Home » Modeling » GMF (Graphical Modeling Framework) » How to extend the diagram xml/xmi file?
How to extend the diagram xml/xmi file? [message #169976] Fri, 25 January 2008 18:51 Go to next message
Originally posted by: raedler.inf.uni-konstanz.de
first of all I have to say that both, model and diagram are written into
the same file. Here called pad file. Now I want to add new attributes to
the model as shown below.
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:Designer="http://www.notnecessary.com/designer"
xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation">
<Designer:PipeArea xmi:id="_lE21oMuCEdys2vun_V9mYA">
<pumpingStations xmi:type="Designer:Tracking"
xmi:id="_mH9RYMuCEdys2vun_V9mYA" name="Trancking_Name"/>
<pumpingStations xmi:type="Designer:Peeking"
xmi:id="_59qJIMuFEdyQ9a1Rsyvaew" name="Peek1" m_noise="0.5" e_noise="0.1"/>
</Designer:PipeArea>
to
<pumpingStations xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="Designer:Peeking" xmi:type="Designer:Peeking"
Is it possible to manipulate the model/diagram output and extend it with
more information?
Thank You!
Re: How to extend the diagram xml/xmi file? [message #169993 is a reply to message #169976] Sat, 26 January 2008 08:57 Go to previous messageGo to next message
--------------090704070107070404060403
Roman,
This XMIResource option can be forced to make it use xmi:type or
xsi:type, but not both:
* Write the type of an element as "xmi:type" instead of "xsi:type"
* which is useful for models with multiple inheritance that may
* conflict with XML schema types
String OPTION_USE_XMI_TYPE = "USE_XMI_TYPE";
Deserialization should handle either form the same.
Roman Raedle wrote:
> into the same file. Here called pad file. Now I want to add new
> attributes to the model as shown below.
> e_noise="0.1"/>
> to
> <pumpingStations
> e_noise="0.1"/>
> with more information?
> Thank You!
<html>
<head>
http-equiv="Content-Type">
</head>
Roman,<br>
<br>
xsi:type, but not both:<br>
<blockquote><small>
Re: How to extend the diagram xml/xmi file? [message #170100 is a reply to message #169993] Sun, 27 January 2008 14:54 Go to previous messageGo to next message
Where do I find this setting or how do I change this?
Re: How to extend the diagram xml/xmi file? [message #170109 is a reply to message #170100] Sun, 27 January 2008 15:49 Go to previous message
--------------030606010909050201070203
Roman,
Ctrl-Shift-T is a handy way to find files if someone hasn't told you the
fully qualified name. It is an option that can be passed while saving a
resource via the options map for the save method. Normally though,
you'd specified it in the resource factory when the resource is created
so so anywhere it's saved, it will use that option. You're getting this
form in the first place because that's how GMFResourceFactory specifies it.
|*public class *GMFResourceFactory
*extends *XMIResourceFactoryImpl {
*public *GMFResourceFactory() {
*super*();
// default load options.
*private static final *Map loadOptions = *new *HashMap();
// default save options.
*private static final *Map saveOptions = *new *HashMap();
*static *{
XMIResource resource = *new *XMIResourceImpl();
loadOptions.putAll(resource.getDefaultLoadOptions());
loadOptions.put(XMIResource.OPTION_LAX_FEATURE_PROCESSING, Boolean.TRUE);
saveOptions.putAll(resource.getDefaultSaveOptions());
saveOptions.put(XMIResource.OPTION_DECLARE_XML, Boolean.TRUE);
saveOptions.put(XMIResource.OPTION_PROCESS_DANGLING_HREF,
XMIResource.OPTION_PROCESS_DANGLING_HREF_DISCARD);
saveOptions.put(XMIResource.OPTION_SCHEMA_LOCATION, Boolean.TRUE);
* saveOptions.put(XMIResource.OPTION_USE_XMI_TYPE, Boolean.TRUE);*
saveOptions.put(XMIResource.OPTION_SAVE_TYPE_INFORMATION, Boolean.TRUE);
saveOptions.put(XMIResource.OPTION_SKIP_ESCAPE_URI, Boolean.FALSE);
saveOptions.put(XMIResource.OPTION_ENCODING, EMFCoreConstants.XMI_ENCODING);
* Get default load options.
*public static *Map getDefaultLoadOptions() {
*return *loadOptions;
* Get default save options.
*public static *Map getDefaultSaveOptions() {
*return *saveOptions;
*public *Resource createResource(URI uri) {
XMIResource resource = *new *GMFResource(uri);
resource.getDefaultLoadOptions().putAll(loadOptions);
resource.getDefaultSaveOptions().putAll(saveOptions);
*if *(!resource.getEncoding().equals(EMFCoreConstants.XMI_ENCODI NG))
resource.setEncoding(EMFCoreConstants.XMI_ENCODING);
*return *resource;
<html>
<head>
</head>
Roman,<br>
<br>
the fully qualified name.
Previous Topic:Getting PropertySource for EMF within GMF editor
Next Topic:Listening on EditPart's label
Current Time: Fri Jul 25 02:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.19380 seconds
