Home » Language IDEs » ServerTools (WTP) » AMD64 and sqlpage
AMD64 and sqlpage [message #171464] Fri, 16 June 2006 06:22
Originally posted by: polimar.unipg.it
Hi to all,
i suppose and hope this is the right ng for my post.
I have a linux debian amd64 sid. I installed eclipse and web tools. All
run ok. But when i create a .sqlpage (section data - SQL ScrapBook Page)
i get this error:
gnu.xml.dom.ls.DomLSException: empty document, with no root element.
at gnu.xml.dom.ls.DomLSParser.doParse (libgcj.so.7)
at gnu.xml.dom.ls.DomLSParser.parse (libgcj.so.7)
at gnu.xml.dom.DomDocumentBuilder.parse (libgcj.so.7)
at javax.xml.parsers.DocumentBuilder.parse (libgcj.so.7)
org.eclipse.wst.rdb.internal.sqlscrapbook.util.SQLUtility.ge tInputSQLPageXML
(SQLUtility.java:216)
org.eclipse.wst.rdb.internal.sqlscrapbook.editor.SQLScrapboo kDocumentProvider.createDocument
(SQLScrapbookDocumentProvider.java:68)
at org.eclipse.ui.editors.text.FileDocumentProvider.createEleme ntInfo
(FileDocumentProvider.java:686)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect
(AbstractDocumentProvider.java:398)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput
(AbstractTextEditor.java:3010)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput
(StatusTextEditor.java:174)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput
(AbstractDecoratedTextEditor.java:1305)
at org.eclipse.ui.editors.text.TextEditor.doSetInput
(TextEditor.java:263)
at org.eclipse.wst.rdb.sqleditor.internal.SQLEditor.doSetInput
(SQLEditor.java:265)
org.eclipse.wst.rdb.internal.sqlscrapbook.editor.SQLScrapboo kEditor.doSetInput
(SQLScrapbookEditor.java:47)
at org.eclipse.ui.texteditor.AbstractTextEditor$16.run
(AbstractTextEditor.java:2360)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread
(ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run (ModalContext.java:291)
at org.eclipse.jface.window.ApplicationWindow$1.run
(ApplicationWindow.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile (BusyIndicator.java:69)
at org.eclipse.jface.window.ApplicationWindow.run
(ApplicationWindow.java:634)
at org.eclipse.ui.internal.WorkbenchWindow.run
(WorkbenchWindow.java:2134)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit
(AbstractTextEditor.java:2378)
at org.eclipse.ui.texteditor.AbstractTextEditor.init
(AbstractTextEditor.java:2406)
at org.eclipse.ui.internal.EditorManager.createSite
(EditorManager.java:778)
at org.eclipse.ui.internal.EditorReference.createPartHelper
(EditorReference.java:596)
(EditorReference.java:384)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart
(WorkbenchPartReference.java:552)
at org.eclipse.ui.internal.EditorReference.getEditor
(EditorReference.java:223)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched
(WorkbenchPage.java:2362)
(WorkbenchPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9
(WorkbenchPage.java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run (WorkbenchPage.java:2272)
at org.eclipse.ui.internal.WorkbenchPage.openEditor
(WorkbenchPage.java:2279)
(WorkbenchPage.java:2241)
org.eclipse.wst.rdb.internal.sqlscrapbook.wizards.NewSQLScra pbookFileWizardPage.finish
(NewSQLScrapbookFileWizardPage.java:83)
org.eclipse.wst.rdb.internal.sqlscrapbook.wizards.NewSQLScra pbookFileCreationWizard.performFinish
(NewSQLScrapbookFileCreationWizard.java:55)
at org.eclipse.jface.wizard.WizardDialog.finishPressed
(WizardDialog.java:676)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed
(WizardDialog.java:354)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected (Dialog.java:557)
at org.eclipse.swt.widgets.TypedListener.handleEvent
(TypedListener.java:91)
at org.eclipse.swt.widgets.EventTable.sendEvent (EventTable.java:62)
at org.eclipse.swt.widgets.Widget.sendEvent (Widget.java:1023)
at org.eclipse.swt.widgets.Display.runDeferredEvents (Display.java:2853)
at org.eclipse.swt.widgets.Display.readAndDispatch (Display.java:2572)
at org.eclipse.jface.window.Window.runEventLoop (Window.java:809)
at org.eclipse.jface.window.Window.open (Window.java:789)
at org.eclipse.ui.actions.NewWizardAction.run (NewWizardAction.java:181)
at org.eclipse.jface.action.Action.runWithEvent (Action.java:997)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:540)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:404)
at org.eclipse.ui.internal.Workbench.runEventLoop (Workbench.java:1699)
at org.eclipse.ui.internal.Workbench.runUI (Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench (PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:376)
(EclipseStarter.java:163)
at java.lang.reflect.Method.invoke (libgcj.so.7)
at org.eclipse.core.launcher.Main.invokeFramework (Main.java:334)
at org.eclipse.core.launcher.Main.basicRun (Main.java:279)
at org.eclipse.core.launcher.Main.run (Main.java:974)
at org.eclipse.core.launcher.Main.main (Main.java:948)
Caused by: org.xml.sax.SAXParseException: empty document, with no root
element.
at gnu.xml.aelfred2.SAXDriver.fatal (libgcj.so.7)
at gnu.xml.aelfred2.XmlParser.error (libgcj.so.7)
at gnu.xml.aelfred2.XmlParser.doParse (libgcj.so.7)
at gnu.xml.aelfred2.SAXDriver.parse (libgcj.so.7)
at gnu.xml.aelfred2.XmlReader.parse (libgcj.so.7)
...68 more
Any suggestion?
Thanks to all.
* Dott. Fabrizio Ortolani *
* Area Servizi Web *
* Università degli Studi di Perugia *
* P.zza Università, 1 - 06125 Perugia - Italia *
* Tel. +39 075 585 5172 - E-mail: fabrizio@unipg.it *
Previous Topic:AMD64 and sqlpage
Next Topic:XSLT
Current Time: Tue Dec 02 15:29:33 EST 2025
Powered by FUDForum. Page generated in 0.56954 seconds
