Home » Archived » BIRT » using ONE parameter MANY TIMES in the SQL query
| using ONE parameter MANY TIMES in the SQL query [message #170939] |
Fri, 16 June 2006 10:38  |
Originally posted by: vincent.tiberghien.ird.sn
I have defined a data set, with one parameter
Nom | Type de données | Direction | Valeur par défaut
ParamDate | DateHeure | Entrée | 01/01/1983
Then i need to add this parameter in my SQL Query, i want to use it two
times, like this
select *
from Table
where Table.date1 > ? and Table.date2 > ?
The two ? should be replaced bu ParamDate. How can i do this ?
| Re: using ONE parameter MANY TIMES in the SQL query [message #185751 is a reply to message #184898] |
Thu, 17 August 2006 17:30   |
Harun,
To do this, you need to build your WHERE clause entirely in Java and
then set it as a parameter. Then, use the before open method. Please use
this file as an example:
Look for the parameter WHERE_CLAUSE and then track how I use it through
the file.
Pay attention to the beforeOpen method--you will need to do that. If you
have more questions, write me at: tyronehed@earthlink.net
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
<20051130-1157></property>
<property name="units">in</property>
<text-property name="displayName">Edit Error By Claim</text-property>
<parameters>
<scalar-parameter name="WHERE_CLAUSE" id="7">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="allowNull">true</property>
<property name="defaultValue">1 = 0</property>
<property name="controlType">text-box</property>
<property name="format">Unformatted</property>
</scalar-parameter>
<scalar-parameter name="CURRENT_DATE" id="8">
<property name="defaultValue">01/01/1970</property>
</scalar-parameter>
<scalar-parameter name="CURRENT_TIME" id="9">
<property name="defaultValue">00:00:00.0</property>
</scalar-parameter>
<scalar-parameter name="REQUESTER" id="10">
<property name="defaultValue">Leo Tolstoy</property>
</scalar-parameter>
<scalar-parameter name="FLAG_TYPES" id="11">
<property name="defaultValue">NOFLAGTYPES</property>
</scalar-parameter>
<scalar-parameter name="ENVIRONMENT" id="12">
<property name="defaultValue">NOENVIRONMENT</property>
</scalar-parameter>
<scalar-parameter name="MOST_RECENT_ANALYSIS" id="13">
</scalar-parameter>
<scalar-parameter name="CLAIM_ID_RANGE" id="14">
<property name="defaultValue">0 TO 0</property>
</scalar-parameter>
<scalar-parameter name="IMPORT_DATE_RANGE" id="15">
<property name="defaultValue">01/01/1970 to 01/01/1970</property>
</scalar-parameter>
<scalar-parameter name="DATE_OF_SERVICE_RANGE" id="16">
</scalar-parameter>
<scalar-parameter name="BATCH_RANGE" id="17">
<property name="defaultValue">0 to 0</property>
</scalar-parameter>
<scalar-parameter name="PROVIDER_RANGE" id="18">
</scalar-parameter>
<scalar-parameter name="PATIENT_RANGE" id="19">
</scalar-parameter>
<scalar-parameter name="SORT_BY" id="20">
<property name="defaultValue">no sort</property>
</scalar-parameter>
<scalar-parameter name="ACCOUNTS" id="21">
<property name="defaultValue">no accounts</property>
</scalar-parameter>
<scalar-parameter name="PLANS" id="22">
<property name="defaultValue">no plans</property>
</scalar-parameter>
<scalar-parameter name="FLAGS" id="23">
<property name="defaultValue">no flags</property>
</scalar-parameter>
<scalar-parameter name="CLAIM_STATUS" id="24">
</scalar-parameter>
<scalar-parameter name="USERS" id="25">
</scalar-parameter>
<scalar-parameter name="PROVIDER_SPECIALTIES" id="26">
<property name="defaultValue">no specialties</property>
</scalar-parameter>
<scalar-parameter name="PLACE_OF_SERVICE" id="27">
<property name="defaultValue">no place of service</property>
</scalar-parameter>
<scalar-parameter name="DIAGNOSIS_CODES" id="28">
<property name="defaultValue">no diag codes</property>
</scalar-parameter>
<scalar-parameter name="PROCEDURE_CODES" id="29">
<property name="defaultValue">no proc codes</property>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="44">
<property
name="odaDriverClass">net.sourceforge.jtds.jdbc.Driver</property >
<property
name="odaURL">jdbc:sqlserver://localhost:1433;databaseName=FREYA_DB</property>
<property name="odaUser">FREYA</property>
<encrypted-property
name="odaPassword">bWlkZ2FyZDE=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Claim Data Set" id="45">
<property name="dataSource">Data Source</property>
<method name="beforeOpen"><![CDATA[this.queryText =
this.queryText + " " + params["WHERE_CLAUSE"];]]></method>
<property name="queryText">SELECT (CASE WHEN
CLAIM1.SUBMITTED_CLAIM_IID IS NULL
THEN CLAIM1.CLAIM_IID
ELSE CLAIM1.SUBMITTED_CLAIM_IID
END
) AS 'COND CLAIM_IID',
CLAIM_LINE.CLAIM_LINE_IID AS 'CLAIM_LINE_IID',
CLAIM1.CLAIM_EID AS 'Claim Id',
PATIENT.MEDICAL_RECORD_NUMBER AS 'Patient Id',
PATIENT.DATE_OF_BIRTH AS 'Patient DOB',
CLAIM1.BATCH_EID AS 'Batch',
CLAIM1.CLAIM_STATUS AS 'Claim Status',
CLAIM1.ACCOUNT_EID AS 'Account Id',
ACCOUNT.NAME AS 'Account',
PATIENT.GENDER AS 'Gender',
ENTERPRISE.NAME AS 'Enterprise',
CLAIM1.PLAN_EID AS 'Plan Id',
INSURANCE_PLAN.DESCRIPTION AS 'Plan',
CLAIM1.SYSTEM_ENTRY_DATE AS 'Import Date',
CLAIM1.CONTEXT AS 'Environment',
CLAIM_LINE.SERVICE_START_DATE AS 'Begin DOS',
CLAIM_LINE.SERVICE_END_DATE AS 'End DOS',
CLAIM_LINE.ADJUSTED_PROCEDURE_CODE AS 'Adj Proc Code',
CLAIM_LINE_MODIFIER.MODIFIER_CODE AS 'Modifier Code',
CLAIM_LINE_DIAGNOSIS.DIAGNOSIS_CODE AS 'Diagnosis Code',
CLAIM_LINE.SERVICE_UNITS AS 'Units',
CLAIM_LINE.PLACE_OF_SERVICE_CODE AS 'POS',
CLAIM_LINE.TYPE_OF_SERVICE_CODE AS 'TOS',
PRACTITIONER.PRACTITIONER_EID AS 'Provider Id',
PRACTITIONER.FIRST_NAME + ' ' + PRACTITIONER.LAST_NAME AS 'Provider Name',
CLAIM_LINE.CHARGED_AMOUNT AS 'Sub Charge',
CLAIM_LINE.ADJUSTED_AMOUNT AS 'Adj Charge',
CLAIM_LINE.SEQUENCE_NUMBER AS 'Claim Line Seq',
CASE
WHEN CLAIM_LINE_EDIT.EDIT_MNEMONIC IS NOT NULL
THEN 'Yes'
ELSE 'No'
END
) AS 'Flag Indicator',
CLAIM_LINE_EDIT.EDIT_MNEMONIC AS 'Edit Mnemonic',
CLAIM_LINE_EDIT.EDIT_MESSAGE AS 'Edit Description',
CLAIM_LINE_EDIT.ACTION AS 'Flag Status',
CLAIM1.SUBMITTED_CLAIM_IID AS 'Submitted CLAIM_IID',
CLAIM1.CLAIM_IID AS 'CLAIM_IID',
CLAIM_LINE.CLAIM_LINE_EID AS 'Line EID',
CLAIM1.IS_MODIFIED AS 'Modified From Claim',
CLAIM_LINE.IS_MODIFIED AS 'Modified From Claim_Line',
CLAIM_LINE.RULESET_NAME AS 'Ruleset Name',
( CASE WHEN ( SELECT COUNT(PROCEDURE_CODE)
FROM PROCEDURE_CODE
WHERE PROCEDURE_CODE = CLAIM_LINE.ADJUSTED_PROCEDURE_CODE
AND CATEGORY = 'CP'
) = 0
THEN 0
ELSE 1
END
) AS 'AMA Adj Proc Code',
( SELECT SUM(CLAIM_LINE.CHARGED_AMOUNT)
FROM CLAIM_LINE
WHERE CLAIM_IID = CLAIM1.CLAIM_IID
AND CLAIM1.IS_MODIFIED = 'N'
GROUP BY CLAIM_IID
) AS 'Total Sub Charge',
( SELECT SUM(CLAIM_LINE.ADJUSTED_AMOUNT)
FROM CLAIM_LINE
GROUP BY CLAIM_IID
) AS 'Total Adj Charge',
( CASE WHEN (( SELECT COUNT(DISTINCT CLAIM_IID)
FROM CLAIM
OR SUBMITTED_CLAIM_IID = CLAIM1.CLAIM_IID
) > 1
AND CLAIM1.IS_MODIFIED = 'N')
THEN 0
ELSE 1
END
) AS 'Show Results'
FROM CLAIM CLAIM1
INNER JOIN CLAIM_LINE ON CLAIM1.CLAIM_IID = CLAIM_LINE.CLAIM_IID
INNER JOIN ENTERPRISE ON CLAIM1.ENTERPRISE_IID = ENTERPRISE.ENTERPRISE_IID
LEFT OUTER JOIN PROCEDURE_CODE ON CLAIM_LINE.ADJUSTED_PROCEDURE_CODE =
PROCEDURE_CODE.PROCEDURE_CODE
LEFT OUTER JOIN CLAIM_LINE_MODIFIER ON CLAIM_LINE.CLAIM_LINE_IID =
CLAIM_LINE_MODIFIER.CLAIM_LINE_IID
LEFT OUTER JOIN MODIFIER_CODE ON CLAIM_LINE_MODIFIER.MODIFIER_CODE =
MODIFIER_CODE.MODIFIER_CODE
LEFT OUTER JOIN CLAIM_LINE_DIAGNOSIS ON CLAIM_LINE.CLAIM_LINE_IID =
CLAIM_LINE_DIAGNOSIS.CLAIM_LINE_IID
LEFT OUTER JOIN DIAGNOSIS_CODE ON CLAIM_LINE_DIAGNOSIS.DIAGNOSIS_CODE =
DIAGNOSIS_CODE.DIAGNOSIS_CODE
LEFT OUTER JOIN INSURANCE_PLAN ON CLAIM1.PLAN_EID =
INSURANCE_PLAN.INSURANCE_PLAN_EID
LEFT OUTER JOIN ACCOUNT ON CLAIM1.ACCOUNT_EID = ACCOUNT.ACCOUNT_EID
LEFT OUTER JOIN CLAIM_LINE_EDIT ON CLAIM_LINE.CLAIM_LINE_IID =
CLAIM_LINE_EDIT.CLAIM_LINE_IID
LEFT OUTER JOIN PATIENT ON CLAIM1.PATIENT_IID = PATIENT.PATIENT_IID
LEFT OUTER JOIN PRACTITIONER ON CLAIM_LINE.PRACTITIONER_IID =
PRACTITIONER.PRACTITIONER_IID
WHERE
</property>
</oda-data-set>
<oda-data-set
name="UDF Data Set" id="907">
<list-property name="parameters">
<structure>
<property name="name">UDF_CL_IID</property>
<property name="dataType">integer</property>
<property name="position">1</property>
<expression name="defaultValue">10007</expression>
<property name="isInput">true</property>
</structure>
</list-property>
CLAIM.CLAIM_IID AS 'UDFDS CLAIM_IID',
CLAIM_LINE.CLAIM_LINE_IID AS 'UDFDS CLAIM_LINE_IID',
CLAIM_LINE.CLAIM_LINE_EID AS 'UDFDS Line ID',
UDF_DEFINITION.NAME AS 'UDFDS UDF Name',
UDF_DEFINITION.ORDINAL AS 'UDFDS Ordinal',
CLAIM_LINE_USER_DEFINED_FIELD.VALUE AS 'UDFDS UDF Value'
FROM
CLAIM
INNER JOIN CLAIM_LINE ON CLAIM.CLAIM_IID = CLAIM_LINE.CLAIM_IID
LEFT OUTER JOIN UDF_DEFINITION ON CLAIM.ENTERPRISE_IID =
UDF_DEFINITION.ENTERPRISE_IID
LEFT OUTER JOIN CLAIM_LINE_USER_DEFINED_FIELD ON
( CLAIM_LINE.CLAIM_LINE_IID = CLAIM_LINE_USER_DEFINED_FIELD.CLAIM_LINE_IID
AND UDF_DEFINITION.ORDINAL = CLAIM_LINE_USER_DEFINED_FIELD.ORDINAL)
WHERE CLAIM_LINE.CLAIM_IID = ?
</property>
</oda-data-set>
</data-sets>
<styles>
<style name="ReportHeader_Style" id="898">
<property name="fontFamily">Times New Roman</property>
<property name="fontSize">large</property>
<property name="fontWeight">bold</property>
</style>
<style name="Labels_Style" id="899">
<property name="fontSize">small</property>
</style>
<style name="Values_Style" id="900">
</style>
<style name="ReportSubHeading_Style" id="901">
<property name="textUnderline">underline</property>
</style>
<style name="Currency_Style" id="902">
<structure name="numberFormat">
<property name="category">Currency</property>
<property name="pattern">$#,##0.00</property>
</structure>
</style>
<style name="ClaimLinesTotals_Style" id="903">
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">thin</property>
</structure>
</style>
<style name="Date_Style" id="904">
<structure name="dateTimeFormat">
<property name="category">Custom</property>
<property name="pattern">Short Date</property>
</structure>
</style>
<style name="HeaderBloack_Style" id="905">
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">thin</property>
</style>
<style name="LineSeperator_Style" id="906">
<property name="borderTopStyle">none</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="orientation">landscape</property>
<property name="topMargin">0.604in</property>
<property name="leftMargin">0.416in</property>
<property name="bottomMargin">0.468in</property>
<property name="rightMargin">0.072in</property>
</simple-master-page>
</page-setup>
<body>
<list id="41">
<property name="dataSet">Claim Data Set</property>
<header>
<label id="200">
<property name="style">ReportHeader_Style</property>
<text-property name="text">Edit Error By
</label>
<grid id="151">
<property name="width">100%</property>
<column id="152">
<property name="style">Labels_Style</property>
</column>
<column id="153"/>
<column id="154">
</column>
<column id="155"/>
<column id="156">
</column>
<column id="157"/>
<row id="158">
<cell id="159">
<property
name="backgroundColor">silver</property>
<label id="201">
<property
Roman</property>
<text-property
name="text">Date:</text-property>
</label>
</cell>
<cell id="1160">
<property name="style">Values_Style</property>
<property
<text-data id="12270">
Set</property>
<expression
name="valueExpr">params["CURRENT_DATE"]</expression>
<property
name="contentType">html</property>
<property name="textAlign">left</property>
</text-data>
</cell>
<cell id="161">
<property
<label id="207">
<property
Roman</property>
<text-property name="text">Claim ID
Range:</text-property>
</label>
</cell>
<cell id="2162">
<property
<text-data id="62270">
Set</property>
<expression
name="valueExpr">params["CLAIM_ID_RANGE"]</expression>
<property
</text-data>
</cell>
<cell id="163">
<property
<label id="213">
<property
Roman</property>
<text-property name="text">Sort
by:</text-property>
</label>
</cell>
<cell id="92164">
<property
<text-data id="162270">
Set</property>
<expression
name="valueExpr">params["SORT_BY"]</expression>
<property
</text-data>
</cell>
</row>
<row id="165">
<cell id="166">
<property
<label id="202">
<property
Roman</property>
<text-property
name="text">Time:</text-property>
</label>
</cell>
<cell id="93167">
<property
<text-data id="32270">
Set</property>
<expression
name="valueExpr">params["CURRENT_TIME"]</expression>
<property
</text-data>
</cell>
<cell id="168">
<property
<label id="208">
<property
Roman</property>
<text-property name="text">Import Date
</label>
</cell>
<cell id="41969">
<property
<text-data id="429270">
Set</property>
<expression
name="valueExpr">params["IMPORT_DATE_RANGE"]</expression >
<property
</text-data>
</cell>
<cell id="170">
<property
<label id="214">
<property
Roman</property>
<text-property
name="text">Account(s):</text-property>
</label>
</cell>
<cell id="41971">
<property
<text-data id="4942270">
Set</property>
<expression
name="valueExpr">params["ACCOUNTS"]</expression>
<property
</text-data>
</cell>
</row>
<row id="172">
<cell id="173">
<property
<label id="203">
<property
Roman</property>
<text-property
name="text">Requester:</text-property>
</label>
</cell>
<cell id="95174">
<property
<text-data id="952270">
Set</property>
<expression
name="valueExpr">params["REQUESTER"]</expression>
<property
</text-data>
</cell>
<cell id="175">
<property
<label id="209">
<property
Roman</property>
<text-property name="text">Date of Service
</label>
</cell>
<cell id="95176">
<property
<text-data id="9852270">
Set</property>
<expression
name="valueExpr">params["DATE_OF_SERVICE_RANGE"]</expression >
<property
</text-data>
</cell>
<cell id="177">
<property
<label id="215">
<property
Roman</property>
<text-property
name="text">Plan(s):</text-property>
</label>
</cell>
<cell id="50178">
<property
<text-data id="502270">
Set</property>
<expression
name="valueExpr">params["PLANS"]</expression>
<property
</text-data>
</cell>
</row>
<row id="179">
<cell id="180">
<property
<label id="204">
<property
Roman</property>
<text-property name="text">Flag
Types:</text-property>
</label>
</cell>
<cell id="60181">
<property
<text-data id="620270">
Set</property>
<expression
name="valueExpr">params["FLAG_TYPES"]</expression>
<property
</text-data>
</cell>
<cell id="182">
<property
<label id="210">
<property
Roman</property>
<text-property name="text">Batch
</label>
</cell>
<cell id="61283">
<property
<text-data id="622270">
Set</property>
<expression
name="valueExpr">params["BATCH_RANGE"]</expression>
<property
</text-data>
</cell>
<cell id="184">
<property
<label id="216">
<property
Roman</property>
<text-property
name="text">Flag(s):</text-property>
</label>
</cell>
<cell id="61285">
<property
<text-data id="6922270">
Set</property>
<expression
name="valueExpr">params["FLAGS"]</expression>
<property
</text-data>
</cell>
</row>
<row id="186">
<cell id="187">
<property
<label id="205">
<property
Roman</property>
<text-property
name="text">Environment(s):</text-property>
</label>
</cell>
<cell id="71388">
<property
<text-data id="732270">
Set</property>
<expression
name="valueExpr">params["ENVIRONMENT"]</expression>
<property
</text-data>
</cell>
<cell id="189">
<property
<label id="211">
<property
Roman</property>
<text-property
name="text">Provider(s):</text-property>
</label>
</cell>
<cell id="73190">
<property
<text-data id="723270">
Set</property>
<expression
name="valueExpr">params["PROVIDER_RANGE"]</expression>
<property
</text-data>
</cell>
<cell id="191">
<property
<label id="217">
<property
Roman</property>
Statuses:</text-property>
</label>
</cell>
<cell id="73192">
<property
<text-data id="7023270">
Set</property>
<expression
name="valueExpr">params["CLAIM_STATUS"]</expression>
<property
</text-data>
</cell>
</row>
<row id="193">
<cell id="194">
<property
<label id="206">
<property
Roman</property>
<text-property name="text">Most Recent
Analysis:</text-property>
</label>
</cell>
<cell id="71495">
<property
<text-data id="742270">
Set</property>
<expression
name="valueExpr">params["MOST_RECENT_ANALYSIS"]</expression >
<property
</text-data>
</cell>
<cell id="196">
<property
<label id="212">
<property
Roman</property>
<text-property
name="text">Patient(s):</text-property>
</label>
</cell>
<cell id="81497">
<property
<text-data id="842270">
Set</property>
<expression
name="valueExpr">params["PATIENT_RANGE"]</expression>
<property
</text-data>
</cell>
<cell id="198">
<property
<label id="218">
<property
Roman</property>
<text-property
name="text">User(s):</text-property>
</label>
</cell>
<cell id="94199">
<property
<text-data id="942270">
Set</property>
<expression
name="valueExpr">params["USERS"]</expression>
<property
</text-data>
</cell>
</row>
</grid>
</header>
<group id="48">
<property name="groupName">Claim Header Group</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["COND
CLAIM_IID"]</expression>
<list-property name="sort">
<structure>
<expression
name="key">row["CLAIM_IID"]</expression>
</structure>
</list-property>
<header>
<label id="51">
<property
name="style">ReportSubHeading_Style</property>
Roman</property>
<property name="fontSize">smaller</property>
Current Time: Sat Nov 29 03:30:37 EST 2025
Powered by FUDForum. Page generated in 0.05205 seconds
