Home » Eclipse Projects » Eclipse Platform » Debugger crashing VM
Debugger crashing VM [message #172833] Sun, 21 December 2003 00:28 Go to next message
I think I will post this question here to this newsgroup to see if there
is any help available before I report this as a bug to Sun or Eclipse.
(I did find a couple of similar reports in the Eclipse bugzilla
database, but cannot be sure any were exactly what I am seeing.) So any
insight is much appreciated! ;-)
I am using as reported by java -version on a linux/x86 platform
java version "1.4.2"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2-b28)
Java HotSpot(TM) Client VM (build 1.4.2-b28, mixed mode)
and working with Eclipse3.0M5 build -
Version: 3.0.0
Build id: 200311211210
Because the default settings for the Java VM was causing my application
to run out of memory, I am using the following VM arguments -
-server -Xms100m -XX:+UseParallelGC -XX:+UseAdaptiveSizePolicy
When I set a breakpoint in my application, I am getting the following
crash reported, and the debug session is terminated and reports that it
cannot find the source file to display. (it is there in my project
workspace) Any suggestions or ideas? Thanks Marc..... -
Unexpected Signal : 11 occurred at PC=0x40551439
Function=(null)+0x40551439
Library=/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/server/libjvm. so
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:02 352738
/opt/j2sdk_nb/j2sdk1.4.2/bin/java
0804e000-0804f000 rw-p 00005000 03:02 352738
40000000-40018000 r-xp 00000000 03:02 6829 /lib/ld-2.3.2.so
40018000-40019000 rw-p 00017000 03:02 6829 /lib/ld-2.3.2.so
4001a000-40022000 r-xp 00000000 03:02 352115
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/native_threads/libhpi. so
40022000-40023000 rw-p 00007000 03:02 352115
40023000-40027000 rw-s 00000000 03:02 350563 /tmp/hsperfdata_marc/4434
40027000-4002a000 r-xp 00000000 03:02 352149
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libdt_socket.so
4002a000-4002b000 rw-p 00002000 03:02 352149
4002b000-4002e000 r--s 00000000 03:02 352153
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/ext/dnsns.jar
4002e000-40030000 r--s 00000000 03:02 355768
/home/marc/eclipse/workspace/jdom2/lib/jaxen-jdom.jar
40030000-4003e000 r-xp 00000000 03:02 6828 /lib/i686/libpthread.so.0
4003e000-4003f000 rw-p 0000d000 03:02 6828 /lib/i686/libpthread.so.0
40081000-40083000 r-xp 00000000 03:02 6838 /lib/libdl.so.2
40083000-40084000 rw-p 00002000 03:02 6838 /lib/libdl.so.2
40084000-401b0000 r-xp 00000000 03:02 6826 /lib/i686/libc.so.6
401b0000-401b5000 rw-p 0012c000 03:02 6826 /lib/i686/libc.so.6
401b8000-40764000 r-xp 00000000 03:02 352117
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/server/libjvm.so
40764000-407be000 rw-p 005ab000 03:02 352117
407d1000-407e3000 r-xp 00000000 03:02 6841 /lib/libnsl.so.1
407e3000-407e4000 rw-p 00011000 03:02 6841 /lib/libnsl.so.1
407e6000-40808000 r-xp 00000000 03:02 6827 /lib/i686/libm.so.6
40808000-40809000 rw-p 00021000 03:02 6827 /lib/i686/libm.so.6
40809000-40819000 r-xp 00000000 03:02 352126
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libverify.so
40819000-4081b000 rw-p 0000f000 03:02 352126
4081b000-4083b000 r-xp 00000000 03:02 352127
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libjava.so
4083b000-4083d000 rw-p 0001f000 03:02 352127
4083d000-40851000 r-xp 00000000 03:02 352129
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libzip.so
40851000-40854000 rw-p 00013000 03:02 352129
40854000-421df000 r--s 00000000 03:02 352731
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/rt.jar
42229000-4223f000 r--s 00000000 03:02 352156
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/sunrsasign.jar
4223f000-4231a000 r--s 00000000 03:02 352639
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/jsse.jar
4231a000-4232b000 r--s 00000000 03:02 352157
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/jce.jar
4232b000-42884000 r--s 00000000 03:02 352677
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/charsets.jar
4492c000-4492e000 r-xp 00000000 03:02 15550
/usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
4492e000-4492f000 rw-p 00001000 03:02 15550
58664000-58690000 r--p 00000000 03:02 9445
/usr/lib/locale/en_US/LC_CTYPE
58690000-586bb000 r-xp 00000000 03:02 352148
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libjdwp.so
586bb000-586bd000 rw-p 0002a000 03:02 352148
586c0000-586cd000 r--s 00000000 03:02 352155
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/ext/ldapsec.jar
586cd000-586d4000 r-xp 00000000 03:02 15663 /usr/X11R6/lib/libXp.so.6.2
586d4000-586d5000 rw-p 00006000 03:02 15663 /usr/X11R6/lib/libXp.so.6.2
586d6000-586df000 r-xp 00000000 03:02 6844 /lib/libnss_files.so.2
586df000-586e0000 rw-p 00008000 03:02 6844 /lib/libnss_files.so.2
58fe9000-59005000 r--s 00000000 03:02 352152
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/ext/sunjce_provider.jar
59005000-590c1000 r--s 00000000 03:02 352678
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/ext/localedata.jar
59142000-5940d000 r-xp 00000000 03:02 352137
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libawt.so
5940d000-59422000 rw-p 002ca000 03:02 352137
59448000-5949b000 r-xp 00000000 03:02 352136
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libmlib_image.so
5949b000-5949c000 rw-p 00052000 03:02 352136
5949c000-594a2000 r--s 00000000 03:02 355770
/home/marc/eclipse/workspace/jdom2/lib/saxpath.jar
594a2000-594aa000 r-xp 00000000 03:02 15647
/usr/X11R6/lib/libXcursor.so.1.0
594aa000-594ab000 rw-p 00007000 03:02 15647
594ab000-594b1000 r--s 00000000 03:02 7440
/usr/lib/gconv/gconv-modules.cache
594b2000-59502000 r-xp 00000000 03:02 15671 /usr/X11R6/lib/libXt.so.6.0
59502000-59505000 rw-p 00050000 03:02 15671 /usr/X11R6/lib/libXt.so.6.0
59506000-59513000 r-xp 00000000 03:02 15649
/usr/X11R6/lib/libXext.so.6.4
59513000-59514000 rw-p 0000d000 03:02 15649
59514000-59519000 r-xp 00000000 03:02 15673
/usr/X11R6/lib/libXtst.so.6.1
59519000-5951a000 rw-p 00004000 03:02 15673
5951a000-59612000 r-xp 00000000 03:02 15639
/usr/X11R6/lib/libX11.so.6.2
59612000-59616000 rw-p 000f8000 03:02 15639
59616000-5961e000 r-xp 00000000 03:02 15637 /usr/X11R6/lib/libSM.so.6.0
5961e000-5961f000 rw-p 00007000 03:02 15637 /usr/X11R6/lib/libSM.so.6.0
5961f000-59633000 r-xp 00000000 03:02 15635
/usr/X11R6/lib/libICE.so.6.3
59633000-59635000 rw-p 00013000 03:02 15635
59636000-598bf000 r--s 00000000 03:02 355536
/home/marc/eclipse/workspace/jdom2/gui.jar
598bf000-59972000 r--s 00000000 03:02 355764
/home/marc/eclipse/workspace/jdom2/lib/ant.jar
59972000-59991000 r--s 00000000 03:02 355776
/home/marc/eclipse/workspace/jdom2/lib/xml-apis.jar
59991000-59acd000 r--s 00000000 03:02 355771
/home/marc/eclipse/workspace/jdom2/lib/xalan.jar
59acd000-59af5000 r--s 00000000 03:02 355767
/home/marc/eclipse/workspace/jdom2/lib/jaxen-core.jar
59af5000-5a4c6000 r--s 00000000 03:02 355766
/home/marc/eclipse/workspace/jdom2/lib/classes.jar
5a4c6000-5a5a1000 r--s 00000000 03:02 355774
/home/marc/eclipse/workspace/jdom2/lib/xerces.jar
5a5a1000-5a65b000 r-xp 00000000 03:02 352140
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libfontmanager.so
5a65b000-5a675000 rw-p 000b9000 03:02 352140
5a676000-5a678000 r-xp 00000000 03:02 7391 /usr/lib/gconv/ISO8859-1.so
5a678000-5a679000 rw-p 00001000 03:02 7391 /usr/lib/gconv/ISO8859-1.so
5a68c000-5a693000 r-xp 00000000 03:02 15669
/usr/X11R6/lib/libXrender.so.1.2
5a693000-5a694000 rw-p 00006000 03:02 15669
5a694000-5a6b1000 r-xp 00000000 03:02 15549
/usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2
5a6b1000-5a6b3000 rw-p 0001c000 03:02 15549
5a8b7000-5a8ee000 r-xp 00000000 03:02 352141
/opt/j2sdk_nb/j2sdk1.4.2/jre/lib/i386/libjpeg.so
5a8ee000-5a8ef000 rw-p 00036000 03:02 352141
5ac8f000-5ad21000 rw-s 00000000 00:05 594083850 /SYSV00000000 (deleted)
Heap at VM Abort:
Heap
PSYoungGen total 13120K, used 11898K [0x44930000, 0x45780000,
0x464f0000)
eden [0x44930000,0x44b96890,0x44ca0000)
from [0x44ca0000,0x455d8010,0x45600000)
to [0x45600000,0x45600000,0x45780000)
PSOldGen total 91072K, used 29409K [0x464f0000, 0x4bde0000,
0x54330000)
object [0x464f0000,0x481a8668,0x4bde0000)
PSPermGen total 16384K, used 9219K [0x54330000, 0x55330000,
0x58330000)
object [0x54330000,0x54c30e88,0x55330000)
Local Time = Sat Dec 20 20:18:17 2003
Elapsed Time = 88
# HotSpot Virtual Machine Error : 11
# Error ID : 4F530E43505002EF
# Please report this error at
# http://java.sun.com/cgi-bin/bugreport.cgi
# Java VM: Java HotSpot(TM) Server VM (1.4.2-b28 mixed mode)
Re: Debugger crashing VM [message #172842 is a reply to message #172833] Sun, 21 December 2003 13:06 Go to previous messageGo to next message
Did you check for reports in Sun's bug parade?
There is not much you can do with Eclipse to work around a virtual machine
error.
I work with the 1.4.2 VM a lot but I have never seen your problem but I also
never use the -XX args.
I always use -Xms and -Xmx
HTH
Darins
"Marc Chamberlin" <marcc@easystreet.com> wrote in message
news:3FE52F78.2010409@easystreet.com...
> Version: 3.0.0
> Dynamic libraries:
> Heap at VM Abort:
> Heap
> 0x464f0000)
> 0x54330000)
> 0x58330000)
> Elapsed Time = 88
Re: Debugger crashing VM [message #172851 is a reply to message #172842] Sun, 21 December 2003 15:25 Go to previous message
Thanks Darin for your input... I did look at the Sun bug parade and
found quite a few reports coming up with this same error, but all were
under quite different scenarios... Anywise, I now suspect my problem is
resulting from trying to use the parallel garbage collection option of
the VM so have turned it off for now and that seems to be helping... Not
completely sure yet, time will tell...;-) Marc...
> error.
> HTH
> Darins
>>Version: 3.0.0
>>Dynamic libraries:
>>Heap at VM Abort:
>>Heap
>>0x464f0000)
>>0x54330000)
>>0x58330000)
>>Elapsed Time = 88
Previous Topic:compiled version: fastest eclipse on the planet?
Next Topic:Xerces in a plug-in
Current Time: Mon Jul 14 21:04:48 EDT 2025
Powered by FUDForum. Page generated in 0.04227 seconds
