Home » Language IDEs » Java Development Tools (JDT) » Class Question
Class Question [message #169320] Mon, 19 July 2004 14:39 Go to next message
Does anyone know if there is a way to dump Eclipse's compiler options that
it will use when your Java source files are compiled by the interface? I am
trying to use the javac ANT task to compile the same Java source and I can't
get the two class files to be identical.
I have tried using a -g:none option on the ANT task and turning off all the
debug settings in Eclipse but the class files are still different.
I guess what I am asking for is to be able to see the compiler options
Eclipse is using when it compiles java source.
Any help will be greatly appreciated.
Marty Jones
Re: Class Question [message #169338 is a reply to message #169320] Mon, 19 July 2004 14:46 Go to previous messageGo to next message
Are you specifying the Eclipse compiler for your Ant script? If not, it
will default to using Sun's JDK javac compiler. If that is the case,
read on...
As you may know, Eclipse uses it's own compiler, not Sun's javac. You
are not going to get javac-compiled classes and Eclipse-compiled classes
to be identical. Different compilers produce (slightly) different .class
files - that is just the nature of compilers.
I don't know why you're trying to get them to be identical, but one
option that might help you is to tell Ant to use the Eclipse compiler
instead of Sun's javac. I don't know off the top of my head the exact
property and value, but I'm sure you can find it by searching these
newsgroups or Googling.
HTH,
Eric
Re: Class Question [message #169346 is a reply to message #169338] Mon, 19 July 2004 14:49 Go to previous messageGo to next message
Eric,
I thought that Eclipse would use the JRE that you specify in the preferences
section to build and run your Java applications?
If it doesn't then what is the point of Setting up your JRE within Eclipse?
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:cdh4s2$sgr$1@eclipse.org...
that
I am
can't
> read on...
> HTH,
> Eric
Re: Class Question [message #169369 is a reply to message #169346] Mon, 19 July 2004 15:12 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
A JRE isn't a compiler and doesn't have a compiler, it is a runtime.
When you set your JRE to compile "against" , eclipse compiles using the
set of jars in the JRE when it compiles your java code.
As Eric says eclipse has its own compiler and no two compilers normally
will generate byte for byte the same class file.
Peter
Marty Jones wrote:
> Eric,
> that
> I am
> can't
>>read on...
>>HTH,
>>Eric
Re: Class Question [message #169376 is a reply to message #169338] Mon, 19 July 2004 15:13 Go to previous messageGo to next message
Eric,
Is there a way in Eclipse for you to overwrite the use of Eclipse's Java
Compiler and use a Sun Java Compiler?
that
I am
can't
> read on...
> HTH,
> Eric
Re: Class Question [message #169384 is a reply to message #169369] Mon, 19 July 2004 15:16 Go to previous messageGo to next message
Peter,
Sorry for the Brain Fart. I understand what you are saying.
Thanks for the Info.
Marty Jones
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:cdh6c0$uc7$2@eclipse.org...
> Peter
> Marty Jones wrote:
> > Eric,
preferences
Eclipse?
> > that
> > I am
> > can't
> >>read on...
> >>HTH,
> >>Eric
Re: Class Question [message #169516 is a reply to message #169376] Tue, 20 July 2004 10:55 Go to previous messageGo to next message
Marty Jones wrote:
> Eric,
Not directly. The only option in that area would be to disable the
Eclipse builder (Java compiler) for that project and instead write an
Ant script that uses javac. You could then set it up to run that Ant
script for every build (file save) or to invoke it manually when you
wanted to build. I recommend against that, however - it is really kind
of wrestling with Eclipse.
Can you share why it is you must use the Sun compiler? Eclipse's
compiler does adhere to the Java spec and produces perfectly fine byte code.
HTH,
Eric
Re: Class Question [message #169665 is a reply to message #169516] Wed, 21 July 2004 10:53 Go to previous messageGo to next message
Eric,
The reason I wanted to use the Sun compiler was to verify the class files
for an automated build system that we are working on. I am automatically
building Java class files using the javac ant task. I wanted to compare
those class files against our current production set of code that is
compiled using Eclipse. When I compared the files I would get class
differences. For our testing purposes I just compiled our production code
base using the javac Ant task instead of Eclipse and then compared the two
sets of class files.
Thanks for all your help,
Marty
news:cdjbmo$ifu$1@eclipse.org...
> Marty Jones wrote:
> > Eric,
code.
> HTH,
> Eric
Re: Class Question [message #169777 is a reply to message #169665] Thu, 22 July 2004 06:40 Go to previous message
Please also note that you may use the Eclipse Java compiler independantly
from Eclipse
as a command line tool (instead of javac), see instructions at:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- core-home/howto/batch%20compile/batchCompile.html
"Marty Jones" <marty_jones@dailyaccess.com> wrote in message
news:cdlvts$q1j$1@eclipse.org...
> Eric,
> Marty
> > Marty Jones wrote:
> > > Eric,
Java
> code.
> > HTH,
> > Eric
Previous Topic:Unreachable code compiler preferences
Next Topic:JUnit - No tests found
Current Time: Mon Jul 21 21:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.05796 seconds
