| Project won't build for "unbound classpath variable" fixed outside of eclipse [message #171507] |
Tue, 19 September 2006 01:00  |
I was running Eclipse 3.1.2, and I installed Eclipse 3.2 in a separate
directory.
I made a copy of the workspace I was using with 3.1.2, and I opened that
workspace in 3.2. In the project in that workspace, I was referencing a
classpath variable that wasn't set when I opened up 3.2, so it complained
"Unbound classpath variable: HOME/.maven/repository/...' in project ...".
The variable was HOME, and I was using it to reference
"HOME/.maven/repository". I decided to change all of them to
"MAVEN_REPO", but after doing a handful of them, I decided to exit
Eclipse and edit the .classpath file manually with another text editor. I
changed all the references, then restarted Eclipse 3.2.
Unfortunately, it still complains about the problem, even though those
references don't exist anymore. It won't let me build the project because
of this.
FUDForum. Page generated in 0.10989 seconds
