Home » Language IDEs » ServerTools (WTP) » Error message with XML Schema Validator
Error message with XML Schema Validator [message #172863] Tue, 04 July 2006 03:28 Go to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi everybody,
I have a strange problem with a dynamic web project which worked fine in WTP 1.5
RC 5.
I upgraded to 1.5, with a completely new workspace, and now the project shows
this error message:
"The validator XML Schema Validator is a delegating validator but no delegate
can found for it.".
An other web project works just fine. I did not find any difference in
".project", ".classpath", ".settings\.component" or any other settings file.
Of course there is nothing to be found in the error log.
Does anybody have an idea what could be wrong ? Currently there is too few
information to make a bugzilla report :-(.
Best regards
Wolfgang
Re: Error message with XML Schema Validator [message #172930 is a reply to message #172863] Tue, 04 July 2006 11:26 Go to previous messageGo to next message
Originally posted by: valentinbaciu.hotmail.com
Try going to Preferences/Validation, select the row with the XML schema
validator, click on the ... button in the settings column. This will open a
dialog with a selection box. If the nothing is selected try to select the
one and only delegate validator (Xerces based validator).
By default it should be selected.
Valentin
"Wolfgang Knauf" <wknauf_NO_@_INSIDE_hg-online.de> wrote in message
news:e8d5aq$q9d$1@utils.eclipse.org...
> Hi everybody,
WTP 1.5
> RC 5.
shows
> this error message:
delegate
> can found for it.".
file.
> Best regards
> Wolfgang
Re: Error message with XML Schema Validator [message #173127 is a reply to message #172930] Wed, 05 July 2006 11:41 Go to previous messageGo to next message
Hi Valentin,
thanks for your reply. Unfortunately this did not help. The project uses the
settings from the eclipse preferences, and there the schema validator and its
delegate are activated (I did not change anything, these are the installation
defaults).
Any other ideas ?
Best regards
Wolfgang
> Valentin
Re: Error message with XML Schema Validator [message #173188 is a reply to message #173127] Wed, 05 July 2006 13:01 Go to previous messageGo to next message
I was wondering if you could try going to the project's
properties/Validation then try overriding the global preferences, make sure
the delegate validator is configured and apply the changes.
Revalidate. Make sure you then revert to using the global preferences.
If this does not work I suggest re-creating the project - if at all
possible. The metadata storing the validation preferences seems to have been
corrupted somehow.
Valentin
news:e8gmj6$2gc$1@utils.eclipse.org...
> Hi Valentin,
the
its
installation
> defaults).
> Any other ideas ?
> Best regards
> Wolfgang
open a
the
> > Regards,
> > Valentin
Re: Error message with XML Schema Validator [message #173353 is a reply to message #173188] Thu, 06 July 2006 11:19 Go to previous messageGo to next message
Hi Valentin,
thanks a lot, I got it working. It was much easier than you suggested: I copied
the project, changed the name, closed the original project and deleted it from
eclipse, then I imported the copy. Validation ran without problems. So i deleted
the copy, too, and re-imported the original project. Now it validates fine
again. No idea what went wrong, and of course no chance to repro it. OK, I could
try a blank eclipse installation and import my project... Seems there is a
severe problem, as you said.
Best regards
Wolfgang
> corrupted somehow.
> Valentin
Re: Error message with XML Schema Validator [message #179307 is a reply to message #173353] Mon, 18 September 2006 15:46 Go to previous message
In case anyone else happens to encounter an "The validator XML Schema
Validator is a delegating validator but no delegate can found for it"
error in their project, I've seen this symptom occur due to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155706
Cleaning the project appears to get rid of the error.
Larry
Wolfgang Knauf wrote:
> Hi Valentin,
> copied the project, changed the name, closed the original project and
> deleted it from eclipse, then I imported the copy. Validation ran
> without problems. So i deleted the copy, too, and re-imported the
> original project. Now it validates fine again. No idea what went wrong,
> and of course no chance to repro it. OK, I could try a blank eclipse
> installation and import my project... Seems there is a severe problem,
> as you said.
> Best regards
> Wolfgang
>> sure
>> have been
>> corrupted somehow.
>> Valentin
Previous Topic:Programmatically add a defined JSF component library to a web project
Next Topic:error using WTP and webapps
Current Time: Thu Jul 17 21:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.33683 seconds
