Home » Eclipse Projects » Eclipse Platform » instantiation of main plugin class and debug model presentation
instantiation of main plugin class and debug model presentation [message #168830] Wed, 10 December 2003 13:53 Go to next message
When I launch a debug run for my custom plugin for my custom language, the
debug model presentation's constructor gets called before the main class for
the plugin is instantiated. The main class is the one that is specified in
the 'class' attribute of the 'plugin' element in my plugin.xml file. The
constructor for the debug model presentation needs to access the preference
store for the plugin which doesn't exist until the main plugin class is
created.
Isn't the main plugin class supposed to be instantiated first? Is there
anything that I can do to guarantee it?
Actually, the debug model presentation and the main plugin class are being
instantiated in parallel by separate threads, so I guess the main plugin
class will sometimes get instantiated first. But right now, the problem is
very reproducible.
This problem has just started to happen and I don't know why. I am using
3.0M5
Patrick Baker
Stilo Corporation
pbaker@ca.stilo.com
"Hail, twin companionship, children of Mars."
This message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged
information. Any unauthorized review, use, disclosure, copying, or
distribution is strictly prohibited. If you are not the intended
recipient(s) please contact the sender by reply email and destroy
all copies of the original message and any attachments.
Re: instantiation of main plugin class and debug model presentation [message #168922 is a reply to message #168830] Wed, 10 December 2003 16:45 Go to previous messageGo to next message
Please file a bug with Platform-Debug. This sound interesting :-)
It is likely something to do with the fact that the debugger now computes
labels in background threads. However, we have not seen this interaction.
Darin
"Patrick Baker" <pbaker@ca.stilo.com> wrote in message
news:br7ptr$r95$1@eclipse.org...
for
preference
> created.
> very reproducible.
> 3.0M5
> Patrick Baker
> Stilo Corporation
> pbaker@ca.stilo.com
Re: instantiation of main plugin class and debug model presentation [message #168943 is a reply to message #168922] Wed, 10 December 2003 17:13 Go to previous messageGo to next message
That's an excellent guess. Here are the callstacks for the two threads (note
the LaunchViewLabelDecorator entry in the worker thread):
Don't worry I will file a bug report.
Main thread
GuiPlugin.<init>(IPluginDescriptor) line: 53
NativeConstructorAccessorImpl.newInstance0(Constructor, Object[]) line: not
available [native method]
NativeConstructorAccessorImpl.newInstance(Object[]) line: 39
DelegatingConstructorAccessorImpl.newInstance(Object[]) line: 27
Constructor.newInstance(Object[]) line: 274
PluginDescriptor.internalDoPluginActivation() line: 744
PluginDescriptor.doPluginActivation() line: 200
PluginClassLoader.activatePlugin(String) line: 109
PluginClassLoader.internalFindClassParentsSelf(String, boolean,
DelegatingURLClassLoader, boolean) line: 181
PluginClassLoader(DelegatingURLClassLoader).findClassParents Self(String,
boolean, DelegatingURLClassLoader, boolean) line: 485
PluginClassLoader(DelegatingURLClassLoader).loadClass(String , boolean,
DelegatingURLClassLoader, Vector, boolean) line: 882
PluginClassLoader(DelegatingURLClassLoader).loadClass(String , boolean) line:
862
PluginClassLoader(ClassLoader).loadClass(String) line: 255
PluginDescriptor.createExecutableExtension(String, Object,
IConfigurationElement, String) line: 128
PluginDescriptor.createExecutableExtension(String, String, Object,
IConfigurationElement, String) line: 179
ConfigurationElement.createExecutableExtension(String) line: 103
DebugUIPlugin$1.run() line: 236
BusyIndicator.showWhile(Display, Runnable) line: 84
DebugUIPlugin.createExtension(IConfigurationElement, String) line: 233
LazyModelPresentation.getPresentation() line: 191
LazyModelPresentation.getImage(Object) line: 114
DelegatingModelPresentation.getImage(Object) line: 166
LaunchView$3.getImage(Object) line: 230
LaunchViewDecoratingLabelProvider(DecoratingLabelProvider).g etImage(Object)
line: 73
LaunchViewer(TreeViewer).doUpdateItem(Item, Object) line: 99
AbstractTreeViewer$UpdateItemSafeRunnable.run() line: 87
InternalPlatform.run(ISafeRunnable) line: 1127
Platform.run(ISafeRunnable) line: 464
LaunchViewer(AbstractTreeViewer).doUpdateItem(Widget, Object, boolean) line:
469
StructuredViewer$UpdateItemSafeRunnable.run() line: 119
LaunchViewer(StructuredViewer).updateItem(Widget, Object) line: 1285
LaunchViewer(AbstractTreeViewer).updateChildren(Widget, Object, Object[],
boolean) line: 1534
LaunchViewer(AbstractTreeViewer).internalRefreshStruct(Widge t, Object,
boolean) line: 1058
LaunchViewer(AbstractTreeViewer).internalRefresh(Widget, Object, boolean,
boolean) line: 1036
LaunchViewer(AbstractTreeViewer).internalRefresh(Object, boolean) line: 999
LaunchViewer(AbstractTreeViewer).internalRefresh(Object) line: 987
StructuredViewer$7.run() line: 870
LaunchViewer(StructuredViewer).preservingSelection(Runnable) line: 810
LaunchViewer(StructuredViewer).refresh(Object) line: 868
LaunchViewer.refresh(Object) line: 82
LaunchViewEventHandler(AbstractDebugEventHandler).refresh(Ob ject) line: 136
LaunchViewEventHandler.access$3(LaunchViewEventHandler, Object) line: 1
LaunchViewEventHandler$4.run() line: 474
UILockListener.doPendingWork() line: 101
UISynchronizer$1.run() line: 33
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages() line: 102
Display.runAsyncMessages() line: 2164
Display.readAndDispatch() line: 1881
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 1405
Workbench.runUI() line: 1381
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 237
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 139
IDEApplication.run(Object) line: 47
InternalBootLoader.run(String, URL, String, String[], Runnable) line: 858
BootLoader.run(String, URL, String, String[], Runnable) line: 461
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object[]) line: 324
Main.basicRun(String[]) line: 299
Main.run(String[]) line: 767
Main.main(String[]) line: 601
Worker thread
OmniMarkDebugModelPresentation.<init>() line: 64
Class.newInstance0() line: 306
Class.newInstance() line: 259
IConfigurationElement, String) line: 138
BusyIndicator.showWhile(Display, Runnable) line: 51
LazyModelPresentation.getText(Object) line: 121
DelegatingModelPresentation.getText(Object) line: 183
LaunchViewLabelDecorator$LabelJob.run(IProgressMonitor) line: 267
Worker.run() line: 62
Re: instantiation of main plugin class and debug model presentation [message #169178 is a reply to message #168830] Thu, 11 December 2003 08:09 Go to previous message
A bug report has been filed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48480
Please, if you can think of a work around that would make this work with
3.0M5 (i.e. guarantee the main plugin class is created first) share your
thoughts.
Previous Topic:I want to use "Hide missing" filter
Next Topic:Running Multiple Instances of Ant at Once
Current Time: Mon Dec 01 05:18:27 EST 2025
Powered by FUDForum. Page generated in 0.03849 seconds
