Home » Eclipse Projects » DTP » Connection Profile Wizard
Connection Profile Wizard [message #16379] Sun, 11 June 2006 12:34 Go to next message
i would like to start the Connection Profile Wizard from my Plugin .
I will have a button to start the wizard.
How can I call the Wizard?
Oliver
Re: Connection Profile Wizard [message #17846 is a reply to message #16379] Mon, 26 June 2006 16:53 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi...
Unfortunately the APIs you would need to call are all internal to pop up
the wizard. You can take a look at
org.eclipse.datatools.connectivity.ui.dse.actions.AddProfile ViewAction.java
at how we did it in the Data Source Explorer (in the
org.eclipse.datatools.connectivity.ui.dse plug-in). You might put in a
Bugzilla entry indicating that you'd like some way of popping up that menu
that was a public API.
Hope that helps!
--Brian Fitzpatrick
Sybase, Inc/DTP-Committer
Re: Connection Profile Wizard [message #19971 is a reply to message #17846] Tue, 25 July 2006 14:07 Go to previous message
Created BZ entry https://bugs.eclipse.org/bugs/show_bug.cgi?id=151733.
Re: Connection Profile Wizard [message #579926 is a reply to message #16379] Mon, 26 June 2006 16:53 Go to previous message
Hi...
Hope that helps!
--Brian Fitzpatrick
Re: Connection Profile Wizard [message #581264 is a reply to message #17846] Tue, 25 July 2006 14:07 Go to previous message
Previous Topic:SQL Editor
Next Topic:DTP going to follow UI guidelines?
Current Time: Wed Jun 04 08:46:02 EDT 2025
Powered by FUDForum. Page generated in 0.10125 seconds
