Home » Eclipse Projects » Eclipse Platform » linux and environment variables
linux and environment variables [message #169707] Fri, 12 December 2003 10:49 Go to next message
Originally posted by: je74.gmx.de
Is it possible to set an
environment varibale within th "run..." or "debug..." diolog ?
(i am new to eclipse :))
In my project i use a java library
which uses shared objects (linux shared libraries).
So while i start the application from shell script i used a modified
LD_LIBRARY_PATH environment variable.
How can i manage this with eclipse ?
Thanks in advance,
Joerg
Re: linux and environment variables [message #169723 is a reply to message #169707] Fri, 12 December 2003 11:07 Go to previous messageGo to next message
Which version of Eclipse are you using?
In the latest versions you can set the environment for your run or debug
launch.
See the Environment tab for your launch configuration.
HTH
Darins
"J
Re: linux and environment variables [message #169731 is a reply to message #169723] Fri, 12 December 2003 11:14 Go to previous messageGo to next message
I use V2.1.1
So i will update to V2.1.2 and try again.
thx
> launch.
> HTH
> Darins
> "Jörg" <je74@gmx.de> wrote in message news:brcns9$pan$1@eclipse.org...
>> Thanks in advance,
>> Joerg
Re: linux and environment variables [message #169738 is a reply to message #169731] Fri, 12 December 2003 11:35 Go to previous message
It is not in 2.1.2 ...only in the later builds of the 3.0
Darins
"J
Previous Topic:Accessing Project Delta's
Next Topic:CVS plugin let me send "edit" command only for read-only files..
Current Time: Wed Nov 19 13:40:42 EST 2025
Powered by FUDForum. Page generated in 0.04953 seconds
