Home » Archived » IMP » LPG in linux
| LPG in linux [message #16493] |
Wed, 13 February 2008 10:17  |
Hi Robert,
I have some questions for you...
I'm working with LPG to generate a parser from some grammar files...At
this moment I'm not using IMP project since I'm working with Ganymede's
milestones and I just want to use the Parser Generator. Generating the
IDE can be set off...
The problem is that I was working with WinXP OS, and I used the lpg.exe
program to generate the lexer, parser, etc... I have moved to a Linux -
Environment and I have tried to recompile the source code with no success...
- cl compiler used by the Makefile seems to be a Windows programme.
- I tried it with g++ linux-programme with no success.
Isn't LPG thought to work in a Linux Env ?
Could you give some clue to tackle this problem?
Greetings,
Adolfo.
| Re: LPG in linux [message #16529 is a reply to message #16493] |
Sat, 16 February 2008 10:36   |
Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Robert,
> success...
LPG *should* build fine out of the box with any recent version of g++,
however, we haven't had the time to get a g++-based build to work on
Windows. [In theory we should be able to use mingw and link statically,
but no one has yet done that.] "cl" indeed refers to the Microsoft C++
compiler.
If you're having trouble compiling LPG with g++, please post details
about the errors you're seeing, so we can help diagnose the problems.
BTW, we've recently migrated to using plugin fragments to house the
platform-specific binaries. The fragments have names like:
lpg.generator.win32_x86 and
lpg.generator.linux_x86
The update manager should automagically pick up the right fragment
given the platform on which you're running Eclipse. This has worked
for me on my Linux boxes (Intel- and AMD-based boxes running Gentoo),
but then I'm installing on the same kind of machines on which I built
the binaries, and I don't have any other Linux platforms to test on.
There's a problem with this mechanism, though: it appears to me that
the Eclipse platform metadata (e.g. the "os", "arch", "platform" and
"ws" variables) doesn't provide enough information to distinguish
Linux boxes running, say, different versions of gcc/libc. As a result,
a plugin fragment may seem to Eclipse to be appropriate for running on
a given kind of host, when in reality it isn't. I'm not sure how to
address this problem at this point. Any help here would be greatly
appreciated!
Of course we wouldn't have this problem if LPG were a Java program,
but we don't have the bandwidth to rewrite it in Java. [Any takers
there?]
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://eclipse-imp.sourceforge.net)
X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
| Re: LPG in linux [message #16546 is a reply to message #16529] |
Sun, 17 February 2008 07:05   |
Hi Robert,
Comments in-line below:
>> Hi Robert,
>> Ganymede's milestones and I just want to use the Parser Generator.
>> Generating the IDE can be set off...
>> lpg.exe program to generate the lexer, parser, etc... I have moved to
>> a Linux - Environment and I have tried to recompile the source code
>> with no success...
> Windows. "cl" indeed refers to the Microsoft C++
> compiler.
I'm using lpgdistribution from sourceforge. And I try to built the
sourcecode included...
What i have changed in order to run the makefile:
GCPPC=g++ -O -DNDEBUG
#GCPPC=cl -O -DNDEBUG -EHsc
The g++ compiler doesn't understand all that options (Only -E one). I
don't know what are its intention in cl compiler.
The output (translated):
g++ -O -DNDEBUG -c jikespg.cpp
g++ -O -DNDEBUG -c symbol.cpp
g++ -O -DNDEBUG -c code.cpp
g++ -O -DNDEBUG -c util.cpp
util.cpp: In function ‘int SystemMkdir(char*)’:
util.cpp:28: error: ‘_IFDIR’ isn't declared in this scope
make: *** [util.obj] Error 1
Besides:
It seems to be a rule related to generic.cpp file, when it doesn't
exists in the sourcecode folder.
I hope, this info suffice...
Well, i'll try this...
I didn't know about imp installation through the update manager...
What update site uses ?¿?
Any official Eclipse site ?
I'll try it...
> appreciated!
Well, i have no knowledge or experience about this. If I have any idea
or clue I'll post it. BTW, it doesn't seem to be a trivial issue...
> there?
Adolfo.
| Re: LPG in linux [message #16563 is a reply to message #16546] |
Mon, 18 February 2008 12:26   |
Hi Robert,
I have tried binary program from:
lpg.generator.linux_x86 project.
It worked, but unfortunately the parser generated is not the expected
one. It seems that my grammars are "deprecated", for example look at
this error:
.... /KeywordTemplateD.g:55:1:55:8:1286:1293: Warning: The use of the
escaped symbol "$Globals" as a keyword has been deprecated. The proper
spelling is %Globals
Upgrading my grammars is not an option, since I'm extending Eclipse
MDT-OCL project, which uses the version 1.1 of LPG, and its grammars are
"deprecated" too...
So i still need to build a binary program from lpg v1.1 soure code
(lpgdistribution package) which works in Linux Environments...And i
don't find the way out to do it :(
Do you have anymore ideas?...
Best Regards,
Adolfo.
Adolfo Sánchez-Barbudo Herrera escribió:
> Hi Robert,
>>> Hi Robert,
>>> files...At this moment I'm not using IMP project since I'm working
>>> with Ganymede's milestones and I just want to use the Parser
>>> Generator. Generating the IDE can be set off...
>>> with no success...
>> compiler.
> Besides:
> I'll try it...
>> appreciated!
>> there?
> Cheers,
> Adolfo.
| Re: LPG in linux [message #16635 is a reply to message #16563] |
Wed, 20 February 2008 15:56   |
> Hi Robert,
> this error:
Note that this is just a warning, not an error. It's telling you that the
new spelling of the directive starts with '%' rather than '$'. [We've done
this so that the space of macro names (which the programmer controls) is
clearly distinct from that of directives (which are hard-wired). At some
point, we may remove support for the old syntax.
The upshot is that your grammar is still perfectly legal, and the generated
parser should work as you expect. I don't think you should need to use the
1.1 binary, but please let us know if the new version doesn't work for you
(and post details on what you tried and what the result was).
> "deprecated" too...
> Best Regards,
> Adolfo.
>> Hi Robert,
>>>> Hi Robert,
>>>> to a Linux - Environment and I have tried to recompile the source
>>> compiler.
>> Besides:
>> I'll try it...
>>> appreciated!
>>> there?
>> Cheers,
>> Adolfo.
-- Bob
Robert M. Fuhrer
| Re: LPG in linux [message #18136 is a reply to message #16635] |
Wed, 27 February 2008 05:38  |
Hi Robert,
I'm sorry for the delay.
It didn't work, the generated parser had a lot of errors, a lot of cases
of the switch broken etc. So the grammar which works well with v1.1
binary doesn't work with the linux binary v2.
I finally solved the problem using the v1.1 executable (for windows)
with the linux wine program (which lets me execute windows programs).
I know that is not a smart solution, but it suffices me ;), and maybe
someone.
Best Regards,
Adolfo.
>> Hi Robert,
>> this error:
>> "deprecated" too...
>> Best Regards,
>> Adolfo.
>>> Hi Robert,
>>>>> Hi Robert,
>>>> compiler.
>>> Besides:
>>> I'll try it...
>>>> appreciated!
>>>> there?
>>> Cheers,
>>> Adolfo.
| Re: LPG in linux [message #569267 is a reply to message #16493] |
> Hi Robert,
> success...
compiler.
appreciated!
there?]
-- Bob
Robert M. Fuhrer
| Re: LPG in linux [message #569290 is a reply to message #16529] |
Hi Robert,
>> Hi Robert,
>> with no success...
> compiler.
Besides:
I'll try it...
> appreciated!
> there?
Adolfo.
| Re: LPG in linux [message #569317 is a reply to message #16546] |
Hi Robert,
this error:
"deprecated" too...
Best Regards,
Adolfo.
> Hi Robert,
>>> Hi Robert,
>>> with no success...
>> compiler.
> Besides:
> I'll try it...
>> appreciated!
>> there?
> Cheers,
> Adolfo.
| Re: LPG in linux [message #569477 is a reply to message #16563] |
> Hi Robert,
> this error:
> "deprecated" too...
> Best Regards,
> Adolfo.
>> Hi Robert,
>>>> Hi Robert,
>>> compiler.
>> Besides:
>> I'll try it...
>>> appreciated!
>>> there?
>> Cheers,
>> Adolfo.
-- Bob
Robert M. Fuhrer
| Re: LPG in linux [message #569720 is a reply to message #16635] |
Hi Robert,
someone.
Best Regards,
Adolfo.
>> Hi Robert,
>> this error:
>> "deprecated" too...
>> Best Regards,
>> Adolfo.
>>> Hi Robert,
>>>>> Hi Robert,
>>>> compiler.
>>> Besides:
>>> I'll try it...
>>>> appreciated!
>>>> there?
>>> Cheers,
>>> Adolfo.
Current Time: Sat Nov 08 19:57:44 EST 2025
Powered by FUDForum. Page generated in 0.06025 seconds
