| How can I get the DocumentRoot?(Q about EMF) [message #169427] |
Tue, 05 September 2006 04:42 |
I use EMF generate an Encore model from some schema files, such like below:
<schema xmlns="http://www.w3.org/2001/XMLSchema" ......>
<element name="module" type="scdl:Module"/>
<element name="component" type="scdl:Component"/>
<complexType name="Module">
<complexContent>
</complexContent>
</complexType>
<complexType name="component">
<complexContent>
</complexContent>
</complexType>
</schema>
There are 2 kinds of xml files which correspond module element and
component element respectively.
I want to parser a component element which can be loaded from a xml file.
But I can't get the namespace attibutes.
I find it could get XMLNSPrefixMap if I get a DocumentRoot first.(From API)
How could I get the object of DocumentRoot type?
It could be parserd as a Component but can't be DocumentRoot when I load
the file like the following way(If I change Component to DocumentRoot ,it
will occur error):
Resource resource = new
XMLResourceImpl(URI.createFileURI(new
File(filelocation).getAbsolutePath()));
XMLResource.XMLInfo info = new XMLInfoImpl();
info.setXMLRepresentation(XMLResource.XMLInfo.ELEMENT);
info.setName("component");
XMLResource.XMLMap map = new XMLMapImpl();
map.add(ScaPackage.eINSTANCE.getComponent(), info);
Map options = new HashMap();
options.put(XMLResource.OPTION_XML_MAP, map);
try {
resource.load(options);
} catch (IOException e) {
e.printStackTrace();
Component component = (Component)resource.getContents().get(0);
Thanks for any help!
FUDForum. Page generated in 0.26371 seconds
