Home » Language IDEs » C / C++ IDE (CDT) » How to include external API header
How to include external API header [message #168483] Thu, 20 April 2006 00:36 Go to next message
Originally posted by: samantha.abc.com
I am using Eclipse SDK 3.1.2 + CDT 3.0.2 + MinGW 3.4.2 for my
developement. I am going to include a external API header for my
developement. I add the include path on "Project" > "Properties" > "C/C++
Include Paths Symbols" > "Add External Include Path...". However, I also
get error "imqi.hpp:No such file or directory" on the line which include
this external header file when building the project. How can I fix this
problem?
Re: How to include external API header [message #168576 is a reply to message #168483] Thu, 20 April 2006 12:15 Go to previous message
Samantha wrote:
> Hello,
> "C/C++ Include Paths Symbols" > "Add External Include Path...". However,
> I also get error "imqi.hpp:No such file or directory" on the line which
> include this external header file when building the project. How can I
> fix this problem?
> Regards
It sounds like you've got a regular make project, so you're maintaining
your own Makefile. I believe that Project>properties>C/C++ Include Paths
is for the indexer, which doesn't know anything about your makefile. You
have to separately configure your makefile(s) to use the correct include
paths as well.
dan
Previous Topic:How can I setup code formatter in eclipse cdt?
Next Topic:Configuring CDT with nmake
Current Time: Mon Sep 01 02:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.66202 seconds
