Home » Eclipse Projects » GEF » Determine nature of drag in createDragSourceFeedbackFigure
Determine nature of drag in createDragSourceFeedbackFigure [message #170712] Sun, 06 March 2005 19:16 Go to next message
I am overriding createDragSourceFeedbackFigure in my ResizableEditPolicy
so that I can add some features to the figure during drag. I don't want
those features during a resize operation. Is there a way to find out
what is causing the call?
As an aside, what causes the figure to change colour during the drag?
Anything I add to the feedback figure stays the same colour as I set it,
so if I use the same colours as the feedback figure they don't match.
Barry
Re: Determine nature of drag in createDragSourceFeedbackFigure [message #170896 is a reply to message #170712] Mon, 07 March 2005 23:11 Go to previous messageGo to next message
You can query the ChangeBoundsRequest object to determine whether the
current operation is a move or resize. If the request has a resize
direction or size delta, then you know it's a resize request.
I don't understand your second question.
"Barry Lay" <blay@laysercomputing.com> wrote in message
news:d0g6hs$pr8$1@www.eclipse.org...
>I am overriding createDragSourceFeedbackFigure in my ResizableEditPolicy so
>that I can add some features to the figure during drag. I don't want those
>features during a resize operation. Is there a way to find out what is
>causing the call?
> Barry
Re: Determine nature of drag in createDragSourceFeedbackFigure [message #171028 is a reply to message #170896] Tue, 08 March 2005 15:40 Go to previous messageGo to next message
How do I get the current Request? I don't have a reference to it (or
much else) in the createDragSourceFeedbackFigure method.
I tried to create my own sub-figures of the default from
NonResizableEditPolicy with the same foreground and background colours
as it has (white and black in the debugger). When I drag the figure the
main rectangle is yellow but my figures remain white and black.
Barry
>>causing the call?
>>Thanks,
>>Barry
Re: Determine nature of drag in createDragSourceFeedbackFigure [message #171082 is a reply to message #171028] Tue, 08 March 2005 22:43 Go to previous messageGo to next message
All EditPolicies do is cater to requests. So, whenever something's
happening in an EditPolicy, there was some request that triggered it. In
your case, it's the resize or move request that is asking to show the
necessary feedback.
Select the method name, and hit Ctrl + Alt + H to bring up the call
hierarchy. You'll find showChangeBoundsFeedback() in
NonResizableEditPolicy.
The default feedback figures use XOR.
news:d0l2k3$4nv$1@www.eclipse.org...
> Barry
so
those
> >>causing the call?
> >>Thanks,
> >>Barry
Re: Determine nature of drag in createDragSourceFeedbackFigure [message #171117 is a reply to message #171082] Wed, 09 March 2005 01:52 Go to previous message
> necessary feedback.
Yes, createDragSourceFeedbackFigure does get called the first time
showChangeBoundsFeedback is called and the latter method does have the
request as a parameter. I suppose that I can keep a local field around
so that I don't keep modifying the feedback figure every time the
feedback is updated for a drag (I am adding features to the original
figure that don't change once done). I have been wary of intercepting
the methods that are active during the drag operation for fear of
getting into timing problems.
Thanks again,
Barry
Previous Topic:DirectedGraph and Edge.tree field
Next Topic:GEF Errors
Current Time: Mon Sep 01 00:09:15 EDT 2025
Powered by FUDForum. Page generated in 0.07445 seconds
