problems loading help [message #171779] |
Wed, 17 December 2003 18:11  |
Originally posted by: brendan.walker.cim.com.au
I'm having problems loading the help pages. I've checked the documentation
and the bug lists, and I've tried everything I've seen there. (This would be
checking if I have a proxy, which I don't, and looking at the log files.)
I get a blank browser screen when I launch help.
I've looked in the tomcat logs and the .metadata/.log. and there doesn't
seem to be anything unusual. Is there a way to turn logging up in 2.1.2? I
can't seem to find it. I know I can get help for the standard installation
at http://help.eclipse.org/help21/index.jsp but I want to get help for the
omodo plugin I've installed. Help wasn't working before I installed this
plugin either.
Can anyone help, I apologize if I'm repeating something that already been
covered. Using this newsgroup has been my last resort.
Brendan
Re: problems loading help [message #172129 is a reply to message #171959] |
Thu, 18 December 2003 17:14  |
Konrad, You're a champ! Thanks. That worked fine.
Brendan
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:brsjao$ifr$1@eclipse.org...
> The point is that you should not have the duplicate J2EE jars on the
> classpath. Delete jre/lib/ext/servlet.jar (not just rename it).
> Konrad
> "Brendan Walker" <brendan.walker@cim.com.au> wrote in message
> news:brrbgs$53h$1@eclipse.org...
> > Cheers for the reply. I do have the servlet.jar in that directory. I
> checked
> > to see if it matched the copy of servlet.jar within the
> > org.eclipse.tomcat_4.0.6.2 plugin directory and it is the same.Any other
> > ideas? Is there any way to turn the logging up?
> > "dorian birsan" <dorian@birsan.net> wrote in message
> > news:brqved$q74$1@eclipse.org...
> > > news:brqnpm$jkp$1@eclipse.org...
> > > > Hi,
> > documentation
> > would
> > > be
> > files.)
> doesn't
> 2.1.2?
> > I
> > installation
for
> > the
> this
> > > > plugin either.
> > been
> > > Check if you have a servlet.jar in your jre/lib/ext/ folder.
> > > -Dorian
> > > > Cheers,
> > > > Brendan
FUDForum. Page generated in 0.04003 seconds
