Home » Modeling » GMF (Graphical Modeling Framework) » How to get editPart from notation.Diagram
How to get editPart from notation.Diagram [message #171083] Fri, 01 February 2008 08:04 Go to next message
Originally posted by: trommas.yahoo.com
I have a gmf.runtime.notation.Diagram - Is there a way to get it's editPart?
Tomas
Re: How to get editPart from notation.Diagram [message #171092 is a reply to message #171083] Fri, 01 February 2008 08:12 Go to previous messageGo to next message
Hi Tomas,
EditParts exist only in the context of an EditPartViewer showing them.
If you have an EditPartViewer, then
viewer.getEditPartRegistry().get(notationalElement) will return the edit
part associated with this notational element. For the diagram itself,
viewer.getContents() is a shorter alternative.
If you don't have any viewer, then the concept of edit part makes little
sense. One notational element may correspond to many different edit
parts, they don't even need to be of the same or related classes (e.g.,
a subclass of GraphicalEditPart vs. subclass of TreeEditPart).
Hope that helps.
Boris
> editPart?
> Tomas
Re: How to get editPart from notation.Diagram [message #171106 is a reply to message #171092] Fri, 01 February 2008 08:22 Go to previous message
Boris Blajer wrote:
> Hi Tomas,
> Hope that helps.
> Best regards,
> Boris
Thanks for clarifying.
What I'm trying to achieve is to run a create command after a diagram
gets created. ...EditorUtil's doExecuteWithResult seems like the best
place. A create command needs a DiagramEditPart to create a node. Simply
adding them to the diagram.getElement()'s collection seems to initialize
the node incorrectly... Hmm.. Anyways, Thanks for helping!
Tomas
>> editPart?
>> Tomas
Previous Topic:accessign properties from IAction
Next Topic:Rotate border figure
Current Time: Mon Sep 01 00:13:26 EDT 2025
Powered by FUDForum. Page generated in 0.02737 seconds
