Home » Archived » MST » OCL text editor
| OCL text editor [message #1346] |
Sat, 18 October 2008 07:02  |
An OCL text editor is available now from the M2M QVT Declarative CVS.
This editor uses IMP to provide the usual syntax coloring, folding, and
completion proposals. MDT-OCL and LPG provide the CST and AST parsing.
The (now QVT Declarative) Model Registry binds the external models to
support semantic validation.
At present it supports a complete OCL text file (a sequence of scoped
constraints). It could be no doubt adapted to support individual
constraints as a pop-up from a UML graphical editor.
For MST, the utility would be support for validated bulk entry of the
large number of OCL statements that occur in the better specifications
and that should occur in all specifications.
Ed Willink
| Re: OCL text editor [message #1366 is a reply to message #1360] |
Mon, 27 October 2008 11:39   |
Originally posted by: cdamus.zeligsoft.com
Hi, Patrick,
The UML metamodel binding in the OCL component supports the definition
of constraints on Stereotypes in Profiles. As a convenience, the UML
environment allows evaluation of a constraint defined in the stereotype
context on an Element to which the stereotype is applied; it does this
by finding the associated stereotype instance and evaluating the
constraint on it, under the covers. The constraint must be well-formed
with respect to the stereotype properties, in particular using
navigation of metaclass extensions to access UML elements. There is no
syntactic short-cut for access to UML attributes in the stereotype context.
Does that answer your question?
Christian
Patrick Tessier wrote:
> We are very interesting by this fucntionnality in Papyrus.
> In the OCL project can we put ocl constraint on profile, and validate theses
> rules when we apply profile on model?
> It could be very interesting to connect directly your ocl editor in the
> diagram in order to see colored syntax.
> Best regards,
> Patrick
> "Kenn Hussey" <Kenn.Hussey@embarcadero.com> a écrit dans le message de news:
> gdhthh$cii$1@build.eclipse.org...
>> Ed,
>> I agree that such functionality would indeed be useful for validating
>> constraints that are defined in a standard metamodel. We plan to use the
>> Papyrus environment as a basis for diagram editors in MST... have you
>> proposed this as an inclusion in Papyrus and/or compared/contrasted it
>> with plans that team has regarding OCL?
>> Kenn
>> "Ed Willink" <ed@willink.me.uk> wrote in message
>> news:gdcfop$rt4$1@build.eclipse.org...
>>> Hi
>>> Regards
>>> Ed Willink
| Re: OCL text editor [message #1378 is a reply to message #1372] |
Tue, 28 October 2008 09:37   |
Hi, Patrick,
By "contact you," you do mean "contact the OCL newsgroup," right?
:-D
In the mean-time, you can see how OCL works with stereotypes in the
org.eclipse.ocl.uml.tests.ProfilesTest class.
cW
> Yes,
> As soon as I have time, I will contact you in order to connect your editor
> into the property view in a first time and then directly on the diagram.
> Patrick,
> "Christian W. Damus" <cdamus@zeligsoft.com> a écrit dans le message de news:
> ge4nba$lv7$1@build.eclipse.org...
>> Hi, Patrick,
>> The UML metamodel binding in the OCL component supports the definition of
>> context on an Element to which the stereotype is applied; it does this by
>> finding the associated stereotype instance and evaluating the constraint
>> on it, under the covers. The constraint must be well-formed with respect
>> to the stereotype properties, in particular using navigation of metaclass
>> extensions to access UML elements. There is no syntactic short-cut for
>> Cheers,
>> Christian
>>> theses rules when we apply profile on model?
>>> Best regards,
>>> Patrick
>>> news: gdhthh$cii$1@build.eclipse.org...
>>>> Ed,
>>>> Kenn
>>>>> Hi
>>>>> Regards
>>>>> Ed Willink
| Re: OCL text editor [message #1391 is a reply to message #1384] |
Wed, 29 October 2008 10:59   |
Hi, Sébastien,
Naturally, I am interested in helping with that. The question is how
thinly I can spread myself ... :-)
Several features that are planned for OCL in this release should help
the integration, such as providing .edit and .editor plugins for the
metamodels and other work that Ed Willink is contributing. I think hes
has also expressed interest in contributing to MST, which probably
reaches into Papyrus as well.
Speaking for myself, working on the Papyrus side of any integration,
although I would undoubtedly enjoy it, is likely to be beyond my means.
We shall have to see in what little ways I can pitch in.
Christian
Sébastien Gérard wrote:
> Hi Christian,
> do you if some guys, may be you, of the OCL group could work on the
> integration of the OCL support (including the OCL editor) within Papyurs? Of
> course, Patrick can help doing that.
> --Séb
> ge74in$dfi$1@build.eclipse.org...
>> Hi, Patrick,
>> :-D
>> cW
>>> Yes,
>>> editor into the property view in a first time and then directly on the
>>> diagram.
>>> Patrick,
>>> news: ge4nba$lv7$1@build.eclipse.org...
>>>> Hi, Patrick,
>>>> context.
>>>> Cheers,
>>>> Christian
>>>>> Best regards,
>>>>> Patrick
>>>>>> Ed,
>>>>>> the Papyrus environment as a basis for diagram editors in MST... have
>>>>>> you proposed this as an inclusion in Papyrus and/or
>>>>>> compared/contrasted it with plans that team has regarding OCL?
>>>>>> Kenn
>>>>>>> Hi
>>>>>>> and completion proposals. MDT-OCL and LPG provide the CST and AST
>>>>>>> parsing. The (now QVT Declarative) Model Registry binds the external
>>>>>>> models to support semantic validation.
>>>>>>> specifications and that should occur in all specifications.
>>>>>>> Regards
>>>>>>> Ed Willink
| Re: OCL text editor [message #1402 is a reply to message #1396] |
Thu, 30 October 2008 09:10  |
Hi, Ed,
Don't worry; budgeting time is a fact of Eclipse committer life. I
wasn't trying to speak for you. :-)
I do have a plan item for this release to deliver the generated .edit
and .editor plug-ins, in a separately downloadable feature. An OCL text
editor is not in the plan.
cW
>> hes has also expressed interest in contributing to MST, which probably
>> means. We shall have to see in what little ways I can pitch in.
> Hi.
> Sorry, I don't read newsgroups very often.
> I was firstly highlighting the availability of OCL editing support in
> case you wanted it. It seems you do. I can assist in making the editor
> invokable in an alternate fashion, but have limited time available to do
> more than that.
> Regards
> Ed Willink
| Re: OCL text editor [message #563178 is a reply to message #1346] |
Mon, 20 October 2008 08:28  |
Ed,
proposed this as an inclusion in Papyrus and/or compared/contrasted it with
Kenn
> Hi
> completion proposals. MDT-OCL and LPG provide the CST and AST parsing. The
> (now QVT Declarative) Model Registry binds the external models to support
> large number of OCL statements that occur in the better specifications and
> Regards
> Ed Willink
| Re: OCL text editor [message #563199 is a reply to message #1354] |
Wed, 22 October 2008 04:52  |
Patrick
| Re: OCL text editor [message #563224 is a reply to message #1360] |
Hi, Patrick,
Christian
> Best regards,
> Patrick
>> Ed,
>> Kenn
>>> Hi
>>> Regards
>>> Ed Willink
| Re: OCL text editor [message #563275 is a reply to message #1372] |
Hi, Patrick,
:-D
cW
> Yes,
> Patrick,
>> Hi, Patrick,
>> Cheers,
>> Christian
>>> Best regards,
>>> Patrick
>>>> Ed,
>>>> Kenn
>>>>> Hi
>>>>> Regards
>>>>> Ed Willink
| Re: OCL text editor [message #563298 is a reply to message #1378] |
Wed, 29 October 2008 04:57  |
Hi Christian,
--S
| Re: OCL text editor [message #563326 is a reply to message #1384] |
Hi, Sébastien,
Christian
> Hi Christian,
> --Séb
>> Hi, Patrick,
>> :-D
>> cW
>>> Yes,
>>> diagram.
>>> Patrick,
>>>> Hi, Patrick,
>>>> context.
>>>> Cheers,
>>>> Christian
>>>>> Best regards,
>>>>> Patrick
>>>>>> Ed,
>>>>>> Kenn
>>>>>>> Hi
>>>>>>> Regards
>>>>>>> Ed Willink
| Re: OCL text editor [message #563349 is a reply to message #1391] |
Thu, 30 October 2008 04:12  |
Hi.
more than that.
Ed Willink
| Re: OCL text editor [message #563371 is a reply to message #1396] |
Hi, Ed,
cW
> Hi.
> more than that.
> Regards
> Ed Willink
Current Time: Sat Nov 08 19:58:37 EST 2025
Powered by FUDForum. Page generated in 0.07370 seconds
