Home » Archived » BIRT » BIRT Designer documentation
BIRT Designer documentation [message #173732] Tue, 27 June 2006 07:22 Go to next message
Originally posted by: levi.hfsistemas.com
Where can I find any documentation about the BIRT Designer classes? I need
to add a simple functionality of BIRT Designer RCP (open a line command
parameter file automatically on start) but I don't even know which is the
first class to be called when it's executed.
Thank you.
Re: BIRT Designer documentation [message #173962 is a reply to message #173732] Wed, 28 June 2006 02:33 Go to previous message
this is more a RCP than a BIRT question. However, the RCP entry point is
a RCP application (IPlatformRunnable). I recommend you write an own RCP
application & product that uses the BIRT app, perspective and its
classes but additionaly processes parameters instead of patching the
BIRT app. I've written a simple example application for this, it
contains of two classes: The application class and a WorkbenchAdvisor
based on BIRT's that processes the parameters. Download here
http://www.nightlabs.de/~alex/download/BIRT/org.eclipse.birt .example.rcp.fileopen_1.0.0.jar
To deploy this app you might want to build a RCP product around it.
More information on RCP applications and products here:
http://wiki.eclipse.org/index.php/Eclipse_FAQs#Building_Your _Own_Application
Best regards
Alex
Leví wrote:
> Hello,
> Thank you.
Previous Topic:BIRT Dynamic Parameters Example
Next Topic:null engine instance
Current Time: Thu Jul 24 21:13:31 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
