Home » Language IDEs » C / C++ IDE (CDT) » CDT3.1.0 The CPU is not supported by selected debugger
CDT3.1.0 The CPU is not supported by selected debugger [message #172797] Thu, 13 July 2006 06:11 Go to next message
Hi all,
I use Eclipse om Windows with GNUARM GCC tools. It works OK with Eclipse
3.1.2 and CDT 3.0.1.
After update to Eclipse 3.2.0 and CDT 3.1.0 Releases if I try to start
debugger all Debugger which I select exept "gdbserver Debugger" tell me
"The CPU is not supported by selected debugger".
Does anyone know about this?
Re: CDT3.1.0 The CPU is not supported by selected debugger [message #172815 is a reply to message #172797] Thu, 13 July 2006 08:41 Go to previous messageGo to next message
Originally posted by: email.henningsievert.de
I had the same problem running Eclipse on a 64-bit linux-machine. I had to
install the newest version of JAVA and the 64-bit-version of Eclipse. Now
the debugger works.
Re: CDT3.1.0 The CPU is not supported by selected debugger [message #172853 is a reply to message #172797] Thu, 13 July 2006 10:36 Go to previous messageGo to next message
Originally posted by: dschaefer.qnx.com
efim wrote:
> Hi all,
> Eclipse 3.1.2 and CDT 3.0.1.
> Thanks
Has there been a bug raised on this? I'm getting tired of the CDT making
such decisions for you incorrectly. We just can't keep up with all the
platforms that people are using the CDT for.
Doug
Re: CDT3.1.0 The CPU is not supported by selected debugger [message #172869 is a reply to message #172853] Thu, 13 July 2006 12:33 Go to previous message
yes I find a bug 110897 for the same message but other CDT Version. I
searched for CDT3.1.0 and not found it.
Is the handling for GDB thread info request changed (qPmodethreadid)? My
stub responce to GDB this command is not supported. The CDT 3.01 ignored
it but CDT 3.1.0 kills the debugging. Is there a possibility to tell the
CDT the application don't use threads?
Previous Topic:CDT 3.1 ctags support
Next Topic:Upcasting in Variables view does not work
Current Time: Sat Nov 15 10:03:55 EST 2025
Powered by FUDForum. Page generated in 0.04771 seconds
