Exception during launch of "Run Application" [message #173019] |
Mon, 22 December 2003 10:03  |
Originally posted by: schujunk2.cox.net
This morning I started up Eclipse and started to do some work. Later I
discovered I had two open, close the one and then continued working.
However, after entering a new test code from the Java Swing book, I get
the exception "Exception occurred during launch - Reason: Source locator
does not exist: org.eclipse.jdt.debug.ui.javaSourceLocator". I did some
searches and it seems that having two open at once and closing one is bad
and perhaps a bug. However, I did not find a solution to get me back to
where I was except for deleting all the Eclipse directory and starting
over, which isn't a big deal. Another note is when I go to preferences,
it comes up empty. I'll try to take my work pc and export the workspace
it has and import it into my laptop in hopes that will fix it.
Any ideas? Thanks, Michael
Re: Exception during launch of "Run Application" [message #173054 is a reply to message #173019] |
Mon, 22 December 2003 10:36  |
See the following bug. It's a known problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=40947
Darin
"Michael" <schujunk2@cox.net> wrote in message
news:bs7143$m08$1@eclipse.org...
FUDForum. Page generated in 0.04229 seconds
