Home » Archived » BIRT » optinal Parameter and SQL Query
optinal Parameter and SQL Query [message #171384] Mon, 19 June 2006 07:20 Go to next message
Originally posted by: vincent.tiberghien.ird.sn
I am setting up a data set with a SQL Query.
In that query, i use a parameter to select either mens or womens, like this
SELECT people
WHERE sex=?
Sex can be equal to 1(men) or 2(women).
Users will be deciding the value of this parameter. But i also would
like them to be able to choose the 'no matter' case where both mens and
womens would be selected, like this
SELECT people
there would not be any WHERE clause.
How can i do that ?
thank you
Re: optinal Parameter and SQL Query [message #171442 is a reply to message #171384] Mon, 19 June 2006 16:23 Go to previous messageGo to next message
Originally posted by: a.bcd.com
vincent tiberghien wrote:
> Hello,
> SELECT people
> WHERE sex=?
> SELECT people
> How can i do that ?
> thank you
Hello ,
you could try :
select people where sex like ?
and default the 1st param to %
Re: optinal Parameter and SQL Query [message #171447 is a reply to message #171384] Mon, 19 June 2006 21:00 Go to previous messageGo to next message
Define your SQL to be: SELECT people WHERE sex = ? OR ?=0
Bind both data set parameters to the same report parameter in BIRT. Then:
param value 1->men, 2->women, 0-> both
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"vincent tiberghien" <vincent.tiberghien@ird.sn> wrote in message
news:e761fh$gdk$1@utils.eclipse.org...
> Hello,
this
> SELECT people
> WHERE sex=?
> SELECT people
> How can i do that ?
> thank you
Re: optinal Parameter and SQL Query [message #184584 is a reply to message #171384] Mon, 14 August 2006 08:21 Go to previous message
> Hello,
> SELECT people
> WHERE sex=?
> SELECT people
> How can i do that ?
> thank you
You can write a beforeOpen script to your dataset and modify the query
by changing queryText variable freely before execution.
Previous Topic:Reuse query defined in "Data Set - Query"
Next Topic:Reloading a report with new values for parameters
Current Time: Tue Oct 28 08:29:31 EDT 2025
Powered by FUDForum. Page generated in 0.04028 seconds
