Home » Archived » BIRT » Building RC5
Building RC5 [message #173552] |
Mon, 26 June 2006 16:44  |
I'm trying to build RC5 from scratch. I followed the instructions at:
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
And noticed that they are not quite tailored to RC5 (still mentions
prototype.js).
1. Is there a "master" build file for building everything? If not, in
what order do I build the projects?
2. In attempting to build the Report Viewer, I get the following errors:
Buildfile:
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.report.viewer\BuildViewer.xml
init:
model:
buildDependents:
[echo] start call Jar task in ../org.eclipse.birt.core
init:
compileSource:
[javac] Compiling 110 source files to
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\bin
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\archive\Archi veUtil.java:30:
package com.ibm.icu.text does not exist
[javac] import com.ibm.icu.text.SimpleDateFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:33:
[javac] import com.ibm.icu.text.DateFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:34:
package com.ibm.icu.util does not exist
[javac] import com.ibm.icu.util.ULocale;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:45:
cannot find symbol
[javac] symbol : class ULocale
[javac] location: class org.eclipse.birt.core.data.DataTypeUtil
[javac] private static ULocale DEFAULT_LOCALE = ULocale.US;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\exception\Bir tException.java:14:
[javac] import com.ibm.icu.text.MessageFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:435:
cannot find symbol
[javac] public static Date toDate( String source, ULocale locale )
[javac] ^
[javac]
toDate(java.lang.String,java.util.Locale) is already defined in
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:516:
cannot find symbol
[javac] public static Date toDateWithCheck( String source, ULocale
locale )
[javac] ^
[javac]
toDateWithCheck(java.lang.String,java.util.Locale) is already defined in
locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:654:
cannot find symbol
[javac] public static String toString( Object source, ULocale locale )
[javac] ^
[javac]
toString(java.lang.Object,java.util.Locale) is already defined in
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:909:
cannot find symbol
[javac] private static String toString( Date source, ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:1080:
cannot find symbol
[javac] location: class org.eclipse.birt.core.data.DateFormatHolder
[javac] public static DateFormat getDateTimeInstance( int
dateStyle, int timeStyle, ULocale locale )
[javac] ^
[javac]
cannot find symbol
[javac] symbol : class DateFormat
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DataType Util.java:1099:
cannot find symbol
[javac] public static DateFormat getDateInstance( int dateStyle,
ULocale locale )
[javac] ^
[javac]
cannot find symbol
ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DateUtil .java:13:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DateUtil .java:14:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DateUtil .java:15:
[javac] import com.ibm.icu.util.GregorianCalendar;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DateUtil .java:28:
cannot find symbol
[javac] symbol : class GregorianCalendar
[javac] location: class org.eclipse.birt.core.data.DateUtil
[javac] private static GregorianCalendar calendarInstance = null;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\data\DateUtil .java:54:
cannot find symbol
[javac] public static boolean checkValid( DateFormat df, String
dateStr )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\exception\Cor eException.java:16:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\exception\Cor eException.java:17:
[javac] import com.ibm.icu.util.UResourceBundle;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\exception\Cor eException.java:27:
cannot find symbol
[javac] symbol : class UResourceBundle
[javac] location: class org.eclipse.birt.core.exception.CoreException
[javac] static protected UResourceBundle rb = new
ResourceHandle(ULocale.getDefault()).getUResourceBundle();
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:15:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:18:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:19:
[javac] import com.ibm.icu.util.TimeZone;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:45:
[javac] private com.ibm.icu.text.DateFormat dateFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:50:
cannot find symbol
[javac] location: class org.eclipse.birt.core.format.DateFormatter
[javac] private ULocale locale = ULocale.getDefault( );
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:81:
cannot find symbol
[javac] public DateFormatter( ULocale localeLoc )
[javac] ^
[javac]
DateFormatter(java.lang.String) is already defined in
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\DateFo rmatter.java:103:
cannot find symbol
[javac] public DateFormatter( String pattern, ULocale localeLoc )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:15:
[javac] import com.ibm.icu.text.DecimalFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:16:
[javac] import com.ibm.icu.text.DecimalFormatSymbols;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:17:
[javac] import com.ibm.icu.text.NumberFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:20:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:50:
cannot find symbol
[javac] location: class org.eclipse.birt.core.format.NumberFormatter
[javac] protected ULocale locale = ULocale.getDefault( );
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:56:
cannot find symbol
[javac] symbol : class NumberFormat
[javac] protected NumberFormat numberFormat;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:86:
cannot find symbol
[javac] public NumberFormatter( ULocale locale )
[javac] ^
[javac]
NumberFormatter(java.lang.String) is already defined in
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\Number Formatter.java:109:
cannot find symbol
[javac] public NumberFormatter( String pattern, ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:16:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:39:
cannot find symbol
[javac] location: class org.eclipse.birt.core.format.StringFormatter
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:75:
cannot find symbol
[javac] public StringFormatter( ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:107:
cannot find symbol
[javac] public StringFormatter( String format, ULocale locale)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:192:
cannot find symbol
[javac] public ULocale getULocale( )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\format\String Formatter.java:211:
cannot find symbol
[javac] public void setLocale( ULocale theLocale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\Pla tform.java:20:
package org.osgi.framework does not exist
[javac] import org.osgi.framework.BundleContext;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseBundle.java:13:
[javac] import org.osgi.framework.Bundle;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseBundle.java:23:
cannot find symbol
[javac] symbol : class Bundle
org.eclipse.birt.core.framework.eclipse.EclipseBundle
[javac] protected Bundle bundle;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseBundle.java:24:
cannot find symbol
[javac] public EclipseBundle(Bundle bundle)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseConfigurationElement.java:17:
package org.eclipse.core.runtime does not exist
[javac] import org.eclipse.core.runtime.CoreException;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseConfigurationElement.java:26:
[javac] org.eclipse.core.runtime.IConfigurationElement object;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseConfigurationElement.java:27:
[javac]
EclipseConfigurationElement(org.eclipse.core.runtime.IConfig urationElement
object)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtension.java:24:
[javac] org.eclipse.core.runtime.IExtension object;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtension.java:25:
[javac] EclipseExtension(org.eclipse.core.runtime.IExtension object)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtensionPoint.java:25:
[javac] org.eclipse.core.runtime.IExtensionPoint object;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtensionPoint.java:27:
[javac]
EclipseExtensionPoint(org.eclipse.core.runtime.IExtensionPoi nt object)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtensionRegistry.java:28:
[javac] org.eclipse.core.runtime.IExtensionRegistry registry;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipseExtensionRegistry.java:29:
[javac]
EclipseExtensionRegistry(org.eclipse.core.runtime.IExtension Registry
registry)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePath.java:10:
[javac] import org.eclipse.core.runtime.IPath;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePath.java:18:
cannot find symbol
[javac] symbol : class IPath
org.eclipse.birt.core.framework.eclipse.EclipsePath
[javac] protected IPath path;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePath.java:19:
cannot find symbol
[javac] public EclipsePath(IPath path)
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:32:
[javac] import org.eclipse.core.runtime.Platform;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:33:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:34:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:43:
cannot find symbol
[javac] symbol : class BundleContext
org.eclipse.birt.core.framework.eclipse.EclipsePlatform
[javac] BundleContext context;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:45:
cannot find symbol
[javac] public EclipsePlatform( BundleContext context )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:89:
[javac] org.eclipse.core.runtime.IConfigurationElement object )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:99:
[javac] org.eclipse.core.runtime.IConfigurationElement[] objects )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:113:
[javac] static IExtensionPoint wrap(
org.eclipse.core.runtime.IExtensionPoint object )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:123:
[javac] org.eclipse.core.runtime.IExtensionPoint[] objects )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:137:
[javac] static IExtension wrap( org.eclipse.core.runtime.IExtension
object )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\framework\ecl ipse\EclipsePlatform.java:146:
[javac] static IExtension[] wrap(
org.eclipse.core.runtime.IExtension[] objects )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:14:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:16:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:19:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:46:
cannot find symbol
[javac] location: class org.eclipse.birt.core.i18n.ResourceHandle
[javac] protected UResourceBundle resources;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:62:
cannot find symbol
[javac] public ResourceHandle( ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\Resource Handle.java:151:
cannot find symbol
[javac] public UResourceBundle getUResourceBundle( )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\ThreadRe sources.java:14:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\ThreadRe sources.java:17:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\ThreadRe sources.java:50:
cannot find symbol
[javac] location: class org.eclipse.birt.core.i18n.ThreadResources
[javac] public static void setLocale( ULocale locale )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\i18n\ThreadRe sources.java:83:
cannot find symbol
[javac] public static ULocale getULocale()
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\internal\plug in\CorePlugin.java:17:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\plugin\BIRTPl ugin.java:15:
[javac] import org.eclipse.core.runtime.Plugin;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\plugin\BIRTPl ugin.java:16:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\plugin\BIRTPl ugin.java:18:
cannot find symbol
[javac] symbol: class Plugin
[javac] public class BIRTPlugin extends Plugin
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\internal\plug in\CorePlugin.java:25:
cannot find symbol
org.eclipse.birt.core.internal.plugin.CorePlugin
[javac] public void start( BundleContext context ) throws Exception
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\internal\plug in\CorePlugin.java:34:
cannot find symbol
[javac] public void stop( BundleContext context ) throws Exception
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\plugin\BIRTPl ugin.java:21:
cannot find symbol
[javac] location: class org.eclipse.birt.core.plugin.BIRTPlugin
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\DateTi meSpan.java:14:
[javac] import com.ibm.icu.util.Calendar;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\Native DateTimeSpan.java:14:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\Native DateTimeSpan.java:17:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\bre\Bi rtComp.java:19:
[javac] import com.ibm.icu.text.Collator;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\bre\Bi rtComp.java:27:
cannot find symbol
[javac] symbol : class Collator
[javac] location: class org.eclipse.birt.core.script.bre.BirtComp
[javac] private static Collator myCollator = Collator.getInstance( );
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\bre\Bi rtDateTime.java:19:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\script\bre\Bi rtDateTime.java:531:
cannot find symbol
[javac] symbol : class Calendar
[javac] location: class org.eclipse.birt.core.script.bre.BirtDateTime
[javac] private static Calendar getCalendar( Date d )
[javac] ^
[javac]
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\src\org\eclipse\birt\core\archive\Archi veUtil.java:117:
cannot find symbol
[javac] symbol : class SimpleDateFormat
[javac] location: class org.eclipse.birt.core.archive.ArchiveUtil
[javac] SimpleDateFormat df = new
SimpleDateFormat("yyyy_MM_dd_HH_mm_ss"); //$NON-NLS-1$
[javac] ^
[javac]
cannot find symbol
[javac] ^
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] 100 errors
BUILD FAILED
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.report.viewer\BuildViewer.xml:217:
The following error occurred while executing this line:
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.report.model\BuildModel.xml:373:
D:\Projects\BDDB\eclipse_BIRTv2.1RC5\birt-workspace\source\o rg.eclipse.birt.core\BuildCore.xml:162:
Compile failed; see the compiler error output for details.
Total time: 3 seconds
Re: Building RC5 [message #173578 is a reply to message #173552] |
Mon, 26 June 2006 18:46   |
By the way, I'm using the All-in-one to check out the sources from CVS.
I've tried setting the compiler to "1.4" and "5.0"; both yield the same
errors.
Severity and Description Path Resource Location Creation Time Id
Bundle 'org.apache.batik.pdf' cannot be resolved
org.eclipse.birt.chart.device.pdf/META-INF MANIFEST.MF line 13
1151361407417 39564
A "source.." build entry is missing
org.eclipse.birt.data.oda.adapter.dtp build.properties line 1
1151361383765 39291
Host bundle 'org.eclipse.birt.chart.reportitem.ui' exists but is
unresolved org.eclipse.birt.chart.reportitem.ui.nl/META-INF MANIFEST.MF
line 6 1151361376266 38999
Host bundle 'org.eclipse.birt.chart.reportitem' exists but is
unresolved org.eclipse.birt.chart.reportitem.nl/META-INF
MANIFEST.MF line 6 1151361376219 38996
Host bundle 'org.eclipse.birt.report.data.oda.jdbc.ui' exists but is
unresolved org.eclipse.birt.report.data.oda.jdbc.ui.nl/META-INF
MANIFEST.MF line 6 1151361376438 39004
Host bundle 'org.eclipse.birt.report.data.oda.jdbc' exists but is
unresolved org.eclipse.birt.report.data.oda.jdbc.nl/META-INF
MANIFEST.MF line 6 1151361376391 39001
Host bundle 'org.eclipse.birt.report.data.oda.sampledb.ui' exists but
is unresolved
org.eclipse.birt.report.data.oda.sampledb.ui.nl/META-INF
MANIFEST.MF line 6 1151361376500 39009
Host bundle 'org.eclipse.birt.report.data.oda.sampledb' exists but is
unresolved org.eclipse.birt.report.data.oda.sampledb.nl/META-INF
MANIFEST.MF line 6 1151361376453 39007
Host bundle 'org.eclipse.birt.report.data.oda.xml.ui' exists but is
unresolved org.eclipse.birt.report.data.oda.xml.ui.nl/META-INF
MANIFEST.MF line 6 1151361376672 39015
Host bundle 'org.eclipse.birt.report.data.oda.xml' exists but is
unresolved org.eclipse.birt.report.data.oda.xml.nl/META-INF MANIFEST.MF
line 6 1151361376625 39012
Host bundle 'org.eclipse.birt.report.debug.ui' exists but is
unresolved org.eclipse.birt.report.debug.ui.nl/META-INF MANIFEST.MF
line 6 1151361376688 39018
Host bundle 'org.eclipse.birt.report.designer.core' exists but is
unresolved org.eclipse.birt.report.designer.core.nl/META-INF
MANIFEST.MF line 6 1151361376750 39020
Host bundle 'org.eclipse.birt.report.designer.ui.editors.schematic'
exists but is unresolved
org.eclipse.birt.report.designer.ui.editors.schematic.nl/MET A-INF
MANIFEST.MF line 6 1151361376875 39024
Host bundle 'org.eclipse.birt.report.designer.ui.ide' exists but is
unresolved org.eclipse.birt.report.designer.ui.ide.nl/META-INF
MANIFEST.MF line 6 1151361376875 39026
Host bundle 'org.eclipse.birt.report.designer.ui.lib.explorer' exists
but is unresolved
org.eclipse.birt.report.designer.ui.lib.explorer.nl/META-INF
MANIFEST.MF line 6 1151361376891 39028
Host bundle 'org.eclipse.birt.report.designer.ui.lib' exists but is
unresolved org.eclipse.birt.report.designer.ui.lib.nl/META-INF
MANIFEST.MF line 6 1151361376906 39030
Host bundle 'org.eclipse.birt.report.designer.ui.preview' exists but
is unresolved org.eclipse.birt.report.designer.ui.preview.nl/META-INF
MANIFEST.MF line 6 1151361376922 39034
Host bundle 'org.eclipse.birt.report.designer.ui.rcp' exists but is
unresolved org.eclipse.birt.report.designer.ui.rcp.nl/META-INF
MANIFEST.MF line 6 1151361376969 39036
Host bundle 'org.eclipse.birt.report.designer.ui' exists but is
unresolved org.eclipse.birt.report.designer.ui.nl/META-INF
MANIFEST.MF line 6 1151361376906 39032
Host bundle 'org.eclipse.birt.report.engine' exists but is unresolved
org.eclipse.birt.report.engine.nl/META-INF MANIFEST.MF line 6
1151361377016 39040
Host bundle 'org.eclipse.birt.report.model' exists but is unresolved
org.eclipse.birt.report.model.nl/META-INF MANIFEST.MF line 6
1151361377109 39043
Host bundle 'org.eclipse.birt.report.viewer' exists but is unresolved
org.eclipse.birt.report.viewer.nl/META-INF MANIFEST.MF line 6
1151361377172 39047
Package 'com.lowagie.bc.asn1' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 9 1151361376078 38947
Package 'com.lowagie.text.html.simpleparser' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 12 1151361376078 38950
Package 'com.lowagie.text.html' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 11 1151361376078 38949
Package 'com.lowagie.text.markup' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 13 1151361376078 38951
Package 'com.lowagie.text.pdf.codec.postscript' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 16 1151361376078 38954
Package 'com.lowagie.text.pdf.codec.wmf' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 17 1151361376078 38955
Package 'com.lowagie.text.pdf.codec' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 15 1151361376078 38953
Package 'com.lowagie.text.pdf.fonts' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 18 1151361376078 38956
Package 'com.lowagie.text.pdf.hyphenation' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 19 1151361376078 38957
Package 'com.lowagie.text.pdf' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 14 1151361376078 38952
Package 'com.lowagie.text.rtf.document.output' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 22 1151361376078 38960
Package 'com.lowagie.text.rtf.document' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 21 1151361376078 38959
Package 'com.lowagie.text.rtf.field' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 23 1151361376078 38961
Package 'com.lowagie.text.rtf.graphic' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 24 1151361376078 38962
Package 'com.lowagie.text.rtf.headerfooter' does not exist in this
plug-in com.lowagie.itext/META-INF MANIFEST.MF line 25 1151361376078 38963
Package 'com.lowagie.text.rtf.list' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 26 1151361376078 38964
Package 'com.lowagie.text.rtf.style' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 27 1151361376078 38965
Package 'com.lowagie.text.rtf.table' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 28 1151361376078 38966
Package 'com.lowagie.text.rtf.text' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 29 1151361376078 38967
Package 'com.lowagie.text.rtf' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 20 1151361376078 38958
Package 'com.lowagie.text.xml' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 30 1151361376078 38968
Package 'com.lowagie.text' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 10 1151361376078 38948
Package 'com.lowagie.tools.arguments' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 32 1151361376078 38970
Package 'com.lowagie.tools.plugins' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 33 1151361376078 38971
Package 'com.lowagie.tools' does not exist in this plug-in
com.lowagie.itext/META-INF MANIFEST.MF line 31 1151361376078 38969
PDFTranscoder cannot be resolved to a type
org.eclipse.birt.chart.device.pdf/src/org/eclipse/birt/chart /device/pdf PDFRendererImpl.java
line 163 1151361407183 39562
line 163 1151361407183 39563
Project com.lowagie.itext is missing required library:
'lib/itext-1.3.jar' com.lowagie.itext Build path 1151361375532 38945
The import org.apache.fop cannot be resolved
line 30 1151361407183 39561
The method getDataTypeMapping(short) in the type DataSetType is not
applicable for the arguments (int)
org.eclipse.birt.report.model.adapter.oda/src/org/eclipse/bi rt/report/model/adapter/oda
NativeDataTypeUtil.java line 65 1151361431491 39927
The method getDefaultOdaDataTypeCode(int) is undefined for the type
DataSetType
org.eclipse.birt.data/src/org/eclipse/birt/data/engine/odaco nsumer
Driver.java line 149 1151361388217 39294
The method getExtensionManifests(String) in the type ManifestExplorer is
not applicable for the arguments (String, boolean)
org.eclipse.birt.data.oda/src/org/eclipse/birt/data/oda/util /manifest
DtpManifestExplorer.java line 121 1151361383155 39257
DtpManifestExplorer.java line 123 1151361383155 39258
The method getOdaScalarDataTypeCode() is undefined for the type
DataTypeMapping
NativeDataTypeUtil.java line 69 1151361431491 39928
The project cannot be built until build path errors are resolved
com.lowagie.itext Unknown 1151361376078 38946
org.eclipse.birt.report.data.oda.flatfile.nl Unknown 1151361376328 39000
The project cannot be built until its prerequisite
org.eclipse.birt.chart.reportitem is built. Cleaning and building all
projects is recommended org.eclipse.birt.chart.examples Unknown
1151361435444 40025
projects is recommended org.eclipse.birt.chart.reportitem.ui Unknown
1151361435334 40024
projects is recommended org.eclipse.birt.report.tests.chart Unknown
1151361435319 40023
org.eclipse.birt.report.designer.ui is built. Cleaning and building all
projects is recommended org.eclipse.birt.report.designer.tests
Unknown 1151361434928 40018
projects is recommended org.eclipse.birt.report.designer.ui.editors
Unknown 1151361433866 39997
projects is recommended org.eclipse.birt.report.designer.ui.ide
Unknown 1151361434678 40015
projects is recommended org.eclipse.birt.report.designer.ui.lib
Unknown 1151361434272 40006
org.eclipse.birt.report.designer.ui.lib.explorer Unknown 1151361434413 40008
projects is recommended org.eclipse.birt.report.designer.ui.rcp
Unknown 1151361434522 40010
org.eclipse.birt.sample.reportitem.rotatedtext Unknown 1151361433757 39995
org.eclipse.birt.report.engine is built. Cleaning and building all
projects is recommended org.eclipse.birt.chart.reportitem Unknown
1151361435256 40022
projects is recommended org.eclipse.birt.report.designer.ui Unknown
1151361433507 39973
org.eclipse.birt.report.designer.ui.editors.schematic Unknown
1151361434007 39999
projects is recommended org.eclipse.birt.report.designer.ui.preview
Unknown 1151361434132 40001
projects is recommended org.eclipse.birt.report.engine.emitter.html
Unknown 1151361433444 39969
projects is recommended org.eclipse.birt.report.engine.emitter.pdf
Unknown 1151361433382 39967
projects is recommended org.eclipse.birt.report.tests.engine Unknown
1151361433304 39965
projects is recommended org.eclipse.birt.report.viewer Unknown
1151361433132 39964
projects is recommended org.eclipse.birt.test.performance Unknown
1151361433069 39962
projects is recommended org.eclipse.birt.tests.data Unknown
1151361432991 39960
org.eclipse.birt.report.viewer is built. Cleaning and building all
projects is recommended org.eclipse.birt.report.debug.ui Unknown
1151361435069 40020
The project was not built since it depends on com.lowagie.itext, which
has build path errors org.eclipse.birt.report.engine Unknown
1151361432851 39953
Unable to read '.classpath' file of project
org.eclipse.birt.report.data.oda.flatfile.nl Build path 1151360227684 23773
Unsatisfied version constraint:
'org.eclipse.datatools.connectivity.oda: [3.0.1,4.0.0)'
org.eclipse.birt.data.oda.adapter.dtp/META-INF MANIFEST.MF line 14
1151361383765 39290
org.eclipse.birt.data.oda/META-INF MANIFEST.MF line 15 1151361383358 39285
org.eclipse.birt.report.data.oda.jdbc/META-INF MANIFEST.MF line 11
1151361379656 39139
org.eclipse.birt.report.data.oda.sampledb/META-INF MANIFEST.MF line
11 1151361382359 39249
org.eclipse.birt.report.data.oda.xml/META-INF MANIFEST.MF line 12
1151361378578 39094
org.eclipse.birt.report.designer.ui/META-INF MANIFEST.MF line 77
1151361433694 39975
org.eclipse.birt.report.model/META-INF MANIFEST.MF line 31
1151361428398 39710
org.eclipse.birt.report.data.oda.jdbc.ui build.properties line 1
1151361380531 39167
org.eclipse.birt.report.data.oda.sampledb.ui build.properties line 1
1151361382687 39256
org.eclipse.birt.report.data.oda.xml build.properties line 1
1151361378594 39095
org.eclipse.birt.report.data.oda.xml.ui build.properties line 1
1151361379234 39124
org.eclipse.birt.report.designer.example.samplereport
build.properties line 1 1151361376813 39023
org.eclipse.birt.report.tests.engine build.properties line 1
1151361433366 39966
A "source.." build entry is missing org.eclipse.birt.tests.data
build.properties line 1 1151361433054 39961
An "source.lib/itext-1.3.jar" build entry is missing
com.lowagie.itext build.properties line 1 1151361376094 38972
An "source.oda.jar" build entry is missing org.eclipse.birt.data.oda
build.properties line 1 1151361383358 39286
An "source.sampledb.jar" build entry is missing
org.eclipse.birt.report.data.oda.sampledb build.properties line 1
1151361382374 39250
An entry for . is required in bin.includes
org.eclipse.birt.report.data.adapter build.properties line 3
1151361432851 39952
org.eclipse.birt.report.engine.emitter.html build.properties line 3
1151361433507 39972
An entry for ui.jar is required in bin.includes
org.eclipse.birt.report.data.oda.xml.ui build.properties line 4
1151361379234 39125
Attribute 'accelerator' is deprecated
org.eclipse.birt.report.designer.ui.preview plugin.xml line 23
1151361434257 40002
org.eclipse.birt.report.designer.ui.preview plugin.xml line 33
1151361434257 40003
org.eclipse.birt.report.designer.ui.preview plugin.xml line 42
1151361434257 40004
Build entries must contain at least one value
org.eclipse.birt.chart.device.extension.nl build.properties line 3
1151361409136 39570
org.eclipse.birt.chart.device.svg.nl build.properties line 3
1151361407058 39559
org.eclipse.birt.chart.engine.extension.nl build.properties line 3
1151361402121 39475
org.eclipse.birt.chart.engine.nl build.properties line 3 1151361401449 39464
org.eclipse.birt.chart.reportitem.nl build.properties line 3
1151361376235 38997
org.eclipse.birt.chart.ui.extension.nl build.properties line 3
1151361405933 39549
org.eclipse.birt.chart.ui.nl build.properties line 3 1151361403855 39494
org.eclipse.birt.core.nl build.properties line 3 1151361395950 39401
org.eclipse.birt.core.ui.nl build.properties line 3 1151361395919 39399
org.eclipse.birt.data.nl build.properties line 3 1151361395450 39369
org.eclipse.birt.report.data.oda.jdbc.nl build.properties line 3
1151361376391 39002
org.eclipse.birt.report.data.oda.jdbc.ui.nl build.properties line 3
1151361376453 39005
org.eclipse.birt.report.data.oda.sampledb.nl build.properties line 3
1151361376453 39008
org.eclipse.birt.report.data.oda.sampledb.ui.nl build.properties
line 3 1151361376500 39010
org.eclipse.birt.report.data.oda.xml.nl build.properties line 3
1151361376625 39013
org.eclipse.birt.report.data.oda.xml.ui.nl build.properties line 3
1151361376672 39016
org.eclipse.birt.report.debug.ui.nl build.properties line 3
1151361376688 39019
org.eclipse.birt.report.designer.core.nl build.properties line 3
1151361376750 39021
org.eclipse.birt.report.designer.ui.ide.nl build.properties line 3
1151361376891 39027
build.properties line 3 1151361376891 39029
org.eclipse.birt.report.designer.ui.lib.nl build.properties line 3
1151361376906 39031
org.eclipse.birt.report.designer.ui.nl build.properties line 3
1151361376906 39033
org.eclipse.birt.report.designer.ui.rcp.nl build.properties line 3
1151361376969 39037
org.eclipse.birt.report.engine.nl build.properties line 3 1151361377016
39041
org.eclipse.birt.report.model.nl build.properties line 3 1151361377109 39044
Feature reference 'org.eclipse.birt.chart.runtime.source' cannot be
resolved org.eclipse.birt.sdk.feature feature.xml line 31 1151361377188
39049
Feature reference 'org.eclipse.birt.chart.source' cannot be resolved
org.eclipse.birt.sdk.feature feature.xml line 27 1151361377188 39048
Feature reference 'org.eclipse.birt.report.designer.source' cannot be
resolved org.eclipse.birt.sdk.feature feature.xml line 39 1151361377188
39050
Feature reference 'org.eclipse.birt.report.runtime.source' cannot be
resolved org.eclipse.birt.sdk.feature feature.xml line 43 1151361377188
39051
Feature reference 'org.eclipse.birt.source' cannot be resolved
org.eclipse.birt.sdk.feature feature.xml line 51 1151361377188 39052
It is recommended for plug-in 'org.eclipse.birt.core' to run from a JAR,
specify 'unpack="false"' attribute org.eclipse.birt-feature feature.xml
line 90 1151361376125 38978
It is recommended for plug-in 'org.eclipse.birt.data.oda.adapter.dtp' to
run from a JAR, specify 'unpack="false"' attribute
org.eclipse.birt-feature feature.xml line 210 1151361376125 38987
It is recommended for plug-in 'org.eclipse.birt.data' to run from a JAR,
line 42 1151361376125 38973
It is recommended for plug-in 'org.eclipse.birt.report.data.oda.jdbc.ui'
to run from a JAR, specify 'unpack="false"' attribute
org.eclipse.birt-feature feature.xml line 102 1151361376125 38979
'org.eclipse.birt.report.data.oda.sampledb.ui' to run from a JAR,
line 192 1151361376125 38984
It is recommended for plug-in 'org.eclipse.birt.report.data.oda.xml.ui'
org.eclipse.birt-feature feature.xml line 204 1151361376125 38986
It is recommended for plug-in 'org.eclipse.birt.report.data.oda.xml' to
org.eclipse.birt-feature feature.xml line 198 1151361376125 38985
It is recommended for plug-in 'org.eclipse.birt.report.debug.ui' to run
org.eclipse.birt-feature feature.xml line 230 1151361376141 38988
It is recommended for plug-in 'org.eclipse.birt.report.designer.core' to
org.eclipse.birt-feature feature.xml line 54 1151361376125 38974
'org.eclipse.birt.report.designer.ui.editors.schematic' to run from a
JAR, specify 'unpack="false"' attribute org.eclipse.birt-feature
feature.xml line 266 1151361376141 38992
'org.eclipse.birt.report.designer.ui.editors' to run from a JAR, specify
'unpack="false"' attribute org.eclipse.birt-feature feature.xml line
272 1151361376141 38993
It is recommended for plug-in 'org.eclipse.birt.report.designer.ui.ide'
org.eclipse.birt-feature feature.xml line 66 1151361376125 38975
'org.eclipse.birt.report.designer.ui.lib.explorer' to run from a JAR,
line 242 1151361376141 38990
It is recommended for plug-in 'org.eclipse.birt.report.designer.ui.lib'
org.eclipse.birt-feature feature.xml line 236 1151361376141 38989
'org.eclipse.birt.report.designer.ui.preview' to run from a JAR, specify
278 1151361376141 38994
'org.eclipse.birt.report.engine.emitter.html' to run from a JAR, specify
168 1151361376125 38982
'org.eclipse.birt.report.engine.emitter.pdf' to run from a JAR, specify
162 1151361376125 38981
It is recommended for plug-in 'org.eclipse.birt.report.engine.fonts' to
org.eclipse.birt.report.runtime.feature feature.xml line 88
1151361377125 39046
It is recommended for plug-in 'org.eclipse.birt.report.engine' to run
org.eclipse.birt-feature feature.xml line 72 1151361376125 38976
'org.eclipse.birt.report.model.adapter.oda' to run from a JAR, specify
284 1151361376141 38995
It is recommended for plug-in 'org.eclipse.birt.report.model' to run
org.eclipse.birt-feature feature.xml line 78 1151361376125 38977
'org.eclipse.datatools.connectivity.oda.design' to run from a JAR,
line 260 1151361376141 38991
Plug-in reference 'org.eclipse.birt.report.data.oda.flatfile.ui'
cannot be resolved org.eclipse.birt-feature feature.xml line 175
1151361376125 38983
Plug-in reference 'org.eclipse.birt.report.data.oda.flatfile' cannot
be resolved org.eclipse.birt-feature feature.xml line 157 1151361376125
38980
Referenced class 'org.apache.derby.jdbc.ClientDriver' in attribute
'driverClass' is not on the plug-in classpath
org.eclipse.birt.report.data.oda.jdbc plugin.xml line 272 1151361379656
39138
Referenced class 'org.apache.derby.jdbc.EmbeddedDriver' in attribute
org.eclipse.birt.report.data.oda.jdbc plugin.xml line 268 1151361379656
39137
Referenced class 'org.eclipse.birt.chart.device.svg.test.TestPlugin' in
attribute 'class' is not on the plug-in classpath
org.eclipse.birt.chart.device.svg.test plugin.xml line 8 1151361406902 39557
Referenced class 'org.eclipse.birt.report.data.oda.sampledb.Driver' in
attribute 'driverClass' is not on the plug-in classpath
org.eclipse.birt.report.data.oda.sampledb plugin.xml line 135
1151361382359 39248
Referenced class
'org.eclipse.birt.report.designer.ui.internal.rcp.adapters.L ibraryProviderAdapterFactory'
in attribute 'class' is not on the plug-in classpath
org.eclipse.birt.report.designer.ui.rcp plugin.xml line 95
1151361434678 40011
Referenced class
'org.eclipse.birt.report.designer.ui.internal.rcp.adapters.R eportProviderFactory'
org.eclipse.birt.report.designer.ui.rcp plugin.xml line 100
1151361434678 40012
src/ is not included in any "source.*" build entry
org.eclipse.birt.chart.device.extension.nl build.properties line 1
1151361409136 39571
org.eclipse.birt.chart.device.svg.nl build.properties line 1
1151361407058 39560
org.eclipse.birt.chart.engine.extension.nl build.properties line 1
1151361402121 39476
org.eclipse.birt.chart.engine.nl build.properties line 1 1151361401449 39465
org.eclipse.birt.chart.reportitem.nl build.properties line 1
1151361376235 38998
org.eclipse.birt.chart.ui.extension.nl build.properties line 1
1151361405933 39550
org.eclipse.birt.chart.ui.nl build.properties line 1 1151361403855 39495
org.eclipse.birt.core.nl build.properties line 1 1151361395950 39402
org.eclipse.birt.core.ui.nl build.properties line 1 1151361395919 39400
org.eclipse.birt.data.nl build.properties line 1 1151361395450 39370
org.eclipse.birt.data.oda build.properties line 1 1151361383358 39287
org.eclipse.birt.report.data.oda.jdbc.nl build.properties line 1
1151361376391 39003
org.eclipse.birt.report.data.oda.jdbc.ui.nl build.properties line 1
1151361376453 39006
1151361382374 39251
line 1 1151361376500 39011
org.eclipse.birt.report.data.oda.xml.nl build.properties line 1
1151361376625 39014
org.eclipse.birt.report.data.oda.xml.ui.nl build.properties line 1
1151361376672 39017
org.eclipse.birt.report.designer.core.nl build.properties line 1
1151361376750 39022
org.eclipse.birt.report.designer.ui.rcp.nl build.properties line 1
1151361376969 39038
org.eclipse.birt.report.engine.nl build.properties line 1 1151361377016
39042
org.eclipse.birt.report.model.nl build.properties line 1 1151361377109 39045
Start tag 'attribute-value' does not have a matching end tag
org.eclipse.birt.report.data.oda.jdbc/schema driverinfo.exsd line 71
1151361379656 39140
Tag 'br' must not contain a terminating '/'
org.eclipse.birt.report.designer.ui/schema datasource.exsd line 16
1151361433741 39983
Re: Building RC5 [message #173627 is a reply to message #173613] |
Tue, 27 June 2006 02:20   |
Hi George,
You can get the batik/Xerces plugins there:
feature@org.apache.batik=HEAD,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/features/org.apache.ba tik-feature
plugin@org.apache.batik=HEAD,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/plugins/org.apache.bat ik
feature@org.apache.batik.pdf=HEAD,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/features/org.apache.ba tik.pdf-feature
plugin@org.apache.batik.pdf=HEAD,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/plugins/org.apache.bat ik.pdf
feature@org.apache.xerces.feature=HEAD,:pserver:anonymous@dev.eclipse.org :/home/webtools,,wst/components/xml/thirdparty/org.apache.xe rces.feature
plugin@org.apache.xerces=HEAD,:pserver:anonymous@dev.eclipse.org :/home/webtools,,wst/components/xml/thirdparty/org.apache.xe rces
I don't think you need the oda.flatfile plugin anymore, but this needs to be
confirmed.
David
"George Handin" <eclipse@dafunks.com> wrote in message
news:e7pu71$4q1$1@utils.eclipse.org...
> OK. I had to make two changes to reduce the errors down to 5:
> 1st, the following packages had to be updated to use the HEAD of their CVS
> repository:
> org.eclipse.datatools.connectivity.oda.flatfile
> Which leaves me with 5 errors:
> 1151367538429 48667
> PDFRendererImpl.java line 163 1151367538210 48665
> PDFRendererImpl.java line 163 1151367538210 48666
> PDFRendererImpl.java line 30 1151367538210 48664
> org.eclipse.birt.report.data.oda.flatfile.nl Build path 1151361686747
> 41176
Re: Building RC5 [message #173672 is a reply to message #173613] |
Tue, 27 June 2006 04:56   |
Greetings,
The chart plug-in "org.eclipse.birt.chart.device.pdf" requires 3 third party
plug-ins:
org.apache.batik
org.apache.xerces
So please checkout these 3rd party plug-ins to your workspace.
You can get
org.apache.batik from:
pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/plugins/org.apache.bat ik;
org.apache.batik.pdf from:
pserver:anonymous@dev.eclipse.org :/cvsroot/technology,,org.eclipse.gmf/plugins/org.apache.bat ik.pdf;
org.apache.xerces from:
Thanks.
Nina
> repository:
> 1151367538429 48667
> 41176
Re: Building RC5 [message #173928 is a reply to message #173627] |
Tue, 27 June 2006 14:33   |
Thanks. Now I only have 100 errors when building the Report Viewer
(using BuildViewer.xml). The org.eclipse.datatools.connectivity.oda
project has been checked out into my workspace; so I'm not sure what the
problem is ...
Buildfile:
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.report.viewer\BuildViewer.xml
[snip]
[javac] Compiling 11 source files to
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\temp.folder\oda-adapter.jar.bin
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:22:
package org.eclipse.datatools.connectivity.oda does not exist
[javac] import org.eclipse.datatools.connectivity.oda.IAdvancedQuery;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:23:
[javac] import org.eclipse.datatools.connectivity.oda.IBlob;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:24:
[javac] import org.eclipse.datatools.connectivity.oda.IClob;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:25:
[javac] import org.eclipse.datatools.connectivity.oda.IParameterRowSet;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:26:
[javac] import org.eclipse.datatools.connectivity.oda.IResultSet;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:27:
[javac] import
org.eclipse.datatools.connectivity.oda.IResultSetMetaData;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:28:
[javac] import org.eclipse.datatools.connectivity.oda.OdaException;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:29:
[javac] import org.eclipse.datatools.connectivity.oda.SortSpec;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:22:
[javac] import
org.eclipse.datatools.connectivity.oda.IParameterMetaData;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:23:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:24:
[javac] import
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:25:
[javac] import org.eclipse.datatools.connectivity.oda.IQuery;
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:26:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:27:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:32:
cannot resolve symbol
[javac] symbol : class IQuery
[javac] location: class org.eclipse.birt.data.oda.adapter.dtp.Query
[javac] public class Query implements IQuery
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:34:
[javac] symbol : class IAdvancedQuery
org.eclipse.birt.data.oda.adapter.dtp.AdvancedQuery
[javac] public class AdvancedQuery extends Query implements
IAdvancedQuery
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:39:
[javac] symbol : class OdaException
[javac] private AdvancedQuery() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:49:
[javac] public AdvancedQuery(
org.eclipse.birt.data.oda.IAdvancedQuery birtAdvancedQuery ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:58:
[javac] public boolean execute() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:73:
[javac] symbol : class IResultSet
[javac] public IResultSet getResultSet() throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:88:
[javac] public boolean getMoreResults() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:103:
[javac] public String[] getResultSetNames() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:118:
[javac] symbol : class IResultSetMetaData
[javac] public IResultSetMetaData getMetaDataOf( String
resultSetName ) throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:133:
[javac] public IResultSet getResultSet( String resultSetName )
throws OdaException
[javac] ^
[javac]
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:148:
[javac] symbol : class IParameterRowSet
[javac] public IParameterRowSet setNewRow( String parameterName )
throws OdaException
[javac] ^
[javac]
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:163:
[javac] public IParameterRowSet setNewRow( int parameterId ) throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:178:
[javac] public IParameterRowSet setNewRowSet( String parameterName
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:193:
[javac] public IParameterRowSet setNewRowSet( int parameterId )
throws OdaException
[javac] ^
[javac]
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:208:
[javac] public int getInt( String parameterName ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:223:
[javac] public int getInt( int parameterId ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:238:
[javac] public double getDouble( String parameterName ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:253:
[javac] public double getDouble( int parameterId ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:268:
[javac] public BigDecimal getBigDecimal( String parameterName )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:283:
[javac] public BigDecimal getBigDecimal( int parameterId ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:298:
[javac] public String getString( String parameterName ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:313:
[javac] public String getString( int parameterId ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:328:
[javac] public Date getDate( String parameterName ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:343:
[javac] public Date getDate( int parameterId ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:358:
[javac] public Time getTime( String parameterName ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:373:
[javac] public Time getTime( int parameterId ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:388:
[javac] public Timestamp getTimestamp( String parameterName )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:403:
[javac] public Timestamp getTimestamp( int parameterId ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:419:
[javac] symbol : class IBlob
[javac] public IBlob getBlob( String parameterName ) throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:428:
[javac] public IBlob getBlob( int parameterId ) throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:437:
[javac] symbol : class IClob
[javac] public IClob getClob( String parameterName ) throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:446:
[javac] public IClob getClob( int parameterId ) throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:454:
[javac] public IParameterRowSet getRow( String parameterName )
throws OdaException
[javac] ^
[javac]
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:469:
[javac] public IParameterRowSet getRow( int parameterId ) throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:484:
[javac] public int findOutParameter( String parameterName ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:499:
[javac] public boolean wasNull() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:514:
[javac] symbol : class SortSpec
[javac] public void setSortSpec( String resultSetName, SortSpec
sortBy ) throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\AdvancedQuery.java:529:
[javac] public SortSpec getSortSpec( String resultSetName ) throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:45:
[javac] public Query( org.eclipse.birt.data.oda.IQuery birtQuery )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:54:
[javac] public void prepare( String query ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:69:
[javac] public void setAppContext( Object context ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:79:
[javac] public void setProperty( String name, String value ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:95:
[javac] public void close() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:111:
[javac] public void setMaxRows( int max ) throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:127:
[javac] public int getMaxRows() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:143:
[javac] public IResultSetMetaData getMetaData() throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:159:
[javac] public IResultSet executeQuery() throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:175:
[javac] public void setInt( String parameterName, int value )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:191:
[javac] public void setInt( int parameterId, int value ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:209:
[javac] throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:225:
[javac] public void setDouble( int parameterId, double value )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:243:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:261:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:279:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:296:
[javac] public void setString( int parameterId, String value )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:313:
[javac] public void setDate( String parameterName, Date value )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:329:
[javac] public void setDate( int parameterId, Date value ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:347:
[javac] public void setTime( String parameterName, Time value )
throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:363:
[javac] public void setTime( int parameterId, Time value ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:381:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:399:
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:415:
[javac] public int findInParameter( String parameterName ) throws
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:431:
[javac] symbol : class IParameterMetaData
[javac] public IParameterMetaData getParameterMetaData() throws
OdaException
[javac] ^
[javac]
OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:447:
[javac] public void clearInParameters() throws OdaException
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:463:
[javac] public void setSortSpec( SortSpec sortBy ) throws OdaException
[javac] ^
[javac]
[javac] ^
[javac]
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\src\org\eclipse\birt\data\oda\adapter \dtp\Query.java:479:
[javac] public SortSpec getSortSpec() throws OdaException
[javac] ^
[javac]
[javac] ^
[javac] Note: Recompile with -deprecation for details.
[javac] 100 errors
BUILD FAILED
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.report.viewer\BuildViewer.xml:263:
D:\Projects\BDDB\eclipse-BIRT\birt-workspace\org.eclipse.bir t.data.oda.adapter.dtp\BuildDtpOdaAdapter.xml:89:
Total time: 13 seconds
Re: Building RC5 [message #173971 is a reply to message #173928] |
Wed, 28 June 2006 02:58   |
Did you check the build instructions on the web site? Maybe you can repost a
new thread in the newsgroups regarding that issue.
David
news:44A179FE.6090505@dafunks.com...
> Thanks. Now I only have 100 errors when building the Report Viewer (using
> BuildViewer.xml). The org.eclipse.datatools.connectivity.oda project has
> been checked out into my workspace; so I'm not sure what the problem is
> Buildfile:
> [snip]
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] import
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] import
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] import
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] import
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> IAdvancedQuery
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public AdvancedQuery( org.eclipse.birt.data.oda.IAdvancedQuery
> birtAdvancedQuery ) throws OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public IResultSet getResultSet( String resultSetName ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> throws OdaException
> [javac] ^
> [javac]
> throws OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] public IParameterRowSet setNewRowSet( String parameterName )
> throws OdaException
> [javac] ^
> [javac]
> throws OdaException
> [javac] ^
> [javac]
> [javac] public IParameterRowSet setNewRowSet( int parameterId ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public BigDecimal getBigDecimal( String parameterName ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public Timestamp getTimestamp( String parameterName ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public IParameterRowSet getRow( String parameterName ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> throws OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public void setInt( String parameterName, int value ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public void setDouble( int parameterId, double value ) throws
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] public void setString( int parameterId, String value ) throws
> OdaException
> [javac] ^
> [javac]
> [javac] public void setDate( String parameterName, Date value ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] public void setTime( String parameterName, Time value ) throws
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> OdaException
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac] 100 errors
> BUILD FAILED
Re: Building RC5 [message #173982 is a reply to message #173971] |
Wed, 28 June 2006 04:27  |
I succeed in building the application with BuildWebViewer but not with BuildViewer ...
So just for my information, what is the difference between these two build file ?
There's some differences in the way they build jar and war.
Also BuildWebViewer doesn't take care of src/*.java ...
George, to Jar with BuildViewer, try to copy axis.jar and javaxrpc.jat from birt_web/lib to birt/lib
It could works ;)
> David
>> Buildfile:
>> [snip]
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] import
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] import
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] import
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] import
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> IAdvancedQuery
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> throws OdaException
>> [javac] ^
>> [javac]
>> throws OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> throws OdaException
>> [javac] ^
>> [javac]
>> throws OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> throws OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> OdaException
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac]
>> [javac] ^
>> [javac] 100 errors
>> BUILD FAILED
Current Time: Sat Jul 12 17:27:08 EDT 2025
Powered by FUDForum. Page generated in 0.20860 seconds
