Home » Archived » BIRT » Display X-axis labels at tick marks rather than inbetween?
Display X-axis labels at tick marks rather than inbetween? [message #168656] Thu, 08 June 2006 12:41 Go to next message
Is it possible to display the X-axis labels at the ticks rather than
inbetween the ticks? Or do I need to log a bugzilla?
Re: Display X-axis labels at tick marks rather than inbetween? [message #168672 is a reply to message #168656] Thu, 08 June 2006 13:34 Go to previous messageGo to next message
Yes, it's possible:
Hide the major ticks
Set Minor grid visible
Set "Minor grid count per unit"=2
Set Minor ticks visible
Set Minor grid invisible if you only need the ticks
I guess you can file an enhancement to better control the major ticks
position, but it will probably require an API change in the model to add a
new position setting (so not possible in 2.1).
David
"George Handin" <eclipse@dafunks.com> wrote in message
news:e69jvm$8va$3@utils.eclipse.org...
Re: Display X-axis labels at tick marks rather than inbetween? [message #168716 is a reply to message #168672] Thu, 08 June 2006 16:52 Go to previous messageGo to next message
This only works if one is not already showing the Minor ticks.
In my current situation, this solution will suffice for now. For other
reports coming down the pipe, this will not be a viable solution. I've
created defect #146114 to address this.
David Michonneau wrote:
> Yes, it's possible:
> David
Re: Display X-axis labels at tick marks rather than inbetween? [message #196834 is a reply to message #168672] Fri, 20 October 2006 10:58 Go to previous message
Originally posted by: mrmikeolson.yahoo.ca
Are there any code examples of this?
> Yes, it's possible:
> David
Previous Topic:Rendering multiple series with different numbers of data points
Next Topic:Version 3.2.6 Wrong for BIRT 2.1.0?
Current Time: Tue Jul 15 06:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.30016 seconds
