Home » Modeling » GMF (Graphical Modeling Framework) » graphical read-only view of non-child object in a compartment
graphical read-only view of non-child object in a compartment [message #171542] Tue, 05 February 2008 12:05 Go to next message
--------------090103080904080302000500
Hello all,
I'd like to use GMF in a specific way but I'm not sure it is possible.
I create to model from the same metamodel but with different root class.
In the metamodel I have "definition" metaclasses that contain "variable"
metaclasses. I edit a first model from the metamodel and I obtain,
for instance a class "def1:definition" that contains "var1:variable" and
"var2:variable".
In the metamodel, there is a "ConcreteThing" metaclasse that refers (but
by no way contains) a specific "definition". I edit a second model from
the metamodel. I load the first model so that I can have access to the
definition (in my case to "def1:definition"). I create
"AConcreteThing:concreteThing" that refers to "def1"
Here is my question:
Can I visualize the object "var1:variable" and "var2:variable" in a
compartment of "AConcreteThing:concreteThing". I just need to see these
object as read only entity but i need to be able to 'grab' them in order
to create an association with other objects created in the second model.
Is it possible ?
thanks in advance
julien
Content-Type: image/jpeg;
name="pbes_GMF.jpg"
Content-Disposition: inline;
filename="pbes_GMF.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQH/wgAR
CASsA2sDASIAAhEBAxEB/8QAHgABAQADAQEBAQEBAAAAAAAAAAgHCQoGBQQC AwH/xAAUAQEA
AAAAAAAAAAAAAAAAAAAA/9oADAMBAAIQAxAAAAHf4AAAAAAAAAAAAAAAAAAA AAAAAAACQPfq
AJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/5Yux3kCOv0AAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QAAAAAAAAAAAAAAAAAAAAAAAAAAA5Auv3kCOv0AAAAAAAAAAAAAAAA AAAAAAAAAAE/
0BP9AAAAAAAAAAAAAAAAAAAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAA AAAAAAAAT/QE
/wBAAAAAAAAAAAAAAAAAAAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAA AAAAAAAT/QE/
0AAAAAAAADB5nBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBL9QAAA AAAADkC6/eQI
6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT/QE/0AAAAAAAAJ/oCfygAAAAAAAAAA T/QE/wBAAAAA
AAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT/QE/wBAAAAAAAACf6An 8oAAAHx5Xk+0
yLKh0U7Bi8o2+BU5B+97UptrAAAJ/oCf6AAAAAAAAHIF1+8gR1+gAAAAAAAA AAAAAAAAAAAA
AAAAAAn+gJ/oAAAAAAAAT/QE/lAAAAjGftp40s5L2tiL/v1iNd+xAAAAJ/oC f6AAAAAAAAHI
F1+8gR1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAASfWE/hQAn9Q An9QAn9QAn9Q
An9QAn9QAn9QAn9QAn9QAiC35/oAAAAAAAAcgXX7yBHX6AAAAAAAAAAAAAAA AAAAAAAAAAAC
f6An+gAAAAAAABP9AT+UAAAAAAAAAACf6An+gAAAAAAAByBdfvIEdfoAAAAA AAAAAAAAAAAA
AAAAAAAAAJ/oCf6AAAAAAAAE/wBAT+UAAAAAAAAAACf6An+gAAAAAAAByBdf vIEdfoAAAAAA
AAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAE/0BP5QAAAAAAAAAAJ/oCf6AAA AAAAAHIF1+8g
R1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAAT/QE/lAAAAAAAAAA An+gJ/oAAAAA
AAAcgXX7yBHX6AAAAAAAAAAAAAAAAAAAAAAAAAACf6An+gAAAAAAABP9AS+V An8UAn8UAn8U
An8UAn8UAl/0BQCfxQCfxQCfxQCfwoCMLPAAAAAAAHIF1+8gR1+gAAAAAAAA AAAAAAAAAAAA
AAAAAAn+gJ/oAAAAAAAAAAAAAaId72HzmC63dcGx8AAAAAAAAAAAAcgXX7yB HX6AAAAAAAAA
AAAAAAAAAAAAAAAAACf6An+gAAAAAAAAAAAAAT+fPpDD+QD0AAAAAAAAAAAA HIF1+8gR1+gA
AAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAAAAAAE/igAYPzgPn/Qn+gA AAAAAAAAAABy
BdfvIEdfoAAAAAAAAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAAAABP4oAAAE /wBAAn+gAAAA
AAAAAAByBdfvIEdfoAAAAAAAAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAAAH z2Hz59AAAAAB
8/D+cPPnoGH8wAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT /QE/0AAAAAAA
AAPnsPjOAAAAAAAeP8/lDH5kBj/IAAAAAAAAA5Auv3kCOv0AAAAAAAAAAAAA AAAAAAAAAAAA
AE/0BP8AQAAAAAAAA+ew+M4AAAAAAAABi/0HsMPmYHn/AEAAAAAAAA5Auv3k COv0AAAAAAAA
AAAAAAAAAAAAAAAAAAE/0BP9AAAAAAAD5+P+aE6Ps4akNt4AAAAAAAAABg/M GtDUgdVyf6AA
AAAAAHIF1+8gR1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAcSXbb pBKP2X/P+gAA
AAAAAAAAQhyo9zujE3ffQAAAAAAByBdfvIEdfoAAAAAAAAAAAAAAAAAAAAAA AAAAJ/oCf6AA
EQW/P4UAJ/UAJ/UAJ/UAJ/8An0gJ/UAJ/UAJ/UAJ/UAJ/UAJfqCf6AJv+goA n9QAn9QAn9QA
n9QAn/59ICf1ACf1ACf1ACf1ACf8QW/P5QAAHIF1+8gR1+gAAAAAAAAAAAAA AAAAAAAAAAAA
An+gJ/oAAT/QE/lAAAAIh/0LaaxPsGyNp+tEzTkfTFudAAAJ/oCf6AJ/oCf6 AAABNhSbD8dm
yRqk9IbN5jn79JX+VdMW50AAT/QE/lAAAcgXX7yBHX6AAAAAAAAAAAAAAAAA AAAAAAAAACf6
An+gABP9AT+UAAADVH6atMmGsHCtufyYQ25zvRBqU21zvRAAABP9AT/QBP8A QE/0AAAPkfXH
ODs9yVnAiTWVtJ/soOINkOuUuLP0D3wAAJ/oCfygAAOQLr95Ajr9AAAAAAAA AAAAAAAAAAAA
AAAAAABP9AT/AEAAJ/oCEC70/igE/igE/igE/igE/igE/igE/igE/igE/igE /hQEn1gT/QEv
+gKAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAn9hAu8ADkC6/eQI6/QAA AAAAAAAAAAAA
AAAAAAAAAAAAT/QE/wBAACf6An8oAAAAAAAAAAE/0BP9AE/0BP8AQAAAAAAA AAAn+gJ/KAAA
5Auv3kCOv0AAAAAAAAAAAAAAAAAAAAAAAAAAE/0BP9AACf6An8oAAAAAAAAA AE/0BP8AQBP9
AT/QAAAAAAAAAAn+gJ/KAAA5Auv3kCOv0AAAAAAAAAAAAAAAAAAAAAAAAAAE /wBAT/QAAn+g
J/KAAAAAAAAAABP9AT/QBP8AQE/0AAAAAAAAAAJ/oCfygAAOQLr95Ajr9AAA AAAAAAAAAAAA
AAAAAAAAAAABP9AT/QAAn+gJ/KAAAAAAAAAABP8AQE/0AT/QE/0AAAAAAAAA AJ/oCfygAAOQ
Lr95Ajr9AAAAAAAAAAAAAAAAAAAAAAAAAABP9AT/AEAAJ/oCfygAAAAAAAAA AT/QE/0AT/QE
/wBAAAAAAAAAACf6An8oAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT /QE/0AAJPrAT
+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAYPzgGH/P0AJ/UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/8fWAAAcgXX7yBHX6AAAAAAAAAAAAAAAAAAAAAAAAAACf6 An+gAAAAAAAA
AAAAAAAAAAAAAAAAYfMIZPzB6An9QAk/EFH0AAAAAAAAAAAAAAAAAAAAAAAA AAAAT/QE/wBA
AAAAAAAAAAAAAAAAAAAAAAACf6An8oACf/YegPYAAAAAAAAAAAAAAAAAAAAA AAAAAAAn+gJ/
oAAAAAAAAAAAAAAAAAAAAAAAAT/QE/lAef8AQT+egzAAAAAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QAAAAAAAAAAAAAAAAAAAAAAAB4/wA/4/IB4/MHj8gAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAE/0BL/oCgE/igE/igE/igE/igE/igE/igE/igE/igE/igE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/igE/igE/igE/j5/oMIW+AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAEn+wKAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+ KAT+KAT+KAT+
KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+ KAT+KAT+KAT+
KAT+KAYfzAAT/QE/0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAT/
AEBP9AAE/wBAT/QAAJAK/T+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+K AT+KAT+KAT+K
AT+KAT+KAT+KAT+KAT+KAT+KAQhd4AAAAAAAAAAAAAAAAAAAAAAAAAAAAABP 9AT/AEAAT/QE
/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBAT/QAAAAAAAAAAAAAAAAAAAAA AAAAAAAAABP9
AT/QABP9AT/QAAn+gJ/KAAAAa989FHIkwAbWmB88AAAABMtNAgcvhpOysbWz DpmJ5X1QAAAB
P9AT/QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABP8AQE/0AAT/AEBP9AACf6An 8oAAAwwa/vne
H8aZx25aZqdKB1r5E8KZNlvLvqD9HjPV4qK518bGMFH8f5SRmA8pRPlZrK32 56Nd5RqUB+X5
mxzTaZi9dhbbWazPtxdsKM2W/AF/gAE/0BP9AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAE/wBA
T/QABP8AQE/0AAJ/oCfygAAPNelH5PP+rHz8X5gDHORh8r43rh5H8vuB8H5/ rh5T/nrB4X9/
qx5P1geReuH4fG5AHhPW/uESwhvJE9UKAAE/0BP9AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QABP8AQE/0AAJ/oCQCv0/igE/igE/igE/igE/igE/igE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/igE/igE/hQEIXeAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAT/QE/0AAT
/QE/0AAJ/oCfygAAAAAAAAAAAAAAAAAAAT/QE/0AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAT/
AEBP9AAE/wBAT/QAAn+gJ/KAAAAAAAAAAAAAAAAAAABP9AT/AEAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAT/QE/0AAT/QE/0AAJ/oCfygAAAAAAAAAAAAAAAAAAAT/QE/0AAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAT/QE/wBAAE/0BP8AQAAn+gJ/KAAAAPHnsE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/0AAAAAT/QE/0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAT/AEBP9AAE
/wBAT/QAAn+gJ/KAAAAn+gJ/KAAAAAAAAAABP9AT/QAAAABP9AT/AEAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAT/QE/0AAT/QE/0AAJ/oCfygAAAJ/oCfygAAAEJZYKVa18Zm 3Rp6q0zFnbni
6HQAACf6An/Xgbj3NDd5tvAABP8AQE/0AAAAAAAAAAAACXyoE/igE/igE/ig E/igE/igE/ig
E/igE/igE/igE/igGD84AAAAAAAE/wBAT/QABP8AQE/0AAJ/oCfygAAAJ/oC fygAAAeB5+ek
TCBIU97dMGGk7pejayzUptrxJlsAAAn/ACBj+gDmBs/deJ/UAPH+wxf48oBP 4UBN9IAAAAAA
AAAAACf6An8oAAAAAAAAAAE/0BP9AAAAAAAAE/0BP9AAE/0BP9AACf6An8oA AACf6A8eewT+
KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+FAT/AEAAAAARBl9QBP8A9DOH zz6CfxQCf8gG
QAAAAAAAAJ/oCfzO0UZMhY2Q4d027ZCxpg1LbQj7nj9fuxUhnbfqo+ObLM6a H6JLukLBeTz1
/wAHbdqMPJbDtZnpCtbs1Kbayf6An+gAAAAAAACf6An+gACf6An+gABP9AT+ UAAAAAAAAAAA
AAAAAAAACf6An+gAABj/ACAJ/UAJ/wAwegw+ZgT+KAT/AEAAAAAJ/oCfzGmH tlg0Kbi8wDVN
5/byNXeS75Gu/wCRsnGoGs7LGu/29sjVdkHYgNM/qdt41Kba9cWx0n+gJ/oA AAAAAAAn+gJ/
oAAn+gJ/oAAT/QE/lAAAAAm/6CgCf1ACf1ACf1ACf1ACf1ACf1ACf1ACf1AC f1ACf/QZgn8o
AAAAE/0BP9AAAAAAACf6AE/qAGL8oePxeUAn8UA1wYfNv8QW/P4UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/UAJPrCf6AAAAAAAAJ/oCf6AAJ/oCf6AAE/wBAT+UAAAAC f6An+gAAAeSP
WvJf2eqeC/3PbIDwGbeGLMpgACf6An8oAAAAE/0BP9AAAAAAAAAAAGkHWB1+ jQDtupCfygAA
AAAAAAAAT/QE/wBAAAAAAAAE/wBAT/QABP8AQE/0AAJ/oCfygAAAAT/QE/0A AANUe1yCjEXm
M6y2TVmD+6FLSg3+f0GxLLuMcnAACf6An8oAAAAE/wBAT/QAAAAAAAAAAAAn +gJ/KAAAAAAA
AAABP9AT/QAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAABP8AQEge/KAT+KAT +KAT+KAT+KAT
+KAT+KAT+KAT+KAT+KAn988pAAAAE/0BP9AAAAAAAAAAAACf6An8oAAAAAAA AAAE/wBAT/QA
AAAAAABP9AT/AEAAT/QE/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBAT/QA AAAAAAAAAAAn
+gJ/KAAAAAAAAAABP9AT/QAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAA AAAAAAAAAAAB
P9AT/QAAAAAAAAAAAAn+gIwLPT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+K AT+FAS/UAAAA
AAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAAAAAAAAAAAAABP9AT/QAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAABP9AT/AEAAT/QE/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBA T/QAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAAAAAAAAAA AAABP9AT/QAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAABP8AQE/0AAT/AEBP9AADB+cBP6gBP6gB P6gBP6gBP6gB
P6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBL9QA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAABP9AT/QABP9AT/QAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAABP8AQE/0AAT/AEBP9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAE/0BP9AAE/0BP9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAE/0BP8AQABP9AT/AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAef
9BL/AKAoBP4oBP4oBP4oDz83+QPf1B5/0ABP9AT/AEAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAMP5gn8zB6AABj8yBg/5+cDH+UAAAn+gJ/oAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAA8/j/z9AABi/wAeMgZAAAAAE/0BP9AAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAwefPoD5+LzKGD/oZwPH+wAAAAACf6A5 UfYHT85gR0/O
YEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85g R0/OYEdPzmBH
T85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdP zmBHT85gR0/O
T85gR0/OYEdPzmBHT9L+iHdeZPzB6AAAAAAAAf/EADIQAAAEAwcEAwABBAID AAAAAAAFBgcE
FzcIFRYgNkBQAxAYMAECYCYUJCU4EyMnSJD/2gAIAQEAAQUC5aLSaWVDpyna wSnawSnawSna
wSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSna wSnawSnawSna
wSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawWjy krI3n5Yuqny1
qOuvLF1U+WtR115Yuqny1qOuvLF1U+WtR115Yuqny1qOuvLF1U+WtR115Yuq ny1qOuvLF1U+
WtR115YuqnsFGoz+AP7xdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XT F4umLxdMXi6Y
vF0xeLpi8XTF4umLxdMXi6YMVUviP67C1HXXli6qewMap7Ry9O7C1HXXli6q ewMap7Ry9O7C
1HXXli6qewMap5o8wgSqCJn8aA/OLGv3+nTaT7Wh2X+po76/KUO3FkP7o3rp F+H4V3UKs7l6
d2FqOuvLF1U9gY1TzWovt1zkzP2kb82R5QfmBJZM+ilRH0SjddFTwtl+zP8A X4+GQtkU5zuX
p3YWo668sXVT2BjVPM9rW9dzk59etabVRcgGAUEew3QNbVvQKfoglEVsmxqa O0e1dpZCqpwE
VncvTuwtR115YuqnsDGqe0cvTuwtR115YuqnsFZ1j/oOTeLpi8XTF4umLxdM Xi6YvF0xeLpi
8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTC2jV91SzYWo 668sXVT2BjVP
aOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVP aOXp3YWo668s
XVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668s XVT2BjVPaOXp
3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2CqMfqRr6 ZadEy06Jlp0T
LTomWnRMtOiZadEy06Jlp0TLToK3hRB5AzLTomWnRMtOiZadEy06Jlp0TLTo mWnRMtOhWq2A
UsBsLUddeWLqp7q166SyJRZudJZIpZbq1HXXli6qe6XSFTjipyzm1CcQCf3V qOuvLF1U921k
XCxab3VqOuvLF1U91r8KErjulHFZpAnUDubUddeWLqp7nX/c9hIohioSLhY+ F3FqOuvLF1U9
xr/KbfwTc2o668sXVT2+v8+gNxajrryxdVPba/8ASU/wTb2o668sXVT2kXFw sBC6/wDVFwkL
HwpFFxRDFbW1HXXli6qezi4uFgIWEhIpVxXrNCuBOoFPGkd0o7aWo668sXVT 2UXFwsBCwkJF
KuK9p0Swp5CkB1FRUVs7UddeWLqp7GLi4WAhYSEilXFe89Ir0BEe3ps7Udde WLqp7CLi4WAh
YSEilXFbE/JYqKiiU6hTyF2NqOuvLF1U/fFxcLAQsJCRSritmoSuO6UcVmkC dQOwtR115Yuq
n7ouLhYCFhISKVcVtT2EiiGKhIuFj4X32o668sXVT9q1jT8sSJta6ck56lnZ 8XCd8/2tox3V
80IKbXTkk3UaxQqNWN97rUddeWLqp+53kh00I5dlNB9RHNdtbSaQ6avZ9AI6 OcBZQkJCwEL7
rUddeWLqp+61M1Ecs1xCQkLAQu2s6M71Eg8HvtR115Yuqnkb1Elh4gZaJ0S0 TolonRLROiWi
dEtE6JaJ0S0TolonR1mpSUR1JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRL ROhKl31I18HA
6HzHx8tE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonR0WpSUP1JaJ0S0Tol onRLROiWidEt
E6JaJ0S0TolonQ4SJLCNA5bUddeWLqp5GnpZtC6qYWWoto7FLMtqOuvLF1U8 jT0s9hQrU8fG
+cuqmFlqL2K95WxQcak1ukl1AZnYpZltR115YuqnkaelmZsXJPlMr49yD7rv cYO45qrWKHd5
cfLj9N+3HNVeoU+5ysS1lEtiiZTZy6qYWWoszuKVTI1v04sS09QyOew5iGhh F5acOif6v9FH
DCt057nOKZMsznUSsGn4IoKLWeZ2KWZbUddeWLqp5GnpZmcLqdFt7QFnSD6y g+USq3YfKJLS
jqEdrWz70un8u6LOdRs5dVMLLUWaPgYUzgegpjdONO5Sq+LPzPfKJdGMJET/ AKbNH0+n0Gp+
p84FoEwb9s0i2ZZmdilmW1HXXli6qeRp6WZnKbVPOonU2QFyVIDezchTA+ir NDbfaJRzZkSI
UIRbZkSFOs5dVMLLUWeJZZGxToKxJkK3ISizQgi3qw9mpCwRWWpmCK0l0LH6 Ahemh7PKXQSl
zOxSzLajrryxdVPI09LNoXVTCy1FtHYpZltR115YuqnkbJviGNbaWidEtE6J aJ0S0TolonRL
ROiWidEtE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6EmRw RA5IcYthzgzl
onRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6 JaJ0S0TolonR
LROhzW+IYJtstqOuvLF1U8jT0s2hdVMLLUW0dilmW1HXXli6qeRp6WbQuqmF lqLaOxSzLajr
ryxdVPI09LNoXVTCy1FtHYpZltR115Yuqnkaelm0LqphZai2jsUsy2o668sX VTyNPSzaF1Uw
stRbR2KWZbUddeWLqp5GnpZtC6qYWWoto7FLMtqOuvLF1U8jT0s2hdVMLLUW 0dilmW1HXXli
6qeRp6WbQuqmFlqLaOxSzLajrryxdVPI09LNoXVTCy1FtHYpZltR115Yuqnk aelm0LqphZai
2jsUsy2o668sXVTyJ5JuSmiC7nTF3OmLudMXc6Yu50xdzpi7nTF3OmLudMXc 6Yu50xdzpi7n
TF3OmLudMXc6Yu50xdzpi7nTF3OmE4nD+APwrU8aHn2u50xdzpi7nTF3OmLu dMXc6Yu50xdz
pi7nTF3OmLudMXc6Yu50xdzpi7nTF3OmLudMXc6Yu50xdzphQpNyVKQZbUdd eWLqp8tajrry
xdVPkUX11thiabfdITRQnWGIV3HA96CwLSyGs2Nwa9Pli6qfIOAaRxKhykrg SMr7p/8Alhpy
5dVPkF9/d5FB/LDTmC6qfIGv+QcfspjqKLumREsKnyzmC6qfIEX964INDSBJ YFNlcd1OtzJd
VPkG7/uC4dD+aHfNF1U+PUJ1CpogRBLFJpFqiLijWKhISFgIXmi6qfHud/2J FSntwFabIrhg
ebLqp8esYuF+FUQwkUcHPOR/UUBGvsZKIYyUQxkohjJRDGSiGMlEMZKIYyUQ xkohjJRDGSiG
MlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxko hjJRDGSiGMlE
MZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJ RDGSiHUI1MvV
9/8AC1PKxyVKQXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMX i6YvF0xeLpi8
XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6Y vF0xeLpi8XTF
4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0 xeLpi8XTF4um
LxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeL pi8XTF4umLxd
MXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8 XTF4umLxdMXi
6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLphJKE0 PPt3aeln6lG6
i7tPSz9SjdRd2npZ+pRuou7T0syRaTSyodOU7WCU7WCU7WCU7WCU7WCU7WCU 7WCU7WCU7WCU
7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU 7WCU7WCU7WCU
7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WBzWybaAbbnUbqLu09L MhdVPhnYpZzq
N1F3aelmQuqnwzsUs51G6i7tPSzIXVT4Z2KWc6jdRd2npZkLqp5n8d09bOFa Vd/DkIB03j6S
Dj4xdWpCSGbdwiRzkr6Slzi02dDsrjO0d0FElHctKLM2XrqvG2jXBfxyxLUk R9Y1iCT0uxSz
nUbqLu09LMhdVPMlvr8OVaUYL7/KCcpnfp9VDaABamkY1pOhCZ0X5LWyVq4S bpMVCOc7CaZ0
8W6feBPxS+tDnzbQTrpBbs3Cu876cNTpYu85RcarVnXIQLffeHtQm52sXfcs uNVqzrkCznUa
2bSdXN86v3RiicVUqCyO+SoUxTZ0WiBdTrJCPfRZRDLKtvHYb1FWcDY0PGYy uxSznUbqLu09
LMhdVPK4is6KGRDO2b0Gpm+cJCpqzyvVXFRrCvKbWm2aLShoEktFS3jCO4lE OjEUZfDv2jLG
9OUr/uGxyxIWSikW8MS4rlWN6cxiQatOPYmCWz/GOoQnhQRWvoxINWnHsTBL Z/jHUFnOo1s2
k7lU5/8ARS0H/rA5VOekWmkCxbkP43py21lyhWV2KWc6jdRd2npZkLqp5TYm Jz+C6HQ6ML0T
ghI1FCfMJC/aGhG9QJfGA5R6SUfUgoGCLYYmICJOw/SICLoHB0mU2pPoWlZY TQhMQESdhzci
JFBDFBCRp6HjkumTQyNyIkUEMUEJGnocFxARE8QckBEo4SJhoeNh8Jpa4jBL pk2K4mGh42Hd
LFiEQ6kdlrzhKNQkeuhG6yuxSznUbqLu09LMhdVPhnYpZzqN1F3aelmQuqnw zsUs51G6i7tP
SzJFqUuTrpzLTomWnRMtOiZadEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTo mWnRMtOiZadE
y06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTomWn RMtOiZadEy06
Jlp0TLTomWnQ5rgkMa23Oo3UXdp6WZC6qfDOxSznUbqLu09LMhdVPhnYpZzq N1F3aelmQuqn
wzsUs51G6i7tPSzIXVT4Z2KWc6jdRd2npZkLqp8M7FLOdRuou7T0syF1U+Gd ilnOo3UXdp6W
ZC6qfDOxSznUbqLu09LMhdVPOdKEgTULNhrBNhrBNhrBNhrBNhrBNhrBNhrB NhrBNhrBNhrB
NhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrPU7FLOdRuou7T0syF 1U86y1FtHYpZ
6XYpZzqN1F3aelmQuqnnWWoto7FLPS7FLOdRuou7T0syF1U86y1F7HDcRPtm Q53YpZ6XYpZz
qN1F3aelmQuqnnWWos1oNTLREoteOBBJtrvlYO0nGQUkFadSaacR7VV9WDbn rO+eHlphpIFJ
Eud2KWLy1Crm3OTS20vurHWdnxcJ3z/M7FLNwXKpfHn1vF0xeLpi8XTF4umL xdMXi6YvF0xe
Lpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLphOKM/jz/AN6N 1F3aelmQuqnn
WWosyqT8Iq00mzUwcQltGrtRo+CdJCt0nW+WXW6XUscfHx8fX4tkU5zuxSxS pVOLIrd6yao0
iLKradT6Np/xuaVDH39ICVQkClhe7sUs3Daad2hdVP3o3UXdp6WZC6qedZai zlLcIoiVakTC
fV5UmmNadI9f4s+tB9SULJCpVwC7O7FLMp0ikioorBhoVi8XHKhMlOQQc2Lh Y9otw2mndoXV
T96N1F3aelmQuqnnWWoto7FLPS7CARv0QOHl3AjEqyLBCOQiYmK2raad6/X6 MN0Yi0iyULGG
C8SBakjh/GiIfgmOilQlh1aAZ1PGblusliRq7OTl9BwUFZrcRFN616NcFGOB CKp7WsRJkQKI
iVRZEvK2cF03Qc5QKs56dklA9XooRQrNqnPK1ERpS1MjXebdwIpRFjfdV+gX VT96N1F3aelm
QuqnnOk8QKWFlO1glO1glO1glO1glO1glO1glO1glO1glO1glO1glO1glO1g lO1glO1glO1g
lO1glO1glO1glO1glO1glO1nqdilnaLhIWPhZbkUGP6NxyYY3ji8ESqTil2T aadd/pJGIbwk
U6RiEkjOp9/vY1ZxvEl0WgbY/M0zZRZZtUWUNaXQfSRaisz/AF+PhkLHqPIY khher0EFaDZF
XEpAimG6RpBOu0CGT6te8n6UKQWvg/H2+se88EkCRXWxLTSfKUXErT/bwF1U /ejdRd2npZkL
qp8M7FLMx6k0sqBgXrFw/qHNKxMUrgQVmxWeQPtbTTr7ttHum38Aa2lTqCI2 ld0lZ9vSuOI0
CzTOnMI0aZh7SzZkyOZNSwaWs9E7gJVG2aUKqm/RRe26g61oRMJ5/mZhmqSz hl8UzqFVSVcJ
4Gi+XE+nTUtrGC6DXNAfFKoPW3eGFtAfKEdx3FktP9vAXVT96N1F3aelmQuq nwzsUs9RogEa
cR2FlYWi/V2ViaKE6PrbTTuyJWqXpi8ILqp+9G6i7tPSzIXVT9HQcCPj/nGS iGMlEMZKIYyU
QxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGM lEE8rfseGnod
ilnulkk4UXU4JMMYHpaCVaJhQRWZEqU6LyzGSiGMlEMZKIYyUQxkohjJRDGS iGMlEMZKIYyU
QxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEEmZRpq5PvRuou7T0syF1U /Q2mndoXVT9D
sUs2J0niBSwsvIGDH/lMvEwOjBB8nkg021TQ2sk4ruzaad2hdVP3o3UXdp6W ZC6qfobTTu0L
qp+h2KWbW1I1LkuQqfFx9Q0JJaoakNT1upEJLaF1U/ejdRd2npZkLqp+htNO 5oM/IjGPNT8i
IgbHhIQQ5KqkupB8qVOfUwdd4/sniRSfe023hGiFXArlJ5i6qfodilm4bTTu 0Lqp+9G6i7tP
SzIXVT9DaadzH/0l7abUPSmNaTc0lZ6DdIzj29hXqNUXDuBat6KCbhLlq2dA 5eKCQSRhUGjs
xdVP0OxSzcNpp3aF1U/ejdRd2npZkLqp+htNO5rRaRNFO39nxNnkGSdKFVzR vG53XdlUqdFF
R/17Tlp77qoyjy19VMTwKNP4xUJrMXVT9DsUs3Daad2hdVP3o3UXdp6WZC6q fobTTu0Lqp+h
2KWbhtNO7Quqn70bqLu09LMhdVP0JwxVCXhMZKIYyUQxkohjJRDGSiGMlEMZ KIYyUQxkohjJ
RDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQTHwdx609DsUs3Daad2hd VP3o3UXdp6WZ
C6qfDOxSzcNpp3aF1U/ejdRd2npZkLqp8M7FLNw2mndoXVT96N1F3aelmQuq nwzsUs3Daad2
hdVP3o3UXdp6WZC6qfDOxSzcJJWwCagJlp0TLTomWnRMtOiZadEy06Jlp0TL TomWnRMtOiZa
dEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLToSpj9Txfe9G6i7tPSzIXVT4Z2 KWc6jdRd2npZ
kLqp8M7FLOdRuou7T0syF1U+GdilnOo3UXdp6WZC6qfDOxSznUbqLu09LMhd VPhnYpZzqN1F
3aelmQuqnwzsUs51G6i7tPSzIbIzrR5/g1RDBqiGDVEMGqIYNUQwaohg1RDB qiGDVEMGqIYN
UQwaohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiG DVEMGqIYNUQw
aohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiBs3JmeFfOo3UXdp6WfqUbqLu09L P1KN1F3aeln6
lG6i7tPSz9SjdRd2npZ+pRuou7T0s/Uo3UXdp6WfqUbqLu09LPz8QbFcJHeg 0NisjgW5Nis8
M+7T0s/PlhSVrg0wHdgvFxyoYyUQxUroof1DpxYuZx4oYHMYgHSRbghhStsS 2OjispKyOB7t
PSz88ujSOLU4UlcCRleaLUxgaRRKmemXRWVp6Wfnup/IHBynqlKyAXOeq0Qk JCwELmaeln50
2NIEjK0KVxxanMmKDRSgiTcCQ+lp6WfnVf8A5g77nSsLyiKwtHKf1tPSz86h /wDMdYRcXCwE
LeyjVYJSIsT8L62npZ+ccCLivgghISFgIU0WMDDx0Ik+oZRXtaeln5yINivq qz/kUawBWVwJ
LA+5PWunJTRB5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0x5qumPN
V0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0x5qumPN
V0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0w0KTL/l
I7D/xAAUEQEAAAAAAAAAAAAAAAAAAADA/9oACAEDAQE/AQDv/8QAFBEBAAAA AAAAAAAAAAAA
AAAAwP/aAAgBAgEBPwEA7//EAFwQAAAFAgEHCQUFBAcFBQERAAIDBAUGAQcA EhMUdpe21xEg
NTY3QFCV1hUhlrfVFiIjMIYQJDEzCCUyNEFgtUJDZnfmFyZFUWGTGEZSU1ZX YmNldIOHkKax
tPD/2gAIAQEABj8C8WlH2ljUfkWgwC3ehe3WZudtD0mRXS0jRdPTqNH0jRyM 9msnO5krLys2
Dk7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAf Bsd+nY7NIB8G
x36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7N IB8Gx36djs0g
HwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36d js0gHwbHfp2O
zSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbH fp2OzSAfBsd+
nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAf Bsd+nY7NIB8G
nYmTWytreztiX7PaM3NaNO3oU+eirGoOzCRIWUnKzqg008zNlhyzjDDBcoxi rXxaZagW03iu
x4vOf0zufH/F5lqBbTeK7Hi85/TO58f8XmWoFtN4rseLzn9M7nx/xeZagW03 iux4vOf0zufH
/F5lqBbTeK7Hi85/TO58f8XmWoFtN4rseLzn9M7nx/xeZagW03iux4vOf0zu fH/F5lqBbTeK
7Hi85/TO58f8XmWoFtN4rsdxYo5HGJnd1ruzyN6NNepGtjyVIljy2MIRlljQ xiTGqlCo2TEC
CERCUsotKbWpoxDADHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1 NgG0uRcJ8dTY
BtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8d TYBtLkXCfHU2
AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfH U2AbS5Fwnx1N
gG0uRcJ8N6t6iEQLbFUgjDEpOa5+9OC5P9ppG1RslUQiV23ak6rRVDqUoMJM cUmWSWZQJtB5
NK9wnP6Z3Pj/AIvMtQLabxXY7jDdQLl7xWn7q3a/2n+acN7jOf0zufH/ABeZ agW03iux3GG6
gXL3itP3Vu1/tP8ANOG9xnP6Z3Pj/i8y1AtpvFdjuMN1AuXvFafnqXJzWJm9 vRFCPVrVp5aZ
KmJB/aNPPOEEssFP8RDFSmCmFrnDac5nnUTpyj0zmgIUHiFkFkpl7ghSt6g0 0fIAkBKoYjh1
CAqgxCDSroYYMJZZczeRjGMVAgAALQwiEMYhclAhDSlaiFWvJSnvrj2PWftG l53M5yhLkJsy
+XJ6bChqzZvl/wB9p+Z5Pfl8nvw+PpjzRuUujS5tsTXpiVS2imSLWJzWMICD EJCkBVDjElTi
lp9SkIMigjVIKCBlOytpcVrhOlYkR9wxLRupoizxOMi+z2SatKAiNziDSRmG IDlI6j/vxlDM
0GiVmjkPuPA0h8gRpVUwe29wjJijRzDTgNrQpTDr/f8ARxHiM08BpyBMeVog ijThF89u1/tP
804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+fZu3hik5KxzmbhTvYiR1LEaS kWMSMkqov9rp
s88osfKCqohObyZZIKhVxKkYY0Df7PNToDUrelIUNR4Sa0TuKVWEuigCtOZk niUVNqYfWg6K
hHBNNCN1TIDDiftLdccdWDT8ue0A9gROSkoPJWleRVRrCkNBy0ocSeYQL7ho qVpDP/cw3bEy
URURVAK2pelDrm83VcJbntK9p1F+P7RoZpVFP41DKD9+LlNEraX5pNYmK4ze zJpK2q21x9if
Zca9EbQhcUWZUkBy5WmJMLyiC8wJMSPJT5IYLWlKUqJM8cteT315JG88nL/5 8mIr/wAyWP8A
0KT/AJDdr/af5pw3uM5/TO58f8XmWoFtN4rsdxhuoFy94rT89CW0OAGeVxty Le4w6GZYSilp
XJlJjzCgmGkkqMgkyigoswwhSmTHZBgADKMrDnqNRWJEriKtrzPk7slWnVbz A5lapZ2VG4KD
iXRSny8yI4olOA4zKBRD9wwh/txNklI0/KpWqkDKbVU3uYUigpC1FoVZg2pY sIqSeIhaiUl5
3SQJzTRhBQWZrUMXrDYgoci0/s4FwRyFHotQ0BmQuprTVXpxizJ/HqP2cEoR /wB8TZUPKnrJ
ISe9OU0ljlDZUiG4ujkcec5Pby1LiiUpCt3U/u6Is88lEk0k8koBIKHn5kQz q0iUbkaL2c9N
hDkBcj0hIrzIlD25KyqaQhPUpTMpOoKM/CPHQOVki5BhEGkfaYi1+1nBFN2p 3Up9NbkGbbkz
S+pjlGdc1aMkeQcsTAzRZgjxZzKCXUIBiDz27X+0/wA04b3Gc/pnc+P+LzLU C2m8V2O4w3UC
5e8Vp+6t2v8Aaf5pw3uM5/TO58f8XmWoFtN4rsdxhI442s7qtrCLkBNTvT4t YEoEvt61lRnF
rEMekppigJtCABTCQlFjLMNNqrAIkBJ/U2AbS5Fwnx1NgG0uRcJ8dTYBtLkX CfHU2AbS5Fwn
x1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5F wnx1NgG0uRcJ
8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uR cJ8dTYBtLkXC
fHU2AbS5Fwnx1NgG0uRcJ8M5b1Gog3tgp/azSVbXOHp4XFclzYjUnMNyu3rG nUZaihRZmcdE
uaJGYeHPDLCnN7hOf0zufH/F5lqBbTeK7HcYbqBcveK0/dW7X+0/zThvcZz+ mdz4/wCLzLUC
2m8V2O4w3UC5e8Vp+6t2v9p/mnDe4zn9M7nx/wAXmWoFtN4rsdxhuoFy94rT 91btf7T/ADTh
vcZz+mdz4/4vMtQLabxXY7jDdQLl7xWn7q3a/wBp/mnDe4zn9M7nx/xeZagW 03iux3GG6gXL
3itP3Vu1/tP804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+6t2v9p/mnDe4z n9M7nx/xeZag
W03iux3GG6gXL3itP3Vu1/tP804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+ 6t2v9p/mnDe4
zn9M7nx/xeZagW03iux3GG6gXL3itP3Vu1/tP804b3Gc/pnc+P8Ai8y1Atpv FdjuMN1AuXvF
afurdr/af5pw3uM5/TO58f8AF5lqBbTeK7HcYg9K2+QKmwuIT9rOUsUYkcm0 dc4PVt1aIhUT
G2p1UJdKTtTiYSYoKLJHohoaGZdKBr0dP9k90/RuOjp/snun6Nx0dP8AZPdP 0bjo6f7J7p+j
cdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7 p+jcEOjLWXvD
YqzmjOLXbO5TghUZk4xOdmFaSJGpzc0oKNIMzZgsg4swsXIMAqU6On+ye6fo 3HR0/wBk90/R
uOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k9 0/RuOjp/snun
6Nw0tDQ0zc1abN7bq6UV23uE1JS0rVcKMOripUuLrGETckTpG5EqVHHKlRJY SyRfeyskNe4T
n9M7nx/xeZagW03iux3tPb1rbXBij763iOcZLWoKfahPXkArYmo9OaZorelz hZcgKPqQ6Ls+
SlMSp4+oobJEEaZG1wlTJKnAslfE0dQVUaRUFAjfWcSg0lIhcEKQnOuBqs9K 1rGtKIDyqRlo
0Tu0d6nP6Z3Pj/i8y1AtpvFdjvayLyhHpTeq5DCTi6hLXNi4sIwpnRrUiAZo rglzg82ZkGEn
EmHolpCpvVK0h7m4pg+0ZMqkEvjzjIFBQSzjEMWl7xHk6VuT5RvstvV+xSXN WlCoUnKFxlNL
WqiULYWi71Of0zufH/F5lqBbTeK7HfHESVSnUh+29xVeUnOLOpor3OpBI2ZT yliFTR3ePvDQ
+th38tezOrc5pRGolyY83vU5/TO58f8AF5lqBbTeK7He/wDgDf8A/wCgN/8A UDr+glDARnnZ
u/d3duJMJTHSyOUJXf1FVQqMA3hcG1wWUfI2pcM0ElcStY6O0eaZZIXOhDk2 n6QkUZygRVLO
TnFHJzjEytIrSKSyVaFwQqyT0Ti3LSE65uXJ1CFcnTq05xIO8zn9M7nx/wAX mWoFtN4rsd6/
4A3/AP8AoDf/AFA6/wD7DZYwplCgRyhBSWMaQkw+j02UMSoVD+mSJwmKqyeN NQdKJE2plrhK
WZsDETW9xWhiKyNplyFSnWolqclWjWJDi1CVWlUFhOTqUygkQyj055QwGknF DEWaWIIwCqGt
K95nP6Z3Pj/i8y1AtpvFdjvP/AG//wD0Bv8A6gdf+Y5SdL1S/fHiXNNP/B/5 ix0mLCX/AO2c
JbHyqf1x+8yNiL+1vtVtnfeJz+mdz4/4vMtQLabxXY7x/wAAb/8A/QG/+oHX /nf8Abgf9Abg
agdQO7zn9M7nx/xeZagW03iux3f/AIA3/wD+gN/9QOv/AOQ2xhV1S/c2eIu1 f/B/5aNrhz8Z
/wCxb4lIDa/1x+7Rx9M+1vspynfdpz+mdz4/4vMtQLabxXY7qpXLlKdEiRJz laxYrOLTpUiV
OWI5QpUqDhAKITkFAGaccaMJZRYRDGKgaVrj/gDf/wD6A3/1A6//AJKlCuTJ 1qJanOSLEask
tQlVpVBYiVCZSnOCMo9OeUMZRxJoBFmliEAYahrWmCom/KVCgRyhfWJvis4w +j02UMVLk7Ap
VqBGKqyeNNQdFOC5KVrhKWZsFLinBxWhlyON91nP6Z3Pj/i8y1AtpvFdjuil cuUp0SJEnOVr
Fis4tOlSJU5YjlClSoOEAohOQUAZpxxowllFhEMYqBpWuEzw8JlCJgRKCVsd jq0kxOqWqk5g
Tkcnk6M4IDSFBBoC1UYjCosJjEYEiQSAikvo1tcE/LPbXIjSEijN1EGhhyc4 o5OcWpSK0itM
YSrQuCFWSQtbnFEenXNy5OnXIVCdWnJOAvi7+fnnZu/eGhxOLJTHSyOUJQ/1 7ROlLA3hcG1w
WVY5Imb80ElcSifKtMeaZZHmyndJz+mdz4/4vMtQLabxXY7mpXLlKdEiRJzl axYrOLTpUiVO
WI5QpUqDhAKITkFAGaccaMJZRYRDGKgaVrhM8PCZQiYESglbHY6tJMTqlqpO YE5HJ5OjOCA0
hQQaAtVGIwqLCYxGBIkEgIpL6NbXBPzSyDzFCVSlUBXNbohEWU5szmUWaUS5 NpxpR5QFACjz
0x5CkhS3uTepWtDuicGZwcG9U4MD0WnKkjGnb1K+qEJlGxybHUxwIaX5tCYa oNRJ3M1odCT2
ZaoOcGZwb1qSqh1a/ZEjfO5zn9M7nx/xeZagW03iux3JSuXKU6JEiTnK1ixW cWnSpEqcsRyh
SpUHCAUQnIKAM0440YSyiwiGMVA0rXCZ4eEyhEwIlBK2Ox1aSYnVLVScwJyO TydGcEBpCgg0
BaqMRhUWExiMCRIJARSX0a2uCfnpVqJV7LkDXnhMzyEnSNH0jNaW3uCTOp/a kfdNHTgeGcah
PpGjo16BY1yBrZHtrVIlqX2XIGvMheWYR2kaPpGd0Rwb1eaT+1I+6aOoGzvA E6fSNHWIF6Nr
kDW9sjX3Kc/pnc+P+LzLUC2m8V2O4qVy5SnRIkSc5WsWKzi06VIlTliOUKVK g4QCiE5BQBmn
HGjCWUWEQxioGla4TPDwmUImBEoJWx2OrSTE6paqTmBORyeTozggNIUEGgLV RiMKiwmMRgSJ
BICKS+jW1wTuLe/spicqSMadwTIKLhGUbHJsdTG892YXIRZSg1EnczWhrOIe USc5wZnBvRK6
J3Vr9rxx8MPILUJVKVQJC6Na4JZTmzOZRZRpza5ElGnlAUAKPIUkHpj1Le5N 6lE7tC1wZnBv
cFXcZz+mdz4/4vMtQLabxXY7gpXLlKdEiRJzlaxYrOLTpUiVOWI5QpUqDhAK ITkFAGaccaMJ
ZRYRDGKgaVrhM8PCZQiYESglbHY6tJMTqlqpOYE5HJ5OjOCA0hQQaAtVGIwq LCYxGBIkEgIp
L6NbXBO5oJQwEZ52bv3d3biTCUx0sjlCV39RVUKjAN4XBtcFlHyNqXDNBJXE rWOjtHmmWSFz
oQ5Np+kJFGcoEVSzk5xRyc4xMrSK0ikslWhcEKsk9E4ty0hOublydQhXJ06t OcSDuE5/TO58
f8XmWoFtN4rsfnqVy5SnRIkSc5WsWKzi06VIlTliOUKVKg4QCiE5BQBmnHGj CWUWEQxioGla
4TPDwmUImBEoJWx2OrSTE6paqTmBORyeTozggNIUEGgLVRiMKiwmMRgSJBIC KS+jW1wTupss
YUyhQI5QgpLGNISYfR6bKGJUKh/TJE4TFVZPGmoOlEibUy1wlLM2BiJre4rQ xFZG0y5CpTrU
S1OSrRrEhxahKrSqCwnJ1KZQSIZR6c8oYDSTihiLNLEEYBVDWle4Tn9M7nx/ xeZagW03iux+
dI3OLEJ1cgbGdc4tSFS2rXctxVICRKwtgW9uXNy09Q5hJEgSaMqzhKpQSfo6 2hVUZ7OJYyQj
NM7wS9ARgbX7Ql6pIlWEoS3RObJTQqk7etUp31AGmaMSP7QzOZJoTUAKCkCd +ZYwkj7EzlHH
LmVOvSqgPK9aWBrSGAcH5wEanUokr2cIRCPkLMRlUNUk1NKKU91jLjGm2PuT I96eiWmPDK9K
PZzojzJ6YAnRA/IEn9apDz6o0BqQCinsdwUAUKyxDLQvAkbJCM08PBz0NGNt ftCQKlaVGSuL
a05UlKClTuC1MofV4a50xW/u7y5nGiNXjoGLyaWIG9te31vq6GpGvKohohWK TzmU8gJi5yMB
pjIJuWGFmrBnFHHmFnFpzAiTE/nTn9M7nx/xeZagW03iux+fMYsnAnKRN7wY c1kJj1SktMzO
pRTuypBHraaUaoSNS9GmViOEdXSijuRSqDyKTUjmuJTgdZsoDJjBhTpaKi2Y 9MSVH0Zy5Oeo
EtT1RBG9pizREVbzH5WkGjJVAVDO7rKQZCeq2OJ/te3HKT1RJaYxgAaochho loOh6g+PjeUK
QhSUYlEqVkjMqnEACxNHoe3DzSh8cAJzFOSSPQUJQBq3RxzJ6lGBT7NbE6tf olFJRyzR9FT1
qoNLDVMhQpk6JEiTkpEaNISWnSpEqcsJKdMmTkhAUQnIKAAokkoASyiwhAAN A0pT8+c/pnc+
P+LzLUC2m8V2Pz7VOLYFw/7xuBNvnZYQUS4EtBOlnPCBwLaSxJ3BRo7eolbm 6H6RoJKFmL0g
5t95ylMhQpk6JEiTkpEaNISWnSpEqcsJKdMmTkhAUQnIKAAokkoASyiwhAAN A0pTu90Vi5Go
oihCgyORg1zRpVxigt/HRzROqd6T5CMh4IiYG+jimRpy1QUsszKsDaEYkSn8 +c/pnc+P+LzL
UC2m8V2ObB3p0eJ+qc3iIRp0cVP/AGp3NJ0hc4MqJWrPzKeXFJys6oNMMzZB RZIMrJLLAClA
06Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/wBr F0/WWOkZ/tYu
n6yx0jP9rF0/WWOkZ/tYun6ywkOUKJueagUCVoTTrpXPNMRKhpVKEalIMcwq JOoEiWrEYjia
gMqlVqU9RZo80AukZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/ tYun6yx0jP8A
axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1liXsqRwkCpsLi EAdCUz7J5HJt
HXOD1chItPSnSR1dVCXSk7U3FnFpzSyR6IUKpeXSoq4ty0DWvCJE7zdUkcqM r48x5UrSp7ez
11KTGOLCubnGieji3IVQiQKglmmJSs6EYaZOOkZ/tYun6yx0jP8AaxdP1ljp Gf7WLp+ssdIz
/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ss dIz/AGsXT9ZY
VnJ1E3INXqAq1xpN0rnlGLVQEqZCBSrGCYUEoUBRIkaMJx1RmUSpEyegs0QU APSM/wBrF0/W
WOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF 0/WWOkZ/tYun
6yx0jP8AaxdP1licPTW8T9K5s8Qkro3Kf+1O5p2jrm9lWq0h+ZUS41ObmlBR ZmbPKMJHk5Jh
YwVqGvNnP6Z3Pj/i8y1AtpvFdjm201Ahu7rd3WZagW03iux+y0+v7j8rLl91 uXqBMt3XHnTn
9M7nx/xeZagW03iuxzbaagQ3d1u/NkTE0uQFrpE1CNJIEwCFYKN6leUYemJ0 g0gtKpGIBJuc
0M5Ro4wCKUZo2mR+RMtQLabxXY/ZafX9x+Vly/zfZkplyBucckAhoCiV7otI CZSgi6qkrQkX
nJc4CtBg0kBWWXWgw8oK0rgblEn5A+JCh0LPEkGKhyUwVK1ABWkPCUrSDGGl RACpIKEMNKiD
StPfz7l6gTLd1x505/TO58f8XmWoFtN4rsc22moEN3dbufcqESxI0onqEPBY EHsohYmA5R9X
U7QlxhS1e4DqdUsCZQaMsworNuCYISqVoIVWm18eSNJ7UkjhshmrgrIWHLm8 A8uiFIhESvTJ
yTTRmNmWJSmVUqW4hGAP4QgilEUtDDmFamhi2rY9yOYK1RKAbkA04gxMkSIl KI+tAnpVRYBg
OVVMCTnjAJgGE5wu1d0oo1MkiXtRrwzOUdVmnta9MQBSaL8BQoWGgLMLQr8g +qvLCekGnNSh
ywmUuLAorDWmRSdhkqptjRZYVSBvSsTcrXpnB4lK5W7UTmDAIDYnTEJTWrST 1R2R7wlEDjRa
CbkW2kdW4gyW0a2BG/kHOChEm0pG3GrXDOoE6JbpWYUJ1hxxpYgcqgWRlivu zrXI54WNMwRt
it3UUGE90UoF8rSnuJwTDlJgTVphQlJgRqDx0EZWgjja/frz5lqBbTeK7H7L T6/uPysuXz3+
UxNK1rnRiJKXmJHdOrUpTW4s8sLkPIRLm84JiVIIxZQefyMhOYGoBZVKhapy MwtO2rY6S/qx
cvKBEXRFpTgWOvv/ALiMB5JvvryCJF764kN3po0IkzYncFv2ca2QhUSqWtoF pDS30VnLFy4I
1ap4NGjMUElkpyiyRKqECDXICTKmi3UBJZlqQLmgZFzi4mSNQ3nF59PyGBdU aSh55FQjLLOT
Jzq5VKCTAHXN4fbsMLQjSPTIcS3qGl0qeubQONHRpSn8g0pzcpUJjETmWpIr QxOMs0dCzM5Q
oVTYy5t8LbEduT27JfpKtNMTrV70UzmiVijbea50UFNBMjCFtLOUJHTPJgGm 0UhMoPMP73cJ
vZHqeyR9cHFwdhUA7ZCNRmxlpkx6tOERATDxKj1ASgBqbUwsBojAEEBLWILe FEJmYcNUDnyJ
qCEDUkdaaRXIzBHIlIOoq9giMAWENS1qlaGtAmjUh59y9QJlu6486c/pnc+P +LzLUC2m8V2O
bbTUCG7ut3PgVwTTAo2GdtSyESdSKuQSWsT0LMa1Kkyv3Q50fsoOUL3BTtR9 fu/4z28DgUIK
u40mVeyM7T8QiLshxqJtJDWvvD+JQxKZSnuGBtSj9/uoGTO0fmrbbeJMr8pY UaJFHED/ACFX
o5RR+eXGO4s2kqYSoJrQ9PQIc9Q4gCf93EeZC29VNHScuZcRcxOri7GI6noF o2qVCo0lJkJZ
ZDenKR6IuCi5KioYvNUVF+8UpT+ksdUNM6CZIigD5PvBLNd5kIwNK/8AkMRJ VRU/xqWH/wAv
2f0lP+ZJ/wDrsy/ImWoFtN4rsfstPr+4/Ky5fPWtq0qh6JwSKEKskX9k5KrJ GQeUL/0MKMEG
v/pXEysEUaI2Yl3HDbpjKrXJMPYZQuOV6XQP9rRVlE7oUMdKZBZLsk5aUyqU w2fZ1AQuPai2
eKs4VYR6JRTVKblOK8BIyzDMoCNSoMAA0sR6w0NBGhoMQsDdp7fhS0N1UFVr oREmJgZETckq
TnVGYkhpY1gyiy+XIXDKLrycgw0/hWtzdbKf/wB6EYttQAQlg+wcTNFye6mW cwoTjh1/9RmD
GYKv+IhVrXDumhb4OA2na3A9oPlCINRyeXHp+TSqNA8oFW5uEEQMg8BhIwgN DU4SwYlDakMb
Ys31JEqEAxyc1ZmlOzseDKyTl60QQ1Hk5Y6lkEgJSEiMNESnLqaZUXOuXqBM t3XHnTn9M7nx
/wAXmWoFtN4rsc22moEN3dbufSNSQbgQjLXpnMhU1mpiF6ZWmCcUEZJqtGuI pQwhQeQbQSYf
KWaLJqEWSKjPG2kAwNrI3JW1HQyoRHCJSlBKoaeMACwmKDq0qcoMoWDOHjMM yaZXJhxkLU7T
WHKng4Sh2TQ+Q+yEDgcYMRhojyBolYwBNMGYMRSY4gkIhjqUWXlVxH17P9oo s5x4Rgy3WOPN
Uro6DPMEaeY8OCxOvVKzjqmHAMPLMTn1IPGloZRKEokqcyVqVuyhdcB0Jdnk pwPRmpEyghQ6
qQAbAJkCQ4kmo3dTQQVR6weSAilDKVCOpmJu+tKt2UK589ifngtxPRmp0ywa tyWVLbQJkCQw
lNnHVRSgFRyw3IATTPZQRiM58y1AtpvFdj9lp9f3H5WXL/IT3aN9p/aROWXS iSh6P2KaoJbh
tZK85LVBVYJaSlqXQsdF4SgmJ05uZywcol0bkqEDg0rwhocTUQyhgMKHQwlQ nPKEE0hQQYEI
yjSxUrStMkWUWIYBJQr3abyhoQmFmIozJpJVdGk4ia5RFKNSZGhLOKJrSmSn UjPTipTJNKMB
WoazJiQu8yRMc1CXRazEvKOrY2CKc0LoE9nSntRwCVOW3J0mkLdPO0DKT0HT 7owoIalULvZz
dHEsZTqxGE+0tCSNgGslQI4KcCfTswWEypgUgSc/96iegPw8UJSzG56Yqla1 oURIGUkula++
taALjIQ8tf8AGvJ78IZQ2ymfOaxABWAtG+PbesbDaLEZ6IdT05DKjNHUss8R hOSoBknBAKuV
SlQ151y9QJlu6486c/pnc+P+LzLUC2m8V2ObbTUCG7ut3dZlqBbTeK7H7LT6 /uPysuX3W5eo
Ey3dcedOf0zufH/F5lqBbTeK7HNt8sOXzcBquERRSaBJc25KBKEw9hQGjCmQ oZWnRIk9BCrQ
lIjTkJU5eSSnJKKAAFOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WW OkZ/tYun6yx0
jP8AaxdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp +ssdIz/axdP1
ljpGf7WLp+ssdIz/AGsXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2 sXT9ZY6Rn+1i
6frLHSM/2sXT9ZYmyNCc8HlGQi26kQ3qQv8AJVVDBv10yqhLXSNydVpSfJJB UKQpQBKAyppw
CQmnnjMxa5uVmOBSdRP1mcMa3Z0Y1wc1bK454cw6Mqxvc0vKMsNDNGVlZ4mp ic7LTmmlj6Rn
+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/wBrF0/W WOkZ/tYun6yx
0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun 6yx0jP8AaxdP
1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/a xdP1li4KwlfN
xmpIRK1JQFdzbkr0ojCGFeaAKlCulahEtT1EGlDkixOelUF5RKgk0oYwV5s5 /TO58f8AF5lq
BbTeK7HNtpqBDd3W7usy1AtpvFdj9lp9f3H5WXL7rcvUCZbuuPOnP6Z3Pj/i 8y1AtpvFdjm2
01Ahu7rd3WZagW03iux+y0+v7j8rLl91uXqBMt3XHnTn9M7nx/xeZagW03iu xzbaagQ3d1u7
rMtQLabxXY/ZafX9x+Vly+63L1AmW7rjzpz+mdz4/wCLzLUC2m8V2ObbTUCG 7ut3dZlqBbTe
K7H7LT6/uPysuX3W5eoEy3dcedOf0zufH/F5lqBbTeK7HNtpqBDd3W7usy1A tpvFdj9lp9f3
H5WXL7rcvUCZbuuPOnP6Z3Pj/i8y1AtpvFdjm201Ahu7rd3WZagW03iux+y0 +v7j8rLl91uX
qBMt3XHnTn9M7nx/xeZagW03iuxzbaagQ3d1u7rMtQLabxXY/ZafX9x+Vly+ 63L1AmW7rjzp
z+mdz4/4vMtQLabxXY5ttNQIbu63d1mWoFtN4rsfstPr+4/Ky5fdbl6gTLd1 x505/TO58f8A
F5lqBbTeK7HNtpqBDd3W7usy1AtpvFdj9lp9f3H5WXL7rcvUCZbuuPOnP6Z3 Pj/i8y1AtpvF
djm201Ahu7rd3WZagW03iux+y0+v7j8rLl91uXqBMt3XHnTn9M7nx/xeZagW 03iuxzWOOIZt
CDUTAztrKjNV23fhqjErUiJQpzFIybpkFDUDKIAI4RRBJYjKiqAosPICnXKA bNJFxYx1ygGz
SRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1yg GzSRcWMdcoBs
0kXFjHXKAbNJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMdco Bs0kXFjHXKAb
NJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMPsjkb6zu613Z4 4ylFMscWx5Kk
Sx5bJ1wDDALpPJjVShUbJjwiEE9KWUWlKpQoYhjH+yNK2V2b2dzjMgMfUxzo zKH1Coz0ckMb
OSnokj3H1FOVPIDVBZxbiHIOTl0EUaAYqU65QDZpIuLGOuUA2aSLixjrlANm ki4sY65QDZpI
uLGOuUA2aSLixjrlANmki4sY65QDZpIuLGOuUA2aSLixjrlANmki4sY65QDZ pIuLGOuUA2aS
LixjrlANmki4sY65QDZpIuLGOuUA2aSLixjrlANmki4sY65QDZpIuLGOuUA2 aSLixjrlANmk
i4sY65QDZpIuLGOuUA2aSLixh8ji6bQgpE/s7kyrDUlt34CotK6ojkKgxMM6 6Z5QFACjxiJE
aQcWEygajKMDygrzZz+mdz4/4vMtQLabxXY8XnP6Z3Pj/i8y1AtpvFdjxJom SNcolyWXpxy5
REnhahRqo83yZQdJkbTD3ujaATkoZ0Tj9nym2WLEzY7GEtqlE+QJqQnNSvJd JQ3xlR/ECCa0
UwV0NJ/gFWQ0zEhjc1DeMdDCSnEhIYhNUEKkxagShIpLK/ql8+1WT/P+wzY8 T7QeX+V7U+xT
e/eydJ5DNC9paLp2jq9Dz+hqsz/VNuvZ2a/n/bmXM7Lnsv8Aley/sUTcrSc3 kGab7S9i5nLS
aH7RzqrQTXOQ3BUJQkKECFuS27hzG0KnVze3BK0Nrar+3iy4KU1QudVbcgbD y1UZb0JixSe+
rTEWQqaxOU6ZFEjlC9QrVOLkpmE3XmALOVHDbWgLiqeyFTmnjrVVDHkjqqTJ FTmlayV6lGjP
UDSleLTLUC2m8V2PEZY5NJ+jvaePulI+KhZKg42RqEhiaOpEiQ8s4tc4Lns5 Aibm6pCgTiuU
J0JadQYoASNtZWsjRWxnb0bW3Js4cdo6FvTlpEhGeUGGqDc0nKLLzh5phw8n KMMGOtRV/bWZ
n/iMiXPIoOjN/EBTR1Dq3uk5IEDkSHfaxIaWnjSsurjmoaWBza3RKXOn9nJ8 XmWoFtN4rseI
wpg/l/aCfxz97/taJ9j9MuX/ACPu5/2j9h/Yv84nRPantH950LQFf7aQwj8R kS5lbOFhX4gK
aOoanBrgx4R8iQ77WJDTFElSGUcc1DSxtjo1pS50wPBPjEy1AtpvFdjxGIIK /vCRij8qlB5R
fv8AZj6eazRqNLlgyuQwjT2R1uEibUyodEbnmHZQWnUK2IB7f+xG3MxadVJX pQWmaUZ4TDiy
EoVSMl5ka5OUamENnjCJX7SWgMXNZbmq9mxlM6o3qQs9DimxIYoPDRQvXKVS sRYlS9zd3BU7
u7kpzBSdKWocnVcsXnEIUqNvTmKBEN6JEiLISleMTLUC2m8V2PEbgOhX3U7e 3wqFHAM9xwnR
nTPcxUnlhDlAq3jbLiMpBBojAKBLkroWYlLTkpFK3B7k5H6OkT5ughULOUHG nKDi0yRIkSJi
zla5wXKziETc3IiFC5xXKE6FCnUK1BJIzpNIyMiQrtNTpEgzCTgxqOGrqnNz EmCnMUJE7goS
J21ZMVKRY4hdZGSIsp2XR5liqZr8ZmWoFtN4rseIyN2N+84O0/n3tA/+zpH2 dlLlCmf8IPIS
VocZi7E2/gll6RoOmKs84KVipRgtf/aiMZcHRGQlP/syCZMruWiG7GJaZAy2 +EubU5oWstxz
wHSRmGSFO2pKReISF28amWoFtN4rseIPkjXFqDUTAzuT0sKSBLGqMStSI5co LTAONIKGoGUQ
MJITTySxGVDQZpYeUdIjHFxic1awRhgZVhqQRg0pipqakiFQYmGcUQaNOM0g YiRGkEmCLqGo
yixcoKfYZoUqEK14Z1qt5fURxhaqLsAzAN2kojEws6kk70acqIhxyqqdEWY0 yB+ynMUWMjzu
mQoUydEiRJyUiNGkJLTpUiVOWElOmTJyQgKITkFAAUSSUAJZRYQgAGgaUp43 MtQLabxXY8QN
QD96R9kEKi7qV/DSmKWTaPRqQIcunIYRp7I6r0WkpxkrEuf0hEoTqyiTyzVR CX2m7KMtHHmI
B2jqJA+jTnnIWdObmlGj6Ro5hq1wMJGjZWtOvfXQSdpbF6og4o5V7Rc3FwWv D06VJzAnB0cT
qmGiCWI1UoLb29PRMysKNWucVDVHGxnZxOCwDcWePxuZagW03iux4hb8lSpT oCmJRLbgOS9e
cWlb07BH4o4RRxqYqGLJKUFrbgtCylT6FIgtiN2UHrCTU6ZOtUTJ0TKElKJ1 LRDUKokxCtRR
hfRmVuSx3bzA0Up3iRvLSSr0VwHpDWwN0eSmtUekBssRqfHHt6SQyQSZseIh DmslSxLYgTo6
5iep4rWkKiZJKY+opyp5A3GEmJylBI8o0NTADKqGvZPP/MbWcS8dk8/8xtZx Lx2Tz/zG1nEv
HZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG 1nEvHZPP/MbW
cS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP /MbWcS8dk8/8
xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8d k8/8xtZxLx2T
z/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZx Lx2Tz/zG1nEv
xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLwjcpFG3CMQRkiDk0jaXZdHj HSWOkiemlY4t
rkXHXuTJDogSkjLQYsRjWM6hzUGGNLiW9xte7tov/wBC1jkaGEwgpE/s7a9I yldyH4CotK6o
iVyctSAm1h5QFACjwBOCUecWEygqANMDyDr1NgG0uRcJ8dTYBtLkXCfHU2Ab S5Fwnx1NgG0u
RcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG 0uRcJ8dTYBtL
kXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYB tLkXCfHU2AbS
5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2A bS5Fwnx1NgG0
uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1Ng G0uRcJ8dTYBt
LkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTY BtLkXCfHU2Ab
S5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2 AbS5Fwnx1NgG
0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1N gG0uRcJ8dTYB
tLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dT YBtLkXCfHU2A
bS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU 2AbS5Fwnx1Ng
G0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1 NgG0uRcJ8dTY
gG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx 1NgG0uRcJ8dT
YBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8 dTYBtLkXCfHU
2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5FwnxJUj00t7O5xmQFsSklreV D6hUZ6OR6SEq
iFqtkj6inKnkBScwkxuDkHJzKhNNAMNafttpqBDd3W7/ADVdjX9u+VltOZbT UCG7ut3+arsa
/t3ystpzLaagQ3d1u/zVdjX9u+VltOZbTUCG7ut3NlH2ljUfkWgwC3ehe3WZ udtD0mRXS0jR
dPTqNH0jRyM9msnO5krLys2Dk7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NI B8Gx36djs0gH
wbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36dj s0gHwbHfp2Oz
SAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHf p2OzSAfBsd+n
Y7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfB sd+nY7NIB8Gx
36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NI B8Gx36djs0gH
wbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36dj s0gHwbHfp2Lg
rkNvoQiWooRK1aNYkijCnVJFSdhXnJ1KZQSgAaQoINAA0k4oYTCjAhGAVBUp Xx67Gv7d8rLa
cy2moEN3dbubMtQLabxXY8HuXqBMt3XHx67Gv7d8rLacy2moEN3dbubMtQLa bxXY8HuXqBMt
3XHx67Gv7d8rLacy2moEN3dbubMtQLabxXY8HuXqBMt3XHx67Gv7d8rLacy2 moEN3dbubMtQ
LabxXY58YQRBsbnqVSVwVBTt7inWKyfZjcmy1p1CEC5vPz+fPR0JGI/NZoKu tQCqDlBH5aMC
clavTmEuqZLQYSEzqiOMSLiySzTTziiBnFVUJizjjjKJTiMo0ytcsTRFI+xK plP5DTLaY0iM
zeaT8pgaL3E8IDREp+Uo4QAUB98tMpNOOSJyhKKDenW10Kc2pOCqlY1MTmoE /FJgUyjAhHR7
cC1BwQ+7kQoFo6194CB0wilTHnCyTxmJVqE/JqpbHJPkaShUVB90QgUMLOKM DyUOTHEH5IM5
kB/JlFrim1aU5RZoRu6lyMGRVCpKWJ2VQAogARZ+hgAvRIRVMBQPKSZyfxDy /scyoVHbarYu
Awn2SpeznULoaXVKRU+qsKd9SE0FRXVQEGQnL/BCXy0rXlFWXMrJGLVjXQl3 EyPtFFH1OWWu
CpXpahTGCk9aKC862qfxA8lOSgK/7eKSmVskFJlhs1TsydGhLdljLVgUM5yo CgYQvtFVHLT0
ikvl02hFE1Afu2WLOfsdlsAaUL5LSdB9ktbkIIESrOOSMpfnhCcWmlMy2DWK C+VwT/ilAp+L
/JMZz31MSiez2tvOeEaevKnSOpiQobgmIrQ9VSpJCuppRVaKVHKANPxzv5gv ybl6gTLd1x8e
uxr+3fKy2nMtpqBDd3W7mzLUC2m8V2OfLpQOmkMNqGoMSaK195Qn1ZpSdwMp Sv4YxFDHICTK
hyhZNG8Qq0/Dpi7Fmj65tIldKy6LFC9wfZa2icJgAVr7hio3qmL7pf8AvE6y uT90eTfuTONM
64x9a3RlsqZ96qZvqe4IhZilf5eUTHEvKIHJWueN9/4xmViUuzI1+x24ftGU vwCVS5SA01Kl
NUq1JRK1WeUmrUgqtM0lonI5AgDkUCAGSouC9XMk0CYHFcuJi0dhagbfQtEi UmJanrFZJqca
ugVRRyeukhOOUGEmm5xMRUlOF0stcF8rK6DaPb0PlB5NCXBYiDSohpVvvEM6 tSy1lcs8w88h
S3qS9JUpzk9SJCkcrmS5kj7XK19Ku6B1VKpU5rT0LbktJLyvOPPamZmJKArC mSV5Fal5Ny6A
zNBVndnJPKV0zbWNiJkTQ8u9RGupZZg2KoSDVJgzVBucTvxYVATzzggUIs4l zRZ4wiljs3T5
9gFuI48nMDETEzKonZ6UpghMNWq3Eowo4OUnNSKhliEcQAKspMQSERR6o93h crcnObwcTUFz
js3cSgacmWUNLCNmcVGdMOPMECqitRHmKK8qdOaUIotWNOS8Nv8A2nSOMsLJ Jl9VEiLXOTpJ
3dcoIR1KZk681xTqW9paExYVNSyVlAGnunJVOdT7yeWQmPThXb+E28qlQPTo zDCRIH19UZ4B
hBCyppJqQhMclWkVzJuSDRs4oKUCWEURw2Kvc5W3EgtwlRzQgWPhoVMgYXwO ZAnAYtzpxykl
ScpSFfiHZoZZp4i0xBqTKVzNl+3M/PrFWiOvonZRIamPMloUVDVvsaUrdGp7 VYzNL0Q1BUBO
UiTJSM5+FlVl0Ljs3V2+hNvRJkDy5sowESB8fVFTwGJ06zOkmpE6U1KtI/BN yAaLQw8pQJYR
RHDYq9zlbcSC3CVHNCBY+GhUyBhfA5kCcBi3OnHKSVJylIV+IdmhlmniLTEG pMpXj+kp/wAy
T/8AXZlhu12aP9Kf8O9w1t35Y0y9AyLJOONsygSCHIQokZjmOPlNpJoaqKpy S6oqOKwR9Tzg
59SQblD5TZ97TVtUoPSthJrszKDmpZn0NwUcfUKiDkAyBpRuCdMYJSWmqUVy KjiAgCQLN4tw
9tUifWx6XfYbTXdvd3BE6LNLia5Qq0penUFqlGkqAhPUZ00WeOCE0zKHSlcP NxlF25UyStAz
LJP9lmZQJFEG4lEkG5CjwUJRgKrTE6cuqL2mtztVSgOeUJxBGLFsFjRotblX Qcz4u3KxElUI
JUN70oYlbwFNUAk2knnBQZJVSdEIOcBnUJqUnCnHIZc13jlcndULA5Hv7U9H KBNZyISI6jir
j9dMGpYV7QWIbm2qEo6GVNRgBXIAMRdYa6PTk4PDmq+0OkuLosUOC5RmZU+J yc+rVmGqDc0n
KKILzhgsgksssPIAAaU5ty9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK 7HOk8rOqDlZm
lSoTBH/ZOcB00dsTV/8ARS4nJU//AOJ/jhilE/Z1jrJZMFQ/KFInh3R10RxU GHN34aJamKEI
9FUlaMwRecEYqHSohBCHFq7hw5Ee1Rw17UMErLNXr1xYSXArN1Oy16hSPlE1 mOhwSssJdDm0
gylKD5R0dbkHNyxwtpchOlIkSpuKqoEwvZebyFRoA/xoM4JiorLGCikpycCk +cUpSizDXUiW
FO5tCamJmpuROFXJWbk8oE+ZUJCApBDr7qjXjTFF/wC2Pl5KVug7zM9xRuN3 gv1GtrclKswt
laHJE6EIxEJVFeVAQce7qBFEFkl5TemQG5OSIsIA22uI4FwyUQlc6olCR6Aa mCqTKHFU5FnE
H0AIgYwCWDIzdB5R5RZKpPniT6DwdciPkqRQqCRgyNo3s5OamJd3A8LgHNpw nAAZWvK9uB+S
INDC0qZKYpAQJYQXWVf8yXz/AEKMYuX/AMtkH/8AEAxNLTXFWhjStFJ1b0xu jkA0pueWtYnS
pCziVdACKDQZbcUqJGdUFDaKTCKV0hKaSF2ZIckRuNuo+zBG5SwSZeAxVITT OQpA2nDNJIEn
qWPl/ERCGOiJWcA3MGpBDlX/ADJfP9CjGLjtt8WgdG6WuhsohMiUrn9vashx WLVzkkGeyrUt
Mqpq4tPU1UERaU5tMAIwqioip0VZLVW/+06hrPBIHaYJZZMS2mJGNZxattUU AqWLErycNUSA
NCB1LRjOGmT1MUZasCa5QHlwTNlX2NRtpZ9MMoRRyc1TfBS0yFJUfJQ5SoGW YAkoNcowZYwh
5ahrTFx22+LQOjdLXQ2UQmRKVz+3tWQ4rFq5ySDPZVqWmVU1cWnqaqCItKc2 mAEYVRURU6Ks
lqrf/adQ1ngkDtMEssmJbTEjGs4tW2qKAVLFiV5OGqJAGhA6loxnDTJ6mKMt WBNj+kp/zJP/
ANdmWG7XZo/0p/xP9SZV/oS/H/8Av/nhxa7/APL3cxwxP9SZV/oS/H9Hm5re hPc01spZJHV4
SJg5RtGtTO1Ko1TWn+BJZjKUmNN/3OmAOHklAMMBI0cReQyN9kkZeEDeyIEy sTinAsa1IV61
yTjID7PTs6CqlesGrqWDISioCo+WmIN+pt8JBzrl6gTLd1x8euxr+3fKy2nM tpqBDd3W7mzL
UC2m8V2OcNtfWptem40RYzUDshSuKIwZQ6GFDGlWFHEDEWOlBliECtQDpQQe StMEpkxJSdMn
KLITpyCwlEkElBoWUSSUXQICyiwBCAssAaBAGlAhpSlMez5AzNT6gzoD9CeG 5I5pM+XQVCzt
GWknE50FBjoAzIyw0GKlK0yq40ISZPVHmdH0SpJdU2j0Dm6EZjJzWZoD7may cjJ+7ycmAuCC
DxBE4BHnArkkaZUywJnLy5YVJKIB1B8vvyqD5eX9hZ0hi0dfjiaZJRryyNro YUGleXJLGtTH
iBTl9/IGtKcuCkTcjSoEZAckhIiTlJUxIf45JRBAQFFh5ffyADSmDUcfZWli SHqRrD0rM3I2
xOcsNAUUYqNIREkFmKTCyCSxnjDU0QCigCFUJYaUUyIhlaSZAtTURrHwpuRl vCtGHR8lKpcw
E0Wnpg6Il5CDThFU0ZPyB/BLySypFH2R+KJrWpJb01IHQBVa/wAalgXEHhBW vJTlyaU5eTBa
BobkLUhK5c0ibUidCkL5f45tOmLKJBy/45IKcuDUcfZWliSHqRrD0rM3I2xO csNAUUYqNIRE
kFmKTCyCSxnjDU0QCigCFUJYaU0J+Zmp7R0Fl6I7t6RyTZf8MrMLCjisrk92 Vk8uKo2BlaWN
IIWXVK0NyNtT1H/DKqQiJJLqLk92Vk8uETy5R1icHdtGUY3Oq5pQK3JAYQZn iBolx6cxSlGS
d+KUIg0FSzPvg5Be/GhPzM1PaOgsvRHdvSOSbL/hlZhYUcVlcnuysnlxVGwM rSxpBCy6pWhu
Rtqeo/4ZVSERJJdRcnuysnl/Y5LGllaWtW8qarHhU3NyNEodVlRnG1VOR6Yk sxcpqYoUGVPV
CNNyzzh5WUaOtQoJCytL8hAcBSFE8tyN0SBUFhMABQFOuJPJocABpoAG0Blh CYYGguQYuVQj
WJyVaRWSamVJVJQD06lOeARR6dQQaERZxJxYhFmlGBEAwAhAGGoa1pj7L/Zq P/Zn/wCTvsZu
9hf3z2j0Ro/s/pD9+/u/98/ef5338JWR1jrE5sqHR9CaHBob1rWj0QkSdLoq BQnMSp9GTiEQ
nzRQcySIRReSCtaYUI1iclWkVkmplSVSUA9OpTngEUenUEGhEWcScWIRZpRg RAMAIQBhqGta
YQqLSR9rolYnQs92ibYypKFKo6eNQc6FtbelJoAtQJUbnz6JU9TRgPVqckZg a0HIo/aSBnju
FNWhXHj21ngxbS5oqPBVUi4bytSpCwj0Yk04fKSoVl6SEsRoyiaDPLiUUV1B Va1NYaL82Kgy
wuKw45wcCyx09xhZa1WeWAyn8wIaD5KZXJzrl6gTLd1x8euxr+3fKy2nMtpq BDd3W7mzLUC2
m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8e uxr+3fKy2nMt
pqBDd3W7myjT08gUaZALd5r2FE5TKMnR5FdLL0r7NMztoOVngZnTdH0nkN0f O6Ofm+jp/snu
n6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/ snun6Nx0dP8A
ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcd HT/ZPdP0bjo6
f7J7p+jcdHT/AGT3T9G46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/2T3T9 G46On+ye6fo3
HR0/2T3T9G46On+ye6fo3HR0/wBk90/RuOjp/snun6Nx0dP9k90/RuOjp/sn un6Nx0dP9k90
/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP8AZPdP0bjo6f7J7p+jcdHT /ZPdP0bjo6f7
J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bi4KMlBNwGq4RK0xQ1dsrkoE oTD2FeUASlcu
iidEiT0EKlTlaxQQlTl5Ryg4ooAx08duxr+3fKy2nMtpqBDd3W7mzLUC2m8V 2PB7l6gTLd1x
8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqB Dd3W7mzLUC2m
8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8eu xr+3fKy2nMtp
qBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2 PB7l6gTLd1x8
euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBD d3W7mzLUC2m8
V2PyC10jfGdgRGqApClj05ImpKYqGWacBMWoXHEFDUDKIPNCSEdTBFkmjoHJ LHWnaXAPjKO/
UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAP jKO/UcdpcA+M
o79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/Ucdp cA+Mo79Rx2lw
D4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79R x2lwD4yjv1H8
q5eoEy3dcfHrsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl91uXqBM t3XH8q5eoEy3
dcfHrsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl91uXqBMt3XH8q5 eoEy3dcfHrsa
/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl/mhkEi0sxOc4I2xKkbgJj V6xWsHWgQJil
SpESPMlANVH1EoBkJyTBBoMeQWPn3L1AmW7rj+VcvUCZbuuPj12Nf275WW05 ltNQIbu63c2Z
agW03iux+RafX9x+Vly+ekmMNcNGowvzYbIkVUTerLcmFUdRKaQIS1GqNTfv hiMvPoxJzgEn
njzlKgBULzcFCcAZNI4W5MZoqBqBQrdySgMPKGuVQQDli1Hl0+9+HUVeStKY jT97IXz+5Ui0
MWZJZAZpsA8hUuCZQ4tzAkRBLStbcBOlPqLMcrkcDSFFAVycOk0VXLiTj7Db FL25xn7MtxSL
REBAla1OmcgthK1QMsgszN0EamEfUOSE8IxBriEXNjigMcd35+b0bkEhIhcS qFFgfk7mQnKd
ky0sJJ6tqocnFWmklFZBdVFa5wQz5dMVTM0Ql4aDDI/BkxJZjy1iUKERzWse HCqChtVvs0Km
ixMW5jICeqD+5kDLzZDFMazCdyd0WzVA0UKlj4Q7pEaNcid3E0KEFG9OcnyD W1OWUGiipQSc
oNShCyBg59y9QJlu644OZpVZhQiFRQoJQuQZicJmey09CBjVsriOGFFL0+aV pDDQhyVSKqgt
M5JkS2hqUs8xlikQb2wWb0ZI6BenhcVyEl0Oz7ikdGNOoy1FDTC821pc0SMs gWeGWJQbIE78
yxhJH2JnKOOXMqdelVAeV60sDWkMA4PzgI1OpRJXs4QiEfIWYjKoapJqaUUp 51y9QJlu6495
cFbLEIgY2JZBJ2JMc6T96b1yj7MyN1jZyo9Ektu6p0ulKGo1QWSW4q8gkwug jajyqU6mwDaX
IuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwD aXIuE+OpsA2l
yLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA 2lyLhPjqbANp
ci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPh9jk jYmdoWtDPHHo
o1lka2QpVaWQrZOhAWYNdGIyalUJTYyeIQQkKizS1RVaGgEAYO4XY1/bvlZb TmW01Ahu7rdz
ZlqBbTeK7H5Fp9f3H5WXL577Gl391fGpc2Gi5MqpWlpxlAPBT/4xOYIJ5Vf4 hMLCKnvpi1f9
H1xCZp0bmz0RPSq5X4cdhJgjkqU0XJyZg8lWoayK/wCCxrTcoeUQaVgzLHXc uKETCSAZXaXC
IKNDHm4IkYDDAZ6mZI/CVGqhG/cNAnbz6EGEirnS5C5Se6kymDsewuNI+mfp 6c4EOL+aiNo0
CRMjeIkJ6cpwEnUZuoVCUggFTFQhEAMrW2wSzSzBEy6oDQgGEQih6bN65BlK VrUAuStK5IuS
vJXlxSlKclKU5KUp/ClKfwpTEV/5ksf+hSf8i5eoEy3dccGssoZW98bDcuuj LyAm5g4ac9Jp
aI73KG9wLTqlBadxQmp1yXOjEmUFDrlYOerfe0JfHA6CXVpzYlsyRnH5RKgz Q25ASneG8CgJ
JmfbyilycC3JPaxI21W8D+1qaQPEbeZU8LxluUcVpTzD480miaU7W6s0laHq NaQS9I3damXk
NJjsQlVAJIeSEy1ybh5pOZEJon/lkHOx7nBXRKSR90sxyUtbXM2yQOC4AqCW HtzLC0KVQQYY
kaxJ15aRq/r+FT+P5z+6f93PthpeT/P7NFk49nZjKJ6a9l6Xnv6u03Rl+iGL o4+M7+iKUCSG
rGVyROqUtUAso4aYxQhOPKAoAUeQaIkQ6GBLOKHUOSYCtf23L1AmW7rj3lx1 /ux805l3WZag
W03iux3C7Gv7d8rLacy2moEN3dbubMtQLabxXY/ItPr+4/Ky5f5DxN2piKSS h/LNKdnQKpeZ
VSA81OefkpDlZiBNU85KQYcNIlIGaMGUYIVRDyjWSTNKN5azhBGNItLywhNB y5B5I6VCanUF
5QqFqE5hZwKCFQI6UFXlPVMUKayFCgg9MYetMXvJlCFJYiVBRI3pW4VTAPJG Mk6ibNZwkYyh
coBCDVdHgw8AGdxdEj0sRgepGChrkgIWJkZ9DgvFFBQSCXBYAKYk4tL+NyiJ qIBdQ4StMua/
azeiciHdMn01xQZtxTEKkxKjOtitGcPIJWKQZowwRAs5lCLqIABB59y9QJlu 6484tweo4zr3
UhOFMjezEJIH9tLKMNPTiaX4kJby0KEak81WgVti5IqQLR1WIjiFXIbTLic0 kDdk/fo1yg9R
PmJQoH+GcoXGSBZ9tv7tk0TImidMrWnWJ06wSA/OupDp+/x2PyxIR/NXRd3N Yn1fnf7Ggw+S
gMZEuimGAJU6bc6ufRp1Dmn5FZxEfxkSr2hAlAfcZSapQs7WE4X3yEhEvLOV wZ0cFKX99Kbm
WUOS4KcCrPpyVDa6EIrgrkKlOtRLbcStWjWJDi1CVWlURlecnUplBIhlHpzy hgNJOKGIs0sQ
RgFUNaV7y46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3NmWoFtN4r sfkWn1/cflZc
vuty9QJlu64/lXLfUceb2l7FEJk5KnhgAOOujmoEyuKw4t6cGIberfG9YryV Ti0vBq5rc1BZ
JzgjUmElCB/VNxfaOd/n/bmIs71mcj+V7L+xR1tdGzmWZpvtL21nshJofs7N KtOzkigedSV+
+JXBpCCWez05PvWKHRueGmFvZ2QWIJiJFFGuWOjhmVZAEBSujenc0zec/p2Z 1WqCUyBklSdd
Dn9wMUmBISibmGVpWZ5Xp1akVUiRWjQnJVS0pQjTnGKkygorurjr/dj5pzLB qlScUnTpyxnH
nnmBKJJJKDUZhppo6hAWWWClRjGOtAgDSohVpSmKoTJ6gEcEebqNO3PqtHy8 vJy0cUjWc3iB
/wDWBU1L5PflcmDJ0pfUg4kUSSoE9oaHuiWpJ6otCWIsLYUrUHfvZoE4wFEj GSZlUOCDNmZL
V7VmiJPV6bW94QFAQvCs/wBnOqUpa3qFidG3KD2zSkh5KgBTmWjPoUYEQyw8 uEjyxuCR1a1x
edSLkRwT05waCqAWSMFf7RZgRFmli5DCjQDKMCEwAg0NaHSctoF5BtSTy0aV 1dSiDg1yRlHL
GpAtRlGFi5QGgMUBEUOggmUCINaUeJc1ylLQDy1u7TEHhrCc5lnSo9ldD2hM WJEnVgTHhUoh
1GNeEhMlNJza0ZIvu1RkrH418mLEV/3tqekUkGpzHJzeRNGWeJImQqs6gRe7 QDD6FUKoFRmz
K0oKRLJjIEbIUruY/gSANCpUq1VS2KLZ2qZAhIVLjwFZQM8YUnEWVUZdDBBq YDlPWw+QI3sl
KIAFQSaHkKktTMqpWlIVpKZcnCbkDzIzk4Am5szN1Fmx8lWeSTFAhdAZNDkJ CdxdD0ohUpUI
VgWhEu0IdQ1oPIV5keQII+TIFStSHmOOqJ5a1HLQpYgPCeVlh/tlD5PvEnl8 vIaQcEBxVfcY
ANcSk1ZKkqQELcy2WRaSjdCKo3U4awspAnCYhCJ2UDE3rahAz0X/AHE5hv8A L5BVhFs7QOlE
rjPWdNJVksoUeSNnia0galOpTgOLKUo1KlEUcrHUwtOvIBoidPQlWuAYRQ51 kU6dJAIOUdJD
H0Ba+qqvvEeQASQ8BYcv7wAHiVmBp7hnmi+/VHZ2cvqmVx2SpDFcClDhUQnE oZNDReylx5gz
BmfyDUuaMOPESo0ASapaRbQkm9L5I3NI0NSOEMGfWrDMgsNRtsBCWWClOUw4 40VaAJIJAYca
OtAlgEL3YMQRKVoXReUARlUAiVzcuGUD+YaQjdUiFQpKL/3hics0BdK0qOtK VpiAubnI3JLc
RLHHMqOxspIeNtcmwaOUBVKlKwLWcnJNKIOdhgAY6pRCEjJpQkecCE/Ey1At pvFdjuF2Nf27
5WW05ltNQIbu63c2ZagW03iux+QWhkbGzv6IpQFWUjem1E6pS1QCzSQKS064 k8oCgBR55QTg
goYEs40FBZJg6V7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0g HwbHfp2OzSAf
Bsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2O zSAfBsd+nY7N
IB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+ nY7NIB8Gx36d
js0gHwbHfp2OzSAfBsd+nflXL1AmW7rj+1ShXJk61EtTnJFiNWSWoSq0qgsR KhMpTnBGUenP
KGMo4k0AizSxCAMNQ1rTGVGlkghZhf8Aciou9rErE25fuUaDB14nK3wNMCI8 SnOxM7KWKlDu
DNvYgOQORA7R+bJKfhlESgs2JvtM5+KNYuksabXVkX5gzLSpm1Fb1i5UZycx Q7Gq288bzySW
DS9oAD8Abi0oCZs1qlwf7Rbanhx7xLhN51AHno3R7iDATVOWWByLanNUmbDF QWJ6b3JQ35mj
ogJPDR0ZjlGdoWkfWkzIc2NwoNOpJNbnZIjXJ1CVUmUJy1CY8svuLjr/AHY+ acyxIks6fFse
i6klKW5uLacEpwyALkx5aRJlI19TjFxpIEg0xaM8xQQaaUENMqowpY1A/wCj 5M5Sx1bQIkax
5i7GytL2DMZui5S9uB3KpGsr+OpctGCOpoxnBoEXupckIxiEEqU5sqla1rQs FXKFm1AD/wCC
HOGGGclPdljEL+Na4iSRSxtrjSTRNncnw1ckJVHuJjw1p1Qi1J5wBGjKSEng RIgZeSkSpyCi
KF0LDi7S9rUHlKUMwcGhCaAYs6jTu5ULazxpx0+8SMsDoqUAMLyRFniqcGtB +/ETLpH2Zec/
xtqeHpWtbki05yUvKAleeFQaoKMEamK0nR0xIvwi04A0oClajqL+ldbVo5Qx Yi3Egk7egyqm
J2xWoi5Z1SktBVFm8kp80OteXODKbkwTBCqRSuILWlKUqJM8cteT315JG88n L/58mJfLVjel
Wu9ZcuYU56sgtRVEiSN7YuMokzoRUTiWGOfIqGXkiOAmTgHWoSw0xf1XHUhD enabOOsoJbkh
QCkVXNI3RN0ztEoKUKyjFZqk0VKB5MtUf7vxK4LVrbJXLnL7IVTovfZghg4J CjezDnFUCgEr
qpNEM9MSWEJSkr3Aq40XGDDUwY61uB7JgE3gdvJEzJ3pE2SiOrWVEjkCNQ3J TyEOWESAnSqL
nE8lKnPytEJCXQqhCEsJV+HGRt6Z5IjkvUaA1uJQVbZpzu7yGntE1AdQaY9U lIbBkpRnlmZm
io0YKUNyBgdkigklGneLapUsWTgLAQQACROy0zCEoFAllllEsTyABZQaBAEs wIaUpStP2f0c
2hByDd0knPeFQC/5pTOFzYDjBjpT35o0hoda0rX3UomP/wDpYn4X9IncUjDH mZ9Ib1ZYT0qh
eVHYY3phqExlKlHlpaOBqgATAiCFSBOPk92Lb3NjCBIzyRtmzc1mDbCCkdXN KcmVrggVlpwg
CozdG4xHWog1qYlXmpjajJqAAbP6kvv+mT39ky1AtpvFdjuF2Nf275WW05lt NQIbu63c2Zag
W03iux4PcvUCZbuuPPS/aWNR+RaDntC9uszc7aHpOa0nRdPTqNH0jRyM9msn O5krLys2Dkzs
YmEvZlH8wZLs+Lp01uJxX3kZbkmm6h8c07eAdTArCIo9RNc4pzzCznQKghsV t37w3RCYJw/v
B6ppVucLdMzT+Y3NsedKS1scXDILqYjVuM3jqFWoUloVdGhOlMd1PJLGqQQT /bqplCFP7CJT
i+4SoXTGPrX6EtOkqaCRJkTvJEDocs0ckKD+sWoS4h0ZXJveGxVnNGcWtYnc EKjMnGJzswrS
GGpzc0oKNIMzZgsg4swsXIMAqU/Ncdf7sfNOZYVRxqVkJHVO4I3hu0oQwJFK hEFQVVIpMLCY
IsBxCo7NmZsdAKAk1HTN5QqFR5RC4jBjakARq5qY+JHckgugM0atZ442qjzA raB5TERC46iM
JuQE7JLp7rn2lNiKNWWvXFusbfE0hZg+21PtmOBMShRqFhVURVG5rPcKKHEx ELl/dcyM2oOW
DsroRormzxCNNbimzhJ2jrm9lRJFZGeTmGpzc0oKMLzhBphI8nKLMGCtBVnl vrhNY2cUqkz4
pLAWtbF5oEKxoYSELmSY3K1qYJydegGcSScOhlDEoamk5oYcsqENsQi0+a2k Ikkekg35K11T
oMoWilOCJa4IVR5aUFQgAQSAIySw6MFYpAWWbi6zhLHVA4XJuuxvjesUk5fs poo4tq5MjRFm
UKoMRQVCsAlVSicyUSmSpUgDAJc+oDDJxF0zEVGfwWRyTvTe6VfgODi7uC0w adCeoqgohqck
LLz4gjVUOqKhZdSxhxIGmXNfslwWzd1d0yfTW5fnG5S0sSYlRnWxWsJBlnI1 IM0YYE8ObyhF
0CMAhXFljuzUFBZTb0MZKX1XN4qLjziImnVoqoSlgnMmgim9xDU45GUT+F90 38QnOKYdEo4w
3JhpSxWojixU9o2NzaSFp41A0y4tarRhMDnzDFBhSYB9M+acYUqCA0KciRSu 5cgEsfpMcRVP
GW1esOjMWQpw8gEzclNNElCrO/DCpOJAZXkICKqxWcoVHGXzfH5r0FrmMoRO McVaa3KfaKMp
wlR5h2ZRq1ChJklOSIWbXFJja57koCoizaAZnxgdxRmexQ7SY3IAUFkU+/Q7 QF+bpUyqURwa
GFmhAcJKMR1aJ1BKhSnO9mG26gzwsLDmQyUt9SJkB1afdorPbRPiNWKov7Yw kp0ga1/sJiqf
co4XOuc9p5JcJzIqkTURhr7JjiAYcgSVuyiyeU6pH7tlFEElEEiUlgqpGqUK jZnc+GIG8pF7
HbKtAnZeg9nSqpLNGGtwjykhOv8AarfUyidwUpFqlKQmCuakuWcEk8s0UWdr qs7NDIdDF4Xd
LGW90Tu6t6cyxFjLGqPRqVifMVESABozDCBFJKmp06Wpqs5UXZ/Ul9/0ye/s mWoFtN4rsdwu
xr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x/LPd1cebyn5Rm85JmsA2 OWBzRJaYOYlb
KNvkaXlRlhbzNGcys821MbTstCaanHyx+4LgMFPwCG6aszbKmtGhp/LLIUNY ojLljgnoAkgp
0f5e+HKE+lDdS3NzUFuabNO0H+0X+7IcIM9s/wC8Zj7pqx0Z5qvinsDTuUs5 E2tr7NNH/e0q
x2/dUqx0/rZ8+yuV/I+3LY8QHTuT+b7L+2rew+1tG5S9N9m6VoOkJNMzGmJc 9+U46/3Y+acy
7miupP32NGUjiByaoy0RghwydBVluqUmrka4EkVAeBO8KzT81VVnFNSwgMLI KoEWJlqBbTeK
7HcLsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8laNotzN3dEieHxlo5JFVvU6VW qjzyuYXExMU6
z1ucaJ6OLcqASJUhSmGlhCbmqBGHHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEv HZPP/MbWcS8d
k8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbW cS8dk8/8xtZx
Lx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8 xtZxLx2Tz/zG
1nEvHZPP/MbWcS8dk8/8xtZxLw7MquNSCMubO3szocmfTI4dpCF9UPaREelO jchkCevIoj7i
WcWoNTnAyShULGA2gqfkXL1AmW7rj+fyx9O4QwYfxCAQp3cow1lrg/y3Q+Lt akmIvDgCoSaG
mP7A7EuCdKlb3Uhe2Jy0VMprk7fME4fxBt01b0zO6KTjPwhFkSyHNyRsa29M DNrCiD7ePq5S
oAqSmOhKdcmOZuSSwKQJSyf768xc1HNGIGc/u+gpEAkdwXLKEMhKpzVvS9DW CUGDy2RKN7EY
3Njunq8kJxK1UeXAUNEoQJQmFF6S5Rd3JQyBtTmVUJRkHL21OWoTrESogRiZ alNN5zwkSW9l
74nKn90826Na2AlIVWXc2XGCzBb1OGdzDmRjEnM0luT8pxRlSc6nqUeZ2Tz/ AMxtZxLx2Tz/
AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/ AMxtZxLx2Tz/
AMxtZxLxNlC6PPEaNBCLbkhQvRzAeqNLC/XTHRWWOOPj+ionGIwZIQmrC1Wc INqNMAqpBp35
92Nf275WW05ltNQIbu63c2ZagW03iux+S46/3Y+acy7rMtQLabxXY/JuXqBM t3XHuRaGRsbO
/oilAVZSN6bUTqlLVALNJApLTriTygKAFHnlBOCChgSzjQUFkmDpXljUgl8S H/LABpfznRrT
If8AZa22LzEqURFlbyahIojLZGBuObU6YtvbT0jYYpRKP/eBLc7rFbv2fkbU Pa+lZf8A9h+z
9G/8S03+r8qTxaXw9OL3gXuzaheGsJJfvWK3J2hDrLWyNN7eCpZyxxlatiQh TjMUkqDk6FzM
RLZLb+TN7g5rZA2Rppe48cxSNC3ula0eV5S/ODWoQ5TCiWFZFSFSgs5chHQg sBlFZJLLcH2f
EJGLTjKO2cCihqwkjJOTl6Y4rzlDO4DTiOLzDgaahUDRZRDoFY5JGcGHHX+7 HzTmXdZlqBbT
eK7HcLsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8lx1/ux805l3WZagW03iux+T cvUCZbuuPdo4
dDoc3ujY0x8ZZ70WvYW10PXK3FSIxrWGujujUKW9tTp0yttLAmzKdQ7uwgnm jUmFkdRv/wBz
Q/1Bglr+w32khxenD+y6yXQtLoyhbkm6Q0u/tRYrbclWDPmIs2paztKcjNAL cl3tIlQoOSKE
Bp83ukcahViSjVIjDbnzAY0ikaFStRCUJxVqScJGsVpamAFVOpPKyDRd0mWo FtN4rsdwuxr+
3fKy2nMtpqBDd3W7mzLUC2m8V2PyXHX+7HzTmXPcGpvemle6NAgBdW1G4o1S 9sEZlULC4IyD
hqEQh1CLIopLLqLJFyfwrhH7bemln9oKQokHtVxRt+nLB/2EiPSzitJUj/2S Ccs0X+AcaY+v
DWypKiyaKnZwSNyeov45OeWGkl5XJ7+TK5cGfZ2SML9macpvsV4b3TNU5eTl M0FQfkU5fdyi
5Pfhe0if2Wjq0o/aLo2VdUNHBtb8kozTl6LP6SjR5B5A9JUFlk5JxQsvkMBy xUq3XsiWyS4T
wYxRI5OtIXstTU6gpGvWCUo1GYU6ErUJ0Yi6KSyilBgxqjKASHEmKJuumUTm qFnJ9oP8XCwJ
UACW8r760aBelb0CxSBGVlmjMNPIMASWI6hKmoMwNhlrcAZSV8QFrAkGVoIx MbyiKVJBjpSg
RjSKizkwhhpQI6lZYaclac+ZagW03iux+TcvUCZbuuPeXHX+7HzTmXdZlqBb TeK7HcLsa/t3
ystpzLaagQ3d1u5sy1AtpvFdj8lx1/ux805lz4xIA/gst22I6NOIv4F/aFto mAjFyf2c6fUl
hTFVryDFVSsFTK5R4jbF/OYbQMv2lc6fxKrJnWqc1tJrWn3c6VT2OuJyvfTQ 1wPu+/lUSu8E
6SO4KtKVGwW8PQuKz2J+EmppZidmULlSkK04CxSWUqbUqc01bUVdI0UoVLLu dpmB6iydwkYG
x4WjaHVhaHtOoXNSSqdtIcc1nqlo1qst1zScovNrUGXQQ60rSdRt0VKy46KJ srlIkCNQYkq9
oEDfFNHaj1BFQHgSDdT29WooSMswYUmSAwsWSYBkM9hMja2QX2guZFa8WUXH KLD6r3JWSvcD
jBpqGn/vB5xh/Jyhp76BDSlHi3Vl2RY8I3Us1lkVwHAo1vi7a3qQ5lwJSHHl 5xWaelGYUIWb
ofUgRg29Gtyyzyo/EUZwlBLG3gS1UiDkVVKRCGoWqs3yizdFKw48+hWULNUM oXliycqvOmWo
FtN4rsfk3L1AmW7rj3lx1/ux805l3WZagW03iux3C7Gv7d8rLacy2moEN3db ubMtQLabxXY/
Jcdf7sfNOZc/T44lUqpVDnlrlUeKQkGKVxqpAooWoITEkBGecPRTjFIE5QRC OUJE4aBysmtJ
LN5c2qWqXXGkzg/OaBcmPSLG5AQoPTtTYanVAAoJAnoJWemAaEIqJFZFKhpy YuHLV9s5FcNq
mqkpYxyCLIPbLozE5Z5g27MBAM5IXknlIlGdMS0qW2Ixk1OJryAtdck+1b6m jUKkwFSSNoaV
d5scUYralq5wcWxEWKiEpUBrKTIkwsoaY4g0S00stUnFiaS9TGpA1sTzbNpC lXubUrTJKLTS
IKaNqEuqXVCJzS1TqilKQlSYYWajVB9+YMrSCR5BDZjLYZRYY+TFvizc6n0d gozyAt7QpXt6
RSFMCuSqNMLH96ucIUl0AcnINCmbGn+jNcttbkRQSUiFExuSZKnKD/ABRJUc CAFP8fdT31rW
teWta1w1vzhH3OLLHACgRzC8lGkubfUlYoTBCqLOISmhqcWSFSXlEF8pJxda ctK0FXnTLUC2
m8V2Pybl6gTLd1x7y46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3N mWoFtN4rsfku
Ov8Adj5pzLusy1AtpvFdj8m5eoEy3dce8uOv92PmnMu6zLUC2m8V2O4XY1/b vlZbTmW01Ahu
7rdzZlqBbTeK7H5Lo0nW2l7p/wB7566J3Brcrd6CsQyCcSF/bjyKOc8bHAGW 3uaaphatAmOK
OzhYi/u5Veyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaz iXjsnn/mNrOJ
eOyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaziXjsnn/m NrOJeOyef+Y2
s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOye f+Y2s4l47J5/
5jaziXiUyNyi7xGES2MQplRFPSuNKFStUyus9XOBhYI3IJAUWnLKkDcEIlR5 BhpgjaAKqEqo
/wAm5eoEy3dce8uOv92PmnMu6zLUC2m8V2O4XY1/bvlZbTmW01Ahu7rdzZlq BbTeK7Hg9y9Q
Jlu6495cdf7sfNOZd1mWoFtN4rsdwuxr+3fKy2nMtpqBDd3W7mzLUC2m8V2P B7l6gTLd1x7y
46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3NmWoFtN4rseD3L1AmW 7rj3lx1/ux80
5l3WZagW03iux3C7Gv7d8rLacy2moEN3dbubMtQLabxXY8HuXqBMt3XHvLs0 O7TNylpU3uQr
rRJbe4TqlMSutwpO6tylM4tUYWtytOrblqVUSclVHFiLOD97Kyg06On+ye6f o3HR0/2T3T9G
46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/wBk 90/RuOjp/snu
ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0biXvSRvkCVsMi EAayVL7GJHGd
IXN71chWtISkyRqalCrRU7q3GHGJyjCQaWUGpmXWoafn3Y1/bvlZbTmW01Ah u7rdzZlqBbTe
K7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY 1/bvlZbTmW01
Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK7H g9y9QJlu64+P
XY1/bvlZbTmW01Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu 7rdzZlqBbTeK
7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzVEjbZhJ4wtWs7UyrSmUmIqEqt KyrXtc3mGAkk
VkBpags2QOIRCSnkFmliKoMqoiqDx2sT/wAutZw0x2sT/wAutZw0x2sT/wAu tZw0x2sT/wAu
tZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAu tZw0x2sT/wAu
tZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0w5MrpdGf qmx4b1jW4ptD
tkTpCFwTmJFZGeT24KUFZ1OaYXnCDSzgZWUWYAdKCp47djX9u+VltOZbTUCG 7ut3+arsa/t3
ystpzLaagQ3d1u/zVdjX9u+VltOZbTUCG7ut3+arsa/t3ystpzLaagQ3d1u/ zVdjX9u+VltO
ZbTUCG7ut3+arsa/t3ystpzLaagQ3d1u/wA1XY1/bvlZbTmW01Ahu7rd/mq7 Gv7d8rLacy2m
oEN3dbv8wNzWrcm9K5vGl+yW5QsTkrnT2eTRQv8AZyQwwKhboScQT1ejFmaM SKhh2QCtK/kn
uj05N7O2Jc3pLi6LE7ehT544tOTn1aswpOVnVBpRBecMDlnGFlh5RjDSt0XR lcm94bFU/R6M
4taxO4IVGZtlbhOdmFaQw1ObmlBRpBmbMFkHFmFi5BgFSn7baagQ3d1u/wAw TN2kDa3vzJ7Q
rCmJG6I07g1mNcZUJzJCf7Nci1Ak7gouCndW11NqWmTuqeExFYSlNLbkDsuy 4fJJBFsn7wGr
S/tFFh5j3tzf9n5F7Q9hx9H99P7HgS+FZbcZoRSxNobQc2fv8dj8sSEfzV0X dzWJ9X53+xoM
PkoDGRLophgCVOm3Orn0adQ5p+RWcRH8dk8/8xtZxLxmEFsZAjVj/lKJRIIU 2sReT98enLY1
Ipo9k5ZYRgTaFGnLOLBJylGhpBnr0uj+xoBH85/4v9pZFMNEyfv9XfsnB/aO fydG60NeiZ7T
v33RvZyvML53H0aQf81RF4Ga2vpeT98GgrZLL5oyE5ZgQAU6bGnLOIxKCk+h qxkL0uadrjT9
2bxfz2/SYtHdIyfvFf1xCopF5MjzR1Czv6tfUOkZvRVmkt5ypGoLUypW8Lm5 SoCjJZ5bN5vL
2x8cDCzTkjUniL+/vSKTvBoiBHs7QS0OTma4JiD2pKJxTpxgIeEsQj9rUhOc AQij0biaG4Jw
TCTES6i+YsZjmkjze6pFS5HocPOpIyUwULsmnTSrVrY+hIa2Vtb2dsS5zRm5 rRp29Cnzxxig
7MJEhZScrOqDTTzM2WHLOMMMFyjGKtf2201Ahu7rd/l9YUyn5iTPfJHomKhZ KgQJG7hGmbl4
khxZ+kN7FymyN+zaReJHHGd4chIVZKI0kTaytZGitjO3o2tuTZw47R0LenLS JCM8oMNUG5pO
UWXnDzTDh5OUYYMdairzlLTCkadeqRqDkjo/u5bmli7OYUYJIdRGoKR5MyeE C0KgtVH2RekS
plDU6tEilETdfZ5K4x5cVih6kqpOIhY7KTFQUpBZxhRqhDHGY5YrRRhnGJMh LGibf3pzLa2p
TJnKQvSOrwdzbaagQ3d1u/y+WQL7zZb9vIcg1L/EJOmUnTOjcWWYoKzdUjhG YjpZh7ScYqAu
Q3Ga3RSjSDQMqtXzUpCo3SHZzzwGKPIxpxvsgUJ81nU7OhOPT6Ro+kEmOC00 xO1sqMYnR9Xt
jSnVLyMuWB9iR8X3fsSiWI3H24jM/GyJy4+z/wD7unVxSNLzGIeYdETzIpxH 3v2ciTIUKZOi
RIk5KRGjSElp0qRKnLCSnTJk5IQFEJyCgAKJJKAEsosIQADQNKU59tNQIbu6 3f5ecnp0P0Vs
Z29Y6OKnNnHaOhb05itWfmU5Zqg3NJyjDM2QUYcPJySyxjrQNUZr0RmJM98s hlgamEqBAkbu
EClxQBVkmH6Q3sXKVHGHOK14kccZ2dtCuVkoijhczMQZJkpBfe+3D+1qBxbI B9/JZWv2mxPc
v08saQxud2sxHDVLcsOdEUsclbb9n3BUcUc4OLm45mro9PC05xdHARGdEWER plaJ29vLUKly
tGwsqZsjjUocXATOztwFh5Y/
Re: graphical read-only view of non-child object in a compartment [message #171561 is a reply to message #171542] Tue, 05 February 2008 12:46 Go to previous messageGo to next message
Hello Julien,
The easiest way is to add "transient volatile readonly derived" reference
into ConcreteThing metaclass returning all "variables" then you can use normal
GMF mappigs to handle this situation.
Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #171582 is a reply to message #171561] Tue, 05 February 2008 13:00 Go to previous messageGo to next message
Hello Alex,
excuse me but you mean, by modifying the metamodel ?
julien
Alex Shatalin wrote:
> Hello Julien,
> reference into ConcreteThing metaclass returning all "variables" then
> you can use normal GMF mappigs to handle this situation.
> Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #171590 is a reply to message #171582] Tue, 05 February 2008 14:00 Go to previous messageGo to next message
Hello again !
sorry but I can not realize this reference because my example is quite
simple but my real problem concerns abstract metaclasses and I can not add
this toplevel reference...
Is there another solution ?
Julien
Re: graphical read-only view of non-child object in a compartment [message #171644 is a reply to message #171561] Wed, 06 February 2008 04:07 Go to previous messageGo to next message
Hello !!
Sorry but I'd like to avoid metamodel modification. Moreover, I do not
want that each type of concreteThing see the variables of each
definition but only the ones of the definition with which it is linked.
Thanks for your help
julien
> Hello Julien,
> Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #171652 is a reply to message #171644] Wed, 06 February 2008 06:49 Go to previous messageGo to next message
Hello Julien,
If you'd like to avoid metamodel modifications then you have to modify GMF-generated
java code. You can try to create child node mapping for "Variable" below
"ConcreteThing" using proper containment reference for "Variable" (from "Definition"
to "Variable"). You should be able to generate code (ignoring validation
errors) and then you'll see compilation errors. You have to correct these
errors.
> linked.
It should not be a problem to iplement corresponding method in java - from
"CocreteThing" instance you can access "Definition" associated with it and
then collect all the "Variables" of this definition. It's really much more
easy to implement corresponding utility methods in EMF-generated code, so
if you have the possibility to modify it I suggest you to follow this way.
Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #171667 is a reply to message #171652] Wed, 06 February 2008 07:14 Go to previous messageGo to next message
Hello Alex !
Thanks for the answer !! i'll try it tonight !
Julien
> Hello Julien,
> GMF-generated java code. You can try to create child node mapping for
> "Variable" below "ConcreteThing" using proper containment reference for
> "Variable" (from "Definition" to "Variable"). You should be able to
> generate code (ignoring validation errors) and then you'll see
> compilation errors. You have to correct these errors.
>> linked.
> from "CocreteThing" instance you can access "Definition" associated with
> it and then collect all the "Variables" of this definition. It's really
> much more easy to implement corresponding utility methods in
> EMF-generated code, so if you have the possibility to modify it I
> Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #175140 is a reply to message #171667] Mon, 03 March 2008 08:43 Go to previous messageGo to next message
Hello again newsgroup list,
>> Hello Julien,
>> for "Variable" (from "Definition" to "Variable"). You should be able
>> to generate code (ignoring validation errors) and then you'll see
>>> linked.
>> with it and then collect all the "Variables" of this definition. It's
>> really much more easy to implement corresponding utility methods in
I realized it like you suggested; by hacking directly the generated
code. It works fine.
Howeveer, I am not able to realize link between the objects contained in
my object and an other object in the model. (a link like in the
previously sent picture). When I try to do one, a stackOverflow exeption
is catched. Should I modify another place in the code ?
Is there another issue ?
thanks,
Julien
>> Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #175416 is a reply to message #175140] Tue, 04 March 2008 05:45 Go to previous messageGo to next message
Hello Julien,
> exeption
Can you post it here?
Alex Shatalin
Re: graphical read-only view of non-child object in a compartment [message #175782 is a reply to message #175416] Wed, 05 March 2008 08:33 Go to previous messageGo to next message
--------------000907050808070707080402
Content-Type: text/plain; charset=UTF-8; format=flowed
Hello Alex,
> Hello Julien,
>> exeption
here it is
any idea ?
> Alex Shatalin
Content-Type: image/jpeg;
name="pbes_GMF.jpg"
Content-Disposition: inline;
filename="pbes_GMF.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQH/wgAR
CASsA2sDASIAAhEBAxEB/8QAHgABAQADAQEBAQEBAAAAAAAAAAgHCQoGBQQC AwH/xAAUAQEA
AAAAAAAAAAAAAAAAAAAA/9oADAMBAAIQAxAAAAHf4AAAAAAAAAAAAAAAAAAA AAAAAAACQPfq
AJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/UAJ/5Yux3kCOv0AAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QAAAAAAAAAAAAAAAAAAAAAAAAAAA5Auv3kCOv0AAAAAAAAAAAAAAAA AAAAAAAAAAE/
0BP9AAAAAAAAAAAAAAAAAAAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAA AAAAAAAAT/QE
/wBAAAAAAAAAAAAAAAAAAAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAA AAAAAAAT/QE/
0AAAAAAAADB5nBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBP4oBL9QAAA AAAADkC6/eQI
6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT/QE/0AAAAAAAAJ/oCfygAAAAAAAAAA T/QE/wBAAAAA
AAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT/QE/wBAAAAAAAACf6An 8oAAAHx5Xk+0
yLKh0U7Bi8o2+BU5B+97UptrAAAJ/oCf6AAAAAAAAHIF1+8gR1+gAAAAAAAA AAAAAAAAAAAA
AAAAAAn+gJ/oAAAAAAAAT/QE/lAAAAjGftp40s5L2tiL/v1iNd+xAAAAJ/oC f6AAAAAAAAHI
F1+8gR1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAASfWE/hQAn9Q An9QAn9QAn9Q
An9QAn9QAn9QAn9QAn9QAiC35/oAAAAAAAAcgXX7yBHX6AAAAAAAAAAAAAAA AAAAAAAAAAAC
f6An+gAAAAAAABP9AT+UAAAAAAAAAACf6An+gAAAAAAAByBdfvIEdfoAAAAA AAAAAAAAAAAA
AAAAAAAAAJ/oCf6AAAAAAAAE/wBAT+UAAAAAAAAAACf6An+gAAAAAAAByBdf vIEdfoAAAAAA
AAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAE/0BP5QAAAAAAAAAAJ/oCf6AAA AAAAAHIF1+8g
R1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAAT/QE/lAAAAAAAAAA An+gJ/oAAAAA
AAAcgXX7yBHX6AAAAAAAAAAAAAAAAAAAAAAAAAACf6An+gAAAAAAABP9AS+V An8UAn8UAn8U
An8UAn8UAl/0BQCfxQCfxQCfxQCfwoCMLPAAAAAAAHIF1+8gR1+gAAAAAAAA AAAAAAAAAAAA
AAAAAAn+gJ/oAAAAAAAAAAAAAaId72HzmC63dcGx8AAAAAAAAAAAAcgXX7yB HX6AAAAAAAAA
AAAAAAAAAAAAAAAAACf6An+gAAAAAAAAAAAAAT+fPpDD+QD0AAAAAAAAAAAA HIF1+8gR1+gA
AAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAAAAAAE/igAYPzgPn/Qn+gA AAAAAAAAAABy
BdfvIEdfoAAAAAAAAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAAAABP4oAAAE /wBAAn+gAAAA
AAAAAAByBdfvIEdfoAAAAAAAAAAAAAAAAAAAAAAAAAAJ/oCf6AAAAAAAAAAH z2Hz59AAAAAB
8/D+cPPnoGH8wAAAAAAAAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT /QE/0AAAAAAA
AAPnsPjOAAAAAAAeP8/lDH5kBj/IAAAAAAAAA5Auv3kCOv0AAAAAAAAAAAAA AAAAAAAAAAAA
AE/0BP8AQAAAAAAAA+ew+M4AAAAAAAABi/0HsMPmYHn/AEAAAAAAAA5Auv3k COv0AAAAAAAA
AAAAAAAAAAAAAAAAAAE/0BP9AAAAAAAD5+P+aE6Ps4akNt4AAAAAAAAABg/M GtDUgdVyf6AA
AAAAAHIF1+8gR1+gAAAAAAAAAAAAAAAAAAAAAAAAAAn+gJ/oAAAAAAAcSXbb pBKP2X/P+gAA
AAAAAAAAQhyo9zujE3ffQAAAAAAByBdfvIEdfoAAAAAAAAAAAAAAAAAAAAAA AAAAJ/oCf6AA
EQW/P4UAJ/UAJ/UAJ/UAJ/8An0gJ/UAJ/UAJ/UAJ/UAJ/UAJfqCf6AJv+goA n9QAn9QAn9QA
n9QAn/59ICf1ACf1ACf1ACf1ACf8QW/P5QAAHIF1+8gR1+gAAAAAAAAAAAAA AAAAAAAAAAAA
An+gJ/oAAT/QE/lAAAAIh/0LaaxPsGyNp+tEzTkfTFudAAAJ/oCf6AJ/oCf6 AAABNhSbD8dm
yRqk9IbN5jn79JX+VdMW50AAT/QE/lAAAcgXX7yBHX6AAAAAAAAAAAAAAAAA AAAAAAAAACf6
An+gABP9AT+UAAADVH6atMmGsHCtufyYQ25zvRBqU21zvRAAABP9AT/QBP8A QE/0AAAPkfXH
ODs9yVnAiTWVtJ/soOINkOuUuLP0D3wAAJ/oCfygAAOQLr95Ajr9AAAAAAAA AAAAAAAAAAAA
AAAAAABP9AT/AEAAJ/oCEC70/igE/igE/igE/igE/igE/igE/igE/igE/igE /hQEn1gT/QEv
+gKAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAn9hAu8ADkC6/eQI6/QAA AAAAAAAAAAAA
AAAAAAAAAAAAT/QE/wBAACf6An8oAAAAAAAAAAE/0BP9AE/0BP8AQAAAAAAA AAAn+gJ/KAAA
5Auv3kCOv0AAAAAAAAAAAAAAAAAAAAAAAAAAE/0BP9AACf6An8oAAAAAAAAA AE/0BP8AQBP9
AT/QAAAAAAAAAAn+gJ/KAAA5Auv3kCOv0AAAAAAAAAAAAAAAAAAAAAAAAAAE /wBAT/QAAn+g
J/KAAAAAAAAAABP9AT/QBP8AQE/0AAAAAAAAAAJ/oCfygAAOQLr95Ajr9AAA AAAAAAAAAAAA
AAAAAAAAAAABP9AT/QAAn+gJ/KAAAAAAAAAABP8AQE/0AT/QE/0AAAAAAAAA AJ/oCfygAAOQ
Lr95Ajr9AAAAAAAAAAAAAAAAAAAAAAAAAABP9AT/AEAAJ/oCfygAAAAAAAAA AT/QE/0AT/QE
/wBAAAAAAAAAACf6An8oAADkC6/eQI6/QAAAAAAAAAAAAAAAAAAAAAAAAAAT /QE/0AAJPrAT
+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAT+oAYPzgGH/P0AJ/UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/8fWAAAcgXX7yBHX6AAAAAAAAAAAAAAAAAAAAAAAAAACf6 An+gAAAAAAAA
AAAAAAAAAAAAAAAAYfMIZPzB6An9QAk/EFH0AAAAAAAAAAAAAAAAAAAAAAAA AAAAT/QE/wBA
AAAAAAAAAAAAAAAAAAAAAAACf6An8oACf/YegPYAAAAAAAAAAAAAAAAAAAAA AAAAAAAn+gJ/
oAAAAAAAAAAAAAAAAAAAAAAAAT/QE/lAef8AQT+egzAAAAAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QAAAAAAAAAAAAAAAAAAAAAAAB4/wA/4/IB4/MHj8gAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAE/0BL/oCgE/igE/igE/igE/igE/igE/igE/igE/igE/igE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/igE/igE/igE/j5/oMIW+AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAEn+wKAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+ KAT+KAT+KAT+
KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+ KAT+KAT+KAT+
KAT+KAYfzAAT/QE/0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAT/
AEBP9AAE/wBAT/QAAJAK/T+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+K AT+KAT+KAT+K
AT+KAT+KAT+KAT+KAT+KAT+KAQhd4AAAAAAAAAAAAAAAAAAAAAAAAAAAAABP 9AT/AEAAT/QE
/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBAT/QAAAAAAAAAAAAAAAAAAAAA AAAAAAAAABP9
AT/QABP9AT/QAAn+gJ/KAAAAa989FHIkwAbWmB88AAAABMtNAgcvhpOysbWz DpmJ5X1QAAAB
P9AT/QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABP8AQE/0AAT/AEBP9AACf6An 8oAAAwwa/vne
H8aZx25aZqdKB1r5E8KZNlvLvqD9HjPV4qK518bGMFH8f5SRmA8pRPlZrK32 56Nd5RqUB+X5
mxzTaZi9dhbbWazPtxdsKM2W/AF/gAE/0BP9AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAE/wBA
T/QABP8AQE/0AAJ/oCfygAAPNelH5PP+rHz8X5gDHORh8r43rh5H8vuB8H5/ rh5T/nrB4X9/
qx5P1geReuH4fG5AHhPW/uESwhvJE9UKAAE/0BP9AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAE
/wBAT/QABP8AQE/0AAJ/oCQCv0/igE/igE/igE/igE/igE/igE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/igE/igE/hQEIXeAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAT/QE/0AAT
/QE/0AAJ/oCfygAAAAAAAAAAAAAAAAAAAT/QE/0AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAT/
AEBP9AAE/wBAT/QAAn+gJ/KAAAAAAAAAAAAAAAAAAABP9AT/AEAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAT/QE/0AAT/QE/0AAJ/oCfygAAAAAAAAAAAAAAAAAAAT/QE/0AAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAT/QE/wBAAE/0BP8AQAAn+gJ/KAAAAPHnsE/igE/igE/i gE/igE/igE/i
gE/igE/igE/igE/igE/0AAAAAT/QE/0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAT/AEBP9AAE
/wBAT/QAAn+gJ/KAAAAn+gJ/KAAAAAAAAAABP9AT/QAAAABP9AT/AEAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAT/QE/0AAT/QE/0AAJ/oCfygAAAJ/oCfygAAAEJZYKVa18Zm 3Rp6q0zFnbni
6HQAACf6An/Xgbj3NDd5tvAABP8AQE/0AAAAAAAAAAAACXyoE/igE/igE/ig E/igE/igE/ig
E/igE/igE/igE/igGD84AAAAAAAE/wBAT/QABP8AQE/0AAJ/oCfygAAAJ/oC fygAAAeB5+ek
TCBIU97dMGGk7pejayzUptrxJlsAAAn/ACBj+gDmBs/deJ/UAPH+wxf48oBP 4UBN9IAAAAAA
AAAAACf6An8oAAAAAAAAAAE/0BP9AAAAAAAAE/0BP9AAE/0BP9AACf6An8oA AACf6A8eewT+
KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+FAT/AEAAAAARBl9QBP8A9DOH zz6CfxQCf8gG
QAAAAAAAAJ/oCfzO0UZMhY2Q4d027ZCxpg1LbQj7nj9fuxUhnbfqo+ObLM6a H6JLukLBeTz1
/wAHbdqMPJbDtZnpCtbs1Kbayf6An+gAAAAAAACf6An+gACf6An+gABP9AT+ UAAAAAAAAAAA
AAAAAAAACf6An+gAABj/ACAJ/UAJ/wAwegw+ZgT+KAT/AEAAAAAJ/oCfzGmH tlg0Kbi8wDVN
5/byNXeS75Gu/wCRsnGoGs7LGu/29sjVdkHYgNM/qdt41Kba9cWx0n+gJ/oA AAAAAAAn+gJ/
oAAn+gJ/oAAT/QE/lAAAAAm/6CgCf1ACf1ACf1ACf1ACf1ACf1ACf1ACf1AC f1ACf/QZgn8o
AAAAE/0BP9AAAAAAACf6AE/qAGL8oePxeUAn8UA1wYfNv8QW/P4UAJ/UAJ/U AJ/UAJ/UAJ/U
AJ/UAJ/UAJ/UAJ/UAJPrCf6AAAAAAAAJ/oCf6AAJ/oCf6AAE/wBAT+UAAAAC f6An+gAAAeSP
WvJf2eqeC/3PbIDwGbeGLMpgACf6An8oAAAAE/0BP9AAAAAAAAAAAGkHWB1+ jQDtupCfygAA
AAAAAAAAT/QE/wBAAAAAAAAE/wBAT/QABP8AQE/0AAJ/oCfygAAAAT/QE/0A AANUe1yCjEXm
M6y2TVmD+6FLSg3+f0GxLLuMcnAACf6An8oAAAAE/wBAT/QAAAAAAAAAAAAn +gJ/KAAAAAAA
AAABP9AT/QAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAABP8AQEge/KAT+KAT +KAT+KAT+KAT
+KAT+KAT+KAT+KAT+KAn988pAAAAE/0BP9AAAAAAAAAAAACf6An8oAAAAAAA AAAE/wBAT/QA
AAAAAABP9AT/AEAAT/QE/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBAT/QA AAAAAAAAAAAn
+gJ/KAAAAAAAAAABP9AT/QAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAA AAAAAAAAAAAB
P9AT/QAAAAAAAAAAAAn+gIwLPT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+KAT+K AT+FAS/UAAAA
AAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAAAAAAAAAAAAABP9AT/QAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAABP9AT/AEAAT/QE/wBAACf6An8oAAAAAAAAAAAAAAAAAAAE/wBA T/QAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABP9AT/QABP9AT/QAAn+gJ/KAAAAAAAAAAAAAAAA AAABP9AT/QAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAABP8AQE/0AAT/AEBP9AADB+cBP6gBP6gB P6gBP6gBP6gB
P6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBP6gBL9QA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAABP9AT/QABP9AT/QAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAABP8AQE/0AAT/AEBP9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAE/0BP9AAE/0BP9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAE/0BP8AQABP9AT/AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAef
9BL/AKAoBP4oBP4oBP4oDz83+QPf1B5/0ABP9AT/AEAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAMP5gn8zB6AABj8yBg/5+cDH+UAAAn+gJ/oAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAA8/j/z9AABi/wAeMgZAAAAAE/0BP9AAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAwefPoD5+LzKGD/oZwPH+wAAAAACf6A5 UfYHT85gR0/O
YEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85g R0/OYEdPzmBH
T85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdPzmBHT85gR0/OYEdP zmBHT85gR0/O
T85gR0/OYEdPzmBHT9L+iHdeZPzB6AAAAAAAAf/EADIQAAAEAwcEAwABBAID AAAAAAAFBgcE
FzcIFRYgNkBQAxAYMAECYCYUJCU4EyMnSJD/2gAIAQEAAQUC5aLSaWVDpyna wSnawSnawSna
wSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSna wSnawSnawSna
wSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawSnawWjy krI3n5Yuqny1
qOuvLF1U+WtR115Yuqny1qOuvLF1U+WtR115Yuqny1qOuvLF1U+WtR115Yuq ny1qOuvLF1U+
WtR115YuqnsFGoz+AP7xdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XT F4umLxdMXi6Y
vF0xeLpi8XTF4umLxdMXi6YMVUviP67C1HXXli6qewMap7Ry9O7C1HXXli6q ewMap7Ry9O7C
1HXXli6qewMap5o8wgSqCJn8aA/OLGv3+nTaT7Wh2X+po76/KUO3FkP7o3rp F+H4V3UKs7l6
d2FqOuvLF1U9gY1TzWovt1zkzP2kb82R5QfmBJZM+ilRH0SjddFTwtl+zP8A X4+GQtkU5zuX
p3YWo668sXVT2BjVPM9rW9dzk59etabVRcgGAUEew3QNbVvQKfoglEVsmxqa O0e1dpZCqpwE
VncvTuwtR115YuqnsDGqe0cvTuwtR115YuqnsFZ1j/oOTeLpi8XTF4umLxdM Xi6YvF0xeLpi
8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTC2jV91SzYWo 668sXVT2BjVP
aOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVP aOXp3YWo668s
XVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668s XVT2BjVPaOXp
3YWo668sXVT2BjVPaOXp3YWo668sXVT2BjVPaOXp3YWo668sXVT2CqMfqRr6 ZadEy06Jlp0T
LTomWnRMtOiZadEy06Jlp0TLToK3hRB5AzLTomWnRMtOiZadEy06Jlp0TLTo mWnRMtOhWq2A
UsBsLUddeWLqp7q166SyJRZudJZIpZbq1HXXli6qe6XSFTjipyzm1CcQCf3V qOuvLF1U921k
XCxab3VqOuvLF1U91r8KErjulHFZpAnUDubUddeWLqp7nX/c9hIohioSLhY+ F3FqOuvLF1U9
xr/KbfwTc2o668sXVT2+v8+gNxajrryxdVPba/8ASU/wTb2o668sXVT2kXFw sBC6/wDVFwkL
HwpFFxRDFbW1HXXli6qezi4uFgIWEhIpVxXrNCuBOoFPGkd0o7aWo668sXVT 2UXFwsBCwkJF
KuK9p0Swp5CkB1FRUVs7UddeWLqp7GLi4WAhYSEilXFe89Ir0BEe3ps7Udde WLqp7CLi4WAh
YSEilXFbE/JYqKiiU6hTyF2NqOuvLF1U/fFxcLAQsJCRSritmoSuO6UcVmkC dQOwtR115Yuq
n7ouLhYCFhISKVcVtT2EiiGKhIuFj4X32o668sXVT9q1jT8sSJta6ck56lnZ 8XCd8/2tox3V
80IKbXTkk3UaxQqNWN97rUddeWLqp+53kh00I5dlNB9RHNdtbSaQ6avZ9AI6 OcBZQkJCwEL7
rUddeWLqp+61M1Ecs1xCQkLAQu2s6M71Eg8HvtR115Yuqnkb1Elh4gZaJ0S0 TolonRLROiWi
dEtE6JaJ0S0TolonR1mpSUR1JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRL ROhKl31I18HA
6HzHx8tE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonR0WpSUP1JaJ0S0Tol onRLROiWidEt
E6JaJ0S0TolonQ4SJLCNA5bUddeWLqp5GnpZtC6qYWWoto7FLMtqOuvLF1U8 jT0s9hQrU8fG
+cuqmFlqL2K95WxQcak1ukl1AZnYpZltR115YuqnkaelmZsXJPlMr49yD7rv cYO45qrWKHd5
cfLj9N+3HNVeoU+5ysS1lEtiiZTZy6qYWWoszuKVTI1v04sS09QyOew5iGhh F5acOif6v9FH
DCt057nOKZMsznUSsGn4IoKLWeZ2KWZbUddeWLqp5GnpZmcLqdFt7QFnSD6y g+USq3YfKJLS
jqEdrWz70un8u6LOdRs5dVMLLUWaPgYUzgegpjdONO5Sq+LPzPfKJdGMJET/ AKbNH0+n0Gp+
p84FoEwb9s0i2ZZmdilmW1HXXli6qeRp6WZnKbVPOonU2QFyVIDezchTA+ir NDbfaJRzZkSI
UIRbZkSFOs5dVMLLUWeJZZGxToKxJkK3ISizQgi3qw9mpCwRWWpmCK0l0LH6 Ahemh7PKXQSl
zOxSzLajrryxdVPI09LNoXVTCy1FtHYpZltR115YuqnkbJviGNbaWidEtE6J aJ0S0TolonRL
ROiWidEtE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6EmRw RA5IcYthzgzl
onRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6JaJ0S0TolonRLROiWidEtE6 JaJ0S0TolonR
LROhzW+IYJtstqOuvLF1U8jT0s2hdVMLLUW0dilmW1HXXli6qeRp6WbQuqmF lqLaOxSzLajr
ryxdVPI09LNoXVTCy1FtHYpZltR115Yuqnkaelm0LqphZai2jsUsy2o668sX VTyNPSzaF1Uw
stRbR2KWZbUddeWLqp5GnpZtC6qYWWoto7FLMtqOuvLF1U8jT0s2hdVMLLUW 0dilmW1HXXli
6qeRp6WbQuqmFlqLaOxSzLajrryxdVPI09LNoXVTCy1FtHYpZltR115Yuqnk aelm0LqphZai
2jsUsy2o668sXVTyJ5JuSmiC7nTF3OmLudMXc6Yu50xdzpi7nTF3OmLudMXc 6Yu50xdzpi7n
TF3OmLudMXc6Yu50xdzpi7nTF3OmE4nD+APwrU8aHn2u50xdzpi7nTF3OmLu dMXc6Yu50xdz
pi7nTF3OmLudMXc6Yu50xdzpi7nTF3OmLudMXc6Yu50xdzphQpNyVKQZbUdd eWLqp8tajrry
xdVPkUX11thiabfdITRQnWGIV3HA96CwLSyGs2Nwa9Pli6qfIOAaRxKhykrg SMr7p/8Alhpy
5dVPkF9/d5FB/LDTmC6qfIGv+QcfspjqKLumREsKnyzmC6qfIEX964INDSBJ YFNlcd1OtzJd
VPkG7/uC4dD+aHfNF1U+PUJ1CpogRBLFJpFqiLijWKhISFgIXmi6qfHud/2J FSntwFabIrhg
ebLqp8esYuF+FUQwkUcHPOR/UUBGvsZKIYyUQxkohjJRDGSiGMlEMZKIYyUQ xkohjJRDGSiG
MlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxko hjJRDGSiGMlE
MZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJ RDGSiHUI1MvV
9/8AC1PKxyVKQXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMX i6YvF0xeLpi8
XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6Y vF0xeLpi8XTF
4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0 xeLpi8XTF4um
LxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeL pi8XTF4umLxd
MXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8 XTF4umLxdMXi
6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLphJKE0 PPt3aeln6lG6
i7tPSz9SjdRd2npZ+pRuou7T0syRaTSyodOU7WCU7WCU7WCU7WCU7WCU7WCU 7WCU7WCU7WCU
7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU 7WCU7WCU7WCU
7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WCU7WBzWybaAbbnUbqLu09L MhdVPhnYpZzq
N1F3aelmQuqnwzsUs51G6i7tPSzIXVT4Z2KWc6jdRd2npZkLqp5n8d09bOFa Vd/DkIB03j6S
Dj4xdWpCSGbdwiRzkr6Slzi02dDsrjO0d0FElHctKLM2XrqvG2jXBfxyxLUk R9Y1iCT0uxSz
nUbqLu09LMhdVPMlvr8OVaUYL7/KCcpnfp9VDaABamkY1pOhCZ0X5LWyVq4S bpMVCOc7CaZ0
8W6feBPxS+tDnzbQTrpBbs3Cu876cNTpYu85RcarVnXIQLffeHtQm52sXfcs uNVqzrkCznUa
2bSdXN86v3RiicVUqCyO+SoUxTZ0WiBdTrJCPfRZRDLKtvHYb1FWcDY0PGYy uxSznUbqLu09
LMhdVPK4is6KGRDO2b0Gpm+cJCpqzyvVXFRrCvKbWm2aLShoEktFS3jCO4lE OjEUZfDv2jLG
9OUr/uGxyxIWSikW8MS4rlWN6cxiQatOPYmCWz/GOoQnhQRWvoxINWnHsTBL Z/jHUFnOo1s2
k7lU5/8ARS0H/rA5VOekWmkCxbkP43py21lyhWV2KWc6jdRd2npZkLqp5TYm Jz+C6HQ6ML0T
ghI1FCfMJC/aGhG9QJfGA5R6SUfUgoGCLYYmICJOw/SICLoHB0mU2pPoWlZY TQhMQESdhzci
JFBDFBCRp6HjkumTQyNyIkUEMUEJGnocFxARE8QckBEo4SJhoeNh8Jpa4jBL pk2K4mGh42Hd
LFiEQ6kdlrzhKNQkeuhG6yuxSznUbqLu09LMhdVPhnYpZzqN1F3aelmQuqnw zsUs51G6i7tP
SzJFqUuTrpzLTomWnRMtOiZadEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTo mWnRMtOiZadE
y06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLTomWn RMtOiZadEy06
Jlp0TLTomWnQ5rgkMa23Oo3UXdp6WZC6qfDOxSznUbqLu09LMhdVPhnYpZzq N1F3aelmQuqn
wzsUs51G6i7tPSzIXVT4Z2KWc6jdRd2npZkLqp8M7FLOdRuou7T0syF1U+Gd ilnOo3UXdp6W
ZC6qfDOxSznUbqLu09LMhdVPOdKEgTULNhrBNhrBNhrBNhrBNhrBNhrBNhrB NhrBNhrBNhrB
NhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrBNhrPU7FLOdRuou7T0syF 1U86y1FtHYpZ
6XYpZzqN1F3aelmQuqnnWWoto7FLPS7FLOdRuou7T0syF1U86y1F7HDcRPtm Q53YpZ6XYpZz
qN1F3aelmQuqnnWWos1oNTLREoteOBBJtrvlYO0nGQUkFadSaacR7VV9WDbn rO+eHlphpIFJ
Eud2KWLy1Crm3OTS20vurHWdnxcJ3z/M7FLNwXKpfHn1vF0xeLpi8XTF4umL xdMXi6YvF0xe
Lpi8XTF4umLxdMXi6YvF0xeLpi8XTF4umLxdMXi6YvF0xeLphOKM/jz/AN6N 1F3aelmQuqnn
WWosyqT8Iq00mzUwcQltGrtRo+CdJCt0nW+WXW6XUscfHx8fX4tkU5zuxSxS pVOLIrd6yao0
iLKradT6Np/xuaVDH39ICVQkClhe7sUs3Daad2hdVP3o3UXdp6WZC6qedZai zlLcIoiVakTC
fV5UmmNadI9f4s+tB9SULJCpVwC7O7FLMp0ikioorBhoVi8XHKhMlOQQc2Lh Y9otw2mndoXV
T96N1F3aelmQuqnnWWoto7FLPS7CARv0QOHl3AjEqyLBCOQiYmK2raad6/X6 MN0Yi0iyULGG
C8SBakjh/GiIfgmOilQlh1aAZ1PGblusliRq7OTl9BwUFZrcRFN616NcFGOB CKp7WsRJkQKI
iVRZEvK2cF03Qc5QKs56dklA9XooRQrNqnPK1ERpS1MjXebdwIpRFjfdV+gX VT96N1F3aelm
QuqnnOk8QKWFlO1glO1glO1glO1glO1glO1glO1glO1glO1glO1glO1glO1g lO1glO1glO1g
lO1glO1glO1glO1glO1glO1nqdilnaLhIWPhZbkUGP6NxyYY3ji8ESqTil2T aadd/pJGIbwk
U6RiEkjOp9/vY1ZxvEl0WgbY/M0zZRZZtUWUNaXQfSRaisz/AF+PhkLHqPIY khher0EFaDZF
XEpAimG6RpBOu0CGT6te8n6UKQWvg/H2+se88EkCRXWxLTSfKUXErT/bwF1U /ejdRd2npZkL
qp8M7FLMx6k0sqBgXrFw/qHNKxMUrgQVmxWeQPtbTTr7ttHum38Aa2lTqCI2 ld0lZ9vSuOI0
CzTOnMI0aZh7SzZkyOZNSwaWs9E7gJVG2aUKqm/RRe26g61oRMJ5/mZhmqSz hl8UzqFVSVcJ
4Gi+XE+nTUtrGC6DXNAfFKoPW3eGFtAfKEdx3FktP9vAXVT96N1F3aelmQuq nwzsUs9RogEa
cR2FlYWi/V2ViaKE6PrbTTuyJWqXpi8ILqp+9G6i7tPSzIXVT9HQcCPj/nGS iGMlEMZKIYyU
QxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGM lEE8rfseGnod
ilnulkk4UXU4JMMYHpaCVaJhQRWZEqU6LyzGSiGMlEMZKIYyUQxkohjJRDGS iGMlEMZKIYyU
QxkohjJRDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEEmZRpq5PvRuou7T0syF1U /Q2mndoXVT9D
sUs2J0niBSwsvIGDH/lMvEwOjBB8nkg021TQ2sk4ruzaad2hdVP3o3UXdp6W ZC6qfobTTu0L
qp+h2KWbW1I1LkuQqfFx9Q0JJaoakNT1upEJLaF1U/ejdRd2npZkLqp+htNO 5oM/IjGPNT8i
IgbHhIQQ5KqkupB8qVOfUwdd4/sniRSfe023hGiFXArlJ5i6qfodilm4bTTu 0Lqp+9G6i7tP
SzIXVT9DaadzH/0l7abUPSmNaTc0lZ6DdIzj29hXqNUXDuBat6KCbhLlq2dA 5eKCQSRhUGjs
xdVP0OxSzcNpp3aF1U/ejdRd2npZkLqp+htNO5rRaRNFO39nxNnkGSdKFVzR vG53XdlUqdFF
R/17Tlp77qoyjy19VMTwKNP4xUJrMXVT9DsUs3Daad2hdVP3o3UXdp6WZC6q fobTTu0Lqp+h
2KWbhtNO7Quqn70bqLu09LMhdVP0JwxVCXhMZKIYyUQxkohjJRDGSiGMlEMZ KIYyUQxkohjJ
RDGSiGMlEMZKIYyUQxkohjJRDGSiGMlEMZKIYyUQTHwdx609DsUs3Daad2hd VP3o3UXdp6WZ
C6qfDOxSzcNpp3aF1U/ejdRd2npZkLqp8M7FLNw2mndoXVT96N1F3aelmQuq nwzsUs3Daad2
hdVP3o3UXdp6WZC6qfDOxSzcJJWwCagJlp0TLTomWnRMtOiZadEy06Jlp0TL TomWnRMtOiZa
dEy06Jlp0TLTomWnRMtOiZadEy06Jlp0TLToSpj9Txfe9G6i7tPSzIXVT4Z2 KWc6jdRd2npZ
kLqp8M7FLOdRuou7T0syF1U+GdilnOo3UXdp6WZC6qfDOxSznUbqLu09LMhd VPhnYpZzqN1F
3aelmQuqnwzsUs51G6i7tPSzIbIzrR5/g1RDBqiGDVEMGqIYNUQwaohg1RDB qiGDVEMGqIYN
UQwaohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiG DVEMGqIYNUQw
aohg1RDBqiGDVEMGqIYNUQwaohg1RDBqiBs3JmeFfOo3UXdp6WfqUbqLu09L P1KN1F3aeln6
lG6i7tPSz9SjdRd2npZ+pRuou7T0s/Uo3UXdp6WfqUbqLu09LPz8QbFcJHeg 0NisjgW5Nis8
M+7T0s/PlhSVrg0wHdgvFxyoYyUQxUroof1DpxYuZx4oYHMYgHSRbghhStsS 2OjispKyOB7t
PSz88ujSOLU4UlcCRleaLUxgaRRKmemXRWVp6Wfnup/IHBynqlKyAXOeq0Qk JCwELmaeln50
2NIEjK0KVxxanMmKDRSgiTcCQ+lp6WfnVf8A5g77nSsLyiKwtHKf1tPSz86h /wDMdYRcXCwE
LeyjVYJSIsT8L62npZ+ccCLivgghISFgIU0WMDDx0Ik+oZRXtaeln5yINivq qz/kUawBWVwJ
LA+5PWunJTRB5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0x5qumPN
V0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0x5qumPN
V0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qumPNV0x5qu mPNV0w0KTL/l
I7D/xAAUEQEAAAAAAAAAAAAAAAAAAADA/9oACAEDAQE/AQDv/8QAFBEBAAAA AAAAAAAAAAAA
AAAAwP/aAAgBAgEBPwEA7//EAFwQAAAFAgEHCQUFBAcFBQERAAIDBAUGAQcA EhMUdpe21xEg
NTY3QFCV1hUhlrfVFiIjMIYQJDEzCCUyNEFgtUJDZnfmFyZFUWGTGEZSU1ZX YmNldIOHkKax
tPD/2gAIAQEABj8C8WlH2ljUfkWgwC3ehe3WZudtD0mRXS0jRdPTqNH0jRyM 9msnO5krLys2
Dk7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAf Bsd+nY7NIB8G
x36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7N IB8Gx36djs0g
HwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36d js0gHwbHfp2O
zSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbH fp2OzSAfBsd+
nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAf Bsd+nY7NIB8G
nYmTWytreztiX7PaM3NaNO3oU+eirGoOzCRIWUnKzqg008zNlhyzjDDBcoxi rXxaZagW03iu
x4vOf0zufH/F5lqBbTeK7Hi85/TO58f8XmWoFtN4rseLzn9M7nx/xeZagW03 iux4vOf0zufH
/F5lqBbTeK7Hi85/TO58f8XmWoFtN4rseLzn9M7nx/xeZagW03iux4vOf0zu fH/F5lqBbTeK
7Hi85/TO58f8XmWoFtN4rsdxYo5HGJnd1ruzyN6NNepGtjyVIljy2MIRlljQ xiTGqlCo2TEC
CERCUsotKbWpoxDADHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1 NgG0uRcJ8dTY
BtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8d TYBtLkXCfHU2
AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfH U2AbS5Fwnx1N
gG0uRcJ8N6t6iEQLbFUgjDEpOa5+9OC5P9ppG1RslUQiV23ak6rRVDqUoMJM cUmWSWZQJtB5
NK9wnP6Z3Pj/AIvMtQLabxXY7jDdQLl7xWn7q3a/2n+acN7jOf0zufH/ABeZ agW03iux3GG6
gXL3itP3Vu1/tP8ANOG9xnP6Z3Pj/i8y1AtpvFdjuMN1AuXvFafnqXJzWJm9 vRFCPVrVp5aZ
KmJB/aNPPOEEssFP8RDFSmCmFrnDac5nnUTpyj0zmgIUHiFkFkpl7ghSt6g0 0fIAkBKoYjh1
CAqgxCDSroYYMJZZczeRjGMVAgAALQwiEMYhclAhDSlaiFWvJSnvrj2PWftG l53M5yhLkJsy
+XJ6bChqzZvl/wB9p+Z5Pfl8nvw+PpjzRuUujS5tsTXpiVS2imSLWJzWMICD EJCkBVDjElTi
lp9SkIMigjVIKCBlOytpcVrhOlYkR9wxLRupoizxOMi+z2SatKAiNziDSRmG IDlI6j/vxlDM
0GiVmjkPuPA0h8gRpVUwe29wjJijRzDTgNrQpTDr/f8ARxHiM08BpyBMeVog ijThF89u1/tP
804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+fZu3hik5KxzmbhTvYiR1LEaS kWMSMkqov9rp
s88osfKCqohObyZZIKhVxKkYY0Df7PNToDUrelIUNR4Sa0TuKVWEuigCtOZk niUVNqYfWg6K
hHBNNCN1TIDDiftLdccdWDT8ue0A9gROSkoPJWleRVRrCkNBy0ocSeYQL7ho qVpDP/cw3bEy
URURVAK2pelDrm83VcJbntK9p1F+P7RoZpVFP41DKD9+LlNEraX5pNYmK4ze zJpK2q21x9if
Zca9EbQhcUWZUkBy5WmJMLyiC8wJMSPJT5IYLWlKUqJM8cteT315JG88nL/5 8mIr/wAyWP8A
0KT/AJDdr/af5pw3uM5/TO58f8XmWoFtN4rsdxhuoFy94rT89CW0OAGeVxty Le4w6GZYSilp
XJlJjzCgmGkkqMgkyigoswwhSmTHZBgADKMrDnqNRWJEriKtrzPk7slWnVbz A5lapZ2VG4KD
iXRSny8yI4olOA4zKBRD9wwh/txNklI0/KpWqkDKbVU3uYUigpC1FoVZg2pY sIqSeIhaiUl5
3SQJzTRhBQWZrUMXrDYgoci0/s4FwRyFHotQ0BmQuprTVXpxizJ/HqP2cEoR /wB8TZUPKnrJ
ISe9OU0ljlDZUiG4ujkcec5Pby1LiiUpCt3U/u6Is88lEk0k8koBIKHn5kQz q0iUbkaL2c9N
hDkBcj0hIrzIlD25KyqaQhPUpTMpOoKM/CPHQOVki5BhEGkfaYi1+1nBFN2p 3Up9NbkGbbkz
S+pjlGdc1aMkeQcsTAzRZgjxZzKCXUIBiDz27X+0/wA04b3Gc/pnc+P+LzLU C2m8V2O4w3UC
5e8Vp+6t2v8Aaf5pw3uM5/TO58f8XmWoFtN4rsdxhI442s7qtrCLkBNTvT4t YEoEvt61lRnF
rEMekppigJtCABTCQlFjLMNNqrAIkBJ/U2AbS5Fwnx1NgG0uRcJ8dTYBtLkX CfHU2AbS5Fwn
x1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5F wnx1NgG0uRcJ
8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uR cJ8dTYBtLkXC
fHU2AbS5Fwnx1NgG0uRcJ8M5b1Gog3tgp/azSVbXOHp4XFclzYjUnMNyu3rG nUZaihRZmcdE
uaJGYeHPDLCnN7hOf0zufH/F5lqBbTeK7HcYbqBcveK0/dW7X+0/zThvcZz+ mdz4/wCLzLUC
2m8V2O4w3UC5e8Vp+6t2v9p/mnDe4zn9M7nx/wAXmWoFtN4rsdxhuoFy94rT 91btf7T/ADTh
vcZz+mdz4/4vMtQLabxXY7jDdQLl7xWn7q3a/wBp/mnDe4zn9M7nx/xeZagW 03iux3GG6gXL
3itP3Vu1/tP804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+6t2v9p/mnDe4z n9M7nx/xeZag
W03iux3GG6gXL3itP3Vu1/tP804b3Gc/pnc+P+LzLUC2m8V2O4w3UC5e8Vp+ 6t2v9p/mnDe4
zn9M7nx/xeZagW03iux3GG6gXL3itP3Vu1/tP804b3Gc/pnc+P8Ai8y1Atpv FdjuMN1AuXvF
afurdr/af5pw3uM5/TO58f8AF5lqBbTeK7HcYg9K2+QKmwuIT9rOUsUYkcm0 dc4PVt1aIhUT
G2p1UJdKTtTiYSYoKLJHohoaGZdKBr0dP9k90/RuOjp/snun6Nx0dP8AZPdP 0bjo6f7J7p+j
cdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7 p+jcEOjLWXvD
YqzmjOLXbO5TghUZk4xOdmFaSJGpzc0oKNIMzZgsg4swsXIMAqU6On+ye6fo 3HR0/wBk90/R
uOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k9 0/RuOjp/snun
6Nw0tDQ0zc1abN7bq6UV23uE1JS0rVcKMOripUuLrGETckTpG5EqVHHKlRJY SyRfeyskNe4T
n9M7nx/xeZagW03iux3tPb1rbXBij763iOcZLWoKfahPXkArYmo9OaZorelz hZcgKPqQ6Ls+
SlMSp4+oobJEEaZG1wlTJKnAslfE0dQVUaRUFAjfWcSg0lIhcEKQnOuBqs9K 1rGtKIDyqRlo
0Tu0d6nP6Z3Pj/i8y1AtpvFdjvayLyhHpTeq5DCTi6hLXNi4sIwpnRrUiAZo rglzg82ZkGEn
EmHolpCpvVK0h7m4pg+0ZMqkEvjzjIFBQSzjEMWl7xHk6VuT5RvstvV+xSXN WlCoUnKFxlNL
WqiULYWi71Of0zufH/F5lqBbTeK7HfHESVSnUh+29xVeUnOLOpor3OpBI2ZT yliFTR3ePvDQ
+th38tezOrc5pRGolyY83vU5/TO58f8AF5lqBbTeK7He/wDgDf8A/wCgN/8A UDr+glDARnnZ
u/d3duJMJTHSyOUJXf1FVQqMA3hcG1wWUfI2pcM0ElcStY6O0eaZZIXOhDk2 n6QkUZygRVLO
TnFHJzjEytIrSKSyVaFwQqyT0Ti3LSE65uXJ1CFcnTq05xIO8zn9M7nx/wAX mWoFtN4rsd6/
4A3/AP8AoDf/AFA6/wD7DZYwplCgRyhBSWMaQkw+j02UMSoVD+mSJwmKqyeN NQdKJE2plrhK
WZsDETW9xWhiKyNplyFSnWolqclWjWJDi1CVWlUFhOTqUygkQyj055QwGknF DEWaWIIwCqGt
K95nP6Z3Pj/i8y1AtpvFdjvP/AG//wD0Bv8A6gdf+Y5SdL1S/fHiXNNP/B/5 ix0mLCX/AO2c
JbHyqf1x+8yNiL+1vtVtnfeJz+mdz4/4vMtQLabxXY7x/wAAb/8A/QG/+oHX /nf8Abgf9Abg
agdQO7zn9M7nx/xeZagW03iux3f/AIA3/wD+gN/9QOv/AOQ2xhV1S/c2eIu1 f/B/5aNrhz8Z
/wCxb4lIDa/1x+7Rx9M+1vspynfdpz+mdz4/4vMtQLabxXY7qpXLlKdEiRJz laxYrOLTpUiV
OWI5QpUqDhAKITkFAGaccaMJZRYRDGKgaVrj/gDf/wD6A3/1A6//AJKlCuTJ 1qJanOSLEask
tQlVpVBYiVCZSnOCMo9OeUMZRxJoBFmliEAYahrWmCom/KVCgRyhfWJvis4w +j02UMVLk7Ap
VqBGKqyeNNQdFOC5KVrhKWZsFLinBxWhlyON91nP6Z3Pj/i8y1AtpvFdjuil cuUp0SJEnOVr
Fis4tOlSJU5YjlClSoOEAohOQUAZpxxowllFhEMYqBpWuEzw8JlCJgRKCVsd jq0kxOqWqk5g
Tkcnk6M4IDSFBBoC1UYjCosJjEYEiQSAikvo1tcE/LPbXIjSEijN1EGhhyc4 o5OcWpSK0itM
YSrQuCFWSQtbnFEenXNy5OnXIVCdWnJOAvi7+fnnZu/eGhxOLJTHSyOUJQ/1 7ROlLA3hcG1w
WVY5Imb80ElcSifKtMeaZZHmyndJz+mdz4/4vMtQLabxXY7mpXLlKdEiRJzl axYrOLTpUiVO
WI5QpUqDhAKITkFAGaccaMJZRYRDGKgaVrhM8PCZQiYESglbHY6tJMTqlqpO YE5HJ5OjOCA0
hQQaAtVGIwqLCYxGBIkEgIpL6NbXBPzSyDzFCVSlUBXNbohEWU5szmUWaUS5 NpxpR5QFACjz
0x5CkhS3uTepWtDuicGZwcG9U4MD0WnKkjGnb1K+qEJlGxybHUxwIaX5tCYa oNRJ3M1odCT2
ZaoOcGZwb1qSqh1a/ZEjfO5zn9M7nx/xeZagW03iux3JSuXKU6JEiTnK1ixW cWnSpEqcsRyh
SpUHCAUQnIKAM0440YSyiwiGMVA0rXCZ4eEyhEwIlBK2Ox1aSYnVLVScwJyO TydGcEBpCgg0
BaqMRhUWExiMCRIJARSX0a2uCfnpVqJV7LkDXnhMzyEnSNH0jNaW3uCTOp/a kfdNHTgeGcah
PpGjo16BY1yBrZHtrVIlqX2XIGvMheWYR2kaPpGd0Rwb1eaT+1I+6aOoGzvA E6fSNHWIF6Nr
kDW9sjX3Kc/pnc+P+LzLUC2m8V2O4qVy5SnRIkSc5WsWKzi06VIlTliOUKVK g4QCiE5BQBmn
HGjCWUWEQxioGla4TPDwmUImBEoJWx2OrSTE6paqTmBORyeTozggNIUEGgLV RiMKiwmMRgSJ
BICKS+jW1wTuLe/spicqSMadwTIKLhGUbHJsdTG892YXIRZSg1EnczWhrOIe USc5wZnBvRK6
J3Vr9rxx8MPILUJVKVQJC6Na4JZTmzOZRZRpza5ElGnlAUAKPIUkHpj1Le5N 6lE7tC1wZnBv
cFXcZz+mdz4/4vMtQLabxXY7gpXLlKdEiRJzlaxYrOLTpUiVOWI5QpUqDhAK ITkFAGaccaMJ
ZRYRDGKgaVrhM8PCZQiYESglbHY6tJMTqlqpOYE5HJ5OjOCA0hQQaAtVGIwq LCYxGBIkEgIp
L6NbXBO5oJQwEZ52bv3d3biTCUx0sjlCV39RVUKjAN4XBtcFlHyNqXDNBJXE rWOjtHmmWSFz
oQ5Np+kJFGcoEVSzk5xRyc4xMrSK0ikslWhcEKsk9E4ty0hOublydQhXJ06t OcSDuE5/TO58
f8XmWoFtN4rsfnqVy5SnRIkSc5WsWKzi06VIlTliOUKVKg4QCiE5BQBmnHGj CWUWEQxioGla
4TPDwmUImBEoJWx2OrSTE6paqTmBORyeTozggNIUEGgLVRiMKiwmMRgSJBIC KS+jW1wTupss
YUyhQI5QgpLGNISYfR6bKGJUKh/TJE4TFVZPGmoOlEibUy1wlLM2BiJre4rQ xFZG0y5CpTrU
S1OSrRrEhxahKrSqCwnJ1KZQSIZR6c8oYDSTihiLNLEEYBVDWle4Tn9M7nx/ xeZagW03iux+
dI3OLEJ1cgbGdc4tSFS2rXctxVICRKwtgW9uXNy09Q5hJEgSaMqzhKpQSfo6 2hVUZ7OJYyQj
NM7wS9ARgbX7Ql6pIlWEoS3RObJTQqk7etUp31AGmaMSP7QzOZJoTUAKCkCd +ZYwkj7EzlHH
LmVOvSqgPK9aWBrSGAcH5wEanUokr2cIRCPkLMRlUNUk1NKKU91jLjGm2PuT I96eiWmPDK9K
PZzojzJ6YAnRA/IEn9apDz6o0BqQCinsdwUAUKyxDLQvAkbJCM08PBz0NGNt ftCQKlaVGSuL
a05UlKClTuC1MofV4a50xW/u7y5nGiNXjoGLyaWIG9te31vq6GpGvKohohWK TzmU8gJi5yMB
pjIJuWGFmrBnFHHmFnFpzAiTE/nTn9M7nx/xeZagW03iux+fMYsnAnKRN7wY c1kJj1SktMzO
pRTuypBHraaUaoSNS9GmViOEdXSijuRSqDyKTUjmuJTgdZsoDJjBhTpaKi2Y 9MSVH0Zy5Oeo
EtT1RBG9pizREVbzH5WkGjJVAVDO7rKQZCeq2OJ/te3HKT1RJaYxgAaochho loOh6g+PjeUK
QhSUYlEqVkjMqnEACxNHoe3DzSh8cAJzFOSSPQUJQBq3RxzJ6lGBT7NbE6tf olFJRyzR9FT1
qoNLDVMhQpk6JEiTkpEaNISWnSpEqcsJKdMmTkhAUQnIKAAokkoASyiwhAAN A0pT8+c/pnc+
P+LzLUC2m8V2Pz7VOLYFw/7xuBNvnZYQUS4EtBOlnPCBwLaSxJ3BRo7eolbm 6H6RoJKFmL0g
5t95ylMhQpk6JEiTkpEaNISWnSpEqcsJKdMmTkhAUQnIKAAokkoASyiwhAAN A0pTu90Vi5Go
oihCgyORg1zRpVxigt/HRzROqd6T5CMh4IiYG+jimRpy1QUsszKsDaEYkSn8 +c/pnc+P+LzL
UC2m8V2ObB3p0eJ+qc3iIRp0cVP/AGp3NJ0hc4MqJWrPzKeXFJys6oNMMzZB RZIMrJLLAClA
06Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/wBr F0/WWOkZ/tYu
n6yx0jP9rF0/WWOkZ/tYun6ywkOUKJueagUCVoTTrpXPNMRKhpVKEalIMcwq JOoEiWrEYjia
gMqlVqU9RZo80AukZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/ tYun6yx0jP8A
axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1liXsqRwkCpsLi EAdCUz7J5HJt
HXOD1chItPSnSR1dVCXSk7U3FnFpzSyR6IUKpeXSoq4ty0DWvCJE7zdUkcqM r48x5UrSp7ez
11KTGOLCubnGieji3IVQiQKglmmJSs6EYaZOOkZ/tYun6yx0jP8AaxdP1ljp Gf7WLp+ssdIz
/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ss dIz/AGsXT9ZY
VnJ1E3INXqAq1xpN0rnlGLVQEqZCBSrGCYUEoUBRIkaMJx1RmUSpEyegs0QU APSM/wBrF0/W
WOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF 0/WWOkZ/tYun
6yx0jP8AaxdP1licPTW8T9K5s8Qkro3Kf+1O5p2jrm9lWq0h+ZUS41ObmlBR ZmbPKMJHk5Jh
YwVqGvNnP6Z3Pj/i8y1AtpvFdjm201Ahu7rd3WZagW03iux+y0+v7j8rLl91 uXqBMt3XHnTn
9M7nx/xeZagW03iuxzbaagQ3d1u/NkTE0uQFrpE1CNJIEwCFYKN6leUYemJ0 g0gtKpGIBJuc
0M5Ro4wCKUZo2mR+RMtQLabxXY/ZafX9x+Vly/zfZkplyBucckAhoCiV7otI CZSgi6qkrQkX
nJc4CtBg0kBWWXWgw8oK0rgblEn5A+JCh0LPEkGKhyUwVK1ABWkPCUrSDGGl RACpIKEMNKiD
StPfz7l6gTLd1x505/TO58f8XmWoFtN4rsc22moEN3dbufcqESxI0onqEPBY EHsohYmA5R9X
U7QlxhS1e4DqdUsCZQaMsworNuCYISqVoIVWm18eSNJ7UkjhshmrgrIWHLm8 A8uiFIhESvTJ
yTTRmNmWJSmVUqW4hGAP4QgilEUtDDmFamhi2rY9yOYK1RKAbkA04gxMkSIl KI+tAnpVRYBg
OVVMCTnjAJgGE5wu1d0oo1MkiXtRrwzOUdVmnta9MQBSaL8BQoWGgLMLQr8g +qvLCekGnNSh
ywmUuLAorDWmRSdhkqptjRZYVSBvSsTcrXpnB4lK5W7UTmDAIDYnTEJTWrST 1R2R7wlEDjRa
CbkW2kdW4gyW0a2BG/kHOChEm0pG3GrXDOoE6JbpWYUJ1hxxpYgcqgWRlivu zrXI54WNMwRt
it3UUGE90UoF8rSnuJwTDlJgTVphQlJgRqDx0EZWgjja/frz5lqBbTeK7H7L T6/uPysuXz3+
UxNK1rnRiJKXmJHdOrUpTW4s8sLkPIRLm84JiVIIxZQefyMhOYGoBZVKhapy MwtO2rY6S/qx
cvKBEXRFpTgWOvv/ALiMB5JvvryCJF764kN3po0IkzYncFv2ca2QhUSqWtoF pDS30VnLFy4I
1ap4NGjMUElkpyiyRKqECDXICTKmi3UBJZlqQLmgZFzi4mSNQ3nF59PyGBdU aSh55FQjLLOT
Jzq5VKCTAHXN4fbsMLQjSPTIcS3qGl0qeubQONHRpSn8g0pzcpUJjETmWpIr QxOMs0dCzM5Q
oVTYy5t8LbEduT27JfpKtNMTrV70UzmiVijbea50UFNBMjCFtLOUJHTPJgGm 0UhMoPMP73cJ
vZHqeyR9cHFwdhUA7ZCNRmxlpkx6tOERATDxKj1ASgBqbUwsBojAEEBLWILe FEJmYcNUDnyJ
qCEDUkdaaRXIzBHIlIOoq9giMAWENS1qlaGtAmjUh59y9QJlu6486c/pnc+P +LzLUC2m8V2O
bbTUCG7ut3PgVwTTAo2GdtSyESdSKuQSWsT0LMa1Kkyv3Q50fsoOUL3BTtR9 fu/4z28DgUIK
u40mVeyM7T8QiLshxqJtJDWvvD+JQxKZSnuGBtSj9/uoGTO0fmrbbeJMr8pY UaJFHED/ACFX
o5RR+eXGO4s2kqYSoJrQ9PQIc9Q4gCf93EeZC29VNHScuZcRcxOri7GI6noF o2qVCo0lJkJZ
ZDenKR6IuCi5KioYvNUVF+8UpT+ksdUNM6CZIigD5PvBLNd5kIwNK/8AkMRJ VRU/xqWH/wAv
2f0lP+ZJ/wDrsy/ImWoFtN4rsfstPr+4/Ky5fPWtq0qh6JwSKEKskX9k5KrJ GQeUL/0MKMEG
v/pXEysEUaI2Yl3HDbpjKrXJMPYZQuOV6XQP9rRVlE7oUMdKZBZLsk5aUyqU w2fZ1AQuPai2
eKs4VYR6JRTVKblOK8BIyzDMoCNSoMAA0sR6w0NBGhoMQsDdp7fhS0N1UFVr oREmJgZETckq
TnVGYkhpY1gyiy+XIXDKLrycgw0/hWtzdbKf/wB6EYttQAQlg+wcTNFye6mW cwoTjh1/9RmD
GYKv+IhVrXDumhb4OA2na3A9oPlCINRyeXHp+TSqNA8oFW5uEEQMg8BhIwgN DU4SwYlDakMb
Ys31JEqEAxyc1ZmlOzseDKyTl60QQ1Hk5Y6lkEgJSEiMNESnLqaZUXOuXqBM t3XHnTn9M7nx
/wAXmWoFtN4rsc22moEN3dbufSNSQbgQjLXpnMhU1mpiF6ZWmCcUEZJqtGuI pQwhQeQbQSYf
KWaLJqEWSKjPG2kAwNrI3JW1HQyoRHCJSlBKoaeMACwmKDq0qcoMoWDOHjMM yaZXJhxkLU7T
WHKng4Sh2TQ+Q+yEDgcYMRhojyBolYwBNMGYMRSY4gkIhjqUWXlVxH17P9oo s5x4Rgy3WOPN
Uro6DPMEaeY8OCxOvVKzjqmHAMPLMTn1IPGloZRKEokqcyVqVuyhdcB0Jdnk pwPRmpEyghQ6
qQAbAJkCQ4kmo3dTQQVR6weSAilDKVCOpmJu+tKt2UK589ifngtxPRmp0ywa tyWVLbQJkCQw
lNnHVRSgFRyw3IATTPZQRiM58y1AtpvFdj9lp9f3H5WXL/IT3aN9p/aROWXS iSh6P2KaoJbh
tZK85LVBVYJaSlqXQsdF4SgmJ05uZywcol0bkqEDg0rwhocTUQyhgMKHQwlQ nPKEE0hQQYEI
yjSxUrStMkWUWIYBJQr3abyhoQmFmIozJpJVdGk4ia5RFKNSZGhLOKJrSmSn UjPTipTJNKMB
WoazJiQu8yRMc1CXRazEvKOrY2CKc0LoE9nSntRwCVOW3J0mkLdPO0DKT0HT 7owoIalULvZz
dHEsZTqxGE+0tCSNgGslQI4KcCfTswWEypgUgSc/96iegPw8UJSzG56Yqla1 oURIGUkula++
taALjIQ8tf8AGvJ78IZQ2ymfOaxABWAtG+PbesbDaLEZ6IdT05DKjNHUss8R hOSoBknBAKuV
SlQ151y9QJlu6486c/pnc+P+LzLUC2m8V2ObbTUCG7ut3dZlqBbTeK7H7LT6 /uPysuX3W5eo
Ey3dcedOf0zufH/F5lqBbTeK7HNt8sOXzcBquERRSaBJc25KBKEw9hQGjCmQ oZWnRIk9BCrQ
lIjTkJU5eSSnJKKAAFOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WW OkZ/tYun6yx0
jP8AaxdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp +ssdIz/axdP1
ljpGf7WLp+ssdIz/AGsXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2 sXT9ZY6Rn+1i
6frLHSM/2sXT9ZYmyNCc8HlGQi26kQ3qQv8AJVVDBv10yqhLXSNydVpSfJJB UKQpQBKAyppw
CQmnnjMxa5uVmOBSdRP1mcMa3Z0Y1wc1bK454cw6Mqxvc0vKMsNDNGVlZ4mp ic7LTmmlj6Rn
+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/2sXT9ZY6Rn+1i6frLHSM/wBrF0/W WOkZ/tYun6yx
0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun6yx0jP9rF0/WWOkZ/tYun 6yx0jP8AaxdP
1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/axdP1ljpGf7WLp+ssdIz/a xdP1li4KwlfN
xmpIRK1JQFdzbkr0ojCGFeaAKlCulahEtT1EGlDkixOelUF5RKgk0oYwV5s5 /TO58f8AF5lq
BbTeK7HNtpqBDd3W7usy1AtpvFdj9lp9f3H5WXL7rcvUCZbuuPOnP6Z3Pj/i 8y1AtpvFdjm2
01Ahu7rd3WZagW03iux+y0+v7j8rLl91uXqBMt3XHnTn9M7nx/xeZagW03iu xzbaagQ3d1u7
rMtQLabxXY/ZafX9x+Vly+63L1AmW7rjzpz+mdz4/wCLzLUC2m8V2ObbTUCG 7ut3dZlqBbTe
K7H7LT6/uPysuX3W5eoEy3dcedOf0zufH/F5lqBbTeK7HNtpqBDd3W7usy1A tpvFdj9lp9f3
H5WXL7rcvUCZbuuPOnP6Z3Pj/i8y1AtpvFdjm201Ahu7rd3WZagW03iux+y0 +v7j8rLl91uX
qBMt3XHnTn9M7nx/xeZagW03iuxzbaagQ3d1u7rMtQLabxXY/ZafX9x+Vly+ 63L1AmW7rjzp
z+mdz4/4vMtQLabxXY5ttNQIbu63d1mWoFtN4rsfstPr+4/Ky5fdbl6gTLd1 x505/TO58f8A
F5lqBbTeK7HNtpqBDd3W7usy1AtpvFdj9lp9f3H5WXL7rcvUCZbuuPOnP6Z3 Pj/i8y1AtpvF
djm201Ahu7rd3WZagW03iux+y0+v7j8rLl91uXqBMt3XHnTn9M7nx/xeZagW 03iuxzWOOIZt
CDUTAztrKjNV23fhqjErUiJQpzFIybpkFDUDKIAI4RRBJYjKiqAosPICnXKA bNJFxYx1ygGz
SRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1yg GzSRcWMdcoBs
0kXFjHXKAbNJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMdco Bs0kXFjHXKAb
NJFxYx1ygGzSRcWMdcoBs0kXFjHXKAbNJFxYx1ygGzSRcWMPsjkb6zu613Z4 4ylFMscWx5Kk
Sx5bJ1wDDALpPJjVShUbJjwiEE9KWUWlKpQoYhjH+yNK2V2b2dzjMgMfUxzo zKH1Coz0ckMb
OSnokj3H1FOVPIDVBZxbiHIOTl0EUaAYqU65QDZpIuLGOuUA2aSLixjrlANm ki4sY65QDZpI
uLGOuUA2aSLixjrlANmki4sY65QDZpIuLGOuUA2aSLixjrlANmki4sY65QDZ pIuLGOuUA2aS
LixjrlANmki4sY65QDZpIuLGOuUA2aSLixjrlANmki4sY65QDZpIuLGOuUA2 aSLixjrlANmk
i4sY65QDZpIuLGOuUA2aSLixh8ji6bQgpE/s7kyrDUlt34CotK6ojkKgxMM6 6Z5QFACjxiJE
aQcWEygajKMDygrzZz+mdz4/4vMtQLabxXY8XnP6Z3Pj/i8y1AtpvFdjxJom SNcolyWXpxy5
REnhahRqo83yZQdJkbTD3ujaATkoZ0Tj9nym2WLEzY7GEtqlE+QJqQnNSvJd JQ3xlR/ECCa0
UwV0NJ/gFWQ0zEhjc1DeMdDCSnEhIYhNUEKkxagShIpLK/ql8+1WT/P+wzY8 T7QeX+V7U+xT
e/eydJ5DNC9paLp2jq9Dz+hqsz/VNuvZ2a/n/bmXM7Lnsv8Aley/sUTcrSc3 kGab7S9i5nLS
aH7RzqrQTXOQ3BUJQkKECFuS27hzG0KnVze3BK0Nrar+3iy4KU1QudVbcgbD y1UZb0JixSe+
rTEWQqaxOU6ZFEjlC9QrVOLkpmE3XmALOVHDbWgLiqeyFTmnjrVVDHkjqqTJ FTmlayV6lGjP
UDSleLTLUC2m8V2PEZY5NJ+jvaePulI+KhZKg42RqEhiaOpEiQ8s4tc4Lns5 Aibm6pCgTiuU
J0JadQYoASNtZWsjRWxnb0bW3Js4cdo6FvTlpEhGeUGGqDc0nKLLzh5phw8n KMMGOtRV/bWZ
n/iMiXPIoOjN/EBTR1Dq3uk5IEDkSHfaxIaWnjSsurjmoaWBza3RKXOn9nJ8 XmWoFtN4rseI
wpg/l/aCfxz97/taJ9j9MuX/ACPu5/2j9h/Yv84nRPantH950LQFf7aQwj8R kS5lbOFhX4gK
aOoanBrgx4R8iQ77WJDTFElSGUcc1DSxtjo1pS50wPBPjEy1AtpvFdjxGIIK /vCRij8qlB5R
fv8AZj6eazRqNLlgyuQwjT2R1uEibUyodEbnmHZQWnUK2IB7f+xG3MxadVJX pQWmaUZ4TDiy
EoVSMl5ka5OUamENnjCJX7SWgMXNZbmq9mxlM6o3qQs9DimxIYoPDRQvXKVS sRYlS9zd3BU7
u7kpzBSdKWocnVcsXnEIUqNvTmKBEN6JEiLISleMTLUC2m8V2PEbgOhX3U7e 3wqFHAM9xwnR
nTPcxUnlhDlAq3jbLiMpBBojAKBLkroWYlLTkpFK3B7k5H6OkT5ughULOUHG nKDi0yRIkSJi
zla5wXKziETc3IiFC5xXKE6FCnUK1BJIzpNIyMiQrtNTpEgzCTgxqOGrqnNz EmCnMUJE7goS
J21ZMVKRY4hdZGSIsp2XR5liqZr8ZmWoFtN4rseIyN2N+84O0/n3tA/+zpH2 dlLlCmf8IPIS
VocZi7E2/gll6RoOmKs84KVipRgtf/aiMZcHRGQlP/syCZMruWiG7GJaZAy2 +EubU5oWstxz
wHSRmGSFO2pKReISF28amWoFtN4rseIPkjXFqDUTAzuT0sKSBLGqMStSI5co LTAONIKGoGUQ
MJITTySxGVDQZpYeUdIjHFxic1awRhgZVhqQRg0pipqakiFQYmGcUQaNOM0g YiRGkEmCLqGo
yixcoKfYZoUqEK14Z1qt5fURxhaqLsAzAN2kojEws6kk70acqIhxyqqdEWY0 yB+ynMUWMjzu
mQoUydEiRJyUiNGkJLTpUiVOWElOmTJyQgKITkFAAUSSUAJZRYQgAGgaUp43 MtQLabxXY8QN
QD96R9kEKi7qV/DSmKWTaPRqQIcunIYRp7I6r0WkpxkrEuf0hEoTqyiTyzVR CX2m7KMtHHmI
B2jqJA+jTnnIWdObmlGj6Ro5hq1wMJGjZWtOvfXQSdpbF6og4o5V7Rc3FwWv D06VJzAnB0cT
qmGiCWI1UoLb29PRMysKNWucVDVHGxnZxOCwDcWePxuZagW03iux4hb8lSpT oCmJRLbgOS9e
cWlb07BH4o4RRxqYqGLJKUFrbgtCylT6FIgtiN2UHrCTU6ZOtUTJ0TKElKJ1 LRDUKokxCtRR
hfRmVuSx3bzA0Up3iRvLSSr0VwHpDWwN0eSmtUekBssRqfHHt6SQyQSZseIh DmslSxLYgTo6
5iep4rWkKiZJKY+opyp5A3GEmJylBI8o0NTADKqGvZPP/MbWcS8dk8/8xtZx Lx2Tz/zG1nEv
HZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG 1nEvHZPP/MbW
cS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP /MbWcS8dk8/8
xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8d k8/8xtZxLx2T
z/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZx Lx2Tz/zG1nEv
xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLwjcpFG3CMQRkiDk0jaXZdHj HSWOkiemlY4t
rkXHXuTJDogSkjLQYsRjWM6hzUGGNLiW9xte7tov/wBC1jkaGEwgpE/s7a9I yldyH4CotK6o
iVyctSAm1h5QFACjwBOCUecWEygqANMDyDr1NgG0uRcJ8dTYBtLkXCfHU2Ab S5Fwnx1NgG0u
RcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG 0uRcJ8dTYBtL
kXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYB tLkXCfHU2AbS
5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2A bS5Fwnx1NgG0
uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1Ng G0uRcJ8dTYBt
LkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTY BtLkXCfHU2Ab
S5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2 AbS5Fwnx1NgG
0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1N gG0uRcJ8dTYB
tLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dT YBtLkXCfHU2A
bS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU 2AbS5Fwnx1Ng
G0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1 NgG0uRcJ8dTY
gG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx 1NgG0uRcJ8dT
YBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5Fwnx1NgG0uRcJ8 dTYBtLkXCfHU
2AbS5Fwnx1NgG0uRcJ8dTYBtLkXCfHU2AbS5FwnxJUj00t7O5xmQFsSklreV D6hUZ6OR6SEq
iFqtkj6inKnkBScwkxuDkHJzKhNNAMNafttpqBDd3W7/ADVdjX9u+VltOZbT UCG7ut3+arsa
/t3ystpzLaagQ3d1u/zVdjX9u+VltOZbTUCG7ut3NlH2ljUfkWgwC3ehe3WZ udtD0mRXS0jR
dPTqNH0jRyM9msnO5krLys2Dk7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NI B8Gx36djs0gH
wbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36dj s0gHwbHfp2Oz
SAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHf p2OzSAfBsd+n
Y7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfB sd+nY7NIB8Gx
36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NI B8Gx36djs0gH
wbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36dj s0gHwbHfp2Lg
rkNvoQiWooRK1aNYkijCnVJFSdhXnJ1KZQSgAaQoINAA0k4oYTCjAhGAVBUp Xx67Gv7d8rLa
cy2moEN3dbubMtQLabxXY8HuXqBMt3XHx67Gv7d8rLacy2moEN3dbubMtQLa bxXY8HuXqBMt
3XHx67Gv7d8rLacy2moEN3dbubMtQLabxXY8HuXqBMt3XHx67Gv7d8rLacy2 moEN3dbubMtQ
LabxXY58YQRBsbnqVSVwVBTt7inWKyfZjcmy1p1CEC5vPz+fPR0JGI/NZoKu tQCqDlBH5aMC
clavTmEuqZLQYSEzqiOMSLiySzTTziiBnFVUJizjjjKJTiMo0ytcsTRFI+xK plP5DTLaY0iM
zeaT8pgaL3E8IDREp+Uo4QAUB98tMpNOOSJyhKKDenW10Kc2pOCqlY1MTmoE /FJgUyjAhHR7
cC1BwQ+7kQoFo6194CB0wilTHnCyTxmJVqE/JqpbHJPkaShUVB90QgUMLOKM DyUOTHEH5IM5
kB/JlFrim1aU5RZoRu6lyMGRVCpKWJ2VQAogARZ+hgAvRIRVMBQPKSZyfxDy /scyoVHbarYu
Awn2SpeznULoaXVKRU+qsKd9SE0FRXVQEGQnL/BCXy0rXlFWXMrJGLVjXQl3 EyPtFFH1OWWu
CpXpahTGCk9aKC862qfxA8lOSgK/7eKSmVskFJlhs1TsydGhLdljLVgUM5yo CgYQvtFVHLT0
ikvl02hFE1Afu2WLOfsdlsAaUL5LSdB9ktbkIIESrOOSMpfnhCcWmlMy2DWK C+VwT/ilAp+L
/JMZz31MSiez2tvOeEaevKnSOpiQobgmIrQ9VSpJCuppRVaKVHKANPxzv5gv ybl6gTLd1x8e
uxr+3fKy2nMtpqBDd3W7mzLUC2m8V2OfLpQOmkMNqGoMSaK195Qn1ZpSdwMp Sv4YxFDHICTK
hyhZNG8Qq0/Dpi7Fmj65tIldKy6LFC9wfZa2icJgAVr7hio3qmL7pf8AvE6y uT90eTfuTONM
64x9a3RlsqZ96qZvqe4IhZilf5eUTHEvKIHJWueN9/4xmViUuzI1+x24ftGU vwCVS5SA01Kl
NUq1JRK1WeUmrUgqtM0lonI5AgDkUCAGSouC9XMk0CYHFcuJi0dhagbfQtEi UmJanrFZJqca
ugVRRyeukhOOUGEmm5xMRUlOF0stcF8rK6DaPb0PlB5NCXBYiDSohpVvvEM6 tSy1lcs8w88h
S3qS9JUpzk9SJCkcrmS5kj7XK19Ku6B1VKpU5rT0LbktJLyvOPPamZmJKArC mSV5Fal5Ny6A
zNBVndnJPKV0zbWNiJkTQ8u9RGupZZg2KoSDVJgzVBucTvxYVATzzggUIs4l zRZ4wiljs3T5
9gFuI48nMDETEzKonZ6UpghMNWq3Eowo4OUnNSKhliEcQAKspMQSERR6o93h crcnObwcTUFz
js3cSgacmWUNLCNmcVGdMOPMECqitRHmKK8qdOaUIotWNOS8Nv8A2nSOMsLJ Jl9VEiLXOTpJ
3dcoIR1KZk681xTqW9paExYVNSyVlAGnunJVOdT7yeWQmPThXb+E28qlQPTo zDCRIH19UZ4B
hBCyppJqQhMclWkVzJuSDRs4oKUCWEURw2Kvc5W3EgtwlRzQgWPhoVMgYXwO ZAnAYtzpxykl
ScpSFfiHZoZZp4i0xBqTKVzNl+3M/PrFWiOvonZRIamPMloUVDVvsaUrdGp7 VYzNL0Q1BUBO
UiTJSM5+FlVl0Ljs3V2+hNvRJkDy5sowESB8fVFTwGJ06zOkmpE6U1KtI/BN yAaLQw8pQJYR
RHDYq9zlbcSC3CVHNCBY+GhUyBhfA5kCcBi3OnHKSVJylIV+IdmhlmniLTEG pMpXj+kp/wAy
T/8AXZlhu12aP9Kf8O9w1t35Y0y9AyLJOONsygSCHIQokZjmOPlNpJoaqKpy S6oqOKwR9Tzg
59SQblD5TZ97TVtUoPSthJrszKDmpZn0NwUcfUKiDkAyBpRuCdMYJSWmqUVy KjiAgCQLN4tw
9tUifWx6XfYbTXdvd3BE6LNLia5Qq0penUFqlGkqAhPUZ00WeOCE0zKHSlcP NxlF25UyStAz
LJP9lmZQJFEG4lEkG5CjwUJRgKrTE6cuqL2mtztVSgOeUJxBGLFsFjRotblX Qcz4u3KxElUI
JUN70oYlbwFNUAk2knnBQZJVSdEIOcBnUJqUnCnHIZc13jlcndULA5Hv7U9H KBNZyISI6jir
j9dMGpYV7QWIbm2qEo6GVNRgBXIAMRdYa6PTk4PDmq+0OkuLosUOC5RmZU+J yc+rVmGqDc0n
KKILzhgsgksssPIAAaU5ty9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK 7HOk8rOqDlZm
lSoTBH/ZOcB00dsTV/8ARS4nJU//AOJ/jhilE/Z1jrJZMFQ/KFInh3R10RxU GHN34aJamKEI
9FUlaMwRecEYqHSohBCHFq7hw5Ee1Rw17UMErLNXr1xYSXArN1Oy16hSPlE1 mOhwSssJdDm0
gylKD5R0dbkHNyxwtpchOlIkSpuKqoEwvZebyFRoA/xoM4JiorLGCikpycCk +cUpSizDXUiW
FO5tCamJmpuROFXJWbk8oE+ZUJCApBDr7qjXjTFF/wC2Pl5KVug7zM9xRuN3 gv1GtrclKswt
laHJE6EIxEJVFeVAQce7qBFEFkl5TemQG5OSIsIA22uI4FwyUQlc6olCR6Aa mCqTKHFU5FnE
H0AIgYwCWDIzdB5R5RZKpPniT6DwdciPkqRQqCRgyNo3s5OamJd3A8LgHNpw nAAZWvK9uB+S
INDC0qZKYpAQJYQXWVf8yXz/AEKMYuX/AMtkH/8AEAxNLTXFWhjStFJ1b0xu jkA0pueWtYnS
pCziVdACKDQZbcUqJGdUFDaKTCKV0hKaSF2ZIckRuNuo+zBG5SwSZeAxVITT OQpA2nDNJIEn
qWPl/ERCGOiJWcA3MGpBDlX/ADJfP9CjGLjtt8WgdG6WuhsohMiUrn9vashx WLVzkkGeyrUt
Mqpq4tPU1UERaU5tMAIwqioip0VZLVW/+06hrPBIHaYJZZMS2mJGNZxattUU AqWLErycNUSA
NCB1LRjOGmT1MUZasCa5QHlwTNlX2NRtpZ9MMoRRyc1TfBS0yFJUfJQ5SoGW YAkoNcowZYwh
5ahrTFx22+LQOjdLXQ2UQmRKVz+3tWQ4rFq5ySDPZVqWmVU1cWnqaqCItKc2 mAEYVRURU6Ks
lqrf/adQ1ngkDtMEssmJbTEjGs4tW2qKAVLFiV5OGqJAGhA6loxnDTJ6mKMt WBNj+kp/zJP/
ANdmWG7XZo/0p/xP9SZV/oS/H/8Av/nhxa7/APL3cxwxP9SZV/oS/H9Hm5re hPc01spZJHV4
SJg5RtGtTO1Ko1TWn+BJZjKUmNN/3OmAOHklAMMBI0cReQyN9kkZeEDeyIEy sTinAsa1IV61
yTjID7PTs6CqlesGrqWDISioCo+WmIN+pt8JBzrl6gTLd1x8euxr+3fKy2nM tpqBDd3W7mzL
UC2m8V2OcNtfWptem40RYzUDshSuKIwZQ6GFDGlWFHEDEWOlBliECtQDpQQe StMEpkxJSdMn
KLITpyCwlEkElBoWUSSUXQICyiwBCAssAaBAGlAhpSlMez5AzNT6gzoD9CeG 5I5pM+XQVCzt
GWknE50FBjoAzIyw0GKlK0yq40ISZPVHmdH0SpJdU2j0Dm6EZjJzWZoD7may cjJ+7ycmAuCC
DxBE4BHnArkkaZUywJnLy5YVJKIB1B8vvyqD5eX9hZ0hi0dfjiaZJRryyNro YUGleXJLGtTH
iBTl9/IGtKcuCkTcjSoEZAckhIiTlJUxIf45JRBAQFFh5ffyADSmDUcfZWli SHqRrD0rM3I2
xOcsNAUUYqNIREkFmKTCyCSxnjDU0QCigCFUJYaUUyIhlaSZAtTURrHwpuRl vCtGHR8lKpcw
E0Wnpg6Il5CDThFU0ZPyB/BLySypFH2R+KJrWpJb01IHQBVa/wAalgXEHhBW vJTlyaU5eTBa
BobkLUhK5c0ibUidCkL5f45tOmLKJBy/45IKcuDUcfZWliSHqRrD0rM3I2xO csNAUUYqNIRE
kFmKTCyCSxnjDU0QCigCFUJYaU0J+Zmp7R0Fl6I7t6RyTZf8MrMLCjisrk92 Vk8uKo2BlaWN
IIWXVK0NyNtT1H/DKqQiJJLqLk92Vk8uETy5R1icHdtGUY3Oq5pQK3JAYQZn iBolx6cxSlGS
d+KUIg0FSzPvg5Be/GhPzM1PaOgsvRHdvSOSbL/hlZhYUcVlcnuysnlxVGwM rSxpBCy6pWhu
Rtqeo/4ZVSERJJdRcnuysnl/Y5LGllaWtW8qarHhU3NyNEodVlRnG1VOR6Yk sxcpqYoUGVPV
CNNyzzh5WUaOtQoJCytL8hAcBSFE8tyN0SBUFhMABQFOuJPJocABpoAG0Blh CYYGguQYuVQj
WJyVaRWSamVJVJQD06lOeARR6dQQaERZxJxYhFmlGBEAwAhAGGoa1pj7L/Zq P/Zn/wCTvsZu
9hf3z2j0Ro/s/pD9+/u/98/ef5338JWR1jrE5sqHR9CaHBob1rWj0QkSdLoq BQnMSp9GTiEQ
nzRQcySIRReSCtaYUI1iclWkVkmplSVSUA9OpTngEUenUEGhEWcScWIRZpRg RAMAIQBhqGta
YQqLSR9rolYnQs92ibYypKFKo6eNQc6FtbelJoAtQJUbnz6JU9TRgPVqckZg a0HIo/aSBnju
FNWhXHj21ngxbS5oqPBVUi4bytSpCwj0Yk04fKSoVl6SEsRoyiaDPLiUUV1B Va1NYaL82Kgy
wuKw45wcCyx09xhZa1WeWAyn8wIaD5KZXJzrl6gTLd1x8euxr+3fKy2nMtpq BDd3W7mzLUC2
m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8e uxr+3fKy2nMt
pqBDd3W7myjT08gUaZALd5r2FE5TKMnR5FdLL0r7NMztoOVngZnTdH0nkN0f O6Ofm+jp/snu
n6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP9k90/RuOjp/ snun6Nx0dP8A
ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcd HT/ZPdP0bjo6
f7J7p+jcdHT/AGT3T9G46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/2T3T9 G46On+ye6fo3
HR0/2T3T9G46On+ye6fo3HR0/wBk90/RuOjp/snun6Nx0dP9k90/RuOjp/sn un6Nx0dP9k90
/RuOjp/snun6Nx0dP9k90/RuOjp/snun6Nx0dP8AZPdP0bjo6f7J7p+jcdHT /ZPdP0bjo6f7
J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0bi4KMlBNwGq4RK0xQ1dsrkoE oTD2FeUASlcu
iidEiT0EKlTlaxQQlTl5Ryg4ooAx08duxr+3fKy2nMtpqBDd3W7mzLUC2m8V 2PB7l6gTLd1x
8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqB Dd3W7mzLUC2m
8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8eu xr+3fKy2nMtp
qBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2 PB7l6gTLd1x8
euxr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x8euxr+3fKy2nMtpqBD d3W7mzLUC2m8
V2PyC10jfGdgRGqApClj05ImpKYqGWacBMWoXHEFDUDKIPNCSEdTBFkmjoHJ LHWnaXAPjKO/
UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAP jKO/UcdpcA+M
o79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/Ucdp cA+Mo79Rx2lw
D4yjv1HHaXAPjKO/UcdpcA+Mo79Rx2lwD4yjv1HHaXAPjKO/UcdpcA+Mo79R x2lwD4yjv1H8
q5eoEy3dcfHrsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl91uXqBM t3XH8q5eoEy3
dcfHrsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl91uXqBMt3XH8q5 eoEy3dcfHrsa
/t3ystpzLaagQ3d1u5sy1AtpvFdj8i0+v7j8rLl/mhkEi0sxOc4I2xKkbgJj V6xWsHWgQJil
SpESPMlANVH1EoBkJyTBBoMeQWPn3L1AmW7rj+VcvUCZbuuPj12Nf275WW05 ltNQIbu63c2Z
agW03iux+RafX9x+Vly+ekmMNcNGowvzYbIkVUTerLcmFUdRKaQIS1GqNTfv hiMvPoxJzgEn
njzlKgBULzcFCcAZNI4W5MZoqBqBQrdySgMPKGuVQQDli1Hl0+9+HUVeStKY jT97IXz+5Ui0
MWZJZAZpsA8hUuCZQ4tzAkRBLStbcBOlPqLMcrkcDSFFAVycOk0VXLiTj7Db FL25xn7MtxSL
REBAla1OmcgthK1QMsgszN0EamEfUOSE8IxBriEXNjigMcd35+b0bkEhIhcS qFFgfk7mQnKd
ky0sJJ6tqocnFWmklFZBdVFa5wQz5dMVTM0Ql4aDDI/BkxJZjy1iUKERzWse HCqChtVvs0Km
ixMW5jICeqD+5kDLzZDFMazCdyd0WzVA0UKlj4Q7pEaNcid3E0KEFG9OcnyD W1OWUGiipQSc
oNShCyBg59y9QJlu644OZpVZhQiFRQoJQuQZicJmey09CBjVsriOGFFL0+aV pDDQhyVSKqgt
M5JkS2hqUs8xlikQb2wWb0ZI6BenhcVyEl0Oz7ikdGNOoy1FDTC821pc0SMs gWeGWJQbIE78
yxhJH2JnKOOXMqdelVAeV60sDWkMA4PzgI1OpRJXs4QiEfIWYjKoapJqaUUp 51y9QJlu6495
cFbLEIgY2JZBJ2JMc6T96b1yj7MyN1jZyo9Ektu6p0ulKGo1QWSW4q8gkwug jajyqU6mwDaX
IuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwD aXIuE+OpsA2l
yLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA 2lyLhPjqbANp
ci4T46mwDaXIuE+OpsA2lyLhPjqbANpci4T46mwDaXIuE+OpsA2lyLhPh9jk jYmdoWtDPHHo
o1lka2QpVaWQrZOhAWYNdGIyalUJTYyeIQQkKizS1RVaGgEAYO4XY1/bvlZb TmW01Ahu7rdz
ZlqBbTeK7H5Fp9f3H5WXL577Gl391fGpc2Gi5MqpWlpxlAPBT/4xOYIJ5Vf4 hMLCKnvpi1f9
H1xCZp0bmz0RPSq5X4cdhJgjkqU0XJyZg8lWoayK/wCCxrTcoeUQaVgzLHXc uKETCSAZXaXC
IKNDHm4IkYDDAZ6mZI/CVGqhG/cNAnbz6EGEirnS5C5Se6kymDsewuNI+mfp 6c4EOL+aiNo0
CRMjeIkJ6cpwEnUZuoVCUggFTFQhEAMrW2wSzSzBEy6oDQgGEQih6bN65BlK VrUAuStK5IuS
vJXlxSlKclKU5KUp/ClKfwpTEV/5ksf+hSf8i5eoEy3dccGssoZW98bDcuuj LyAm5g4ac9Jp
aI73KG9wLTqlBadxQmp1yXOjEmUFDrlYOerfe0JfHA6CXVpzYlsyRnH5RKgz Q25ASneG8CgJ
JmfbyilycC3JPaxI21W8D+1qaQPEbeZU8LxluUcVpTzD480miaU7W6s0laHq NaQS9I3damXk
NJjsQlVAJIeSEy1ybh5pOZEJon/lkHOx7nBXRKSR90sxyUtbXM2yQOC4AqCW HtzLC0KVQQYY
kaxJ15aRq/r+FT+P5z+6f93PthpeT/P7NFk49nZjKJ6a9l6Xnv6u03Rl+iGL o4+M7+iKUCSG
rGVyROqUtUAso4aYxQhOPKAoAUeQaIkQ6GBLOKHUOSYCtf23L1AmW7rj3lx1 /ux805l3WZag
W03iux3C7Gv7d8rLacy2moEN3dbubMtQLabxXY/ItPr+4/Ky5f5DxN2piKSS h/LNKdnQKpeZ
VSA81OefkpDlZiBNU85KQYcNIlIGaMGUYIVRDyjWSTNKN5azhBGNItLywhNB y5B5I6VCanUF
5QqFqE5hZwKCFQI6UFXlPVMUKayFCgg9MYetMXvJlCFJYiVBRI3pW4VTAPJG Mk6ibNZwkYyh
coBCDVdHgw8AGdxdEj0sRgepGChrkgIWJkZ9DgvFFBQSCXBYAKYk4tL+NyiJ qIBdQ4StMua/
azeiciHdMn01xQZtxTEKkxKjOtitGcPIJWKQZowwRAs5lCLqIABB59y9QJlu 6484tweo4zr3
UhOFMjezEJIH9tLKMNPTiaX4kJby0KEak81WgVti5IqQLR1WIjiFXIbTLic0 kDdk/fo1yg9R
PmJQoH+GcoXGSBZ9tv7tk0TImidMrWnWJ06wSA/OupDp+/x2PyxIR/NXRd3N Yn1fnf7Ggw+S
gMZEuimGAJU6bc6ufRp1Dmn5FZxEfxkSr2hAlAfcZSapQs7WE4X3yEhEvLOV wZ0cFKX99Kbm
WUOS4KcCrPpyVDa6EIrgrkKlOtRLbcStWjWJDi1CVWlURlecnUplBIhlHpzy hgNJOKGIs0sQ
RgFUNaV7y46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3NmWoFtN4r sfkWn1/cflZc
vuty9QJlu64/lXLfUceb2l7FEJk5KnhgAOOujmoEyuKw4t6cGIberfG9YryV Ti0vBq5rc1BZ
JzgjUmElCB/VNxfaOd/n/bmIs71mcj+V7L+xR1tdGzmWZpvtL21nshJofs7N KtOzkigedSV+
+JXBpCCWez05PvWKHRueGmFvZ2QWIJiJFFGuWOjhmVZAEBSujenc0zec/p2Z 1WqCUyBklSdd
Dn9wMUmBISibmGVpWZ5Xp1akVUiRWjQnJVS0pQjTnGKkygorurjr/dj5pzLB qlScUnTpyxnH
nnmBKJJJKDUZhppo6hAWWWClRjGOtAgDSohVpSmKoTJ6gEcEebqNO3PqtHy8 vJy0cUjWc3iB
/wDWBU1L5PflcmDJ0pfUg4kUSSoE9oaHuiWpJ6otCWIsLYUrUHfvZoE4wFEj GSZlUOCDNmZL
V7VmiJPV6bW94QFAQvCs/wBnOqUpa3qFidG3KD2zSkh5KgBTmWjPoUYEQyw8 uEjyxuCR1a1x
edSLkRwT05waCqAWSMFf7RZgRFmli5DCjQDKMCEwAg0NaHSctoF5BtSTy0aV 1dSiDg1yRlHL
GpAtRlGFi5QGgMUBEUOggmUCINaUeJc1ylLQDy1u7TEHhrCc5lnSo9ldD2hM WJEnVgTHhUoh
1GNeEhMlNJza0ZIvu1RkrH418mLEV/3tqekUkGpzHJzeRNGWeJImQqs6gRe7 QDD6FUKoFRmz
K0oKRLJjIEbIUruY/gSANCpUq1VS2KLZ2qZAhIVLjwFZQM8YUnEWVUZdDBBq YDlPWw+QI3sl
KIAFQSaHkKktTMqpWlIVpKZcnCbkDzIzk4Am5szN1Fmx8lWeSTFAhdAZNDkJ CdxdD0ohUpUI
VgWhEu0IdQ1oPIV5keQII+TIFStSHmOOqJ5a1HLQpYgPCeVlh/tlD5PvEnl8 vIaQcEBxVfcY
ANcSk1ZKkqQELcy2WRaSjdCKo3U4awspAnCYhCJ2UDE3rahAz0X/AHE5hv8A L5BVhFs7QOlE
rjPWdNJVksoUeSNnia0galOpTgOLKUo1KlEUcrHUwtOvIBoidPQlWuAYRQ51 kU6dJAIOUdJD
H0Ba+qqvvEeQASQ8BYcv7wAHiVmBp7hnmi+/VHZ2cvqmVx2SpDFcClDhUQnE oZNDReylx5gz
BmfyDUuaMOPESo0ASapaRbQkm9L5I3NI0NSOEMGfWrDMgsNRtsBCWWClOUw4 40VaAJIJAYca
OtAlgEL3YMQRKVoXReUARlUAiVzcuGUD+YaQjdUiFQpKL/3hics0BdK0qOtK VpiAubnI3JLc
RLHHMqOxspIeNtcmwaOUBVKlKwLWcnJNKIOdhgAY6pRCEjJpQkecCE/Ey1At pvFdjuF2Nf27
5WW05ltNQIbu63c2ZagW03iux+QWhkbGzv6IpQFWUjem1E6pS1QCzSQKS064 k8oCgBR55QTg
goYEs40FBZJg6V7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0g HwbHfp2OzSAf
Bsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2O zSAfBsd+nY7N
IB8Gx36djs0gHwbHfp2OzSAfBsd+nY7NIB8Gx36djs0gHwbHfp2OzSAfBsd+ nY7NIB8Gx36d
js0gHwbHfp2OzSAfBsd+nflXL1AmW7rj+1ShXJk61EtTnJFiNWSWoSq0qgsR KhMpTnBGUenP
KGMo4k0AizSxCAMNQ1rTGVGlkghZhf8Aciou9rErE25fuUaDB14nK3wNMCI8 SnOxM7KWKlDu
DNvYgOQORA7R+bJKfhlESgs2JvtM5+KNYuksabXVkX5gzLSpm1Fb1i5UZycx Q7Gq288bzySW
DS9oAD8Abi0oCZs1qlwf7Rbanhx7xLhN51AHno3R7iDATVOWWByLanNUmbDF QWJ6b3JQ35mj
ogJPDR0ZjlGdoWkfWkzIc2NwoNOpJNbnZIjXJ1CVUmUJy1CY8svuLjr/AHY+ acyxIks6fFse
i6klKW5uLacEpwyALkx5aRJlI19TjFxpIEg0xaM8xQQaaUENMqowpY1A/wCj 5M5Sx1bQIkax
5i7GytL2DMZui5S9uB3KpGsr+OpctGCOpoxnBoEXupckIxiEEqU5sqla1rQs FXKFm1AD/wCC
HOGGGclPdljEL+Na4iSRSxtrjSTRNncnw1ckJVHuJjw1p1Qi1J5wBGjKSEng RIgZeSkSpyCi
KF0LDi7S9rUHlKUMwcGhCaAYs6jTu5ULazxpx0+8SMsDoqUAMLyRFniqcGtB +/ETLpH2Zec/
xtqeHpWtbki05yUvKAleeFQaoKMEamK0nR0xIvwi04A0oClajqL+ldbVo5Qx Yi3Egk7egyqm
J2xWoi5Z1SktBVFm8kp80OteXODKbkwTBCqRSuILWlKUqJM8cteT315JG88n L/58mJfLVjel
Wu9ZcuYU56sgtRVEiSN7YuMokzoRUTiWGOfIqGXkiOAmTgHWoSw0xf1XHUhD enabOOsoJbkh
QCkVXNI3RN0ztEoKUKyjFZqk0VKB5MtUf7vxK4LVrbJXLnL7IVTovfZghg4J CjezDnFUCgEr
qpNEM9MSWEJSkr3Aq40XGDDUwY61uB7JgE3gdvJEzJ3pE2SiOrWVEjkCNQ3J TyEOWESAnSqL
nE8lKnPytEJCXQqhCEsJV+HGRt6Z5IjkvUaA1uJQVbZpzu7yGntE1AdQaY9U lIbBkpRnlmZm
io0YKUNyBgdkigklGneLapUsWTgLAQQACROy0zCEoFAllllEsTyABZQaBAEs wIaUpStP2f0c
2hByDd0knPeFQC/5pTOFzYDjBjpT35o0hoda0rX3UomP/wDpYn4X9IncUjDH mZ9Ib1ZYT0qh
eVHYY3phqExlKlHlpaOBqgATAiCFSBOPk92Lb3NjCBIzyRtmzc1mDbCCkdXN KcmVrggVlpwg
CozdG4xHWog1qYlXmpjajJqAAbP6kvv+mT39ky1AtpvFdjuF2Nf275WW05lt NQIbu63c2Zag
W03iux4PcvUCZbuuPPS/aWNR+RaDntC9uszc7aHpOa0nRdPTqNH0jRyM9msn O5krLys2Dkzs
YmEvZlH8wZLs+Lp01uJxX3kZbkmm6h8c07eAdTArCIo9RNc4pzzCznQKghsV t37w3RCYJw/v
B6ppVucLdMzT+Y3NsedKS1scXDILqYjVuM3jqFWoUloVdGhOlMd1PJLGqQQT /bqplCFP7CJT
i+4SoXTGPrX6EtOkqaCRJkTvJEDocs0ckKD+sWoS4h0ZXJveGxVnNGcWtYnc EKjMnGJzswrS
GGpzc0oKNIMzZgsg4swsXIMAqU/Ncdf7sfNOZYVRxqVkJHVO4I3hu0oQwJFK hEFQVVIpMLCY
IsBxCo7NmZsdAKAk1HTN5QqFR5RC4jBjakARq5qY+JHckgugM0atZ442qjzA raB5TERC46iM
JuQE7JLp7rn2lNiKNWWvXFusbfE0hZg+21PtmOBMShRqFhVURVG5rPcKKHEx ELl/dcyM2oOW
DsroRormzxCNNbimzhJ2jrm9lRJFZGeTmGpzc0oKMLzhBphI8nKLMGCtBVnl vrhNY2cUqkz4
pLAWtbF5oEKxoYSELmSY3K1qYJydegGcSScOhlDEoamk5oYcsqENsQi0+a2k Ikkekg35K11T
oMoWilOCJa4IVR5aUFQgAQSAIySw6MFYpAWWbi6zhLHVA4XJuuxvjesUk5fs poo4tq5MjRFm
UKoMRQVCsAlVSicyUSmSpUgDAJc+oDDJxF0zEVGfwWRyTvTe6VfgODi7uC0w adCeoqgohqck
LLz4gjVUOqKhZdSxhxIGmXNfslwWzd1d0yfTW5fnG5S0sSYlRnWxWsJBlnI1 IM0YYE8ObyhF
0CMAhXFljuzUFBZTb0MZKX1XN4qLjziImnVoqoSlgnMmgim9xDU45GUT+F90 38QnOKYdEo4w
3JhpSxWojixU9o2NzaSFp41A0y4tarRhMDnzDFBhSYB9M+acYUqCA0KciRSu 5cgEsfpMcRVP
GW1esOjMWQpw8gEzclNNElCrO/DCpOJAZXkICKqxWcoVHGXzfH5r0FrmMoRO McVaa3KfaKMp
wlR5h2ZRq1ChJklOSIWbXFJja57koCoizaAZnxgdxRmexQ7SY3IAUFkU+/Q7 QF+bpUyqURwa
GFmhAcJKMR1aJ1BKhSnO9mG26gzwsLDmQyUt9SJkB1afdorPbRPiNWKov7Yw kp0ga1/sJiqf
co4XOuc9p5JcJzIqkTURhr7JjiAYcgSVuyiyeU6pH7tlFEElEEiUlgqpGqUK jZnc+GIG8pF7
HbKtAnZeg9nSqpLNGGtwjykhOv8AarfUyidwUpFqlKQmCuakuWcEk8s0UWdr qs7NDIdDF4Xd
LGW90Tu6t6cyxFjLGqPRqVifMVESABozDCBFJKmp06Wpqs5UXZ/Ul9/0ye/s mWoFtN4rsdwu
xr+3fKy2nMtpqBDd3W7mzLUC2m8V2PB7l6gTLd1x/LPd1cebyn5Rm85JmsA2 OWBzRJaYOYlb
KNvkaXlRlhbzNGcys821MbTstCaanHyx+4LgMFPwCG6aszbKmtGhp/LLIUNY ojLljgnoAkgp
0f5e+HKE+lDdS3NzUFuabNO0H+0X+7IcIM9s/wC8Zj7pqx0Z5qvinsDTuUs5 E2tr7NNH/e0q
x2/dUqx0/rZ8+yuV/I+3LY8QHTuT+b7L+2rew+1tG5S9N9m6VoOkJNMzGmJc 9+U46/3Y+acy
7miupP32NGUjiByaoy0RghwydBVluqUmrka4EkVAeBO8KzT81VVnFNSwgMLI KoEWJlqBbTeK
7HcLsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8laNotzN3dEieHxlo5JFVvU6VW qjzyuYXExMU6
z1ucaJ6OLcqASJUhSmGlhCbmqBGHHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEv HZPP/MbWcS8d
k8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbW cS8dk8/8xtZx
Lx2Tz/zG1nEvHZPP/MbWcS8dk8/8xtZxLx2Tz/zG1nEvHZPP/MbWcS8dk8/8 xtZxLx2Tz/zG
1nEvHZPP/MbWcS8dk8/8xtZxLw7MquNSCMubO3szocmfTI4dpCF9UPaREelO jchkCevIoj7i
WcWoNTnAyShULGA2gqfkXL1AmW7rj+fyx9O4QwYfxCAQp3cow1lrg/y3Q+Lt akmIvDgCoSaG
mP7A7EuCdKlb3Uhe2Jy0VMprk7fME4fxBt01b0zO6KTjPwhFkSyHNyRsa29M DNrCiD7ePq5S
oAqSmOhKdcmOZuSSwKQJSyf768xc1HNGIGc/u+gpEAkdwXLKEMhKpzVvS9DW CUGDy2RKN7EY
3Njunq8kJxK1UeXAUNEoQJQmFF6S5Rd3JQyBtTmVUJRkHL21OWoTrESogRiZ alNN5zwkSW9l
74nKn90826Na2AlIVWXc2XGCzBb1OGdzDmRjEnM0luT8pxRlSc6nqUeZ2Tz/ AMxtZxLx2Tz/
AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/AMxtZxLx2Tz/ AMxtZxLx2Tz/
AMxtZxLxNlC6PPEaNBCLbkhQvRzAeqNLC/XTHRWWOOPj+ionGIwZIQmrC1Wc INqNMAqpBp35
92Nf275WW05ltNQIbu63c2ZagW03iux+S46/3Y+acy7rMtQLabxXY/JuXqBM t3XHuRaGRsbO
/oilAVZSN6bUTqlLVALNJApLTriTygKAFHnlBOCChgSzjQUFkmDpXljUgl8S H/LABpfznRrT
If8AZa22LzEqURFlbyahIojLZGBuObU6YtvbT0jYYpRKP/eBLc7rFbv2fkbU Pa+lZf8A9h+z
9G/8S03+r8qTxaXw9OL3gXuzaheGsJJfvWK3J2hDrLWyNN7eCpZyxxlatiQh TjMUkqDk6FzM
RLZLb+TN7g5rZA2Rppe48cxSNC3ula0eV5S/ODWoQ5TCiWFZFSFSgs5chHQg sBlFZJLLcH2f
EJGLTjKO2cCihqwkjJOTl6Y4rzlDO4DTiOLzDgaahUDRZRDoFY5JGcGHHX+7 HzTmXdZlqBbT
eK7HcLsa/t3ystpzLaagQ3d1u5sy1AtpvFdj8lx1/ux805l3WZagW03iux+T cvUCZbuuPdo4
dDoc3ujY0x8ZZ70WvYW10PXK3FSIxrWGujujUKW9tTp0yttLAmzKdQ7uwgnm jUmFkdRv/wBz
Q/1Bglr+w32khxenD+y6yXQtLoyhbkm6Q0u/tRYrbclWDPmIs2paztKcjNAL cl3tIlQoOSKE
Bp83ukcahViSjVIjDbnzAY0ikaFStRCUJxVqScJGsVpamAFVOpPKyDRd0mWo FtN4rsdwuxr+
3fKy2nMtpqBDd3W7mzLUC2m8V2PyXHX+7HzTmXPcGpvemle6NAgBdW1G4o1S 9sEZlULC4IyD
hqEQh1CLIopLLqLJFyfwrhH7bemln9oKQokHtVxRt+nLB/2EiPSzitJUj/2S Ccs0X+AcaY+v
DWypKiyaKnZwSNyeov45OeWGkl5XJ7+TK5cGfZ2SML9macpvsV4b3TNU5eTl M0FQfkU5fdyi
5Pfhe0if2Wjq0o/aLo2VdUNHBtb8kozTl6LP6SjR5B5A9JUFlk5JxQsvkMBy xUq3XsiWyS4T
wYxRI5OtIXstTU6gpGvWCUo1GYU6ErUJ0Yi6KSyilBgxqjKASHEmKJuumUTm qFnJ9oP8XCwJ
UACW8r760aBelb0CxSBGVlmjMNPIMASWI6hKmoMwNhlrcAZSV8QFrAkGVoIx MbyiKVJBjpSg
RjSKizkwhhpQI6lZYaclac+ZagW03iux+TcvUCZbuuPeXHX+7HzTmXdZlqBb TeK7HcLsa/t3
ystpzLaagQ3d1u5sy1AtpvFdj8lx1/ux805lz4xIA/gst22I6NOIv4F/aFto mAjFyf2c6fUl
hTFVryDFVSsFTK5R4jbF/OYbQMv2lc6fxKrJnWqc1tJrWn3c6VT2OuJyvfTQ 1wPu+/lUSu8E
6SO4KtKVGwW8PQuKz2J+EmppZidmULlSkK04CxSWUqbUqc01bUVdI0UoVLLu dpmB6iydwkYG
x4WjaHVhaHtOoXNSSqdtIcc1nqlo1qst1zScovNrUGXQQ60rSdRt0VKy46KJ srlIkCNQYkq9
oEDfFNHaj1BFQHgSDdT29WooSMswYUmSAwsWSYBkM9hMja2QX2guZFa8WUXH KLD6r3JWSvcD
jBpqGn/vB5xh/Jyhp76BDSlHi3Vl2RY8I3Us1lkVwHAo1vi7a3qQ5lwJSHHl 5xWaelGYUIWb
ofUgRg29Gtyyzyo/EUZwlBLG3gS1UiDkVVKRCGoWqs3yizdFKw48+hWULNUM oXliycqvOmWo
FtN4rsfk3L1AmW7rj3lx1/ux805l3WZagW03iux3C7Gv7d8rLacy2moEN3db ubMtQLabxXY/
Jcdf7sfNOZc/T44lUqpVDnlrlUeKQkGKVxqpAooWoITEkBGecPRTjFIE5QRC OUJE4aBysmtJ
LN5c2qWqXXGkzg/OaBcmPSLG5AQoPTtTYanVAAoJAnoJWemAaEIqJFZFKhpy YuHLV9s5FcNq
mqkpYxyCLIPbLozE5Z5g27MBAM5IXknlIlGdMS0qW2Ixk1OJryAtdck+1b6m jUKkwFSSNoaV
d5scUYralq5wcWxEWKiEpUBrKTIkwsoaY4g0S00stUnFiaS9TGpA1sTzbNpC lXubUrTJKLTS
IKaNqEuqXVCJzS1TqilKQlSYYWajVB9+YMrSCR5BDZjLYZRYY+TFvizc6n0d gozyAt7QpXt6
RSFMCuSqNMLH96ucIUl0AcnINCmbGn+jNcttbkRQSUiFExuSZKnKD/ABRJUc CAFP8fdT31rW
teWta1w1vzhH3OLLHACgRzC8lGkubfUlYoTBCqLOISmhqcWSFSXlEF8pJxda ctK0FXnTLUC2
m8V2Pybl6gTLd1x7y46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3N mWoFtN4rsfku
Ov8Adj5pzLusy1AtpvFdj8m5eoEy3dce8uOv92PmnMu6zLUC2m8V2O4XY1/b vlZbTmW01Ahu
7rdzZlqBbTeK7H5Lo0nW2l7p/wB7566J3Brcrd6CsQyCcSF/bjyKOc8bHAGW 3uaaphatAmOK
OzhYi/u5Veyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaz iXjsnn/mNrOJ
eOyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaziXjsnn/m NrOJeOyef+Y2
s4l47J5/5jaziXjsnn/mNrOJeOyef+Y2s4l47J5/5jaziXjsnn/mNrOJeOye f+Y2s4l47J5/
5jaziXiUyNyi7xGES2MQplRFPSuNKFStUyus9XOBhYI3IJAUWnLKkDcEIlR5 BhpgjaAKqEqo
/wAm5eoEy3dce8uOv92PmnMu6zLUC2m8V2O4XY1/bvlZbTmW01Ahu7rdzZlq BbTeK7Hg9y9Q
Jlu6495cdf7sfNOZd1mWoFtN4rsdwuxr+3fKy2nMtpqBDd3W7mzLUC2m8V2P B7l6gTLd1x7y
46/3Y+acy7rMtQLabxXY7hdjX9u+VltOZbTUCG7ut3NmWoFtN4rseD3L1AmW 7rj3lx1/ux80
5l3WZagW03iux3C7Gv7d8rLacy2moEN3dbubMtQLabxXY8HuXqBMt3XHvLs0 O7TNylpU3uQr
rRJbe4TqlMSutwpO6tylM4tUYWtytOrblqVUSclVHFiLOD97Kyg06On+ye6f o3HR0/2T3T9G
46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/2T3T9G46On+ye6fo3HR0/wBk 90/RuOjp/snu
ZPdP0bjo6f7J7p+jcdHT/ZPdP0bjo6f7J7p+jcdHT/ZPdP0biXvSRvkCVsMi EAayVL7GJHGd
IXN71chWtISkyRqalCrRU7q3GHGJyjCQaWUGpmXWoafn3Y1/bvlZbTmW01Ah u7rdzZlqBbTe
K7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY 1/bvlZbTmW01
Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzZlqBbTeK7H g9y9QJlu64+P
XY1/bvlZbTmW01Ahu7rdzZlqBbTeK7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu 7rdzZlqBbTeK
7Hg9y9QJlu64+PXY1/bvlZbTmW01Ahu7rdzVEjbZhJ4wtWs7UyrSmUmIqEqt KyrXtc3mGAkk
VkBpags2QOIRCSnkFmliKoMqoiqDx2sT/wAutZw0x2sT/wAutZw0x2sT/wAu tZw0x2sT/wAu
tZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAu tZw0x2sT/wAu
tZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0x2sT/wAutZw0w5MrpdGf qmx4b1jW4ptD
tkTpCFwTmJFZGeT24KUFZ1OaYXnCDSzgZWUWYAdKCp47djX9u+VltOZbTUCG 7ut3+arsa/t3
ystpzLaagQ3d1u/zVdjX9u+VltOZbTUCG7ut3+arsa/t3ystpzLaagQ3d1u/ zVdjX9u+VltO
ZbTUCG7ut3+arsa/t3ystpzLaagQ3d1u/wA1XY1/bvlZbTmW01Ahu7rd/mq7 Gv7d8rLacy2m
oEN3dbv8wNzWrcm9K5vGl+yW5QsTkrnT2eTRQv8AZyQwwKhboScQT1ejFmaM SKhh2QCtK/kn
uj05N7O2Jc3pLi6LE7ehT544tOTn1aswpOVnVBpRBecMDlnGFlh5RjDSt0XR lcm94bFU/R6M
4taxO4IVGZtlbhOdmFaQw1ObmlBRpBmbMFkHFmFi5BgFSn7baagQ3d1u/wAw TN2kDa3vzJ7Q
rCmJG6I07g1mNcZUJzJCf7Nci1Ak7gouCndW11NqWmTuqeExFYSlNLbkDsuy 4fJJBFsn7wGr
S/tFFh5j3tzf9n5F7Q9hx9H99P7HgS+FZbcZoRSxNobQc2fv8dj8sSEfzV0X dzWJ9X53+xoM
PkoDGRLophgCVOm3Orn0adQ5p+RWcRH8dk8/8xtZxLxmEFsZAjVj/lKJRIIU 2sReT98enLY1
Ipo9k5ZYRgTaFGnLOLBJylGhpBnr0uj+xoBH85/4v9pZFMNEyfv9XfsnB/aO fydG60NeiZ7T
v33RvZyvML53H0aQf81RF4Ga2vpeT98GgrZLL5oyE5ZgQAU6bGnLOIxKCk+h qxkL0uadrjT9
2bxfz2/SYtHdIyfvFf1xCopF5MjzR1Czv6tfUOkZvRVmkt5ypGoLUypW8Lm5 SoCjJZ5bN5vL
2x8cDCzTkjUniL+/vSKTvBoiBHs7QS0OTma4JiD2pKJxTpxgIeEsQj9rUhOc AQij0biaG4Jw
TCTES6i+YsZjmkjze6pFS5HocPOpIyUwULsmnTSrVrY+hIa2Vtb2dsS5zRm5 rRp29Cnzxxig
7MJEhZScrOqDTTzM2WHLOMMMFyjGKtf2201Ahu7rd/l9YUyn5iTPfJHomKhZ KgQJG7hGmbl4
khxZ+kN7FymyN+zaReJHHGd4chIVZKI0kTaytZGitjO3o2tuTZw47R0LenLS JCM8oMNUG5pO
UWXnDzTDh5OUYYMdairzlLTCkadeqRqDkjo/u5bmli7OYUYJIdRGoKR5MyeE C0KgtVH2RekS
plDU6tEilETdfZ5K4x5cVih6kqpOIhY7KTFQUpBZxhRqhDHGY5YrRRhnGJMh LGibf3pzLa2p
TJnKQvSOrwdzbaagQ3d1u/y+WQL7zZb9vIcg1L/EJOmUnTOjcWWYoKzdUjhG YjpZh7ScYqAu
Q3Ga3RSjSDQMqtXzUpCo3SHZzzwGKPIxpxvsgUJ81nU7OhOPT6Ro+kEmOC00 xO1sqMYnR9Xt
jSnVLyMuWB9iR8X3fsSiWI3H24jM/GyJy4+z/wD7unVxSNLzGIeYdETzIpxH 3v2ciTIUKZOi
RIk5KRGjSElp0qRKnLCSnTJk5IQFEJyCgAKJJKAEsosIQADQNKU59tNQIbu6 3f5ecnp0P0Vs
Z29Y6OKnNnHaOhb05itWfmU5Zqg3NJyjDM2QUYcPJySyxjrQNUZr0RmJM98s hlgamEqBAkbu
EClxQBVkmH6Q3sXKVHGHOK14kccZ2dtCuVkoijhczMQZJkpBfe+3D+1qBxbI B9/JZWv2mxPc
v08saQxud2sxHDVLcsOdEUsclbb9n3BUcUc4OLm45mro9PC05xdHARGdEWER plaJ29vLUKly
tGwsqZsjjUocXATOztwFh5Y/yLaagQ3d1u/y9EIdT7gFrh9tXE+v3RBa7du8 edE5CIz8SlHB
VLnCIAOKPTCTnRwMkCBUic6Nhg/2ltJBSh+kp6cKxLFGU5sG/nt9TDSxuphL k4tiJuZyREHl
id3de3Nhi0BTQmVHvS5ublmeuD7PVoRe6kBRjJeIaERPuTrXZU4sbY5ypwy6 nKyyXBMhjiAY
20REbOfo+klar8q2moEN3dbv8vP83N945G4DbWetPeSGGxVc6N0cMSKC8hO5 t78oPepy3OwS
Ms5DME6AtY5NjY1qx4UrlylOiRIk5ytYsVnFp0qRKnLEcoUqVBwgFEJyCgDN OONGEsosIhjF
QNK1xmo4mcIoz/7+TyNiEQ6LiR/gGERiMOihI5tbgmHpQqvU2ZSkKVQlbzEU VmTO7GLUBiRs
KUUCeoErVKVy9wd3NeqEWURpLk7u6pc6uSgtKnSoSDl6xQYnb0aJvIEWiRJS Cvy7aagQ3d1u
/wAu1YmtSoRvszUViLGsSHGJlTcqdESw5wfUygAiqBURaPo3qVEkVVoDHExk C1IlpDkvRVqm
QoUydEiRJyUiNGkJLTpUiVOWElOmTJyQgKITkFAAUSSUAJZRYQgAGgaUpg9g ZQfaKVl5ssTI
gEcIlrOUklqEhkudkyZakh7eckMq4FHvAQrnRCmV0jDXInQslqUJnmamp3xx TKCXFrY6kpVM
XiDgUYEwlQwANbky1weEoSk5dJU951zCoC4KY6kiDc+ODB+dbTUCG7ut3+XX 2QSByb2iOW10
ZgIPeFidAhKlMjbWl0cnpUYtMqhBo7C+R1gjTiA5C4lHPs7ajyT0bmhMNySy 3CHRYf4agSwg
SSZSJIZ+LQxpMSOgVEFbz0+YJMPdEn24qBa5Ji2uAvLS3PSohtbSNHS
Re: graphical read-only view of non-child object in a compartment [message #176426 is a reply to message #175140] Fri, 07 March 2008 07:12 Go to previous messageGo to next message
> thanks,
> Julien
please ?
any idea ?
Re: graphical read-only view of non-child object in a compartment [message #176433 is a reply to message #175782] Fri, 07 March 2008 07:51 Go to previous message
Hello Julien,
> here it is
I mean exception stacktrace.
Alex Shatalin
Previous Topic:Issue with mindmap in 2.0.1
Next Topic:Some connection problems
Current Time: Thu Jul 31 03:47:21 EDT 2025
Powered by FUDForum. Page generated in 0.31035 seconds
