Home » Archived » M2M (model-to-model transformation) » How to create safe "models"
How to create safe "models" [message #16525] Wed, 14 February 2007 09:06 Go to next message
Originally posted by: walcir.fontanini.cenpra.gov.br
I am a newcomer to ATL and I would like to know if there is a safe way
(or preferably a visual tool) to create "models". I have found several
distincts examples of models, like the excerpts below. What about this
tool
http://wiki.eclipse.org/index.php/Modeling_Corner#eUML2_-_UM L_.26_EMF_Designer
[ KM3-KM3.ecore from KM32DOT example ]
<?xml version="1.0" encoding="ISO-8859-1"?>
<Metamodel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="KM3"
location="1:1-83:2">
<contents location="7:1-83:2" name="KM3">
<contents xsi:type="Class" location="9:9-11:10"
name="LocatedElement" isAbstract="true">
<structuralFeatures xsi:type="Attribute" location="10:17-10:45"
name="location" lower="1" upper="1" isOrdered="false"
type="//@contents.0/@contents.2"/>
</contents>
[ outClassXMI.ecore from Class2Relational example ]
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="Class">
<Class name="Family">
<attr name="name" multiValued="false" type="/2"/>
<attr name="members" multiValued="true" type="/1"/>
</Class>
<Class name="Person">
<attr name="firstName" multiValued="false" type="/2"/>
<attr name="closestFriend" multiValued="false" type="/1"/>
<attr name="emailAddresses" multiValued="true" type="/2"/>
</Class>
<DataType name="String"/>
<DataType name="Integer"/>
</xmi:XMI>
-walcir fontanini
CEnPRA
Re: How to create safe "models" [message #16541 is a reply to message #16525] Wed, 14 February 2007 09:24 Go to previous messageGo to next message
Hi Walcir,
You may want to take a look at
http://wiki.eclipse.org/index.php/ATL_FAQ#I_can_use_KM3_to_c reate_metamodels.2C_but_what_about_models.3F
and http://wiki.eclipse.org/index.php/Modeling_Corner#Exeed
Dimitrios
walcir fontanini wrote:
> tool
> </contents>
> xmlns="Class">
> </Class>
> </Class>
> </xmi:XMI>
> -walcir fontanini
> CEnPRA
Re: How to create safe "models" [message #16622 is a reply to message #16541] Thu, 15 February 2007 10:58 Go to previous messageGo to next message
Hi Dimitrius,
I have downloaded Exeed from
http://www-users.cs.york.ac.uk/~dkolovos/epsilon/bundles/bun dle-win.php
and unzip the file to d:\ directory. After executing eclipse.exe
But it did NOT worked. It does not produced any extra icons typical from
Exeed ! Any hint for me ?
-walcir
Dimitrios Kolovos wrote:
> Hi Walcir,
> Cheers,
> Dimitrios
>> tool
>> </contents>
>> xmlns="Class">
>> </Class>
>> </Class>
>> </xmi:XMI>
>> Thanks,
>> -walcir fontanini
>> CEnPRA
Re: How to create safe "models" [message #16655 is a reply to message #16622] Fri, 16 February 2007 05:40 Go to previous messageGo to next message
Hi Walcir,
Can you please send me your .ecore metamodel for a quick look?
Dimitrios
> Hi Dimitrius,
> -walcir
>> Hi Walcir,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> way (or preferably a visual tool) to create "models". I have found
>>> several distincts examples of models, like the excerpts below. What
>>> about this tool
>>> </contents>
>>> xmlns="Class">
>>> </Class>
>>> </Class>
>>> </xmi:XMI>
>>> Thanks,
>>> -walcir fontanini
>>> CEnPRA
Re: How to create safe "models" [message #16672 is a reply to message #16655] Fri, 16 February 2007 11:23 Go to previous messageGo to next message
Dimitrius,
It was not my own ecore model, but the problem occurred with
OOinstance.ecore (even after "Register ecore Metamodel" on OO.ecore).
The same problem happens to DBInstance.ecore/DB.ecore pair.
-walcir
> Hi Walcir,
> Cheers,
> Dimitrios
>> Hi Dimitrius,
>> from Exeed ! Any hint for me ?
>> Thanks,
>> -walcir
>>> Hi Walcir,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> about this tool
>>>> location="10:17-10:45" name="location" lower="1" upper="1"
>>>> isOrdered="false" type="//@contents.0/@contents.2"/>
>>>> </contents>
>>>> xmlns="Class">
>>>> </Class>
>>>> </Class>
>>>> </xmi:XMI>
>>>> Thanks,
>>>> -walcir fontanini
>>>> CEnPRA
Re: How to create safe "models" [message #16689 is a reply to message #16672] Fri, 16 February 2007 11:08 Go to previous messageGo to next message
Hi Walcir,
I see. The OO.ecore that comes with the Epsilon bundle that you have
downloaded is not annotated for Exeed. You can find an annotated version
in the example provided at
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/examples/ExeedOO/ExeedOO.zip
(as discussed in the Exeed manual).
Dimitrios
> Dimitrius,
> -walcir
>> Hi Walcir,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrius,
>>> Thanks,
>>> -walcir
>>>> Hi Walcir,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> about this tool
>>>>> </contents>
>>>>> xmlns="Class">
>>>>> </Class>
>>>>> </Class>
>>>>> </xmi:XMI>
>>>>> Thanks,
>>>>> -walcir fontanini
>>>>> CEnPRA
Re: How to create safe "models" [message #16704 is a reply to message #16689] Fri, 16 February 2007 13:27 Go to previous messageGo to next message
Dimitrios,
Now it works fine. But for now on, how can I add these Exeed features
to other .ecore files ?
-walcir
> Hi Walcir,
> Cheers,
> Dimitrios
Re: How to create safe "models" [message #16717 is a reply to message #16704] Fri, 16 February 2007 15:53 Go to previous message
Hi Walcir,
You can refer to the manual available at
http://www.eclipse.org/gmt/epsilon/doc/Exeed.pdf . If you have trouble
customizing your metamodel please let me know. We may also want to move
this discussion to the eclipse.modeling.gmt newsgroup where GMT
components such as Epsilon are discussed.
Dimitrios
> Dimitrios,
> -walcir
>> Hi Walcir,
>> version in the example provided at
>> Cheers,
>> Dimitrios
Previous Topic:XMI tutorial
Next Topic:[ATL] programatically launch already loaded model
Current Time: Mon Jun 02 16:08:48 EDT 2025
Powered by FUDForum. Page generated in 0.04910 seconds
