Home » Language IDEs » C / C++ IDE (CDT) » eclipse/CDT setup for code browsing and debugging only
eclipse/CDT setup for code browsing and debugging only [message #168745] Tue, 25 April 2006 21:51 Go to next message
Originally posted by: msandhu.cisco.com
I have eclipse 3.0.0 with CDT 2.1.1.
I would like to use the source browsing capabilities of eclipse
and also be able to use our customized gdb version with it.
When I use the wizard to setup my C/C++ project, no source shows up in
the left hand projects pane.
How can I setup eclipse for this purpose without going thru a build
cycle using eclipse.
Mandeep
Re: eclipse/CDT setup for code browsing and debugging only [message #168752 is a reply to message #168745] Tue, 25 April 2006 22:26 Go to previous messageGo to next message
My bad.
i was pointing to the wrong source dir. I can see the source now.
But I still need to figure out how to use gdb with eclipse.
> Mandeep
Re: eclipse/CDT setup for code browsing and debugging only [message #168768 is a reply to message #168752] Wed, 26 April 2006 01:59 Go to previous message
Mandeep,
you may want to go through one of the CDT beginner's tutorials to get the
hang of how debugging essentially works with CDT.
If you have special problems related to your customized gdb the please give
more information.
Norbert Ploett
Previous Topic:Problems with class instantiation and a destructor reference
Next Topic:Using gdb checkpoints
Current Time: Sat Jul 26 08:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.25356 seconds
