Home » Newcomers » Newcomers » Built in J2SE API Doc?
Built in J2SE API Doc? [message #169132] Sun, 03 September 2006 15:44 Go to next message
Originally posted by: jim.evans.strategicforge.com
I'm trying out the Eclipse JDT for doing J2SE Desktop App development and
can't seem to access any built in Java API documentation like the Borland
IDE has. Am I missing something or is this functionality not provided?
Re: Built in J2SE API Doc? [message #169205 is a reply to message #169132] Mon, 04 September 2006 00:12 Go to previous messageGo to next message
Originally posted by: eclipse4.rizzoweb.com
> and can't seem to access any built in Java API documentation like the
> Borland IDE has. Am I missing something or is this functionality not
> provided?
Is the JVM you are launching Eclipse with a JDK? If so, the JavaDoc and,
if available, source code for the core Java classes should be picked up
automatically.
What's that you say? You don't know what JVM your Eclipse is using to
run? Well, you really should be telling it explicitly what JVM it should
use (and I highly recommend it be a JDK as opposed to a JRE). See here
for details:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
You can also specify a VM in the eclipse.ini file - I wrote about that
in another thread just a few minutes ago (Subject: "not able to install
eclipse...")
Hope this helps,
Eric
Re: Built in J2SE API Doc? [message #169256 is a reply to message #169205] Mon, 04 September 2006 09:37 Go to previous message
Thank you. Operator error. :-(
Previous Topic:Callisto doesn't work
Next Topic:Plugin auto-update mechanism
Current Time: Sat Nov 08 08:21:39 EST 2025
Powered by FUDForum. Page generated in 0.09188 seconds
