IndexOutOfBoundsException in [message #172870] |
Mon, 21 March 2005 18:21  |
Originally posted by: p.clark.mindspring.com
In certain situations I am seeing an exception when drawing a connector
from one figure to another in my GEF drawing. The exception seems to be
coming from the GEF and draw2d. This only occurs when I am attempting
to reconnect an existing connection and happens while I am moving the
end of the connector.
I have been looking at this for some time and can't seem to find the
root cause. I haven't found anything in the news group. Please let me
know if anyone has any ideas or additional information is necessary.
Here is the stack trace:
!ENTRY org.eclipse.ui 4 0 Mar 21, 2005 17:08:00.525
!MESSAGE Index: 3, Size: 3
!STACK 0
java.lang.IndexOutOfBoundsException: Index: 3, Size: 3
at org.eclipse.draw2d.geometry.PointList.getPoint(PointList.jav a:183)
org.eclipse.draw2d.BendpointLocator.getReferencePoint(Bendpo intLocator.java:56)
at org.eclipse.draw2d.AbstractLocator.relocate(AbstractLocator. java:103)
at org.eclipse.gef.handles.AbstractHandle.validate(AbstractHand le.java:208)
at org.eclipse.draw2d.Figure.validate(Figure.java:1606)
org.eclipse.draw2d.FreeformLayeredPane.validate(FreeformLaye redPane.java:122)
org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.c alculatePreferredSize(FreeformViewport.java:28)
org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:93)
org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(Abstr actHintLayout.java:86)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:648)
at org.eclipse.draw2d.ScrollPaneSolver.solve(ScrollPaneSolver.j ava:75)
at org.eclipse.draw2d.FigureCanvas.layoutViewport(FigureCanvas. java:222)
at org.eclipse.draw2d.FigureCanvas.access$4(FigureCanvas.java:2 20)
org.eclipse.draw2d.FigureCanvas$3.notifyValidating(FigureCan vas.java:185)
at org.eclipse.draw2d.UpdateManager.fireValidating(UpdateManage r.java:93)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:233)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:137)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:62)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
com.fastrieve.eclipse.plugin.FastrieveAdminApplication.run(F astrieveAdminApplication.java:28)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Patrick
Re: IndexOutOfBoundsException in [message #173036 is a reply to message #173022] |
Tue, 22 March 2005 11:53  |
Thanks for the guidance. I was able to track it down to the problem
section of code.
In my ConnectionEditPart (extends AbstractConnectionEditPart)
createEditPolicies I was installing the following edit policy :
installEditPolicy(EditPolicy.CONNECTION_BENDPOINTS_ROLE, new
PartConnectionSelectionHandlesEditPolicy());
When I comment that line out, I no longer have the problem. This was
probably due to an improperly extended SelectionHandlesEditPolicy. Here
is the policy
public class PartConnectionSelectionHandlesEditPolicy extends
SelectionHandlesEditPolicy {
public PartConnectionSelectionHandlesEditPolicy() {
super();
protected List createSelectionHandles() {
List list = new ArrayList();
ConnectionEditPart connPart = (ConnectionEditPart) getHost();
PointList points = getConnection().getPoints();
for (int i = 0; i < points.size() - 2; i++) {
BendpointHandle handle = new BendpointCreationHandle(connPart, 0,
new BendpointLocator(getConnection(), i + 1));
list.add(handle);
return list;
protected Connection getConnection() {
return (Connection) getHostFigure();
Patrick
Randy Hudson wrote:
> Try hard to reproduce in the logic example. That way we can reproduce it
> and debug.
> It looks like the number of bends in the connection might be changing as you
> drag the connection around, and the bendpoint editpolicy for some reason is
> not rebuilding its handles when this occurs. Therefore, it ends up with a
> handle referencing a bend index which is too large.
> the policy should track the "points" property of the connection, and refresh
> its handles if the number of points changes.
> "Patrick Clark" <p.clark@mindspring.com> wrote in message
> news:d1npkm$r9e$1@news.eclipse.org...
>>coming from the GEF and draw2d. This only occurs when I am attempting to
>>reconnect an existing connection and happens while I am moving the end of
>>the connector.
>>I have been looking at this for some time and can't seem to find the root
>>cause. I haven't found anything in the news group. Please let me know if
>>!STACK 0
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
>>Thanks,
>>Patrick
FUDForum. Page generated in 0.05488 seconds
