Home » Language IDEs » ServerTools (WTP) » Publishing a webapp when resource files are locked
| Publishing a webapp when resource files are locked [message #168845] |
Tue, 09 May 2006 18:15  |
I am trying to solve a problem that I am having with WTP publishing. I
use a library in my web application, which keeps one of the resource
files locked when running on an application server. If I deploy my web
application to Tomcat, the application will run fine. However, every
time I edit the locked resource file in the IDE when the application is
already running, WTP displays:
"Error copying file to (my workspace
location)\.metadata.plugins\org.eclipse.wst.server.core\tmp0 \webapps\...
Error deleting:
(my workspace
location)\.metadata.plugins\org.eclipse.wst.server.core\tmp0 \webapps\... "
Is that a way I can workaround this? The file is locked for delete but
I can overwrite the file...
I tried the antiResourceLocking flag for Tomcat, but I am hoping to find
a solution that works for all servers and still allow me to make
modifications to the file.
For example, if there's a way I can hook up to an extension point such
that I can stop/restart the web application during publish, I'll be able
to release the lock on the resource files and overwrite them...
ap
| Re: Publishing a webapp when resource files are locked [message #168899 is a reply to message #168845] |
Wed, 10 May 2006 09:13   |
My understanding is that this is a Windows issue, so outside of
replacing your OS, I'm not sure what can be done beyond what the
application offers. I believe that Tomcat achieves the "anti-locking"
by making copies so the original remains writable while the server uses
the copy. Obviously, this impacts startup and deployment performance.
Larry
ap wrote:
> Error deleting:
> (my workspace
> ap
| Re: Publishing a webapp when resource files are locked [message #168921 is a reply to message #168899] |
Wed, 10 May 2006 11:19   |
Thanks, Larry. I am wondering, if it's not possible to fully fix this
issue on Windows, whether or not there's a way I can customize the
publishing logic, such that I can tell the server adapters to restart
the application as opposed to publishing the modified resource? This
behavior is similar to modification to any resources in the WEB-INF
folder, except I would like to be able to extend the list of items that
will trigger a restart...
ap
> Cheers,
> Larry
> ap wrote:
>> I use a library in my web application, which keeps one of the resource
>> web application to Tomcat, the application will run fine. However,
>> every time I edit the locked resource file in the IDE when the
>> application is already running, WTP displays:
>> Error deleting:
>> (my workspace
>> but I can overwrite the file...
>> find a solution that works for all servers and still allow me to make
>> able to release the lock on the resource files and overwrite them...
>> Thanks,
>> ap
| Re: Publishing a webapp when resource files are locked [message #169127 is a reply to message #168921] |
Thu, 11 May 2006 10:05  |
The issue should be fixable, but what can be easily done with the
current code base, I'm not sure. There is no "list" that I'm aware of.
Larry
> ap
>> uses the copy. Obviously, this impacts startup and deployment
>> performance.
>> Cheers,
>> Larry
>> ap wrote:
>>> Hi,
>>> resource files locked when running on an application server. If I
>>> deploy my web application to Tomcat, the application will run fine.
>>> However, every time I edit the locked resource file in the IDE when
>>> the application is already running, WTP displays:
>>> Error deleting:
>>> (my workspace
>>> such that I can stop/restart the web application during publish, I'll
>>> be able to release the lock on the resource files and overwrite them...
>>> Thanks,
>>> ap
Current Time: Thu Nov 06 18:32:21 EST 2025
Powered by FUDForum. Page generated in 0.04279 seconds
