Home » Newcomers » Newcomers » Complier on 1.4 not compling correctly
Complier on 1.4 not compling correctly [message #170692] Wed, 13 September 2006 02:49 Go to next message
Originally posted by: rmeder.gmail.com
Hi All,
I have recently upgraded eclispe to the latest version 3.2. I never ran
into complier problems before. We are still using jdk 1.4 so had to change
the complier in eclispe from 5 to 1.4 when running our web application i
recieve the error listed below. Seems as if the complier is not compling
the BigDEcimal class correctly. Has enbody seen this before and have any
suggestions in fixes this. Would not want to go back to a previous version
of eclipse.
The line of code looks as follows: Bigdecimal bd = new Bigdecimal(0);
Err below:
java.lang.NoSuchMethodError: java.math.BigDecimal.(I)V
Workflow.entity.WorkflowItemSkel.getTotalTimeForChildren(Wor kflowItemSkel.java:254)
org.apache.jsp.show_005fTaskNormal_jsp._jspService(show_005f TaskNormal_jsp.java:674)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:133)
javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:311)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:301)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :248)
com.workpool.webapp.WorkpoolFilter.doFilter(WorkpoolFilter.j ava:86)
com.workpool.faces.HackFilter.doFilter(HackFilter.java:72)
Re: Complier on 1.4 not compling correctly [message #170755 is a reply to message #170692] Wed, 13 September 2006 04:32 Go to previous messageGo to next message
Ryan Meder wrote:
> Hi All,
> ran into complier problems before. We are still using jdk 1.4 so had
> to change the complier in eclispe from 5 to 1.4 when running our web
> application i recieve the error listed below. Seems as if the complier
> is not compling the BigDEcimal class correctly.
You must not only set the compliance to 1.4 but make sure your projects
have a 1.4 and not a 5.0 JRE on their Java build paths. It looks like
you used a BigDecimal constructor which is not yet available in 1.4.
Dani
> Has enbody seen this before and have any suggestions in fixes this.
> Would not want to go back to a previous version of eclipse.
> Err below:
Re: Complier on 1.4 not compling correctly [message #170798 is a reply to message #170755] Wed, 13 September 2006 06:11 Go to previous message
I had 1.4 and 1.5 jre installed after uninstalling 1.5 it works
Previous Topic:message
Next Topic:PDA Debugger
Current Time: Sun Nov 23 10:39:06 EST 2025
Powered by FUDForum. Page generated in 0.09016 seconds
