Home » Eclipse Projects » Eclipse Platform » Startup problem Eclipse 2.1.2 with Solaris 8
Startup problem Eclipse 2.1.2 with Solaris 8 [message #169512] Fri, 12 December 2003 03:54 Go to next message
Originally posted by: chicky013.gmx.de
Hi all,
I've got a problem with starting eclipse under Solaris 8 and I am nearly
desperated. I already searched the groups for help but without success.
The systemwide installed java sdk version is 1.4.2_02-b03 and I tried to
launch eclipse 2.1.2 as well as eclipse 3.0M5, both terminating with the
same error message. I deleted the workspace directory and tried to start
again, but no effect. I explicitly told eclipse where the vm is located
with the -vm parameter, no way.
Here is the error message:
java.lang.ExceptionInInitializerError
org.eclipse.ui.internal.WorkbenchPlugin.initializeDefaultPre ferences(WorkbenchPlugin.java:441)
org.eclipse.ui.plugin.AbstractUIPlugin.initializeDefaultPlug inPreferences(AbstractUIPlugin.java:631)
org.eclipse.core.runtime.Plugin.getPluginPreferences(Plugin. java:347)
org.eclipse.ui.plugin.AbstractUIPlugin$CompatibilityPreferen ceStore.initialize(AbstractUIPlugin.java:176)
org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.java:568)
org.eclipse.ui.internal.Workbench.getPreferenceStore(Workben ch.java:701)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:844)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.NullPointerException
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:75)
... 17 more
I don't know what to do here, it seems to be an internal eclipse problem.
Is the eclipse-sdk not sufficient for solaris? Do I have to install jface
seperately? With windows, the eclipse-sdk was always sufficient.
Has anyone a hint!
Help is greatly appreciated!
Thanks and greets,
Christian
Re: Startup problem Eclipse 2.1.2 with Solaris 8 [message #169539 is a reply to message #169512] Fri, 12 December 2003 04:28 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
There is a bug report for a very similar problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=33828
HTH,
Csaba
"Christian Vogt" <chicky013@gmx.de> wrote in message
news:oprz18djx8pc0c72@news.eclipse.org...
> Hi all,
> at
chPlugin.java:441)
> at
> at
> at
> at
ava:568)
> at
> at
a:858)
> at
> at
..java:25)
> at
r.java:75)
> ... 17 more
> Has anyone a hint!
> Thanks and greets,
> Christian
Re: Startup problem Eclipse 2.1.2 with Solaris 8 [message #169554 is a reply to message #169539] Fri, 12 December 2003 05:15 Go to previous message
thanks a lot for your hint! The comments to the bug solved my problem,
cause the described situation is exactly the situation I have over here.
I connected to the Solaris-Server with telnet. When I connect to the
server over XDMCP everything works fine.
Have a nice day!
Christian
Previous Topic:Support for JSR-168 (portlet spesification)?
Next Topic:How do I specify specific context-menu for the nodes on my view?
Current Time: Thu Nov 20 06:05:22 EST 2025
Powered by FUDForum. Page generated in 0.03273 seconds
