Home » Language IDEs » ServerTools (WTP) » facet runtimes ?
facet runtimes ? [message #169739] Sat, 20 May 2006 12:53 Go to next message
From my understanding the facet's concept of a runtime-component is
independent of server runtimes, is that correct ?
e.g. a runtime-component does not need to be a "full" server definition,
but could also be a framework, e.g. Hibernate or JBPM.
My question is then:
Is there any examples of this somewhere ?
Is there any ui to manage those runtimes similar to the Installed Server
Runtimes ?
/max
Re: facet runtimes ? [message #169747 is a reply to message #169739] Sat, 20 May 2006 12:59 Go to previous message
I think runtime is not meant for frameworks - just realized that there
apparently only can be one runtime
associated to the facet enabled projects hence you cannot enable multiple
"framework-runtimes".
....I guess that the whole framework should be embodied in one or multiple
dependent facets then.
/max
> Runtimes ?
> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:Using Hibernate Mapping Files from Spring with Dynamic Web Projects...
Next Topic:Profile Server (WTP and TPTP)
Current Time: Wed Oct 29 07:00:27 EDT 2025
Powered by FUDForum. Page generated in 0.03764 seconds
