Home » Language IDEs » ServerTools (WTP) » WTP1.5 Tomcat Lauch Error
WTP1.5 Tomcat Lauch Error [message #174190] Wed, 12 July 2006 14:55 Go to next message
Originally posted by: aimee.ukasick.att.com
Windows XP Pro
Tomcat 5.0.28
WTP 1.5
I just downloaded and installed WTP 1.5 (all-in-one).
I blew away my workspace from WTP 1.0.2, checked my project out of CVS, and
configured my existing Tomcat installation in Eclipse.
When I try to start Tomcat from within Eclipse, I get the following error:
Can't load server.xml
Jul 12, 2006 1:51:30 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 0 ms
java.lang.reflect.InvocationTargetException
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 87)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:42 5)
Caused by: java.lang.NullPointerException
at org.apache.catalina.startup.Catalina.await(Catalina.java:619 )
at org.apache.catalina.startup.Catalina.start(Catalina.java:579 )
... 6 more
I never had a problem with WTP 1.0.2, and I can start Tomcat from a command
line.
Any ideas?
Thanks in advance.
Aimee
Re: WTP1.5 Tomcat Lauch Error [message #174204 is a reply to message #174190] Wed, 12 July 2006 15:52 Go to previous message
Double-click on the server in the Servers view. Then in the
configuration editor that opens, click "Open launch configuration".
Under the VM Arguments tab of the launch configuration, note the path
specified by catalina.base. What is that path, and is there a
server.xml file in the "conf" folder at that location?
Your error implies there is no server.xml file in that "conf" folder or
the file is for some reason unreadable or corrupt.
Larry
Aimee Ukasick wrote:
> Windows XP Pro
> Tomcat 5.0.28
> WTP 1.5
> at
> at
> ... 6 more
> line.
> Any ideas?
> Thanks in advance.
> Aimee
Previous Topic:Error while creating bottom-up Web Service
Next Topic:servlet API help
Current Time: Tue Nov 18 17:19:00 EST 2025
Powered by FUDForum. Page generated in 0.03491 seconds
