Home » Eclipse Projects » Plugin Development Environment (PDE) » Classes in a jar within a plugin are not visible to other plugins
Classes in a jar within a plugin are not visible to other plugins [message #16268] Wed, 13 August 2008 12:04
Originally posted by: bruce.skingle.org
I have a plugin which is a wrapper around a jar file. The plugin
contains an Activator, a view and the jar file. Other plugins need to be
able to access classes in the jar file.
When I create a second plugin in my development workbench everything is
fine, I add the first plugin as a dependency in the manifest of the
second plugin and I can instatntiate classes from the jar.
When I create a feature and update site, install a new copy of Eclipse
and use the update site to install my first plugin, containing the jar,
the plugin appears, but when I create another plugin and try to use
classes from the first plugin, I can see the Activator and the view
(i.e. classes built as part of the plugin) but nothing contained in the
jar. The jar itself is present, and the view, which calls classes in the
jar file works fine.
The jar file is on the plugin classpath and all of the packages in the
jar are in the Exported Packages list on the runtime tab of the manifest.
Normally I would use the "Plugin from existing jar" wizard to explode
the jar file into my plugin, but in this case the jar file is a signed
JCE provider (http://www.bouncycastle.org) so I cannot so this.
Am I missing something or is this a real limitation of the runtime?
Bruce.
Previous Topic:JUnit Plugin Tests are not recognised by PDE test run
Next Topic:Classes in a jar within a plugin are not visible to other plugins
Current Time: Fri Nov 21 11:08:06 EST 2025
Powered by FUDForum. Page generated in 0.03783 seconds
