Home » Newcomers » Newcomers » Why does Eclispe Reformat My Files?
Why does Eclispe Reformat My Files? [message #173362] Tue, 03 October 2006 11:02 Go to next message
Originally posted by: hal.thresholddigital.com
I've had a similar problem that I've posted before with the Java Editor. (I
created my own definitions for code formatting and they're ignored when I
press ctrl-shift-f.) I have not had time to re-install Eclipse or file a
bug report on it. I could deal with that issue if Eclipse didn't just go
through an reformat my files while I'm editing.
I had just gone through and added blank lines, by hand, in front of every
method in my class, or in front of the Javadoc comment before that method.
For me, finally, the code was easily readable. Then I added a new method
to my class, in the middle, and below it, all the methods that were one
space apart, so I could easily read them and keep them separate, had been
moved together. The blank lines before the method declarations had been
removed in most, but not all cases.
This is not something done when I opened or closed a file, and it's an
ongoing problem. I understand the need to unfold a method when I'm editing
right above it. This is completely different, though. I can have the
class formatted the way I want, then I add a new method, and suddenly
everything below it is reformatted.
If ctrl-shift-f would reformat to my specs, or if this auto-reformatting
while I'm editing would stop, it'd be okay, but as it is, I have to keep
reformatting by hand when I get confused in reading the classes. Can I
turn off this obnoxious re-writing of my code? It's like Eclipse has it's
standards and won't listen to mine.
Thanks!
Hal
Re: Why does Eclispe Reformat My Files? [message #173434 is a reply to message #173362] Tue, 03 October 2006 21:39 Go to previous messageGo to next message
How is it reformatting while you're editing? Do you mean it's stripping
out extra lines and such from methods you're not even editing?
What version of Eclipse are you using?
Wayne
Re: Why does Eclispe Reformat My Files? [message #173442 is a reply to message #173434] Wed, 04 October 2006 01:16 Go to previous messageGo to next message
>> it's standards and won't listen to mine.
I've had a number of times today where I've edited a class that has a blank
line after each method, followed either by another method or a Javadoc
comment and a method. I start editing a method and look below and find
that extra blank lines after (or before) methods have been inserted or the
blank lines that were there were removed.
I'm using either my format defs, which specify a blank line before methods,
or the default Java defs. This is in the Java editor.
All I have to do is do a little editing in one method, and all the ones that
follow get extra blank lines added between them or the blank lines between
following methods are removed.
OOps. Forgot to include it. Version 3.2 on Linux.
Hal
Re: Why does Eclispe Reformat My Files? [message #173490 is a reply to message #173442] Wed, 04 October 2006 09:04 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
It sounds to me like there's some confusion in the interpretation of the
newline characters going on in your file. Did you create this file from
scratch, or bring it on to you linux system from a windows or mac? Does
this problem happen with a new file you create from scratch? If you're
working on a Windows file on Linux, and don't use a system like CVS
which will handle the conversion automatically, you can go to
Window->Preferences->General->Workspace and change the New text file
line delimiter to Windows and see if that helps.
- Jeff
> Hal
Re: Why does Eclispe Reformat My Files? [message #173519 is a reply to message #173490] Wed, 04 October 2006 14:04 Go to previous messageGo to next message
> - Jeff
The file was created from scratch. It's not a problem of when the file is
read in. The problem is not on loading or saving, but what happens WHILE I
am editing in the Java editor.
There should be no problem with EOL characters, since Eclipse and the files
have been on Linux from the start.
Hal
> Hal Vaughan wrote:
>> Wayne Beaton wrote:
>>>> auto-reformatting while I'm editing would stop, it'd be okay, but as it
>>>> is, I have to keep
>> blank line after each method, followed either by another method or a
>> Javadoc
>> the blank lines that were there were removed.
>> methods,
>> that follow get extra blank lines added between them or the blank lines
>> between following methods are removed.
>> Hal
Re: Why does Eclispe Reformat My Files? [message #174020 is a reply to message #173519] Mon, 09 October 2006 12:04 Go to previous message
>> - Jeff
Please file a bug report against JDT Text with steps to reproduce.
Dani
>Hal
>>Hal Vaughan wrote:
>>>>>is, I have to keep
>>>Javadoc
>>>methods,
>>>Hal
Previous Topic:error executing jar file
Next Topic:Eclipse 3.2 and introspection
Current Time: Thu Nov 06 23:20:45 EST 2025
Powered by FUDForum. Page generated in 0.10901 seconds
