE services are driven off of an AST representation that is
constructed by a parser. IMP can also help you to build an incremental
builder, and you can use that to invoke a compiler if you have one.
Regarding error markers, errors returned by the parser will appear as
markers in the editor. Errors returned by the compiler can be converted
by a builder into problem markers that show up in the problems view.
I hope this is helpful,
Stan Sutton
Giuseppe wrote:
> Hi to all.
> Giuseppe
| Re: Javacc Builder [message #570211 is a reply to message #16581] |
Giuseppe wrote:
> Hi to all.
googling gave this:
-- Bob
Robert M. Fuhrer
FUDForum. Page generated in 0.04262 seconds
