Can't run SQL commands [message #168463] |
Wed, 30 August 2006 10:48 |
Originally posted by: nospam.home.com
I have just installed the SQL development tools and have managed to set up a
jConnect driver to a Sybase Adaptive Server Enterprise 15.0 database.
However, when I go to run an adhoc query in "Run..." (which I presume is the
place to do it?) it complains with the error:
java.sql.SQLException: Can not determine the correct server type by the
conection profile: jConnect
org.eclipse.datatools.sqltools.internal.core.ControlConnecti onManager.getOrCreateControlConnection(ControlConnectionMana ger.java:68)
org.eclipse.datatools.sqltools.routineeditor.launching.SPLau nchConfigurationDelegate.launch_run(SPLaunchConfigurationDel egate.java:86)
org.eclipse.datatools.sqltools.routineeditor.launching.SPLau nchConfigurationDelegate.launch(SPLaunchConfigurationDelegat e.java:193)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:641)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
What can I do about this? The connection works fine and I can browse
through the schema OK so what do you think might be the problem? In the
connection properties under "Version" it says "JDBC: unknown" which may be a
pointer.
Wes
FUDForum. Page generated in 0.08597 seconds
