Home » Eclipse Projects » GEF » How to refresh/redraw the whole of the container edit part
How to refresh/redraw the whole of the container edit part [message #170696] Sun, 06 March 2005 07:13 Go to next message
Hi all
I draw a line on the container editpart, and place right besides it another
edit part (this line marks the margin of the editing area). If i move the
edit part right or left, the line should be re-drawn accordingly, and remain
attached to left to the edit part. So far, if i move the edit part, only the
portion of the line that actually touched the edit part is re-drawn, this
results in a broken line. Is there a way to refresh the whole of the
appearance of the container editpart so that the all of the line would be
re-drawn?
thanks
Yoav
Re: How to refresh/redraw the whole of the container edit part [message #170743 is a reply to message #170696] Mon, 07 March 2005 03:09 Go to previous messageGo to next message
Originally posted by: no.mail.please
You should refresh the whole container in its refreshVisuals() method.
There, you can redraw the line at the exact position. This should work,
I use it in a gef editor to draw a blue rectangle at an exact position
of the container editpart.
Arnaud
PS :
I notice I use this piece of code in my refreshVisuals() (at the
beginning of it), which is taken from the ShapesDiagram example :
// notify parent container of changed position & location
// if this line is removed, the XYLayoutManager used by the parent
container
// (the Figure of the ShapesDiagramEditPart), will not know the bounds
of this figure
// and will not draw it correctly.
Rectangle bounds = new Rectangle(getCastedModel().getLocation(),
getCastedModel().getSize());
Maybe you should have a look at this if you encounter strange problems
with my solution.
Yoav Rubin a écrit :
> Hi all
> re-drawn?
> thanks
> Yoav
Re: How to refresh/redraw the whole of the container edit part [message #170904 is a reply to message #170696] Mon, 07 March 2005 23:17 Go to previous messageGo to next message
Have the child edit part, when it is moved or resized, call repaint() on the
parent container's figure. Or the parent can listen for this change on the
child and do that itself.
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:d0es5t$ku7$1@www.eclipse.org...
> Hi all
another
remain
the
> re-drawn?
> thanks
> Yoav
Re: How to refresh/redraw the whole of the container edit part [message #178719 is a reply to message #170904] Thu, 21 April 2005 15:07 Go to previous messageGo to next message
Originally posted by: kevinlouisnospam.hotmail.com
Can it call child.erase()? It causes the parent to repaint.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d0j909$803$1@www.eclipse.org...
the
the
> > Hi all
> another
the
> remain
> the
this
be
> > re-drawn?
> > thanks
> > Yoav
Re: How to refresh/redraw the whole of the container edit part [message #178785 is a reply to message #178719] Thu, 21 April 2005 17:19 Go to previous messageGo to next message
Hmm, I didn't even know there was an erase() method on Figure....
It seems that that method will erase the child from the old location, but
still not draw it in the new one.
Also, the best way to do what Rubin mentioned in this thread is to have the
line editpart's model be updated (either by the command, or the line model
can listen to the other model for bounds changes). Then, it's business as
usual: line model notifies line editpart of the change, and line editpart
updates the constraint which would cause it to be repainted.
"Kevin" <kevinlouisnospam@hotmail.com> wrote in message
news:d48tnt$2us$1@news.eclipse.org...
> the
> the
> > > Hi all
> > another
> the
> > remain
only
> > the
> this
> be
> > > re-drawn?
> > > thanks
> > > Yoav
Re: How to refresh/redraw the whole of the container edit part [message #179036 is a reply to message #170696] Mon, 25 April 2005 10:06 Go to previous message
I read the thread and still don't understand this part. Are you adding a
Polyline, painting inside the figure's paint method, or painting on the
canvas itself?
If you are using a Polyline, call setPoints(), don't just get the points and
modify them.
Previous Topic:Wrap Text
Next Topic:Question about SWT Image, ImageDescriptor, ImageData in the context of GEF
Current Time: Thu Jul 17 05:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.09811 seconds
