Home » Eclipse Projects » GEF » Trouble launching TextEditor from GEF
Trouble launching TextEditor from GEF [message #171233] Thu, 10 March 2005 11:08 Go to next message
Originally posted by: a.morgan.pilz.ie
I have a figure and it can be programmed using a simple low level language.
What I am trying to do is launch a TextEditor when I double click on the
figure.
In the performRequest method of the relevant EditPart when I receive a
REQ_OPEN I try to open a textEditor.
I use the following code to launch the Editor :
IEditorPart part = PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getActivePage().openEditor(input, "main.FBTextEditor");
FBTextEditor is a subclass of TextEditor.
The first problem I got was that I had no document provider. I overrode the
getDocumentProvider() method to return a new FilDocumentProvider.
Next I had to figure out what IEditorInput to pass.
I tried to pass a FileEditorInput with an IFile created as follows :
IFile newFile = ResourcesPlugin.getWorkspace().getRoot().getFile(path);
I tried passing both the path a file that doesn't exist and one that does.
When the Editor launched all that appeared was a blank editor space
containing the word "ERROR".
Any ideas guys cause this is wrecking my head.
Alan.
Re: Trouble launching TextEditor from GEF [message #171315 is a reply to message #171233] Fri, 11 March 2005 00:20 Go to previous message
What was in the error log?
BTW, you'll probably get a better answer on the platform newsgroup.
"Alan Morgan" <a.morgan@pilz.ie> wrote in message
news:d0preu$6is$1@www.eclipse.org...
language.
> figure.
> IEditorPart part =
the
> IFile newFile =
> Alan.
Previous Topic:How can i make my editor read-only?
Next Topic:removal of toolbar from logic example
Current Time: Thu Nov 20 11:56:45 EST 2025
Powered by FUDForum. Page generated in 1.04639 seconds
