Home » Eclipse Projects » Eclipse Platform » CVS branches
CVS branches [message #169992] Fri, 12 December 2003 19:51 Go to next message
Originally posted by: rajeshk.andrew.cmu.edu
I have created a branch in the CVS repository for a java project (not a
plugin). I was using Eclipse as a pure Java development environment. I
am using Eclipse 2.1
However when I access the the CVS server from another machine (not the
one on which I made the branch) then the branch does not appear in the
CVS perspective - actually none of the branches except one particulat
branch (say 'X')appears. On the machine where I made the branch I can
see different branches but not the 'X' branch.
This seems bizarre. Has anyone any idea how to fix this?
I have tried "Refresh View" and "Refresh Branches" in the CVS
perspective and it doesn't work.
Appreciate all comments.
Re: CVS branches [message #170553 is a reply to message #169992] Mon, 15 December 2003 14:32 Go to previous message
Originally posted by: Michael_Valenta.oti.com
Try Configure Branches and Versions on the project in the CVS
Repositories view. You should be able to select a file and see the tags
on that file. You can then add all or selected tags to those known by
Eclipse.
Previous Topic:Preferences and CVS windows completely empty!!
Next Topic:[ANN] SWT Designer 1.2.2 Released
Current Time: Mon Sep 01 01:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.04659 seconds
