Home » Eclipse Projects » Eclipse Platform » how to convert an Ipath to an Ifile
how to convert an Ipath to an Ifile [message #168758] Wed, 10 December 2003 11:43 Go to next message
Originally posted by: petchia.yahoo.com
I have a plugin I created for Eclipse that launches an external editor
using the IEditorLauncher interface. Apparently this interface changed in
3.0M4 to take an IPath object instead of an IFile object. How can I
convert the IPath into an IFile? I could easily convert IFile into IPath
however I would like to keep IFile since my code is already written around
it (ie. watching for file changes from other editors, opening an input
stream).
-Bill
Re: how to convert an Ipath to an Ifile [message #168870 is a reply to message #168758] Wed, 10 December 2003 16:42 Go to previous message
Probably the move to IPath is to support launching arbitrary files rather
than just files in the workspace, but I am speculating. An IPath is just a
high level data structure for manipulating paths, while an IFile is supposed
to represent a file resource in the workspace (although that is only the
case is the exists() method returns true).
To find a resource in the workspace who's actual location on disk is an
IPath use:
IWorkspaceRoot.findFilesForLocation(IPath location)
But if you are trying to launch the editor on a file that isn't in the
Eclipse workspace, you will need to be more careful.
Here are some utility functions that I have written and that I use:
public static IFile findFileResourceByLocation (String FileLocation)
IPath ResourcePath = new Path(FileLocation);
if (!ResourcePath.isAbsolute())
//this methods does not support relative paths
return null;
else
IFile[] Files =
getWorkspaceRoot().findFilesForLocation(ResourcePath);
return (Files.length > 0) ? Files[0] : null;
public static IFile[] findFileResourcesByLocation (String FileLocation)
return new IFile[0];
else
return getWorkspaceRoot().findFilesForLocation(ResourcePath);
To call these with an IPath do something like (or change them to take
IPath's instead):
IPath p
findFileResourceByLocation(p.toOSString());
Patrick Baker
Stilo Corporation
pbaker@ca.stilo.com
"Hail, twin companionship, children of Mars."
This message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged
information. Any unauthorized review, use, disclosure, copying, or
distribution is strictly prohibited. If you are not the intended
recipient(s) please contact the sender by reply email and destroy
all copies of the original message and any attachments.
"Bill Johnson" <petchia@yahoo.com> wrote in message
news:br7iep$hf7$1@eclipse.org...
> stream).
> -Bill
Previous Topic:building M5 fails
Next Topic:RPC plugin w/ two perspectives
Current Time: Sun Nov 23 03:57:47 EST 2025
Powered by FUDForum. Page generated in 0.02768 seconds
