| Stored Proc dataset not returned [message #168612] |
Thu, 08 June 2006 12:05  |
Originally posted by: keith.chappelow.siemens.com
I have two stored procedures in MS SqlServer that return data using SQL
Query Analyzer but BIRT does not get any data in the dataset.
I first noticed this when creating the dataset and trying to do a preview.
I then modified the stored procedure to just do a select statement and
created a report with the fields. With just the "fake" select statement
every works but as soon as I restore the stored procedure to what it
should really be returning I get no data returned.
I have returned data with the stored procedure using the SqlServer jdbc
driver so I don't think that is the problem.
I can see no errors logged.
Here is the report definition for the dataset:
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.0.1 Build
<20060222-1204></property>
<property name="units">in</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="4">
<property
name="odaDriverClass">com.microsoft.jdbc.sqlserver.SQLServerDriver </property>
<property
name="odaURL">jdbc:microsoft:sqlserver://localhost:1433;SelectMethod=cursor;DatabaseName=LMS</property>
<property name="odaUser">LMS</property>
<encrypted-property
name="odaPassword">TE1T</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.SPSelectDataSet "
name="Data Set" id="5">
<property name="dataSource">Data Source</property>
<list-property name="parameters">
<structure>
<property name="name">StartDate</property>
<property name="dataType">string</property>
<property name="position">1</property>
<expression name="defaultValue">'05/04/2006
7:00'</expression>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
<structure>
<property name="name">StopDate</property>
<property name="position">2</property>
12:00'</expression>
</structure>
<structure>
<property name="name">SortControllerName</property>
<property name="position">3</property>
<expression name="defaultValue">'ALL'</expression>
</structure>
</list-property>
<property name="queryText">{call
LMS.GetLogicalDivertSumFromMC(?,?,?)} </property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
</report>
Here is the stored procedure:
CREATE PROCEDURE LMS.GetLogicalDivertSumFromMC
@aStartDate udt_CharDateTime,
@aStopDate udt_CharDateTime,
@aSortControllerName VARCHAR(30)
AS
** Revision Information:
** $Source:
//Grrp403a/DEPT1/SPE/Data/Product_Components/LMS/03-Developm ent/Code/Source/Database/SP/rcs/GetLogicalDivertSumFromMC.SQ L
** $Id: GetLogicalDivertSumFromMC.SQL 1.1 2006/02/14 15:24:10Z guntihs
Developing $
** $Name: SD_5.3_QC PD3.1SP1 PD3.1B445 PD3.1B428 $
BEGIN
-- Create a temporary table to put the data to be queried an returned
in to.
CREATE TABLE #TempTable
LogicalDestination VARCHAR(32),
PhysicalDestinationID VARCHAR(10),
PhysicalDestination VARCHAR(32),
ScannerID INT,
SortControllerName VARCHAR(32),
Data INT DEFAULT 0
-- Preload the data into the temporary table
INSERT IGNORE INTO #TempTable( LogicalDestination, PhysicalDestinationID,
PhysicalDestination, ScannerID, SortControllerName)
SELECT LDM.LogicalDestinationID, P.PhysicalDestinationID,
P.PhysicalDestination, CDM.ScannerID, SC.SortControllerName
FROM SortDirector.SortD.PhysicalDestination P
INNER JOIN SortDirector.SortD.ScannerParameters SP ON P.ScannerID
= SP.ScannerID
INNER JOIN SortDirector.SortD.SortController SC ON
SP.SortControllerID = SC.SortControllerID
INNER JOIN SortDirector.SortD.ControllerDestinationMap CDM ON
P.PhysicalDestinationID = CDM.PhysicalDestinationID
AND P.ScannerID = CDM.ScannerID
INNER JOIN SortDirector.SortD.LogicalDestinationMap LDM ON
LDM.ControllerDestinationID = CDM.ControllerDestinationID
AND CDM.ScannerID = LDM.ScannerID
WHERE @aSortControllerName = 'ALL' OR SC.SortControllerName =
UPDATE #TempTable
SET Data = Total
FROM #TempTable INNER JOIN
( SELECT ClientID , GroupType , Tag, SUM(Data) Total FROM
LMS.StatisticsLog WITH (NOLOCK)
WHERE SubGroupType = 'PDESTARRIVAL'
AND TIMESTAMP >= @aStartDate AND TIMESTAMP <= @aStopDate
AND (@aSortControllerName = 'ALL' OR ClientID =
@aSortControllerName)
GROUP BY ClientID, GroupType, Tag ) Stat
ON ClientID = SortControllerName
AND GroupType = ScannerID
AND Tag = PhysicalDestinationID
SELECT LogicalDestination, ScannerID, PhysicalDestination, Data
LogicalDestinationCount FROM #TempTable
END
This is an example of calling the stored procedure in Query Analyzer:
DECLARE @RC int
DECLARE @aStartDate varchar(50)
DECLARE @aStopDate varchar(50)
DECLARE @aSortControllerName varchar(30)
SELECT @aStartDate = '05/04/2006 7:00'
SELECT @aStopDate = '05/04/2006 12:00'
SELECT @aSortControllerName = 'ALL'
EXEC @RC = [LMS].[LMS].[GetLogicalDivertSumFromMC] @aStartDate,
@aStopDate, @aSortControllerName
And the data returned:
LogicalDestination ScannerID PhysicalDestination
Door1 301 1011
0
Door10 301 2021
0
Door2 301 1022
0
| Re: Stored Proc dataset not returned [message #168687 is a reply to message #168623] |
Thu, 08 June 2006 15:05  |
I found what was causing the problem. I added "SET NOCOUNT ON" in the
stored procedure. What was happening is the rowcount for the temporary
table was being interpreted as the data set.
FUDForum. Page generated in 0.24070 seconds
