Home » Language IDEs » Java Development Tools (JDT) » Java Project Wizard could not be started
Java Project Wizard could not be started [message #169397] Mon, 19 July 2004 17:03 Go to next message
Originally posted by: scout.hyperspace-travel.de
I am trying to use Eclipse for the first time.
I have built Eclipse from source, using
eclipse-sourceBuild-srcFetch-3.0.zip from the R-3.0-200406251208
directory, keeping close to the srcFetchBuildInstructions.html in that
directory. The command line I used was
./build -os linux -ws gtk -arch amd64.
When I start Eclipse, everything looks fine to me. But when I try to
create a new (Java) project or pull one of my projects from CVS, I get the
following error:
The selected wizard could not be started.
Reason:
Plug-in org.eclipse.jdt.ui was unable to load class
org.eclipse.jdt.internal.ui.wizards.JavaProjectWizard.
I figure the source build did nout build the SDK, although it says so in
the build instructions, but only the runtime. (platform, isthat the
correct term?)
Am I correct? If so, what can I do to build the full SDK? If not, what
else is wrong?
TIA
Helge
Re: Java Project Wizard could not be started [message #171313 is a reply to message #169397] Tue, 03 August 2004 06:50 Go to previous message
>following error:
> Reason:
>correct term?)
Ensure that you build the Eclipse SDK and not the Platfrom SDK.
Dani
>else is wrong?
>TIA
>Helge
Previous Topic:Auto update always wants to install upgrade...
Next Topic:Alternate File Tab appearance
Current Time: Fri Nov 07 21:33:08 EST 2025
Powered by FUDForum. Page generated in 0.03239 seconds
