Home » Modeling » GMF (Graphical Modeling Framework) » Arrage Element always in the (horizontal) center of a compartment
Arrage Element always in the (horizontal) center of a compartment [message #169921] Fri, 25 January 2008 12:30 Go to next message
Originally posted by: snej_NO-SPAM_.esuark.de
Hi there,
i want that an childelement is always horizontal centered in a
compartment. Could it be an option that new created elements could only
be created in the center, so "snap" on a virtual line in the center of
the compartment? Could this be done with gmf own stuff like .gmfgraph /
..gmfmap specifications?
Any suggestion would be a great help.
Jens
Re: Arrage Element always in the (horizontal) center of a compartment [message #170881 is a reply to message #169921] Thu, 31 January 2008 08:07 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Sounds like ToolbarLayout )))
Jens Krause wrote:
> Hi there,
> Jens
Re: Arrage Element always in the (horizontal) center of a compartment [message #171114 is a reply to message #170881] Fri, 01 February 2008 08:38 Go to previous messageGo to next message
--------------040106020509000101050001
Content-Type: text/plain; charset=UTF-8; format=flowed
Well, thanks for this suggestion, but my understanding of ToolbarLayout
is that you could not move the elements, right? I need the opportunity
to move the element up and down, but not left and right.
I have attached two screenshots. Sequence_is.png shows how you could
move the "method" EditPart right away from the center of the parent
figure "objekt:typ", and sequence_should_be.png as i want it to be by
default. If i take ToolbarLayout, there is no space between two "method"
EditParts, right?
jens
Content-Type: image/png;
name="sequence_is.png"
Content-Disposition: inline;
filename="sequence_is.png"
iVBORw0KGgoAAAANSUhEUgAAAKIAAAGcCAIAAAGikNyzAAAABGdBTUEAALGP C/xhBQAAAAlw
SFlzAAALEwAACxMBAJqcGAAAAAd0SU1FB9gCAQ0iASio5QIAABeKSURBVHja 7Z19cBRVusaf
NpFCdJPMrJlcE9hZZSHoIhiq8A+um/QQpRAWXFIiRGQvfkRTZYzWQgEKSAIx GqiSy8B642VL
XF29y8V1vcarJYsyEUkVF8UyopWYgFJISBiYgTUwEDLp+0ePPZP5ynx0z/T0 +/6KonpOf5zz
nOeck9Onu88RJElCElyVzMl8frjzbTYbgLFjx44bNw7AhAkTopwvGNs/QRD0 nf7sJM51JBV/
Z+cPJtOCEfwXhIgHyFkbfrcgCC6Xb9tkktxuvwsm07Djw6dfkiS7vQ5AZSV+ 8QvBbI6cwEjJ
C4wzkJjijx1t/FeyPUr+R4s/9kqdbv18vurnu91CfX292y243YLLBXnD7RbC toVhilekmmM2
hylXOtQfF4m3f/pIP5+vu/PdbuHW559Xp/4VFKCvz7edSP1TTtZr/mV6/Uuq /5xU5HzyT3R3
d3d3dweGTJ8+PfQwtiqVJyd8Y+NINuYEfY52P4OAVtlshnJvE9QkXxXpTPlm BkBnpz88Ly8v
pmSH7Y/FdBsT+R7INPLJsWbbiLkd2IYHtedcJWmcHKYxkMtmeTk++mhYeFDB Rly3KKEnZ2iG
ccXgk0ckYq167TX8/vfDwhOsVVYrrlyBxxN8ZEx/3I8f11uGZWitSnaMPm0J 57gNGLfNZnN8
/6q8XVVVdenSpaampsuXLwOwWCxyuDLUIW84nc5rr7125MgltZk0aVKMR3Id y7C4R3yyp1/d
GVvWEsjze++deebM/wAOwJGU7hFHAsPh8J+exjyPbygktBe2dy/uvBMYPvSg cNNNeW63O9LV
ki3nd96JoSGUlWHNGn+g1QoAxcUjnBtHnsvuRrqtC0vY4fBEdMcbMUKGbhLX LRMavdxfj2Xk
J9m4VYTb89TDeZ560pnnMemOtzmL3pQmolsZ8AbQ2goA11+fjOxM0a06GVvH EuqvGUB3knB7
nno4z1NPTPdEaW7PS5sbqzralJ+LF6ugm/+OpR5uW1JP2vI8baI5YkNFHLbu GVoxR6z3iB3f
vyp/3AUgNzcXgPxYzev13n///YIgjB071vcamyDk5+dfuXJFeTYXjRGfjomi GDZ83Lhxcjuv
hMjbDz/8cFdX19ixY4PCg0jwgd9nn30W+8FhI07FX6ewN8A6LlwccaZHzH0u jth4ESfzhWzc
CIIgSfvSo/j48b7f/nZtGiK2WgtGjbp65I+B1SUwq1MdsX87XU1mHKU68GPq QMK+DQAVH4zL
KI9ylK+ww8Y6IvFF3N7uEEWxvd0h/2xpGbbX5YLFgqNHccstOHZspGvF1Vl0 uTC5sdHl8qmU
N8aN8/8EsHQpTp3C/fePcPH4Cldcg37RXwKII6vjHWKKfryGLVf0Qkfvz2J8 L7iEDY9UiKIX
rvharrBxxxvu28vdW46YI+aIOWKOmCNOe8SaPMKP3veIT3HgS2gIuH8J2o6d RLJaHq/Pz8fP
f+4PzM/H4KDv/1jQ5K0BNbNadThijlgz+E6CI+aIOWKOmCPmiDni1KP7e6fS 5sbAn6m7dyoW
RSVu+alPR4f/U1OPB7fcgu5u/PrXOHo0tivG8uBHfswT+A/AunV49VXIExe4 XDh1yvfgp74+
pmvyTRtHbLyI+d6JIzZexOn8RCRdpPPzENbMmllzLMT+go5xNMcOa6YBa6aB OpptNpvynVS8
RGpvk/wWNxoJfAIVhCiK+77bue+7nUEfan377beSJBUWFkqS1NXVJUlSUVGR vMtqtUqS1Nvb
K/d8lXDlRVjl/2PHjg0MDDz22GOhFwl9fTbGBKs/1aPCI488kpOT4/F4JElq amoaM2aMvC1J
ktfrtVqtt912m5LWm2++WZKk6667TglpaGiQN1paWoaGhkIvkrBm49xjxD63 C7dhNGDNNKCo
OdYX3jXsIaSctP2tSnLasGSgWLZZMw2M0/eMnZR+OJxiIv2tSZvm1LTbygfD gRi8Ps+f/+zB
gx3Kz4qK+v5+j8E1Dw0N3Xjjv5w65ZozZw2A7OyrRo8eZeQ+SeDH8MPCud1W B7nBlCQpaO27
SLjdbvmU6FO9B3Lu3DnEs/T2sORp5HPg3AGlzY2fVD+jehTR1x+IgrZtWHu7 w26v2z5jht1e
p0wjAMBsxu7dALByJQB4vZg4EVVVvl3yu207d6KgAF9/DQBPPgmrFfIUWjU1 KC5O8P03HxoN
egL+N9fq6upC32U7exY33+z7WVQ0bFfQkS4XPvsMLhduuMG/DSAvLy+xtKWi bGtEwmVbE81K
GxbvS4OxI5ftxBKvSX2Wk6KdYAAuVxyNfCo06xzWTANt27AYR0tjPzL0RL1o 1jkUy3b6XjRN
30MC9pkGFDVzu00DbrdpwJppwO02DbjdpoFq9TkFvqmVVNWeVymj2fLziilT xLhOjzQfdOAB
aqFm2S5tblRmarPb6wJnHjh+HJIEm82X9AUL0N/ve3Cj0NODTZsAYO1aOJ2o qACA9etx5gwW
LlQxmao+l5QfxMk+19bW1QbskhfX3rfPpzk7G6NHQ34I0d2NX/0KAAoLfbkg CBAEZGX5tlVH
tfqs6Qg+Yl4CLxYottusmQasmQZGflcqEhR9Zs004HESGvA4CQ1YMw243aYB t9s0YM004Hab
BhTbbR7TT5rS5saqjraqjragabLXrQOADz7wPbvZsAGFhbh40f9lkdmMqVMh igBw+TKsVjz1
lG+7qAjbtqmZSPV9ltWGfkQ2fToOHfI9f+zpQWHhsL2BzyVvuQXffIOjRzF+ PCZPxpEjOHoU
06er5jOXbRqwZhqwZhpQfG+I7zFSCI+TsGbWrDoU2zCKmimWbdZMA9ZMA9ZM A9YcASNNUByr
ZoPBmmnAmmnAmmnAmmnAmhMl4QW7MlizKL8IEoHA7nqUrnvKevXJam5tba2v rxdFsb6+vrW1
VQm/dOlSbm7uo48+Kv8sKCh46KGHlL1PP/30mDFjLly4IP88dOiQ3W4PlC0I giAIbrf7zJkz
ACwWiyAIQRdJm+ZIjB8//vz588uXL5d/9vX1rV69Wtn7wAMPXLx4cfz48QA2 b96clZVVW1uL
gCeP8sS6JpNp2rRpALZv3x56kcSJccLh6AfU1dUFhcjL0HV2diqnB26fOHFC OfLEiRObNm2K
FMuhQ4f2798fdJEkUUdz0Op7kiR5PJ6cnJxHHnlEPt1isSxbtky5VGNj49VX X71792754FOn
Tm3YsEFZgE5GXptO+mnBvsCLJElMzzFU/J6zqKjo5MmTsR9//vz5CxcuFBYW qpiGVGvWA9wn
oQFrpgFrpgFrpgFrpgFFzcZZOzX2OwJD3TzECMWyzZppwJppwJppwJppQFEz xTWvjd3fdoQN
pVi2Da55xYqXvd6hd945QEiz291/6dLA7373rwA2b/7vnp6zjz++zfj1WZKk mprtf/zjE/n5
9w4OemF4n//+9wNDQ1Je3nUAnn668vDh/zhw4N+N73MoBvc5LEb2mWafJDwU y7Ym/W25UMW+
JvW5c+cASJJkMpliOd7tdivL8CaSPC3Ktpyg2NdzVxYqj3GiJpNJ0p1mk8l0 7Ng51S8blE0J
p1zz+lza3Bg0fxqA117zJz2SJO3QVnNpc2OxKBaLYpDsri4A+OAD38/QaeMA DaeNS0+7vXEj
Wlrw5z/7ft53H3p6UFICl8vfCnz5pS9TSkpw/DhqagBg2jScPIk5c5KKXdtx kk+qn4k0Vd6G
Db6p8gDk5ABAZ2fw6ddc49+W+xeqPB3V3OdPqp8JFQzg0CH/9q5dKCjAu+8C wLhxwUd+8QWs
VtjtAPD55ygsxPvvJ5Ukiu22hn1P7WZFNJmSSrMmZVv+skAjwclHQbG/rYnm vLy82DueCSDX
Gv32w3QIa6YBa6YBRc266Icp/arYx0l0pzmxHpIkSTGeqByZWOI1vJeM46XT n6SmZuCZx7dp
wJppwJppwJppwJppwJppwJppwJppwJppwJppwJppwJppwJppwJppwJppwJpp oM4z9wxaLFY1
zYjnK5u0o37ZDv3iJHnU/SRFZc1VHW3FoljV0RaUYq8XAObP11ZMGjTLDj8x MIAQt8vKIEnY
sgUANm9GT4/vmxKFZcvg8aC8HAAWLYLTiXXrAGDxYjidKmtW5x0aQRDk+qw4 vGPSDGWv2Yy3
3sL69di/HwAsFkgSvF64XDCbhzUE8k+vF1lZsFhw+rRvO5kvEUJRuWzvmDSj 0+EIFCwzc6ZP
MIDVq3HwINraACA3N8xFli6F04nqagBYskT3PmtHku/+BUKxT8KaacCaacCa acCaacCaaUBR
M3+PQQPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPWTAPW TAPWTAPWTAPW
TAOKmlX7poz0e/pafF+lLuprvndgIChE+Yhq715E2hUd/X5T1t7usNvrRFG0 2+va2x2Bu3bv
BoA9ewDA68XEiaiqGqZn504UFODrrwHgySdhteLyZQCoqUFxsZqCVdYchbff RksLNm0CgGnT
8O23aPypBsgNwT33oK8PNhsA1Nbi+HGUlADAH/4QZu2fJFFzLuopU8QpU2C3 19XW1gXtevNN
3HEH5s0DgKEhAMjPH3aA7PbgIKDqEkZhUd/nt0aNCg0UBBz4aW3eL7/E1Kko KwOANWvC1NWt
W2G14vBhAHjxRfXLNn9TRgPWTAPWTAPWTAPWTAPWTAPV+ttaJ1TF78D4mzIa sGYasGYasGYa
sGYasGYaUOxvE4Ri0SYI20wCtpkEbDMJ2GYSsM0kYJtJoOY7jyl4QkcE1Qcz 1LRZi/QRRIva
wo02CdhmErDNJGCbScA2k4BtJgHbTAK2mQRsMwnYZhLoyObW1labzdba2prY 6QmPEVIYiteL
zY7vX3U4HOt3/pvD4XB8/2q6kxPN+0wsFmm22Waz2Wy2+vp6AKIoCsdvFEUR QH19vbwr9JTl
y5fPnTv39OnTfX19s2bNWrFihbJr7ty5fX19p0+fvvvuu1etWiUHKq5s3Ljx rrvu+uGHH378
8ccHH3ywZvj62m+//bbFYnnvvffCpjOStbW1tQ0NDfL2hx9+OG/ePPngsClJ J5J6JHO1fd/t
rKurU/6PcmRWVtbg4KC8feXKlezsbCX2SOHyRnZ2dlZWVlZW1lVXXSWboRxw 0003rVmzJkYt
Qbvuu+++119/3ev1FhcXezyeKClJQTZGvKaa10oufQ6HQxRFh8MR/bDly5fP mzdPrs2zZ89e
sWKFErtch+TwVatWBaXqueeemz17dldX15UrV44cOVJZWRl4wMmTJ4uLixsb G+XAvLy8jo6O
sNKCdkmSVFZWNmPGDCXlkVKSmmwMi5qv48v1I93NU3BblZ2d7fV6NY3lpZde Onny5HPPPadK
PmiRjQa3ORPRIhv10tNmNIVtJgHbTAK2mQRsMwnYZhKwzSRgm0nANpOAbSYB 20wCtpkEatqc
Ec8tmpqa0p2EEdAiG8k9U6L5GI0bbRKwzSRgm0nANpOAbSYB20wCtpkE5GzW xTcQKYfiWAFB
yNVmmqg8y5/+aWpqMkC7LQiCJO2L43hqjbYxxrTjtZlcbTYS//znxeef/6/3 3/+/np6zP/vZ
NXfcMbmqas5vfnNr6JFGKNpxYaTaXFCw8Nix16+9dnToAV7vUEPDG3/5y0f9 /Z45c243gub4
MyjjJcs2nz9/Ydu2d/bs+byr6+T11+fMnz9j1apFOTljAEyZ8ujf/rZ+woQi AKdPnzOC5vgz
KOMlh/3b7PEM/PKXS/r6dgOYPLnqH/9ouuEGs7yL/zZnMJ9+euTll//300+P 9Pd78vNzZ84s
+eqrHfKu9vb/3Lr17Z07P+ztdU+YUGSEoh0XBq7NUeDhERKQa7QNMDaC+F8L NEILxoxIxtTm
wJm5NCqaxogiLBljcxCqT7UXmukpiCJlZIzNQXnkchkhipSRST1tk8kkCILb Lbjdw+pZe7uj
tLmxvd2RzMXlywb+C3uY2ZxUFDImkynFWZdJNoelqqPN4XAUi6LD4ajqaIty pNmM8nIEzgQ3
f/7ItiXjq37IVJtLmxtLmxvt9joAoig+MTAgz+lqt9fJu8Ke9corKCuDJEGS YLNhyxb/rs2b
sWABenrQ34+aGqxcGTHqZcvQ0wOPB5s2obzcF7h2LRYtgtMJpxMVFVi3zhe+ fj0WL8aZM3A6
sXBh2rIrk26oTCbTuXPngv5kVnW03bpnz1ezZsn/75g0I9LpZjNcLnz8MTZu xOAgGhpQVuYL
BGCxQM4JScLQEAQBZ8/6zwq6SOjP/Hz09iIrCwAGB1FYiNOnw4RbLACQl5fn drtTmXWZWpsV
dkyaIYpip8MhimIUjxVmzsS+fdi/H2Vlw8JXr4Yo4uBB9PairQ0VFb7w3Fx0 d4+cjOpqLF3q
q7WVlaiu9oU//jiWLPGHp4uMr80Zh9nMtZnRhoypzUHjR5FuePSMySSlaxSM azMJMnUULEPh
UbCRiTQKlinIKedRMEYr2GYSsM0kYJtJwDaTgG0mAY+C+QgdokpBFJrkVDgy 1WbVbz3dbnfq
o9Akp8KRMTarxerVq1944YV0pyLVkLOZJtwFIwE5m/U/n7YWkGu0jfFFZLyQ q800YZtJwDaT
gG0mAdtMAraZBGwzCcjZbIy5R+KF4lgBQcjVZpqQs5nHtEnAY9qMYWGbScA2 k4BtJgHbTAK2
mQRsMwnI2cxj2oxhIVebaULOZh7TJgGPaTOGhW0mAdtMAraZBPrqjwiCYIB5 lHWVpTKZUZsj
LWrAxEgG2Fza3HjvwMCITpvNeO21YSF798a9YkmSC5jodv0T/dosLztkt9cV i6IoisWiKC9X
EmUhoq4u7N7t2/7gA+zZ49/l9WLDBkyciMJCVFXh4kXgJ1fM5mH27NyJqVNR UABRxNdf+wIv
X8aTT8JqhdWKp57C5cv+8JoaFBWhuBjbtqU7yyKTMRMtx8LGjaisxOjRAPDG G/jrX/GnP/l2
TZuGXbvw7LMA4HSipASdnXC5gpcoAXDPPXjwQQDweGC1+lYmKSlBSwu2bgWA 7m6UlOCbb3yX
bWnB9u0AcPQo1q9PdxZEQL82T5kifjIFAEqbRzkGBjpHjdpRW1c70llvvonb b8eoUThwYFj4
0BBycnzb+fno7Ix4BaVmX3MNBgf94cpUT4IwbDsj0G+jrfBJ9TNvjRr1SfUz sRwsCDh0KNhj
AF9+iV27fK1xWRnefdcXvmYNxo0b+W/qF19g61Zfo2234/BhX/jnn+PFF1FY iOJivP9+unMq
SrboqvfPN1QakQG1mUketpkEbDMJ2GYSsM0kYJtJwDaTgG0mAdtMAraZBGwz CXQ3pp3uJKiA
rrJURl82p0Iwv47PGBW2mQRsMwnYZhKwzSRgm0lAzmaee4QxLORqM03I2cxz j5CABzsZw8I2
k4BtJgHbTAK2mQRsMwnYZhKQs5nHtBnDQq4204SczTymTQIe02YMC9tMAraZ BGwzCdhmErDN
JGCbSUDOZh7TZgwLudpME3I285g2CWiOaetLM08xoxG6W+vCALPj65AM+Nss r1QUZV0iFeF1
qNJDVUebw+EoFkWHw1HV0RblSLMZ5eXwev0h8+fHvdyYUdGpzaXNjfJaYwBE UXxiYEAURQDy
imORVph75RWUlUGSIEmw2bBli3/X5s1YsAA9PejvR00NVq6MGPWyZejpgceD TZtQXu4LXLsW
ixbB6YTTiYoKrFvnC1+/HosX48wZOJ1YuDDduRYZ3XXBgv42V3W03bpnz1ez Zsn/75g0I9K5
8sJhH3+MjRsxOIiGBpSV+VcTs1ggC5UkDA1BEHD2rP+soIuE/szPR28vsrIA YHAQhYW+ZciC
wi0WOQodZamMTmuzwo5JM0RR7HQ4RFGM4rHCzJnYtw/796OsbFj46tUQRRw8 iN5etLWhosIX
npuL7u6Rk1FdjaVLfbW2shLV1b7wxx/HkiX+cN2i99qccfA6VEzaYJtJwDaT gG0mAdtMAraZ
BGwzCdhmErDNJGCbScA2k4BtJoG+Hl0wGsG1mQTkbOb3tElA8z1tcrWZJmwz CdhmErDNJGCb
ScA2k4BtJgE5m3nuEcaw/D8zBcV40y6aCgAAAABJRU5ErkJggg==
name="sequence_should_be.png"
filename="sequence_should_be.png"
iVBORw0KGgoAAAANSUhEUgAAALsAAAGkCAIAAAGRAvNRAAAABGdBTUEAALGP C/xhBQAAAAlw
SFlzAAALEwAACxMBAJqcGAAAAAd0SU1FB9gCAQ0iGTvEfVQAABSSSURBVHja 7d19bBR1/gfw
91Bo8OFA9q7tZQvZ388Yine5YolnCLm0sxINhhMi8QE0nKBUSY4r3mkEebAt kBpqgqFq0kRz
GKJEgjHRGokEjwUCF0PA0BPTCujPIAgt18b4UFq6nd8fs2zb5fPd8tnuw8zy foWQ6ezu9Lvv
vmdmt9PZsRzHQTqMSctSuCAvLCgcDtfX18e/XLp06UcffWRZVk1Nzdy5c8WH WOwRF5SXCxpr
uqG723InAgF0dcX+BzBpkrwmjDwi9/Hu/77KKG0L4maEC0qHkVfaBKaV1rig uPja/9vfYswY
nD2rHFGcb9d+rrRckKcWlN2137LgOCgoAID+fuWI4kZc79OcEdf+bD219Awn D5ZiWVYalpLF
Z7R//34AFy5c6Ojo2Lhxozt+y7I++eSTVatWCU8wtb5Y1rAHej8X9RPkeuTf pdTX13d3W1f/
E+9s/Emr9ry+yEWFawCXopGeV7DGsVQ2NwD44x9x7lxszunTOH1avnP+rdNc G7mU7C8lw+t0
U1MdgHAYRUWxOf39xvejXKczORYvPaN0Sdub6jwczQi/3Ul435sWSboxNuVH pib50/PWT0o3
Gvf9f2rPO/2jGaqjoyP+f0NDw4kTJwC89NJL7e3tlmVNmjTJHf2f//zn1atX X+Mys729Sfi1
R9qyyQRvjYZ7Bo6Go0mvkY/QJDC9UjYxHWMSpZKN+wbAFQ4jEEBREX79awAI BACgqAj9/bH/
VdTbG89lkzneGg33DBwNR8PRcDTXpLvbevDf//7DSy/Fj2pZlvX3v1tnz1qu 6dOt8+etxx+3
zp+3NmzQ7dS41/TLaNQ/Ke1bf9XyuQ/naDgajoajuSbd3VbCn6hYljyd5O9W TLgP52hSwX24
GbPhaDiafB5Nto+HJ9+gcHvD0Vxvo0n+lwtZHY37SQLhcBjA3Llzn3vuublz 57qnT3z33XcA
3n///asf5f5pQ/pHU1tbC2Dfvn0ACgoKrCsAXLp0CcDMmTOH3t+2bW023N5w NBwNRzOSdL0M
ysdsOBoz8dTDFOTjforrFEeTivxcp3R/06b91XUgoDuuOaq/aZs9O73RjK43 n34K9w3Wb36T
ntHoeuPFn1TmcDQcjf9HAycdVq1alZbleGs/xdd+HE3uRpOfr/24TnE0uRsN 16kkz4nrVMb5
/P1UZXNDddthd3r9euzeDQDBYOw8runTASAUAoDS0qxkU9nccGD5mkxk4/Of VEZxNBxNKnTr
VAr7oxycz5D80wKunbd+Uvk4Gr72S/Kc+NqPo0kB16kkz4nrFEeTAq5TSZ5T mtYp/7+74xFo
iRd/UpnD0XA0/h8N91OZHk26cDRm3mqxp4z94IMPcj0Gj2JrjLy1ensKozFi NEaMxijPoxnN
q9E8j2Y0GI0RozFiNEaMxiiD0dTX17ufhZAC054lE5cWMcl2a6LRKIBx48Yl TLsTY8eOjT/5
devWJVnO22+/PW3atKsXkk5pOSljlAYGBrQPef3116/lbqN5gnn+zns0f5bE zbARozFiNEaM
xojRGHkrms2bN6d3gaPZ/3pr552uPwFOC2+1xlMYjRGjMfLQuu013mpN2vdQ o+Gt1nAP5Q+M
xojRGHlo3fYa9dUzVbLwW+7M/WgzG01XV2yitTUCoLzcVj08EBhcgukOmZPx bU1lc0P87/eb
muoqmxviN337LRwndp1UAA88gJ9+wvPPD3v4uXNobASAdevQ2YkFCwCgthYX L+KhhzI78sy2
BoB7Or/bmpqaupohN7mfLLBvXyyasWMxfjy6uwHg1CncdhsABIOxsCwLloWC gth0FmR2M6w9
s0FLeyaECnfeRozGiNEYMRojRmPkrTcKnvqlhIeG4jXeWqH4Wz7zaLy0Qnmr NZ7CaIwYjZGH
1m2v8VZruIcyj4Z7KF9gNEaMxshD67bXeKs13EOZR8M9lC/wYItRllpT2dww 9Lila/v2wWdo
euY5lI1oKpsbymy7zLYT0vnLX9DSgoULY1+2tQFAWVniw3t6AOB3vwOAU6cA 4Pe/B4DTpzM8
7oyeA9bVhWv5B6CrC+vXY9w4vPUWurpw002D891/33+PX/0KixfHpsePh3vy YuYGz22NEfdQ
RozGiNEYMRojRmPkofcs4Hsov2A0RozGyEPrttd4qzX8LZ95NNxD+QKjMWI0 Rh5at73GW63h
Hso8Gu6hfIHRGDEaIw+t217jrdZcR3sonsxsxJOZk+HJzEY8mVnGY975idEY MRojRmPEaIz4
HsrIW625jt5DqUfD3/L5AqMxYjRGHlq3PYWVkTEXGa8fK+P2Rcb1SMZcZMxF xlxkzEXGXGTM
RcZcZMxFlvrh2mxejjRlKb+aH9Vh7Dx+D8H1SMZcZMxFxlxkzEXGXGTMRcZc ZMxFxlxkGcwl
HA4nudXjb69SP06S/O8zIv/3ljth/8+SFB6uvVvaZaQvblOsb/8Xw1vz7LPP dnR03Hvvve6X
Fy5cuO+++3ClO/fcc8+PP/64YsUK99bi4mLT8jdt2gTg/vvvtywrvpA0S/mT wpI/dt8329x/
Q2cWFBQ4jnP58uX4w4dOFxQUjBkzxi3IrbfemuS7PPzww9FotKenZ+hC0itT uTiOY9t2why3
L3PmzHEffuHChfi04zhz5sy5fPnyokWL3DuXlZU5jnPLLbcMXUJbW5s7MWvW rISF+CaXazdm
zBjtQ9asWZPeMSTI1HbX7/j6RcZcZMxFxlxkzEXGXGTMRcZcZMxFxlxkzEXG XGT5/N5vNNgX
GXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEX GXORMRcZc5Ex
F1kGP9aZH5JulPwjzr0sexdMT/sy/f3J8QCq2w6X2XZ12+GEZxWNAsC8eVl9 wl7JxW3K3/r6
cFVrqqrgOHjlFQB4+WWcO4cr50zELFmCnh7Mng0AjzyCzk6sXw8ACxeiszOz w87gcXvLstzt
S7wpb0ybFb81EMB776G2FgcPAkBxMRwH0Si6uhKvveB+GY2ioADFxejoiE37 /gPj35g2qz0S
GRqK6+67Y6EAWL0an32Gw4cBYOJEYSGLF6OzE8uXA8Bjj+VFXzJn0iQ/98WP mIuMuciYi4y5
yJiLjLnImIuMuciYi4y5yJiLjOcHyNgXGXORMRcZc5ExFxlzkTEXGXORMRcZ c5ExFxlzkTEX
GXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEX GXORMRdZZs+H
5Xk2I8jEeZ8ZlaVcHuzrS5gTP7lz716YbkrO3+fDtrZGmprqbNtuaqprbY0M vWnXLgDYswcA
olFMnYrq6mHPeds2lJTgxAkAWLkSoRB6ewFgxQqUlWV22Lnc7r7/Plpa0NgI ADNm4Kuv0HBl
bXM3TPPn48IFuBciq6nBt9+iogIA/vEPtLdndmyZPd8eQHm5XV6Opqa6mpq6 hJt27MCf/oT7
7weAgQEAKCoadge3Nf39AOB+qEHWLuKXpb68V1h49UzLwqFDsenjxzF9Oqqq AGDtWmHbsXUr
QiEcOwYAW7ZkfD3i+bAyvq6TMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkWX2 /VGmR5/BwfN8
WBHXIxlzkTEXGXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEXGXORMRcZ c5ExFxlzkTEX
GXORMRcZc5ExFxlzkTEXGXORMRcZc5ExFxlzkTEXGXORMRcZrycs4/WEZT4+ r9zf50+D1xMW
8XrCVy2a1xNOjtcTHr5onj+df5iLjLnImIuMuciYi4y5yJiLjLnImIuMuciY i4znT8vYFxlz
kTEXGXORMRcZc5ExFxlzkTEXGXOR8X0A6XBNIh02hnTYGNJhY0iHjSEdNoZ0 2BjSYWNIh40h
HTaGdNgY0mFjSIeNIZ3cNCYLH19wPchJjNzGkA4bQzpsDOmwMaTDxpAOG0M6 bAzpsDGkw8aQ
DhtDOn5tTDgczvUQrlO+bEw4HLZtO+XSmA7HjHiYRrxDkkfl5eEzPzVm//79 4XC4vr6+dtvj
tm3Xbnu8vr4+HA7v379fvP+lS5eqq6snTpw4ceLEp5566tKlS/GbNm/eXFJS ctNNNz3xxBO9
vb0JD4xGoy+88EJxcfGNN9746KOP/vzzzwl3OHLkyOTJk5uamtxOWJZ1dTmG 3tTd3V1UVHTx
4kX3psuXLxcXF3d2dlqWlXwkXuTkQmrfNxKJ2LZdV1e375ttkUhk3zfb6urq bNuORCLi/YPB
4FdffeVOt7W1BYPB+Hc/efKkO93e3l5aWpowqlAo9MUXX7jT58+fLykpid+h sbGxtLT06NGj
pucy9Muh019//fWUKVP6+vocx3n66ad37tyZZCQZjXGU/NSYOLc3tm0nv1sw GDQ1Y+j8yZMn
J4xqypQpZ86cEYd95syZ2267rbGx8VqeS8JNR44cufPOOw8ePPjkk08mH0l2 YkyNLxvjOM6I
dXEcp6enZ9myZRMmTJgwYcKyZct6enri333z5s3uTmfJkiVD57sT0Wi0oaEh FAqNGzfujjvu
2LVrV8Idvv/++9tvv33Dhg2O42zatOnmm2+O3zT0qSXc5DhOS0tLKBQaGBhI PpKsxZiC3Hwa
iGV57lNIjh49Om/evLNnz2buW/zwww8zZ8789NNPg8FgWnLISYxsjI/lJEY/ vVciL2BjSIeN
IR02hnTYGNJhY0iHjSEdNoZ02BjSYWNIh40hnbG5+sZ5+fdp1wMeETTi4VIR 90qkw8aQDhtD
OmwM6bAxpMPGkA4bQzpsDOnwl1Skw20M6bAxpMPGGPFYqYiNIR02hnTYGNJh Y0iHjSEdNoZ0
2BjSYWNIh8eVSIfbGNJhY0gnZ2e4jZJlWV1duR7E6AQC8ONLgnzbxlQ2N+R6 CHkurxpT2dzw
YF/fiKUJBLB9+7A5e/ciEMCIj0rypdYoH55D+dCY1tZIZXNDU1NdmW3btl1m 201NdZXNDa2t
EdNDTp7Erl2x6d27sWfP4E3RKDZswNSpCAZRXY1ffgGu/IADgWE/6W3bMH06 Skpg2zhxIjaz
txcrVyIUQiiEZ55B/NoUvb1YsQKlpSgrw6uv5jqyUfDr65hR2rgRixZh/HgA eOcdvPsu3nwz
dtOMGdi5Ey++CACdnaioQHs7uroQCCDhldP8+Vi6FAB6ehAKoaMDACoq0NKC rVsB4NQpVFTg
yy9ji21pwWuvAcDp06itzXUEqcqHxpSX2wfKAaCyuTDS19deWPhGTV3NSI/a sQN33YXCQhw6
NGz+wAAmTIhNFxWhvd24hPj25oYb0N8/OD/+l1iWNWw6P+TDXinuwPI17xUW Hli+5lrubFk4
ciSxLgCOH8fOnbHdTVUVPvwwNn/tWkyZMvLrj88/x9atsb1SUxOOHYvNP3oU W7YgGERZGT7+
ONdJjYJff+fLd9e5klfbGMoCNoZ02BjSYWNIh40hHTaGdNgY0mFjSIeNIR02 hnTYGNLx8XGl
XA8hDfwYvl8bkwW8LoGIoZAOX8eQDhtDOmyMUX68uE47NoZ02BjSYWNIh40h HTaGdNgY0mFj
SIeNIR0eVyIdbmNIh40hHTbGiMeVRGwM6bAxpMPGkA4bQzpsDOmwMaTDxpAO G0M6PK5EOtzG
kA4bQzpsjBGPK4nYGNJhY0iHjSEdNoZ0/Pr7mPx4WerH8H18Ra48uFqOH+XV Xsm9YGSSy0Om
Ea8s6nvVbYcjkUiZbUcikeq2w0nuGQhg9mxEo4Nz5s1TX4v2uuX7xlQ2N7gX ogVg2/bf+vps
2wbgXo7WdCXjf/4TVVVwHDgOwmG88srgTS+/jAcewLlz+OknrFiB5583fusl S3DuHHp60NiI
2bNjM9etwyOPoLMTnZ1YsADr18fm19Zi4UJcvIjOTjz0UK5TGwUfv/JNeB1T 3Xb4D3v2/Ofe
e93/35g2y/RY96qy//oXNm5Efz82bUJV1eClZouL4UbiOBgYgGXhv/8dfFTC Qq7+sqgI58+j
oAAA+vsRDMauUZswv7jY/Rb+C9/325i4N6bNsm27PRKxbTtJXeLuvhv79uHg QVRVDZu/ejVs
G599hvPncfgwFiyIzZ84EadOjTyM5cuxeHFsW7JoEZYvj83/61/x2GOD8/0r f7YxvsMri9J1
gY0hHTaGdNgY0mFjSIeNIR02hnTYGNJhY0iHjSEdNoZ02BjS8euRyCzglUVF 3MaQDhtDOmwM
6bAxpMPGkA4bQzpsDOnwVw6kw20M6bAxpMPGGOXHB46kHRtDOmwM6bAxpMPG kA4bQzpsDOmw
MaTDxpAOjyuRDrcxpMPGkA4bY8TjSiI2hnTYGNJhY0iHjSEdNoZ02BjSYWNI h40hHR5XIh1u
Y0iHjSEdNsaIx5VEbAzp+PWVL6/hliv5to0xXXyW0iWvGlPZ3PBgX9+IpQkE sH37sDl796qv
d80rpPtYa2vEveR1mW3btl1m2+7FrltbI6aHnDyJXbti07t3Y8+ewZuiUWzY gKlTEQyiuhq/
/AJc+QEHAsN+0tu2Yfp0lJTAtnHiRGxmby9WrkQohFAIzzyD3t7B+StWoLQU ZWV49dVcRzYK
Y3M9gNzYuBGLFmH8eAB45x28+y7efDN204wZ2LkTL74IAJ2dqKhAezu6uhIv cA1g/nwsXQoA
PT0IhWLXta6oQEsLtm4FgFOnUFGBL7+MLbalBa+9BgCnT6O2NtcRpCofGlNe bh8oB4DK5sJI
X197YeEbNXU1Iz1qxw7cdRcKC3Ho0LD5AwOYMCE2XVSE9nbjEuLbmxtuQH// 4Pz4u3LLGjad
H/JhrxR3YPma9woLDyxfcy13tiwcOZJYFwDHj2PnztjupqoKH34Ym792LaZM Gfn1x+efY+vW
2F6pqQnHjsXmHz2KLVsQDKKsDB9/nOukRoHvrnOG767pusDGkA4bQzpsDOmw MaTDxpAOG0M6
bAzpsDGkw8aQDhtDOj4+rpTrIaSBH8P3a2MoV7hXIh02xig/dnxpx8aQDhtD OmwM6bAxpMPG
kA4bQzpsDOmwMaTz/wTWmWlaD3C7AAAAAElFTkSuQmCC
--------------040106020509000101050001--
Re: Arrage Element always in the (horizontal) center of a compartment [message #171235 is a reply to message #171114] Fri, 01 February 2008 12:39 Go to previous messageGo to next message
I see... guess you have to write some code )))
You may try ILayoutNodeProvider; I have written one for TaiPan named
PortLayoutProvider. Just snap children to the center there.
> EditParts, right?
> jens
Re: Arrage Element always in the (horizontal) center of a compartment [message #171243 is a reply to message #171235] Fri, 01 February 2008 13:51 Go to previous message
Could you advise me a little bit in this manner? What should be the
common workflow to implement an ILayoutNodeProvider?
jens
Previous Topic:Disable 'Delete from Model' in the popup menu
Next Topic:RelativeBendpoints Notation
Current Time: Thu Nov 06 12:16:47 EST 2025
Powered by FUDForum. Page generated in 0.08619 seconds
