Home » Archived » BIRT » Problem with Javascript
Problem with Javascript [message #171205] Sat, 17 June 2006 01:59 Go to next message
OK. Maybe the following bug is due to a syntax error, but I'm not so
sure. The following code is entered through the Expression Builder for
a data item. When the report is previewed, the "result" is overridden
with the current date when the "currentFiscalStart" variable is setup.
If I comment it out, the result is unmodified. What is going on here?
result = "BOOKED "
var currentTime = new Date()
function TwoDigitYear(year) {
year = year % 100
return(year<0||year>9?year:"0"+year)
result += "FY" + TwoDigitYear(currentTime.getFullYear())
// For some reason, the following operation operation
// screws up the "result"
currentFiscalStart = currentTime
Re: Problem with Javascript [message #171253 is a reply to message #171205] Sat, 17 June 2006 12:09 Go to previous messageGo to next message
> result = "BOOKED "
> year = year % 100
I've executed the same code within an HTML file and it works just fine. So
this appears to be bug with BIRT. I've logged a defect:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147612
Re: Problem with Javascript (resolved) [message #171443 is a reply to message #171253] Mon, 19 June 2006 17:04 Go to previous message
>> result = "BOOKED "
>> year = year % 100
User error. My knowledge of JavaScript continues to grow. As noted in
the bug report, the last line to execute in a JavaScript function is
what gets returned.
Previous Topic:Installing BIRT on Sybase's EAServer
Next Topic:Providing "missing" rows via scripted dataset
Current Time: Wed Nov 05 01:39:12 EST 2025
Powered by FUDForum. Page generated in 0.03335 seconds
