Home » Newcomers » Newcomers » Eclipse 3.2 & AIX 5.3
Eclipse 3.2 & AIX 5.3 [message #171413] Mon, 18 September 2006 11:35 Go to next message
Originally posted by: kmromberg.verizon.net
Has anyone used Eclipse 3.2 on AIX 5.3 with 1.4.2 successfully? And
'success' I define as 'it actually runs'. All I get is a splash screen, and
the process hanging in the background. It's probably something simple that
I'm missing, but I have no idea where to even begin.
I've run java apps on this machine, but I really would like to be able to
debug them with Eclipse.
Kathy
Re: Eclipse 3.2 & AIX 5.3 [message #171419 is a reply to message #171413] Mon, 18 September 2006 11:51 Go to previous messageGo to next message
> Kathy
Would be helpful if you could post eclipse's log file.
Should be located within the eclipse directory ;-)
Stefan Teitge
Re: Eclipse 3.2 & AIX 5.3 [message #171573 is a reply to message #171419] Tue, 19 September 2006 09:29 Go to previous messageGo to next message
There is no log file. I would post one if there was one.
The only thing I have to go on is what I get from ps. /usr/java14... is
where Java 1.4.2 is installed. I've been able to run other Java apps on the
machine without problem.
I am setting display back to my laptop, and I believe that to be working
fine - the smit gui can find its way there.
AIX is at 5300-03, and the Java is the Java that came with AIX.
Am I missing some environment variable? Is there some way to turn on debug
or logging so that I can see what it's trying to do?
[eclipse_aix]$ ps -eaf | grep eclipse
kromberg 352266 364798 16 09:18:22 pts/2 0:00
/home/kromberg/eclipse_aix/eclipse/eclipse
/home/kromberg/eclipse_aix/eclipse/plugins/org.eclipse.platf orm_3.2.0.v20060601/splash.bmp
kromberg 364798 389310 0 09:18:22 pts/2 0:00
/usr/java14/jre/bin/java -Xms40m -Xmx256m -jar
/home/kromberg/eclipse_aix/eclipse/startup.jar -os aix -ws motif -arch
ppc -launcher /home/kromberg/eclipse_aix/eclipse/eclipse -name
Eclipse -showsplash 600 -exitdata 12 -vm
/usr/java14/jre/bin/java -vmargs -Xms40m -Xmx256m -jar
kromberg 389310 413812 0 09:18:21 pts/2 0:00 eclipse
[eclipse_aix]$
"Stefan Teitge" <stefan.teitge@web.de> wrote in message
news:eemf8f$bcg$1@utils.eclipse.org...
>> and
>> that I'm missing, but I have no idea where to even begin.
>> Kathy
> Stefan Teitge
Re: Eclipse 3.2 & AIX 5.3 [message #171599 is a reply to message #171573] Tue, 19 September 2006 14:12 Go to previous message
Cannot see anything unusual.
Try running "eclipse -consolelog -debug -clean".
This enables Eclipse to make more detailed output to console.
Another guess: Maybe try an older version of Eclipse, e.g. 3.1.2
Download here:
http://download.eclipse.org/eclipse/downloads/drops/R-3.1.2- 200601181600/index.php
Stefan Teitge
Previous Topic:Project won't build for "unbound classpath variable" fixed outside of eclipse
Next Topic:add Show View submenu
Current Time: Thu Jul 17 06:09:21 EDT 2025
Powered by FUDForum. Page generated in 0.33711 seconds
