Home » Language IDEs » ServerTools (WTP) » JSP as a second class citizen
JSP as a second class citizen [message #171703] Tue, 20 June 2006 09:41 Go to next message
I've noticed that when working with JSPs, I don't have all of eclipse's
services available. For example, when I search for references to a method
(in the entire workspace), I don't get references in JSPs where the method
is invoked. Another example is when changing a method's name through
refactoring - the method's references in JSPs are not updated.
Is this intentional?
Re: JSP as a second class citizen [message #171734 is a reply to message #171703] Tue, 20 June 2006 17:55 Go to previous messageGo to next message
Originally posted by: dserodio.gmail.com
Zohar wrote:
I've posted questions like this before, and the answer I got was along
the lines of "scriptlets are bad, you shouldn't be using scriptlets".
HTH,
Daniel Serodio
Re: JSP as a second class citizen [message #171742 is a reply to message #171734] Wed, 21 June 2006 01:31 Go to previous messageGo to next message
So why support them at all...?
"Daniel Serodio" <dserodio@gmail.com> wrote in message
news:e79qso$rjd$1@utils.eclipse.org...
> Zohar wrote:
>> method
> HTH,
> Daniel Serodio
Re: JSP as a second class citizen [message #171750 is a reply to message #171734] Wed, 21 June 2006 01:47 Go to previous messageGo to next message
Why are they so bad and what is the alternative to using them?
> Zohar wrote:
>> method
> HTH,
> Daniel Serodio
Re: JSP as a second class citizen [message #171758 is a reply to message #171750] Wed, 21 June 2006 04:05 Go to previous messageGo to next message
Originally posted by: mikael.staldal.ingen-reklam-univits.com
>> along the lines of "scriptlets are bad, you shouldn't be using
>> scriptlets".
Scriptlets in JSP are bad because it's messy to mix HTML and Java code
in the same file, and because of the risk of including business logic
in the presentation layer.
The alternative, if you use JSP, is to use taglibs. Another alternative
is to not use JSP at all, use some other presentation layer template
technology instead, e.g. Velocity (http://jakarta.apache.org/velocity/)
or LSP (http://sourceforge.net/projects/lspx).
(This is not an Eclipse issue, it's a general Java web app design issue.)
Re: JSP as a second class citizen [message #172188 is a reply to message #171703] Fri, 23 June 2006 01:21 Go to previous message
Not at all. If you're finding that there are problems, ensure that
all of your JSP files have been saved to disk. If you still have
problems, please open a bug report against the JSP component (see
below) and include exactly which WTP build you are using. Please
try it with at least 1.0.2 or higher.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols&component=jst.jsp
- Nitin
Previous Topic:Validating XML files with DTD in Catalog
Next Topic:Configuration of html formatting style
Current Time: Sun Aug 31 22:38:45 EDT 2025
Powered by FUDForum. Page generated in 0.04543 seconds
