Home » Modeling » GMF (Graphical Modeling Framework) » how can I change the standard property dialog for a multivalued attribute?
how can I change the standard property dialog for a multivalued attribute? [message #170950] Thu, 31 January 2008 13:40 Go to next message
Originally posted by: bmoros.um.es
Hi all,
I would like to open a custom dialog when I select a multivalued attribute
from the PropertyView. The standard dialog lists all the objects from the
resource that match the type of the selected attribute but I would like to
limit this list only to those objects that fullfil some condition. I do not
know where the property dialog is defined neither how to change it.
Some hint will be very wellcome!!
Bego
Re: how can I change the standard property dialog for a multivalued attribute? [message #171023 is a reply to message #170950] Fri, 01 February 2008 05:05 Go to previous messageGo to next message
Hello Begoa,
See ???ItemProvider class generated for you by EMF. You have to modify appropriate
itemPropertyDescriptor..
Alex Shatalin
Re: how can I change the standard property dialog for a multivalued attribute? [message #171130 is a reply to message #171023] Fri, 01 February 2008 08:51 Go to previous messageGo to next message
Originally posted by: nospam.nospam.com
This is for a single valued attribute with a drop down list of possible
choices (not sure if you really meant multi valued).
You can try this code in XXX.edit/src/XXX/provider/XXXItemProvider:
protected void addXXXPropertyDescriptor(Object object) {
itemPropertyDescriptors.add
(new ItemPropertyDescriptor
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
getResourceLocator(),
getString("_UI_XXX_XXX_feature"),
getString("_UI_PropertyDescriptor_description", "_UI_XXX_XXX_feature",
"_UI_XXX_type"),
XXXPackage.Literals.XXX__XXX,
true,
false,
true,
null,
null,
null) {
public Collection<?> getChoiceOfValues(Object object) {
Collection<?> result = new
ArrayList<Object>(super.getChoiceOfValues(object));
// ...limit the choices from result
// or create a new result Collection
return result;
Re: how can I change the standard property dialog for a multivalued attribute? [message #171286 is a reply to message #171130] Sun, 03 February 2008 14:39 Go to previous message
Thank you very much!!!!
I have managed to do what I wanted to do.
Bego
Previous Topic:How to customize enablement in popups
Next Topic:Compartment ScrollBar not coming
Current Time: Sat Nov 08 00:17:52 EST 2025
Powered by FUDForum. Page generated in 0.03979 seconds
